Bug in 1.52 and 1.53 with letter E and PinballFX2
Haven't tried any older builds but I've since a bug where I have the following Table name in my database Pinball FX2.xml called Zen-E (for the Excalibur table). For some reason it keeps pulling up the media for Biolab (which I have named Zen-BL in my xml). The only other E title I have listed is Z-ED for ElDorado and Z-EQ for Epic Quest. If I change it from Z-E to Z-EX then it loads the proper media. For some reason using just Z-E keeps loading Z-BL media.
I have a workaround (using Z-EX) but I thought I'd throw this out there in case someone else runs across a similar issue.
Note: I also use other letters (ie Z-M for Zen Mars and Z-T for Zen Tesla and M-A for Marvel Avengers etc. and haven't had any issues with those. Only seems to be Z-E so far).
At the bottom of PinballX.ini, try setting
EnableFileMatching=False
When it is set to True, PinballX "searches" for the media file, so it can guess wrong sometimes
