GameEx - Tv's and Powerstrip
Guest Archived From Old Forum
How does powerstrip differ in how it makes its custom resolutions?
the one I made I did with the geforce driver, and it worked, but I
don't think windows really supported it, because in the basic windows
display/settings window it still showed 640x480 8bit color, when the
custom gforce driver settings windows showed my custom resolution at
32bit color.
____________________________________
Powerstrip runs as a process in the background. It does not differ in how it creates the resolution, but dynamically applies all the sizing, position, refresh etc in all applications or games using a resolution defined within it. In other words it MAKES windows and all apps support it.
