Finished my Desktop Pinball Controller for use with Pinball X:
post-17456-0-83687400-1377769756_thumb.j
post-17456-0-82564000-1377769784_thumb.j
It supports Manual Nudge with the top black/red buttons and Analog Nudge using the U-HID G (as seen in the middle of the box).
Depending on the loaded profile you can activate Manual Nudge or Analog Nudge or both.
Great work! Looks like a commercial product.
It is easy to build one. I ordered the U-HID G and leaf buttons from Ultimarc and bought the box from my local electronics shop. I printed the artwork on a large format Xerox at the office and a friend provided the plexiglass for the top. Using a dremel for the holes and a soldering iron for the cabling the whole project took about 4 hours.
The box is a TEKO box (http://www.teko.it/) used for electronic projects and comes with a thin metal plate. You can easily make all kind of controllers with this, like my Dual Arcade Stick:
post-17456-0-66599500-1377906385_thumb.j
