Hi! often i have this error:
00:34:12.3 10/05/2013: Restoring Emulator from Cache
00:34:12.5 10/05/2013: Restoring Emulator Database From Cache
00:34:12.8 10/05/2013: Restoring Emulator from Cache
00:34:12.9 10/05/2013: Restoring Emulator Database From Cache
00:34:13.0 10/05/2013: Restoring Emulator from Cache
00:34:13.1 10/05/2013: Restoring Emulator Database From Cache
00:34:13.3 10/05/2013: Restoring Emulator from Cache
00:34:13.3 10/05/2013: Restoring Emulator Database From Cache
00:34:13.4 10/05/2013: Restoring Emulator from Cache
00:34:13.4 10/05/2013: No Database Data
00:34:36.3 10/05/2013: Setting Up RawInput Hook
00:34:36.3 10/05/2013: Launching RawInputHook.exe
00:34:38.0 10/05/2013: Running: cmd.exe /c C: C:\Emulators GameEx\MAME\mame.exe sfa3u -rompath C:\Roms\MAME -nowindow -joy -skip_gameinfo
00:34:38.0 10/05/2013: Shutting down display
00:36:37.1 10/05/2013: Exiting game
00:36:37.1 10/05/2013: Closing MAME window
00:36:37.1 10/05/2013: Waiting for MAME to exit
00:36:41.1 10/05/2013: MAME has exited
00:36:41.5 10/05/2013: Shutting down RawInput Hook
00:36:41.5 10/05/2013: Writing MAME stats
00:36:41.6 10/05/2013: Plugin: Game Exit
00:36:41.6 10/05/2013: Plugin: Process Commands
00:36:41.6 10/05/2013: Restoring Window
00:36:41.6 10/05/2013: Reinitializing Graphics System
00:36:42.0 10/05/2013: 21 Consecutive Exceptions Occured
00:36:42.0 10/05/2013: Object reference not set to an instance of an object.
00:36:42.1 10/05/2013: at o.a(Boolean A_0, Color A_1)
00:36:42.1 10/05/2013: at o.a(Boolean A_0)
00:36:42.1 10/05/2013: at ag.s(Boolean A_0)
00:36:42.1 10/05/2013: at ag.ad()
00:36:42.1 10/05/2013: Trying reinitialising the display after sleeping for 4 seconds
00:36:42.1 10/05/2013: Exception count will be dropped to 15
00:36:46.2 10/05/2013: Exception initializing display
00:36:46.2 10/05/2013: Error in the application.
00:36:46.2 10/05/2013: at Microsoft.DirectX.Direct3D.Device..ctor(Int32 adapter, DeviceType deviceType, Control renderWindow, CreateFlags behaviorFlags, PresentParameters[] presentationParameters)
00:36:46.2 10/05/2013: at o.a(Form A_0, Int32 A_1, Int32 A_2, Boolean A_3, Boolean A_4, Boolean A_5, Boolean A_6)
00:36:46.2 10/05/2013: at o..ctor(Form A_0, Int32 A_1, Int32 A_2, Boolean A_3, Boolean A_4, Boolean A_5, Boolean A_6)
00:36:46.2 10/05/2013: at ag.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4)
00:36:46.2 10/05/2013: at ag.ad()
00:36:46.2 10/05/2013: --**--
00:36:46.2 10/05/2013: 21 Consecutive Exceptions Occured: Exiting
00:36:46.2 10/05/2013: Closing database connection
00:36:46.2 10/05/2013: First Exception:
00:36:46.3 10/05/2013: at ag.aa()
00:36:46.3 10/05/2013: at ag.d(String A_0)
00:36:46.3 10/05/2013: at ag.m(Boolean A_0)
00:36:46.3 10/05/2013: at ag.ad()
00:36:46.3 10/05/2013: Last Exception:
00:36:46.3 10/05/2013: Object reference not set to an instance of an object.
00:36:46.3 10/05/2013: at o.a(Boolean A_0, Color A_1)
00:36:46.3 10/05/2013: at o.a(Boolean A_0)
00:36:46.3 10/05/2013: at ag.s(Boolean A_0)
Can you help me?
When reporting a possible GameEx bug or error, please ensure you submit a copy of your full log.txt and gameex.ini file so we may quickly assist you. Please refer to this link for additional information.
Thanks!
this is the complete error:
13:07:28.0 10/05/2013: Opening Configuration File
13:07:29.2 10/05/2013: GameEx: Version 12.55: Starting Log
13:07:29.5 10/05/2013: Operating System Platform: Win32NT
13:07:29.5 10/05/2013: Operating System Name: Windows XP
13:07:29.5 10/05/2013: Operating System Version: 5.1.2600
13:07:29.6 10/05/2013: Intel® Pentium® 4 CPU 3.00GHz, 1279MB
13:07:29.7 10/05/2013: 3Ghz - 2 Cores or CPU's
13:07:29.7 10/05/2013: Running Randomize()
13:07:31.9 10/05/2013: Loading PlugIns
13:07:32.0 10/05/2013: Checking for applications to Launch On Startup
13:07:32.0 10/05/2013: Running Misc startup tasks
13:07:32.0 10/05/2013: Setting Menu types
13:07:32.0 10/05/2013: Getting Configuration Values
13:07:32.0 10/05/2013: Using Theme: Default - Media Center V1
13:07:32.0 10/05/2013: Checking for alternate Image Directory for Theme: Default - Media Center V1
13:07:32.0 10/05/2013: Launching HideOS.exe
13:07:32.0 10/05/2013: Initialising Video/MNG DLL's
13:07:32.0 10/05/2013: GameEx will check for media insertion (may affect performance)
13:07:32.0 10/05/2013: Hiding Taskbar
13:07:32.1 10/05/2013: Is Media Center running?
