I'm having some problems with Kega Fusion ver 3.64 and GameEx ver 13.16
The emulator loads fine, plays roms well, it's just having problems when I exit back to GameEx that it shuts both Fusion and GameEx down and exits back to windows.
I have my 'escape' key set to exit all emulators back to GameEx.
GameEx uses the keystroke combo 'esc+home' to exit GameEx so I'm not sure what is going on. It's the only emulator that is causing this issue.
Doesn't seem to matter which game is loaded either. I've attached my log file.
Why not try an advance confif of Alt+F4 as the exit for just the emulators that use Kega.
Maybe use a command line in launch after to "kill" the process for Fusion
Maybe something like taskkill /f /im Fusion.exe (or whatever the process name is).
Not sure how to do that exactly. But, since Fusion uses a "process quit" command (or whatever it's called, hownwould that work?
I can confirm that Alt+F4 works to close Fusion, and I agree that this might solve your issue. The [Mapping Off] Exit (Alt+F4) Advanced Config is even included with GameEx by default.
On the Advanced Emulator Setup screen please refer to the Advanced Config entry. Select [Mapping Off] Exit (Alt+F4) from the dropdown selections. This just means that when you press your exit key it will use Alt+F4 to exit the emulator rather than whatever it's doing now. Give that a shot and see if it helps.
