Hi Folks :),
I still have a problem with the Listnum field. It gets clipped (truncated), if i put it on the right side of the list field. The left side of the listfield however works. As i have seen other themes with no problems, i am asking what could cause my problem?
At this point i want to say, that i am sure, that there is NO object in the foreground, that could cover the Listnum field. the listnum field gets clipped, right at the moment where it touches the right border of the List field. if its completely over the right border, it disappears completely :(.
Even if I try to make a completely new theme, the error is still there. Is there really no solution to this?
My second problem is the Description field. The height needs to be 160 pixel, regardless how big the width is (in my case 802 pixels, which is the whole screen :)) to show the FULL description of a game. If the height is less than 150 pixels, than the description is truncated, right after the first 2-3 words. It looks like this:
Donkey Kong is a.......
Even if there is enough place, because of the width, to place much more text (maybe even the whole?), it gets shortened :(. Is there a workaround for this?
The stars should have a fixed size, but they change size and more critical the position depending on the length of the text displayed. It would be nice to have the option to turn them off and to spend the place needed for the stars for the text. Other option could be, to place the text right after the stars ;).
Do a user have a influence on this stars anyway ? For my taste, there are some games under-rated. How would i gave them a better rating?
Hoping for answers... u-man :)