13:07:32.1 10/05/2013: Checking/Creating LCD Registry values
13:07:32.3 10/05/2013: Check Media Center Exit/Start Mode
13:07:32.7 10/05/2013: Media Center Mode 2
13:07:32.7 10/05/2013: Video previews on. Warning: Only recommended on modern systems
13:07:32.7 10/05/2013: Custom Game Device Input enabled: Getting custom codes
13:07:32.8 10/05/2013: Snap Delay set to: 2
13:07:32.8 10/05/2013: Get other settings
13:07:32.8 10/05/2013: Desktop set to Hide ICONS and set Background to Black
13:07:32.8 10/05/2013: Set: Find emulator artwork on best match basis
13:07:32.8 10/05/2013: Start work for Form
13:07:32.8 10/05/2013: Getting Original Screen Size
13:07:32.8 10/05/2013: Opening Database Connection
13:07:42.9 10/05/2013: Initializing Component
13:07:44.2 10/05/2013: MAME Path is: C:\Emulators GameEx\MAME
13:07:44.2 10/05/2013: MAME EXE file is: mame.exe
13:07:44.3 10/05/2013: ROM Path is: C:\Roms\MAME
13:07:44.3 10/05/2013: Catver.ini is located at: C:\Emulators GameEx\MAME\Catver.ini
13:07:44.3 10/05/2013: controls.ini is located at: C:\Emulators GameEx\MAME\controls.ini
13:07:44.3 10/05/2013: History.dat is located at: C:\Emulators GameEx\MAME\history.dat
13:07:44.4 10/05/2013: nplayers.ini is located at: C:\GameEx\DATA\nplayers.ini
13:07:44.4 10/05/2013: command.dat is located at: C:\GameEx\DATA\command.dat
13:07:44.4 10/05/2013: MAMEinfo.dat is located at: C:\GameEx\DATA\mameinfo.dat
13:07:44.4 10/05/2013: Loading Controls.ini map file
13:07:44.7 10/05/2013: Snap Path is: C:\Assets\MAME\Snaps
13:07:44.7 10/05/2013: Background Snap Path: Not Found
13:07:44.7 10/05/2013: AVI Snap Path: Not Found
13:07:44.7 10/05/2013: Flyer Path: Not Found
13:07:44.7 10/05/2013: Cabinet Path is: C:\Emulators GameEx\MAME\Cabinets
13:07:44.7 10/05/2013: Cabinet 3D Path: Not Found
13:07:44.8 10/05/2013: Title Path is: C:\Assets\MAME\Titles
13:07:44.8 10/05/2013: PCB Path: Not Found
13:07:44.8 10/05/2013: Artwork Preview Path: Not Found
13:07:44.8 10/05/2013: Panel Path is: C:\Assets\MAME\Controls
13:07:44.8 10/05/2013: Manual Path: Not Found
13:07:44.8 10/05/2013: Icon Path: Not Found
13:07:44.8 10/05/2013: Marquee Path is: C:\Emulators GameEx\MAME\marquees
13:07:44.9 10/05/2013: Applying Language/Text
13:07:44.9 10/05/2013: Text/Language: Italian
13:07:45.0 10/05/2013: Loading Custom Emulators
13:07:45.0 10/05/2013: Loading Emulator 1: A) Famicom
13:07:45.1 10/05/2013: Loading Emulator 2: B) Super Famicom
13:07:45.1 10/05/2013: Loading Emulator 3: C) Nintendo 64
13:07:45.2 10/05/2013: Loading Emulator 4: D) Sega Master System
13:07:45.2 10/05/2013: Loading Emulator 5: E) Sega Genesis
13:07:45.2 10/05/2013: Loading Emulator 6: F) Nintendo Game Boy
13:07:45.3 10/05/2013: Loading Emulator 7: G) Nintendo Game Boy Color
13:07:45.3 10/05/2013: Loading Emulator 8: H) Nintendo Game Boy Advance
13:07:45.4 10/05/2013: Loading Emulator 9: I) Sony Playstation
13:07:45.4 10/05/2013: Using 2D Animations
13:07:45.4 10/05/2013: Retrieving resolution setting
13:07:45.4 10/05/2013: Using General Font: Trebuchet MS
13:07:45.4 10/05/2013: Using Title Font: Trebuchet MS
13:07:45.4 10/05/2013: GameEx will try to reduce CPU usage
13:07:45.5 10/05/2013: Initialising Direct3D
13:07:46.5 10/05/2013: Setting Resolution to 1280x1024 32 bit color
13:07:46.6 10/05/2013: Creating Surfaces
13:07:47.3 10/05/2013: Creating Primary Surface - Full Screen Mode
13:07:47.3 10/05/2013: Creating Back Buffer
13:07:47.8 10/05/2013: Loading graphic Surfaces
13:07:47.9 10/05/2013: Display is running at: 1280x1024 32bit color, 60hz
13:07:47.9 10/05/2013: Adapter: NVIDIA GeForce FX 5500
13:07:47.9 10/05/2013: Max texture size: 4096x4096
13:07:47.9 10/05/2013: Available texture memory: 615MB
13:07:48.0 10/05/2013: Initialising Bass Audio Library
13:07:48.1 10/05/2013: Creating Surfaces Misc and Dialogs
13:07:48.9 10/05/2013: Creating Surfaces Volume
13:07:48.9 10/05/2013: Creating Surfaces Arrows
13:07:48.9 10/05/2013: Creating Surfaces GameEXlogo Text
13:07:48.9 10/05/2013: Creating Surfaces Toolbar
13:07:49.1 10/05/2013: Creating Surfaces Toolbar Controls
13:07:49.2 10/05/2013: Creating Surfaces Backgrounds
13:07:49.2 10/05/2013: Creating Surfaces GameEx Logo
13:07:49.3 10/05/2013: Creating Surface Unselected
13:07:49.3 10/05/2013: Creating Surfaces Home & Exit
13:07:49.4 10/05/2013: Creating Surfaces Snaps
13:07:49.4 10/05/2013: Creating Surfaces Menu and List Bars
13:07:50.4 10/05/2013: Creating Fonts
13:07:50.4 10/05/2013: Creating Game Font
13:07:51.4 10/05/2013: Creating Game Font Faded
13:07:51.7 10/05/2013: Creating Title Font
13:07:51.7 10/05/2013: Restoring Title Font From Cache
13:07:52.2 10/05/2013: Creating Menu Font
13:07:52.3 10/05/2013: Creating Font Black
13:07:52.5 10/05/2013: Creating Font Black Small
13:07:52.7 10/05/2013: Fonts Created Succesfully
13:07:52.7 10/05/2013: 5MB Video Memory Used
13:08:16.3 10/05/2013: Attempting to load game list
13:08:17.1 10/05/2013: MAME CMD options: -nowindow -joy -skip_gameinfo
13:08:17.1 10/05/2013: Creating DirectSound Device
13:08:17.1 10/05/2013: Trying: Driver audio principale
13:08:17.2 10/05/2013: Loading Sound Files
13:08:17.3 10/05/2013: DirectSound Device Created Successfully
13:08:17.3 10/05/2013: Initialising DirectInput for Gamepad support
13:08:17.3 10/05/2013: Unable to create a joystick device
13:08:17.3 10/05/2013: Loading Start Page
13:08:17.5 10/05/2013: Initializing MCE Remote
13:08:17.5 10/05/2013: Playing intro sound file
13:08:17.6 10/05/2013: Initialization OK! Starting GameEx!
