Hi
I think I might have found a small bug, I noticed that if a file name has a . in the title such as Ecco Jr..rom or Smash T.V.rom then the video snap is not found on the selection menu. However it will be found and displayed in you select the game on the games menu page.
Also having started to use Aeon Inspiriat I have few questions or maybe feature requsts.
Is it possible to remove the small gap between menu items?
Is it possible to remove the white outline of the popup description text box?
If the text does not fit in the area on a highlighted menu item is it possible to make the text scroll so the whole file name can be read?
Many thanks
  Quote
You may need to rename the ROM and the video snap to remove the periods from the file names. This is not so much a bug as a Windows issue.
  Quote
You may want to ask Crylen in his project page for his theme.
1.) Yes, just delete "Unselected.png" in the theme-media folder, or replace it with a 100% transparent .png.
2.) No... not that i am aware off. I told that allready in the Request/Feature Quest. Maybe you do it also and it maybe will done in future.
Hate that white Line, looks even more terrible on a real cab with interlaced resolution (i.e. 640x480). It jitters a lot.
3.) No... not that I am aware off
4.) Welcome here ;)
Hi, thanks for your replies.
@Draco1962: I have renamed the files as a work around. However I don't think it's a windows limitation as it finds the video fine when you select the game. So the code in gameex to look for a video snap must have different logic in the games menu as it does in the selected game page.
I have spoken with Crylen around these matters, and they are limitations of Gameex as he is also quite keen to get rid of the small gap between list items.
@U-Man: I removed the unslected.png to test but there is still a small game between each item on the list :( So I guess all 3 things are feature requests. I will make the the formal way. Oh and thanks for the welcome!
use this attached .png and tell us, if it works.
replace it with the one in your theme media folder.
it works for me.
good luck :)
hover over the attached thingy, because its transparent, it cant be previewed and thats the reason why you see nothing.
post-9755-0-93023400-1371583202_thumb.pn
Hey U-Man, there is still a pixel or two gap I've made a request to Tom about seeing if this can be changed, but it's much less noticeable with your image so many thanks!
