Beaps73 Posted December 21, 2013 Share Posted December 21, 2013 Any ideas why Mame is not loading my config for games I have rotated. It just keeps them in the standard format. When I load them through MAME.exe they play perfect (rotated as I setup) Link to comment Share on other sites More sharing options...
Draco1962 Posted December 21, 2013 Share Posted December 21, 2013 I split this out from your Fusion thread since it is a separate issue and will have more visibility than if you lump it in with your original thread. Link to comment Share on other sites More sharing options...
Tempest Posted December 21, 2013 Share Posted December 21, 2013 What is your command for Mame? Link to comment Share on other sites More sharing options...
Beaps73 Posted December 23, 2013 Author Share Posted December 23, 2013 I know its an old thread but I have a similar problem.When I start GameEx the TATE games are NOT rotated (I have to go into MAME GUI & rotate 90 degrees). Once I exit the game & go back into GameEx, then load the same game again, its back as I first started the game (not rotated like I just like I started it for the first time) If I go into the MAME setup in GameEX & select the 'Rotate Screen' option, it does nothing.If I forget about GameEx & load up MAME.exe and select a game, then Rotate 90 Degrees it in the GUI & then exit MAME & go back in & load the game again it perfect, it in TATE mode.Its doing my head in, why is GameEx not loading the game like MAME.exe does? Link to comment Share on other sites More sharing options...
Draco1962 Posted December 23, 2013 Share Posted December 23, 2013 I know its an old thread but I have a similar problem.When I start GameEx the TATE games are NOT rotated (I have to go into MAME GUI & rotate 90 degrees). Once I exit the game & go back into GameEx, then load the same game again, its back as I first started the game (not rotated like I just like I started it for the first time) If I go into the MAME setup in GameEX & select the 'Rotate Screen' option, it does nothing.If I forget about GameEx & load up MAME.exe and select a game, then Rotate 90 Degrees it in the GUI & then exit MAME & go back in & load the game again it perfect, it in TATE mode.Its doing my head in, why is GameEx not loading the game like MAME.exe does?I split this post and merged it for two reasons - first of all, you already opened a new thread on this topic for which someone had asked some questions that did not get answered. Second, you bumped an old thread (from 2008) that may or may not be related to your issue since the version of GameEx then is way older than current. Please respond to Tempest's request and provide copies of your gameex.ini and log.txt files while you are at it. If you need assistance with this, please go to the How to Ask for Help thread for instruction. Thank you. Link to comment Share on other sites More sharing options...
Beaps73 Posted December 23, 2013 Author Share Posted December 23, 2013 Whoops sorry about that, it's just mame.exe in the command line Link to comment Share on other sites More sharing options...
Tempest Posted December 23, 2013 Share Posted December 23, 2013 In addition to posting your Mame command, you should post your mame.ini file. Link to comment Share on other sites More sharing options...
Beaps73 Posted December 24, 2013 Author Share Posted December 24, 2013 Here you go, and thanks for your help by the waymame.ini Link to comment Share on other sites More sharing options...
Tempest Posted December 24, 2013 Share Posted December 24, 2013 Try using -rotate as an option under Advance Mame Settings > Mame Options Link to comment Share on other sites More sharing options...
Beaps73 Posted December 24, 2013 Author Share Posted December 24, 2013 I thought that would then rotate all the games, sure I will try it & report back. Link to comment Share on other sites More sharing options...
Tom Speirs Posted December 26, 2013 Share Posted December 26, 2013 There should be an auto rotate command line option for MAME. Cant recall what it isGameEx has built in support for a rotating monitor via HeadKazes plugin Link to comment Share on other sites More sharing options...
Beaps73 Posted December 31, 2013 Author Share Posted December 31, 2013 I tried messing with the -rotate in the mame ini, still didn't work Link to comment Share on other sites More sharing options...
Tempest Posted December 31, 2013 Share Posted December 31, 2013 Try it in the command from GameEX. Just for kicks. Link to comment Share on other sites More sharing options...
Beaps73 Posted January 1, 2014 Author Share Posted January 1, 2014 Ok will do and report back Link to comment Share on other sites More sharing options...
DazzleHP Posted January 2, 2014 Share Posted January 2, 2014 Hi Beaps,Something you mentioned in your other thread sparked an idea - you mentioned marquees while playing? This means your games are most likely using layout files (these are needed to display artwork elements in the correct position for each game) and if i'm not mistaken these layout files also include a set resolution for each game, thus overriding any settings you alter in respect to resolution/orientation.So, ill give you 2 options to try (do either of these - both at the same time are not rquired):1) Open MAME.ini (found in your mame directory) and find the Artwork section. Change it as per the following:## CORE ARTWORK OPTIONS#artwork_crop 0use_backdrops 0use_overlays 0use_bezels 0use_cpanels 0use_marquees 02) Delete all artwork paths form GameEx MAME Settings apart from Snap/Video Snap/Title. This method is not ideal as you won't be able to see all the lovely artwork in the gameinfo screens.I would go for option 1 for reasons specified - i only really gave you option 2 incase you have uncontrollable .iniphobia like some people do 1 Link to comment Share on other sites More sharing options...
Beaps73 Posted January 2, 2014 Author Share Posted January 2, 2014 Let my try that, back in tick Link to comment Share on other sites More sharing options...
Beaps73 Posted January 2, 2014 Author Share Posted January 2, 2014 I feel really dumb round about now, to much emu setting up going on my brain must of fried lolI did a schoolboy error. I should of check mame outside first which I thought I did as the same was happening their. Turns out its a flaky build of mame I was using. I updated mame, rotated, then exited & it worked, it saved. Went into GEx selected a different game, rotated 90deg and exited, went back in it was rotated.. Yeeee Harrr! Link to comment Share on other sites More sharing options...
DazzleHP Posted January 2, 2014 Share Posted January 2, 2014 Glad you got that issue sorted! You know, persistence is a great and practically required quality to have when it comes to emulation, and i'm pleased to see you have plenty Link to comment Share on other sites More sharing options...
Beaps73 Posted January 2, 2014 Author Share Posted January 2, 2014 It's funny as in life I don't, but when it comes to emulation, I am like dog with a bone. I spent about 2h last night configuring a C64 emulator and I am still not there. Sad I know lol Link to comment Share on other sites More sharing options...