13:08:17.6 10/05/2013: Testing Main Loop Once: Processing Frame
13:08:18.5 10/05/2013: Testing Main Loop Once: Main Loop ran successfully
13:08:57.6 10/05/2013: Gamepad inserted. Attached devices: 1
13:09:00.0 10/05/2013: Validating: Emulator_1: Snap Path: C:\Assets\Nintendo NES\Snaps
13:09:00.0 10/05/2013: Validating: Emulator_1: Control Panel Path: C:\Assets\Nintendo NES\Nintendo NES\Controls
13:09:00.0 10/05/2013: Warning: Emulator_1: Control Panel Path Does not exist
13:09:00.0 10/05/2013: Validating: Emulator_1: Database: [Console] Nintendo NES
13:09:00.1 10/05/2013: Validating: Emulator_1: Title Snap Path: C:\Assets\Nintendo NES\Titles
13:09:00.1 10/05/2013: Validating: Emulator_1: Box Art Path: C:\Assets\Nintendo NES\Nintendo NES\Boxes
13:09:00.1 10/05/2013: Warning: Emulator_1: Box Art Path Does not exist
13:09:00.1 10/05/2013: Validating: Emulator_1: Cart Art Path: C:\Assets\Nintendo NES\Nintendo NES\Cartridges
13:09:00.1 10/05/2013: Warning: Emulator_1: Cart Art Path Does not exist
13:09:00.1 10/05/2013: Validating: Emulator_1: Manual Path: C:\Assets\Nintendo NES\Nintendo NES\Manuals
13:09:00.1 10/05/2013: Warning: Emulator_1: Manual Path Does not exist
13:09:00.1 10/05/2013: Validating: Emulator_2: Snap Path: C:\Assets\Nintendo SNES\Snaps
13:09:00.2 10/05/2013: Validating: Emulator_2: Control Panel Path: C:\Assets\Nintendo SNES\Controls
13:09:00.2 10/05/2013: Validating: Emulator_2: Database: [Console] Nintendo SNES
13:09:00.2 10/05/2013: Validating: Emulator_2: Title Snap Path: C:\Assets\Nintendo SNES\Titles
13:09:00.2 10/05/2013: Validating: Emulator_2: Box Art Path: C:\Assets\Nintendo SNES\Boxes
13:09:00.2 10/05/2013: Validating: Emulator_2: Cart Art Path: C:\Assets\Nintendo SNES\Cartridges
13:09:00.2 10/05/2013: Validating: Emulator_2: Manual Path: C:\Assets\Nintendo SNES\Manuals
13:09:00.2 10/05/2013: Validating: Emulator_3: Snap Path: C:\Assets\Nintendo N64\Snaps
13:09:00.3 10/05/2013: Validating: Emulator_3: Control Panel Path: C:\Assets\Nintendo N64\Controls
13:09:00.3 10/05/2013: Validating: Emulator_3: Database: [Console] Nintendo N64
13:09:00.3 10/05/2013: Validating: Emulator_3: Title Snap Path: C:\Assets\Nintendo N64\Titles
13:09:00.3 10/05/2013: Validating: Emulator_3: Box Art Path: C:\Assets\Nintendo N64\Boxes
13:09:00.3 10/05/2013: Validating: Emulator_3: Cart Art Path: C:\Assets\Nintendo N64\Cartridges
13:09:00.3 10/05/2013: Validating: Emulator_3: Manual Path: C:\Assets\Nintendo N64\Manuals
13:09:00.3 10/05/2013: Validating: Emulator_4: Snap Path: C:\Assets\Sega Master System\Snaps
13:09:00.4 10/05/2013: Validating: Emulator_4: Control Panel Path: C:\Assets\Sega Master System\Controls
13:09:00.4 10/05/2013: Validating: Emulator_4: Database: [Console] Sega Master System
13:09:00.4 10/05/2013: Validating: Emulator_4: Title Snap Path: C:\Assets\Sega Master System\Titles
13:09:00.4 10/05/2013: Validating: Emulator_4: Box Art Path: C:\Assets\Sega Master System\Boxes
13:09:00.4 10/05/2013: Validating: Emulator_4: Cart Art Path: C:\Assets\Sega Master System\Cartridges
13:09:00.4 10/05/2013: Validating: Emulator_4: Manual Path: C:\Assets\Sega Master System\Manuals
13:09:00.4 10/05/2013: Validating: Emulator_5: Snap Path: C:\Assets\Sega Genesis\Snaps
13:09:00.5 10/05/2013: Validating: Emulator_5: Control Panel Path: C:\Assets\Sega Genesis\Controls
13:09:00.5 10/05/2013: Validating: Emulator_5: Database: [Console] Sega Genesis
13:09:00.5 10/05/2013: Validating: Emulator_5: Title Snap Path: C:\Assets\Sega Genesis\Titles
13:09:00.5 10/05/2013: Validating: Emulator_5: Box Art Path: C:\Assets\Sega Genesis\Boxes
13:09:00.5 10/05/2013: Validating: Emulator_5: Cart Art Path: C:\Assets\Sega Genesis\Cartridges
13:09:00.5 10/05/2013: Validating: Emulator_5: Manual Path: C:\Assets\Sega Genesis\Manuals
13:09:00.5 10/05/2013: Validating: Emulator_6: Snap Path: C:\Assets\Nintendo Game Boy\Snaps
13:09:00.6 10/05/2013: Validating: Emulator_6: Control Panel Path: C:\Assets\Nintendo Game Boy\Controls
13:09:00.6 10/05/2013: Validating: Emulator_6: Database: [Handheld] Nintendo Game Boy
13:09:00.6 10/05/2013: Validating: Emulator_6: Title Snap Path: C:\Assets\Nintendo Game Boy\Titles
13:09:00.6 10/05/2013: Validating: Emulator_6: Box Art Path: C:\Assets\Nintendo Game Boy\Boxes
13:09:00.6 10/05/2013: Validating: Emulator_6: Cart Art Path: C:\Assets\Nintendo Game Boy\Cartridges
13:09:00.7 10/05/2013: Validating: Emulator_6: Manual Path: C:\Assets\Nintendo Game Boy\Manuals
13:09:00.7 10/05/2013: Validating: Emulator_7: Snap Path: C:\Assets\Nintendo Game Boy Color\Snaps
13:09:00.7 10/05/2013: Validating: Emulator_7: Control Panel Path: C:\Assets\Nintendo Game Boy Color\Controls
13:09:00.7 10/05/2013: Validating: Emulator_7: Database: [Handheld] Nintendo Game Boy Color
13:09:00.7 10/05/2013: Validating: Emulator_7: Title Snap Path: C:\Assets\Nintendo Game Boy Color\Titles
13:09:00.7 10/05/2013: Validating: Emulator_7: Box Art Path: C:\Assets\Nintendo Game Boy Color\Boxes
13:09:00.7 10/05/2013: Validating: Emulator_7: Cart Art Path: C:\Assets\Nintendo Game Boy Color\Cartridges
13:09:00.7 10/05/2013: Validating: Emulator_7: Manual Path: C:\Assets\Nintendo Game Boy Color\Manuals
13:09:00.7 10/05/2013: Validating: Emulator_8: Snap Path: C:\Assets\Nintendo Game Boy Advance\Snaps
13:09:00.8 10/05/2013: Validating: Emulator_8: Control Panel Path: C:\Assets\Nintendo Game Boy Advance\Nintendo Game Boy Advance\Controls
