Hi, I have my arcade machine setup with mame and x-arcade running just fine. I decide to add nes,snes and sega emulators to work with my x-arcade. Can anybody point me to rigth direction on how to setup the emulators to work with the xarcade?
You might want to start by telling us what emulators you are running as the approach may vary between emulators for the same system.
I was thinking to run nestopia, snesx and kega fusion... Or if you think about any other emulators easier to set up...
Those are the 3 emus I'm running with the X-Arcade. Do you have the X-Arcade Duel Stick? Or the Tankstick with trackball? What exactly are you needing to know? Controller mapping? Give me some detail and I'll be glad to help where I can.
I was running Fusion and Nestopia through my X-Arcade Dual using JoyToKey (later changed to XPadder), Once you have your X-Arcade stick setup with either of these program's it's a breeze to setup any emulator.
For the small price to pay, Xpadder is the way to go. Joined with Adlutery's Xpadder Plugin, integration with GameEx is almost seamless (not to mention eliminating launch before and after custom bat files).
I have a xarcade dual stick and i like to play those emulators with the xarcade. So i want everytime i choose a diffrent emulator im ready to go with the xarcade. I want to emulate the controlers of those emulators (nestopia,snes and fusion) with the xarcade. Can someome put me to the right direction?
I just load each emulator (without GameEx) and assign the x-arcade buttons in the options.
Then when you use GameEx to load each game, the buttons are set ready to go
Yup, rhymin is correct. Open each emulator separatly, outside of GameEx, and configure the controls in the options.
