- UPDATE - PCSX2 works now, but ePSXe doesn't. I have updated the attached files.
I have done the following:
* Downloaded and allowed GameEx to configure these emulators from GameEx Setup.
* Verified that both emulators work outside of GameEx including through the command line.
* Installed ISO support.
...and yet, ePSXe will not work from GameEx.
I have included some logs/ini files for reference.
Console Sony Playstation (ePSXe).ini
GameEx.ini
Update: I have fixed PS2 by re-installing GameEx and adding ISO mounting support. So only ePSXe doesn't work now.
Log says
03:01:14.7 6/28/2013: Unable to mount ISO. Did you install ISO Support when installing GameEx?
You may want to post an updated gameex.ini and log.txt file since things have changed things by adding the ISO support.
Done! I updated the first post and all of its attachments.
