Installed Last version today... BUG REPORT: I had problems setting up my Gamepad... It's appears that all the options have to be "maped" if you leave any in "blank" the buttons mess up.. and did not save ( if you were modifing them)
plus the first time i ran the application.. it didnt work.. it exit to pinball X showin' 2 windows.. (program terminated or any "negative" advertisement....)
gonna try tomorrow...
the thing is... I was getting crazy using HyperPin. SETUP was AWSOME.... i will try to move to this... I believe in PinballX
For me and many others i think the ASPECT RATIO thing has to be urgent... seeying the BG compress in size is a shame.
THANKS!!!! for all your great work..
Mariano.
I took the liberty of splitting your post in the PinballX - Features and Enhancements thread and moving it to the General thread where bug reports should go. You may want to tell us what version you are running and any PC stats so that someone may be of help.
My Mistake.. sorry..... VER. 1.39 and PD stats... windows 7 64bits on core AMD athlon 64 (x2) 4600+ Nvidia GeForce 9600GT 5gb ram