13:09:00.8 10/05/2013: Warning: Emulator_8: Control Panel Path Does not exist
13:09:00.8 10/05/2013: Validating: Emulator_8: Database: [Handheld] Nintendo Game Boy Advance
13:09:00.8 10/05/2013: Validating: Emulator_8: Title Snap Path: C:\Assets\Nintendo Game Boy Advance\Nintendo Game Boy Advance\Titles
13:09:00.8 10/05/2013: Warning: Emulator_8: Title Snap Path Does not exist
13:09:00.8 10/05/2013: Validating: Emulator_8: Box Art Path: C:\Assets\Nintendo Game Boy Advance\Nintendo Game Boy Advance\Boxes
13:09:00.8 10/05/2013: Warning: Emulator_8: Box Art Path Does not exist
13:09:00.8 10/05/2013: Validating: Emulator_8: Cart Art Path: C:\Assets\Nintendo Game Boy Advance\Nintendo Game Boy Advance\Cartridges
13:09:00.8 10/05/2013: Warning: Emulator_8: Cart Art Path Does not exist
13:09:00.8 10/05/2013: Validating: Emulator_8: Manual Path: C:\Assets\Nintendo Game Boy Advance\Nintendo Game Boy Advance\Manuals
13:09:00.8 10/05/2013: Warning: Emulator_8: Manual Path Does not exist
13:09:00.8 10/05/2013: Validating: Emulator_9: Snap Path: C:\Assets\Sony Playstation\Snaps
13:09:00.8 10/05/2013: Validating: Emulator_9: Control Panel Path: C:\Assets\Sony Playstation\Controls
13:09:00.8 10/05/2013: Validating: Emulator_9: Database: [Console] Sony Playstation
13:09:00.9 10/05/2013: Validating: Emulator_9: Title Snap Path: C:\Assets\Sony Playstation\Titles
13:09:00.9 10/05/2013: Validating: Emulator_9: Box Art Path: C:\Assets\Sony Playstation\Boxes
13:09:00.9 10/05/2013: Validating: Emulator_9: Cart Art Path: C:\Assets\Sony Playstation\Cartridges
13:09:00.9 10/05/2013: Validating: Emulator_9: Manual Path: C:\Assets\Sony Playstation\Manuals
13:09:00.9 10/05/2013: Warning: Emulator_9: MAPFile Does Not Exist
13:09:01.0 10/05/2013: Restoring Emulator from Cache
13:09:01.4 10/05/2013: Restoring Emulator Database From Cache
13:09:01.8 10/05/2013: Restoring Emulator from Cache
13:09:02.0 10/05/2013: Restoring Emulator Database From Cache
13:09:02.3 10/05/2013: Restoring Emulator from Cache
13:09:02.5 10/05/2013: Restoring Emulator Database From Cache
13:09:02.7 10/05/2013: Restoring Emulator from Cache
13:09:02.9 10/05/2013: Restoring Emulator Database From Cache
13:09:03.2 10/05/2013: Restoring Emulator from Cache
13:09:03.4 10/05/2013: Restoring Emulator Database From Cache
13:09:03.7 10/05/2013: Restoring Emulator from Cache
13:09:03.7 10/05/2013: Restoring Emulator Database From Cache
13:09:03.8 10/05/2013: Restoring Emulator from Cache
13:09:03.9 10/05/2013: Restoring Emulator Database From Cache
13:09:04.1 10/05/2013: Restoring Emulator from Cache
13:09:04.1 10/05/2013: Restoring Emulator Database From Cache
13:09:04.2 10/05/2013: Restoring Emulator from Cache
13:09:04.2 10/05/2013: No Database Data
13:09:30.4 10/05/2013: Setting Up RawInput Hook
13:09:30.4 10/05/2013: Launching RawInputHook.exe
13:09:32.4 10/05/2013: Running: cmd.exe /c C: C:\Emulators GameEx\MAME\mame.exe ssf2t -rompath C:\Roms\MAME -nowindow -joy -skip_gameinfo
13:09:32.5 10/05/2013: Shutting down display
13:11:15.2 10/05/2013: Exiting game
13:11:15.2 10/05/2013: Closing MAME window
13:11:15.2 10/05/2013: Waiting for MAME to exit
13:11:15.4 10/05/2013: MAME has exited
13:11:15.8 10/05/2013: Shutting down RawInput Hook
13:11:15.9 10/05/2013: Writing MAME stats
13:11:15.9 10/05/2013: Plugin: Game Exit
13:11:15.9 10/05/2013: Plugin: Process Commands
13:11:16.0 10/05/2013: Restoring Window
13:11:16.0 10/05/2013: Reinitializing Graphics System
13:11:17.7 10/05/2013: Returning to GameEx
13:11:47.8 10/05/2013: Setting Up RawInput Hook
13:11:47.8 10/05/2013: Launching RawInputHook.exe
13:11:49.0 10/05/2013: Running: cmd.exe /c C: C:\Emulators GameEx\MAME\mame.exe 3countb -rompath C:\Roms\MAME -nowindow -joy -skip_gameinfo
13:11:49.0 10/05/2013: Shutting down display
13:14:57.4 10/05/2013: Exiting game
13:14:57.4 10/05/2013: Closing MAME window
13:14:57.4 10/05/2013: Waiting for MAME to exit
13:14:57.5 10/05/2013: MAME has exited
13:14:57.9 10/05/2013: Shutting down RawInput Hook
13:14:57.9 10/05/2013: Writing MAME stats
13:14:57.9 10/05/2013: Plugin: Game Exit
13:14:57.9 10/05/2013: Plugin: Process Commands
13:14:57.9 10/05/2013: Restoring Window
13:14:58.0 10/05/2013: Reinitializing Graphics System
13:14:59.5 10/05/2013: Returning to GameEx
13:18:31.0 10/05/2013: Setting Up RawInput Hook
13:18:31.0 10/05/2013: Launching RawInputHook.exe
13:18:32.2 10/05/2013: Running: cmd.exe /c C: C:\Emulators GameEx\MAME\mame.exe ssf2t -rompath C:\Roms\MAME -nowindow -joy -skip_gameinfo
13:18:32.2 10/05/2013: Shutting down display
13:19:28.5 10/05/2013: Exiting game
13:19:28.5 10/05/2013: Closing MAME window
13:19:28.5 10/05/2013: Waiting for MAME to exit
13:19:32.4 10/05/2013: MAME has exited
13:19:32.8 10/05/2013: Shutting down RawInput Hook
13:19:32.9 10/05/2013: Writing MAME stats
13:19:32.9 10/05/2013: Plugin: Game Exit
13:19:32.9 10/05/2013: Plugin: Process Commands
13:19:32.9 10/05/2013: Restoring Window
13:19:32.9 10/05/2013: Reinitializing Graphics System
13:19:33.2 10/05/2013: 21 Consecutive Exceptions Occured
13:19:33.2 10/05/2013: Object reference not set to an instance of an object.
13:19:33.4 10/05/2013: at ag.t(Boolean A_0)
13:19:33.4 10/05/2013: at ag.ad()
13:19:33.4 10/05/2013: Trying reinitialising the display after sleeping for 4 seconds
13:19:33.4 10/05/2013: Exception count will be dropped to 15
13:19:37.4 10/05/2013: Exception initializing display
13:19:37.4 10/05/2013: Error in the application.
