I am currently running the "Talos 101" full HD Theme,but previously used "The Blue Neon " one i loved the music in it, but dont like the music in Talos, Is there anyway the music can be interchanged? :rolleyes: .Regards
Theme files are located in GameEx\THEMES folder. Search for mp3 or wav files "in the blue neon" folder and overwrite those in "Talos 101" folder. I think this would be sufficient.
Although I'm not totally sure to understand what you mean with "music". Do you refer to the sound effects?
GameEx sounds don't support mp3, only wav AFAIK. ;)
You can copy the .wav files from one theme to another. I frequently borrow from others or create my own depending on the theme I am creating at the time.
yea thanks everyone sorted! :)
