Has anyone had any luck with modding the xbox with Mame? If so, have you been able to encorporate this front end, or any front end with it??
if u you use mame on the xbox it comes with its own frontend there are like 4 mame ports so u can choose wich one u like but most are ports of older mame builds.
every emulator that is ported to the xbox has its own frontend.
Thanks for the info!