13:19:37.5 10/05/2013: at Microsoft.DirectX.Direct3D.Device..ctor(Int32 adapter, DeviceType deviceType, Control renderWindow, CreateFlags behaviorFlags, PresentParameters[] presentationParameters)
13:19:37.5 10/05/2013: at o.a(Form A_0, Int32 A_1, Int32 A_2, Boolean A_3, Boolean A_4, Boolean A_5, Boolean A_6)
13:19:37.5 10/05/2013: at o..ctor(Form A_0, Int32 A_1, Int32 A_2, Boolean A_3, Boolean A_4, Boolean A_5, Boolean A_6)
13:19:37.5 10/05/2013: at ag.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4)
13:19:37.5 10/05/2013: at ag.ad()
13:19:37.5 10/05/2013: --**--
13:19:37.5 10/05/2013: 21 Consecutive Exceptions Occured: Exiting
13:19:37.5 10/05/2013: Closing database connection
13:19:37.5 10/05/2013: First Exception:
13:19:37.5 10/05/2013: Error in the application.
13:19:37.5 10/05/2013: at ag.aa()
13:19:37.5 10/05/2013: at ag.d(String A_0)
13:19:37.5 10/05/2013: at ag.m(Boolean A_0)
13:19:37.5 10/05/2013: Last Exception:
13:19:37.5 10/05/2013: Object reference not set to an instance of an object.
13:19:37.5 10/05/2013: at ag.t(Boolean A_0)
Before we go down that path it will be imperative that you download and install the latest GameEx version. Your log show you are using version 12.55. The latest is version 13.10. It is possible that installing the latest version will resolve your errors. Please do so before going any further. Thanks!
Are you asking if you will lose it or telling that you did? :wacko:
If asking, then the answer is no. The install will detect the current installation and update those files that need to be updated. All of your emulator settings, etc., will remain. It may be a good idea, however, to back up the contents of your GameEx folder elsewhere so that you have them safe.
i install new version but the problem persist. After 10 minutes of mame the system crashes wih this error message:
16:06:04.2 10/05/2013: Opening Configuration File
16:06:04.3 10/05/2013: GameEx: Version 13.10: Starting Log
16:06:04.3 10/05/2013: Operating System Platform: Win32NT
16:06:04.3 10/05/2013: Operating System Name: Windows XP
16:06:04.3 10/05/2013: Operating System Version: 5.1.2600
16:06:04.3 10/05/2013: Getting CPU and RAM info
16:06:04.3 10/05/2013: Intel® Pentium® 4 CPU 3.00GHz, 1279MB
16:06:04.3 10/05/2013: 3Ghz - 2 Cores or CPU's
16:06:04.3 10/05/2013: Running Randomize()
16:06:04.3 10/05/2013: Loading PlugIns
16:06:04.3 10/05/2013: Checking for applications to Launch On Startup
16:06:04.3 10/05/2013: Setting default net connection limit to 15
16:06:04.3 10/05/2013: Running Misc startup tasks
16:06:04.3 10/05/2013: Setting Menu types
16:06:04.3 10/05/2013: Getting Configuration Values
16:06:04.3 10/05/2013: Using Theme: Default - Media Center V1
16:06:04.3 10/05/2013: Checking for alternate Image Directory for Theme: Default - Media Center V1
16:06:04.3 10/05/2013: Launching HideOS.exe
16:06:04.3 10/05/2013: Initialising Video/MNG DLL's
16:06:04.3 10/05/2013: GameEx will check for media insertion (may affect performance)
16:06:04.4 10/05/2013: Hiding Taskbar
16:06:04.4 10/05/2013: Is Media Center running?
16:06:04.4 10/05/2013: Checking/Creating LCD Registry values
16:06:04.4 10/05/2013: Check Media Center Exit/Start Mode
16:06:04.4 10/05/2013: Media Center Mode 2
16:06:04.4 10/05/2013: Video previews on. Warning: Only recommended on modern systems
16:06:04.4 10/05/2013: Custom Game Device Input enabled: Getting custom codes
16:06:04.4 10/05/2013: Snap Delay set to: 2
16:06:04.4 10/05/2013: Get other settings
16:06:04.4 10/05/2013: Desktop set to Hide ICONS and set Background to Black
16:06:04.4 10/05/2013: Set: Find emulator artwork on best match basis
16:06:04.5 10/05/2013: Start work for Form
16:06:04.5 10/05/2013: Getting Original Screen Size
16:06:04.5 10/05/2013: Opening Database Connection
16:06:05.2 10/05/2013: Converting Data.mdb to SQLite
16:06:07.1 10/05/2013: 338 Row/s converted
16:06:07.2 10/05/2013: Converting moviesv2.mdb to SQLite
16:06:07.3 10/05/2013: 0 Row/s converted
16:06:07.3 10/05/2013: Initializing Component
16:06:07.4 10/05/2013: MAME Path is: C:\Emulators GameEx\MAME
16:06:07.4 10/05/2013: MAME EXE file is: mame.exe
16:06:07.4 10/05/2013: ROM Path is: C:\Roms\MAME
16:06:07.4 10/05/2013: Catver.ini is located at: C:\Emulators GameEx\MAME\Catver.ini
16:06:07.4 10/05/2013: controls.ini is located at: C:\Emulators GameEx\MAME\controls.ini
16:06:07.6 10/05/2013: History.dat is located at: C:\Emulators GameEx\MAME\history.dat
16:06:07.6 10/05/2013: nplayers.ini is located at: C:\GameEx\DATA\nplayers.ini
16:06:07.6 10/05/2013: command.dat is located at: C:\GameEx\DATA\command.dat
16:06:07.6 10/05/2013: MAMEinfo.dat is located at: C:\GameEx\DATA\mameinfo.dat
16:06:07.6 10/05/2013: Loading Controls.ini map file
16:06:07.6 10/05/2013: Snap Path is: C:\Assets\MAME\Snaps
16:06:07.6 10/05/2013: Background Snap Path: Not Found
16:06:07.6 10/05/2013: AVI Snap Path: Not Found
16:06:07.6 10/05/2013: Flyer Path: Not Found
16:06:07.6 10/05/2013: Cabinet Path is: C:\Emulators GameEx\MAME\Cabinets
16:06:07.6 10/05/2013: Cabinet 3D Path: Not Found
16:06:07.6 10/05/2013: Title Path is: C:\Assets\MAME\Titles
16:06:07.6 10/05/2013: PCB Path: Not Found
16:06:07.6 10/05/2013: Artwork Preview Path: Not Found
