I have just downloaded the Dreamcast emulator from setup wizard and added some Roms, the roms have CDI file ext and the emulator doesnt see them ! what am I doing wrong? anyone help? :unsure: Regards an avid user
Edited by Draco1962
Please refrain from discussing how ROMs were obtained. Please review the Forum Rules and Guidelines link at the bottom right of the forum page if any questions.
Well, CD-i is Phillips CD Interactive and .cdi is the format for those types. I don't run any Dreamcast emulators but what you are saying doesn't sound right to me.
Sega Dreamcast .CDI files are ripped from .GDI files (The original Sega Dreamcast format).
CDI files are smaller and downsampled in audio and video quality whilst the actual game remains the same.
Also .CDI files are used rather than .GDI so they can fit on a 700mb CDR.
If you can upload your GameEx Log and Ini file's and also your emulator config, I should be able to get this sorted for you.
I spent numerous years within the Sega Dreamcast community and it's one of the system's I am extremely familiar with.
Found the log files , But where are the ini files? :wub:
Thanks for the reply, problem solved. :)
If you don't mind sharing what you did to resolve the issue so this information can be passed on to the next that might run into the same problem you presented. Thanks!
