frans Posted November 9, 2013 Share Posted November 9, 2013 PinballX.zip 567.78 Kb has expired. What is this? Link to comment Share on other sites More sharing options...
nullPointer Posted November 9, 2013 Share Posted November 9, 2013 Could you explain the nature of your problem a bit more? Is this even related to Pinmame focus problems with DirectB2S? Link to comment Share on other sites More sharing options...
frans Posted November 19, 2013 Author Share Posted November 19, 2013 When i click Attached Files: PinballX.Zip. Is says the program are Expired.Which directory i have to put this file?Noob question. TKS. Link to comment Share on other sites More sharing options...
Draco1962 Posted November 19, 2013 Share Posted November 19, 2013 I have split this to its own topic as I do not think it has anything to do with the topic the OP originally posted within.@Frans - please be mindful of the topic before posting within. If the error you are receiving is not related, it is easy for it to get overlooked. Thanks! Link to comment Share on other sites More sharing options...
zeenon Posted November 19, 2013 Share Posted November 19, 2013 frans,Can you give us a little more information. Are you trying to install PinballX for the first time or upgrading?It's almost like the file is being cached on a gateway between, the PBX site and your PC. The install file is 48MB.Also, you are downloading the file directly from the PinballX site and not another site right? Link to comment Share on other sites More sharing options...
frans Posted November 19, 2013 Author Share Posted November 19, 2013 I installed the pinballX 1.69. I have to download shark codecs,too?I´m using win XP SP3 dual monitors. I´m downloaded this site.Sorry, I'm confused with pinballX Frontend.My sincere apologies. Maybe it posted in the wrong place Link to comment Share on other sites More sharing options...
Draco1962 Posted November 19, 2013 Share Posted November 19, 2013 Codecs are required for proper video file displays. You can try other codecs, but this is what the author recommends. Link to comment Share on other sites More sharing options...