16:06:07.6 10/05/2013: Panel Path is: C:\Assets\MAME\Controls
16:06:07.6 10/05/2013: Manual Path: Not Found
16:06:07.6 10/05/2013: Icon Path: Not Found
16:06:07.6 10/05/2013: Marquee Path is: C:\Emulators GameEx\MAME\marquees
16:06:07.7 10/05/2013: Applying Language/Text
16:06:07.7 10/05/2013: Text/Language: Italian
16:06:07.7 10/05/2013: Loading Language/Text
16:06:07.7 10/05/2013: Loading Custom Emulators
16:06:07.7 10/05/2013: Loading Emulator 1: A) Famicom
16:06:07.7 10/05/2013: Loading Emulator 2: B) Super Famicom
16:06:07.7 10/05/2013: Loading Emulator 3: C) Nintendo 64
16:06:07.7 10/05/2013: Loading Emulator 4: D) Sega Master System
16:06:07.7 10/05/2013: Loading Emulator 5: E) Sega Genesis
16:06:07.7 10/05/2013: Loading Emulator 6: F) Nintendo Game Boy
16:06:07.8 10/05/2013: Loading Emulator 7: G) Nintendo Game Boy Color
16:06:07.8 10/05/2013: Loading Emulator 8: H) Nintendo Game Boy Advance
16:06:07.8 10/05/2013: Loading Emulator 9: I) Sony Playstation
16:06:07.8 10/05/2013: Using 2D Animations
16:06:07.8 10/05/2013: Retrieving resolution setting
16:06:07.8 10/05/2013: Using General Font: Trebuchet MS
16:06:07.8 10/05/2013: Using Title Font: Trebuchet MS
16:06:07.8 10/05/2013: GameEx will try to reduce CPU usage
16:06:07.9 10/05/2013: Initialising Direct3D
16:06:08.2 10/05/2013: Setting Resolution to 1280x1024 32 bit color
16:06:08.2 10/05/2013: Creating Surfaces
16:06:08.3 10/05/2013: Creating Primary Surface - Full Screen Mode
16:06:08.3 10/05/2013: Creating Back Buffer
16:06:08.3 10/05/2013: Loading graphic Surfaces
16:06:08.4 10/05/2013: Display is running at: 1280x1024 32bit color, 60hz
16:06:08.4 10/05/2013: Adapter: NVIDIA GeForce FX 5500
16:06:08.4 10/05/2013: Max texture size: 4096x4096
16:06:08.4 10/05/2013: Available texture memory: 615MB
16:06:08.5 10/05/2013: Initialising Bass Audio Library
16:06:08.5 10/05/2013: Creating Surfaces Misc and Dialogs
16:06:08.9 10/05/2013: Creating Surfaces Volume
16:06:08.9 10/05/2013: Creating Surfaces Arrows
16:06:08.9 10/05/2013: Creating Surfaces GameEXlogo Text
16:06:08.9 10/05/2013: Creating Surfaces Toolbar
16:06:09.0 10/05/2013: Creating Surfaces Toolbar Controls
16:06:09.0 10/05/2013: Creating Surfaces Backgrounds
16:06:09.0 10/05/2013: Creating Surfaces GameEx Logo
16:06:09.0 10/05/2013: Creating Surface Unselected
16:06:09.0 10/05/2013: Creating Surfaces Home & Exit
16:06:09.0 10/05/2013: Creating Surfaces Snaps
16:06:09.0 10/05/2013: Creating Surfaces Menu and List Bars
16:06:09.5 10/05/2013: Creating Fonts
16:06:09.5 10/05/2013: Creating Game Font
16:06:09.7 10/05/2013: Creating Game Font Faded
16:06:09.8 10/05/2013: Creating Title Font
16:06:09.9 10/05/2013: Restoring Title Font From Cache
16:06:10.0 10/05/2013: Creating Menu Font
16:06:10.3 10/05/2013: Creating Font Black
16:06:10.4 10/05/2013: Creating Font Black Small
16:06:10.5 10/05/2013: Fonts Created Succesfully
16:06:10.5 10/05/2013: 5MB Video Memory Used
16:06:33.1 10/05/2013: Attempting to load game list
16:06:33.5 10/05/2013: MAME CMD options: -nowindow -joy -skip_gameinfo
16:06:33.5 10/05/2013: Initialising DirectInput for Gamepad support
16:06:33.6 10/05/2013: Using Device Controller (XBOX 360 For Windows)
16:06:33.6 10/05/2013: Loading Start Page
16:06:33.7 10/05/2013: Initializing MCE Remote
16:06:33.7 10/05/2013: Playing intro sound file
16:06:33.7 10/05/2013: Initialization OK! Starting GameEx!
16:06:33.7 10/05/2013: Testing Main Loop Once: Processing Frame
16:06:34.3 10/05/2013: Testing Main Loop Once: Main Loop ran successfully
16:06:41.8 10/05/2013: Validating: Emulator_1: Snap Path: C:\Assets\Nintendo NES\Snaps
16:06:41.8 10/05/2013: Validating: Emulator_1: Control Panel Path: C:\Assets\Nintendo NES\Nintendo NES\Controls
16:06:41.8 10/05/2013: Warning: Emulator_1: Control Panel Path Does not exist
16:06:41.8 10/05/2013: Validating: Emulator_1: Database: [Console] Nintendo NES
16:06:41.8 10/05/2013: Validating: Emulator_1: Title Snap Path: C:\Assets\Nintendo NES\Titles
16:06:41.9 10/05/2013: Validating: Emulator_1: Box Art Path: C:\Assets\Nintendo NES\Nintendo NES\Boxes
16:06:41.9 10/05/2013: Warning: Emulator_1: Box Art Path Does not exist
16:06:41.9 10/05/2013: Validating: Emulator_1: Cart Art Path: C:\Assets\Nintendo NES\Nintendo NES\Cartridges
16:06:41.9 10/05/2013: Warning: Emulator_1: Cart Art Path Does not exist
16:06:41.9 10/05/2013: Validating: Emulator_1: Manual Path: C:\Assets\Nintendo NES\Nintendo NES\Manuals
16:06:41.9 10/05/2013: Warning: Emulator_1: Manual Path Does not exist
16:06:41.9 10/05/2013: Caching Video Snap Path
16:06:41.9 10/05/2013: Caching Snap Path
16:06:41.9 10/05/2013: Caching Title Path
16:06:46.0 10/05/2013: Validating: Emulator_2: Snap Path: C:\Assets\Nintendo SNES\Snaps
16:06:46.0 10/05/2013: Validating: Emulator_2: Control Panel Path: C:\Assets\Nintendo SNES\Controls
16:06:46.0 10/05/2013: Validating: Emulator_2: Database: [Console] Nintendo SNES
16:06:46.0 10/05/2013: Validating: Emulator_2: Title Snap Path: C:\Assets\Nintendo SNES\Titles
16:06:46.0 10/05/2013: Validating: Emulator_2: Box Art Path: C:\Assets\Nintendo SNES\Boxes
16:06:46.0 10/05/2013: Validating: Emulator_2: Cart Art Path: C:\Assets\Nintendo SNES\Cartridges
16:06:46.0 10/05/2013: Validating: Emulator_2: Manual Path: C:\Assets\Nintendo SNES\Manuals
