I have messed around and around.. Tried multiple emulators that all work stand alone to no avail. When viewing the log can see the problem is:
21:08:12.2 5/20/2013: Running: cmd.exe /c S: snes9x.exe -fullscreen "S:\_Good Stuff\HTPC\emulators\emu\Nintendo_SNES\roms\Super Mario Kart.zip"
It is neglecting the path to snes9x. It does this for all the emulators. I've tried searching the forums to no avail. What have I done wrong?
GameEx.ini
Hi verbosene and Welcome to the GameEx forums!
Hmm ... I see what you mean, but in this case the log may not tell the whole story. Take a look at your runitgame.bat (or post it) and see if everything looks OK with that. If it does look OK you can try to run a game from runitgame.bat and see what happens. The How to Ask For Help thread has some really good tips for using runitgame.bat as a troubleshooting measure.
Thanks, I was unaware of this other file. Turns out I had the 64 bit version of the emulator and needed to change the name. I can't believe I missed this. I guess getting stuck in my head that the problem was something else. Thanks null!