16:06:46.0 10/05/2013: Caching Video Snap Path
16:06:46.0 10/05/2013: Caching Snap Path
16:06:46.0 10/05/2013: Caching Title Path
16:06:49.4 10/05/2013: Caching Box Path
16:06:49.4 10/05/2013: Caching Cart Path
16:06:49.4 10/05/2013: Validating: Emulator_3: Snap Path: C:\Assets\Nintendo N64\Snaps
16:06:49.4 10/05/2013: Validating: Emulator_3: Control Panel Path: C:\Assets\Nintendo N64\Controls
16:06:49.4 10/05/2013: Validating: Emulator_3: Database: [Console] Nintendo N64
16:06:49.4 10/05/2013: Validating: Emulator_3: Title Snap Path: C:\Assets\Nintendo N64\Titles
16:06:49.4 10/05/2013: Validating: Emulator_3: Box Art Path: C:\Assets\Nintendo N64\Boxes
16:06:49.4 10/05/2013: Validating: Emulator_3: Cart Art Path: C:\Assets\Nintendo N64\Cartridges
16:06:49.4 10/05/2013: Validating: Emulator_3: Manual Path: C:\Assets\Nintendo N64\Manuals
16:06:49.4 10/05/2013: Caching Video Snap Path
16:06:49.4 10/05/2013: Caching Snap Path
16:06:49.4 10/05/2013: Caching Title Path
16:06:49.4 10/05/2013: Validating: Emulator_4: Snap Path: C:\Assets\Sega Master System\Snaps
16:06:49.4 10/05/2013: Validating: Emulator_4: Control Panel Path: C:\Assets\Sega Master System\Controls
16:06:49.4 10/05/2013: Validating: Emulator_4: Database: [Console] Sega Master System
16:06:49.4 10/05/2013: Validating: Emulator_4: Title Snap Path: C:\Assets\Sega Master System\Titles
16:06:49.4 10/05/2013: Validating: Emulator_4: Box Art Path: C:\Assets\Sega Master System\Boxes
16:06:49.4 10/05/2013: Validating: Emulator_4: Cart Art Path: C:\Assets\Sega Master System\Cartridges
16:06:49.4 10/05/2013: Validating: Emulator_4: Manual Path: C:\Assets\Sega Master System\Manuals
16:06:49.8 10/05/2013: Caching Snap Path
16:06:49.8 10/05/2013: Caching Title Path
16:06:49.8 10/05/2013: Caching Box Path
16:06:49.8 10/05/2013: Caching Cart Path
16:06:49.8 10/05/2013: Validating: Emulator_5: Snap Path: C:\Assets\Sega Genesis\Snaps
16:06:49.8 10/05/2013: Validating: Emulator_5: Control Panel Path: C:\Assets\Sega Genesis\Controls
16:06:49.8 10/05/2013: Validating: Emulator_5: Database: [Console] Sega Genesis
16:06:49.8 10/05/2013: Validating: Emulator_5: Title Snap Path: C:\Assets\Sega Genesis\Titles
16:06:49.8 10/05/2013: Validating: Emulator_5: Box Art Path: C:\Assets\Sega Genesis\Boxes
16:06:49.8 10/05/2013: Validating: Emulator_5: Cart Art Path: C:\Assets\Sega Genesis\Cartridges
16:06:49.8 10/05/2013: Validating: Emulator_5: Manual Path: C:\Assets\Sega Genesis\Manuals
16:06:49.8 10/05/2013: Caching Video Snap Path
16:06:53.0 10/05/2013: Caching Box Path
16:06:53.0 10/05/2013: Caching Cart Path
16:06:53.0 10/05/2013: Validating: Emulator_6: Snap Path: C:\Assets\Nintendo Game Boy\Snaps
16:06:53.0 10/05/2013: Validating: Emulator_6: Control Panel Path: C:\Assets\Nintendo Game Boy\Controls
16:06:53.0 10/05/2013: Validating: Emulator_6: Database: [Handheld] Nintendo Game Boy
16:06:53.0 10/05/2013: Validating: Emulator_6: Title Snap Path: C:\Assets\Nintendo Game Boy\Titles
16:06:53.0 10/05/2013: Validating: Emulator_6: Box Art Path: C:\Assets\Nintendo Game Boy\Boxes
16:06:53.0 10/05/2013: Validating: Emulator_6: Cart Art Path: C:\Assets\Nintendo Game Boy\Cartridges
16:06:53.0 10/05/2013: Validating: Emulator_6: Manual Path: C:\Assets\Nintendo Game Boy\Manuals
16:06:53.0 10/05/2013: Caching Video Snap Path
16:06:53.1 10/05/2013: Caching Snap Path
16:06:53.1 10/05/2013: Caching Title Path
16:06:53.1 10/05/2013: Caching Box Path
16:06:53.1 10/05/2013: Caching Cart Path
16:06:53.1 10/05/2013: Validating: Emulator_7: Snap Path: C:\Assets\Nintendo Game Boy Color\Snaps
16:06:53.1 10/05/2013: Validating: Emulator_7: Control Panel Path: C:\Assets\Nintendo Game Boy Color\Controls
16:06:53.1 10/05/2013: Validating: Emulator_7: Database: [Handheld] Nintendo Game Boy Color
16:06:53.1 10/05/2013: Validating: Emulator_7: Title Snap Path: C:\Assets\Nintendo Game Boy Color\Titles
16:06:53.1 10/05/2013: Validating: Emulator_7: Box Art Path: C:\Assets\Nintendo Game Boy Color\Boxes
16:06:53.1 10/05/2013: Validating: Emulator_7: Cart Art Path: C:\Assets\Nintendo Game Boy Color\Cartridges
16:06:53.1 10/05/2013: Validating: Emulator_7: Manual Path: C:\Assets\Nintendo Game Boy Color\Manuals
16:06:53.1 10/05/2013: Caching Video Snap Path
16:06:53.4 10/05/2013: Caching Snap Path
16:06:53.4 10/05/2013: Caching Title Path
16:06:53.4 10/05/2013: Caching Box Path
16:06:53.4 10/05/2013: Caching Cart Path
16:06:53.4 10/05/2013: Validating: Emulator_8: Snap Path: C:\Assets\Nintendo Game Boy Advance\Snaps
16:06:53.4 10/05/2013: Validating: Emulator_8: Control Panel Path: C:\Assets\Nintendo Game Boy Advance\Nintendo Game Boy Advance\Controls
16:06:53.4 10/05/2013: Warning: Emulator_8: Control Panel Path Does not exist
16:06:53.4 10/05/2013: Validating: Emulator_8: Database: [Handheld] Nintendo Game Boy Advance
16:06:53.4 10/05/2013: Validating: Emulator_8: Title Snap Path: C:\Assets\Nintendo Game Boy Advance\Nintendo Game Boy Advance\Titles
16:06:53.4 10/05/2013: Warning: Emulator_8: Title Snap Path Does not exist
16:06:53.4 10/05/2013: Validating: Emulator_8: Box Art Path: C:\Assets\Nintendo Game Boy Advance\Nintendo Game Boy Advance\Boxes
16:06:53.4 10/05/2013: Warning: Emulator_8: Box Art Path Does not exist
16:06:53.4 10/05/2013: Validating: Emulator_8: Cart Art Path: C:\Assets\Nintendo Game Boy Advance\Nintendo Game Boy Advance\Cartridges
16:06:53.4 10/05/2013: Warning: Emulator_8: Cart Art Path Does not exist
16:06:53.4 10/05/2013: Validating: Emulator_8: Manual Path: C:\Assets\Nintendo Game Boy Advance\Nintendo Game Boy Advance\Manuals
16:06:53.4 10/05/2013: Warning: Emulator_8: Manual Path Does not exist
16:06:53.4 10/05/2013: Caching Video Snap Path
16:06:53.4 10/05/2013: Validating: Emulator_9: Snap Path: C:\Assets\Sony Playstation\Snaps
16:06:53.4 10/05/2013: Validating: Emulator_9: Control Panel Path: C:\Assets\Sony Playstation\Controls
16:06:53.4 10/05/2013: Validating: Emulator_9: Database: [Console] Sony Playstation
16:06:53.4 10/05/2013: Validating: Emulator_9: Title Snap Path: C:\Assets\Sony Playstation\Titles
16:06:53.4 10/05/2013: Validating: Emulator_9: Box Art Path: C:\Assets\Sony Playstation\Boxes
16:06:53.4 10/05/2013: Validating: Emulator_9: Cart Art Path: C:\Assets\Sony Playstation\Cartridges
16:06:53.4 10/05/2013: Validating: Emulator_9: Manual Path: C:\Assets\Sony Playstation\Manuals
16:06:53.4 10/05/2013: Warning: Emulator_9: MAPFile Does Not Exist
16:06:53.4 10/05/2013: Cache Diff: - false
16:06:53.4 10/05/2013: Not Restoring Emulator from Cache: 1
16:06:54.4 10/05/2013: DBCache Diff: 28/11/2011 18.25.09 - 10/07/2012 19.29.24
16:06:54.7 10/05/2013: Not Restoring Emulator Database From Cache: 1
16:06:57.1 10/05/2013: Cache Diff: - nintendo snes
16:06:57.1 10/05/2013: Not Restoring Emulator from Cache: 2
16:06:58.3 10/05/2013: DBCache Diff: 28/11/2011 18.25.20 - 10/07/2012 19.29.34
16:06:58.5 10/05/2013: Not Restoring Emulator Database From Cache: 2
16:07:00.5 10/05/2013: Cache Diff: - false
16:07:00.5 10/05/2013: Not Restoring Emulator from Cache: 3
16:07:01.6 10/05/2013: DBCache Diff: 28/11/2011 18.25.08 - 10/07/2012 19.29.12
16:07:01.7 10/05/2013: Not Restoring Emulator Database From Cache: 3
16:07:04.5 10/05/2013: Cache Diff: - false
16:07:04.5 10/05/2013: Not Restoring Emulator from Cache: 4
16:07:06.1 10/05/2013: DBCache Diff: 28/11/2011 18.25.33 - 10/07/2012 19.29.58
16:07:06.2 10/05/2013: Not Restoring Emulator Database From Cache: 4
16:07:07.4 10/05/2013: Cache Diff: - false
16:07:07.4 10/05/2013: Not Restoring Emulator from Cache: 5
16:07:09.8 10/05/2013: DBCache Diff: 28/11/2011 18.25.36 - 10/07/2012 19.29.55
16:07:09.9 10/05/2013: Not Restoring Emulator Database From Cache: 5
16:07:11.8 10/05/2013: Cache Diff: - false
16:07:11.8 10/05/2013: Not Restoring Emulator from Cache: 6
16:07:12.8 10/05/2013: DBCache Diff: 28/11/2011 18.25.40 - 10/07/2012 19.30.57
16:07:12.8 10/05/2013: Not Restoring Emulator Database From Cache: 6
16:07:13.1 10/05/2013: Cache Diff: - false
16:07:13.1 10/05/2013: Not Restoring Emulator from Cache: 7
16:07:14.0 10/05/2013: DBCache Diff: 28/11/2011 18.25.40 - 10/07/2012 19.30.52
16:07:14.1 10/05/2013: Not Restoring Emulator Database From Cache: 7
16:07:14.5 10/05/2013: Cache Diff: - false
16:07:14.5 10/05/2013: Not Restoring Emulator from Cache: 8
16:07:15.5 10/05/2013: DBCache Diff: 28/11/2011 18.25.13 - 10/07/2012 19.30.47
16:07:15.5 10/05/2013: Not Restoring Emulator Database From Cache: 8
16:07:15.7 10/05/2013: Cache Diff: - false
16:07:15.7 10/05/2013: Not Restoring Emulator from Cache: 9
16:07:16.9 10/05/2013: Not Restoring Emulator Database From Cache: 9
16:07:40.6 10/05/2013: Setting Up RawInput Hook
16:07:40.6 10/05/2013: Launching RawInputHook.exe
16:07:41.8 10/05/2013: Running: cmd.exe /c C: C:\Emulators GameEx\MAME\mame.exe ssf2t -rompath C:\Roms\MAME -nowindow -joy -skip_gameinfo
16:07:41.8 10/05/2013: Shutting down display
16:11:22.1 10/05/2013: Exiting game
16:11:22.1 10/05/2013: Closing MAME window
16:11:22.1 10/05/2013: Waiting for MAME to exit
16:11:22.3 10/05/2013: MAME has exited
16:11:22.6 10/05/2013: Shutting down RawInput Hook
16:11:22.7 10/05/2013: Writing MAME stats
16:11:22.7 10/05/2013: Plugin: Game Exit
16:11:22.7 10/05/2013: Plugin: Process Commands
16:11:22.7 10/05/2013: Restoring Window
16:11:22.7 10/05/2013: Reinitializing Graphics System
16:11:24.5 10/05/2013: Returning to GameEx
16:13:22.3 10/05/2013: Setting Up RawInput Hook
16:13:22.3 10/05/2013: Launching RawInputHook.exe
16:13:23.5 10/05/2013: Running: cmd.exe /c C: C:\Emulators GameEx\MAME\mame.exe mbombrdj -rompath C:\Roms\MAME -nowindow -joy -skip_gameinfo
16:13:23.5 10/05/2013: Shutting down display
16:15:17.7 10/05/2013: Exiting game
16:15:17.7 10/05/2013: Closing MAME window
16:15:17.7 10/05/2013: Waiting for MAME to exit
16:15:17.8 10/05/2013: MAME has exited
16:15:18.2 10/05/2013: Shutting down RawInput Hook
16:15:18.2 10/05/2013: Writing MAME stats
16:15:18.2 10/05/2013: Plugin: Game Exit
16:15:18.2 10/05/2013: Plugin: Process Commands
16:15:18.3 10/05/2013: Restoring Window
16:15:18.3 10/05/2013: Reinitializing Graphics System
16:15:20.0 10/05/2013: Returning to GameEx
16:15:32.8 10/05/2013: Setting Up RawInput Hook
16:15:32.8 10/05/2013: Launching RawInputHook.exe
16:15:34.0 10/05/2013: Running: cmd.exe /c C: C:\Emulators GameEx\MAME\mame.exe nemo -rompath C:\Roms\MAME -nowindow -joy -skip_gameinfo
16:15:34.0 10/05/2013: Shutting down display
16:19:49.9 10/05/2013: Exiting game
16:19:49.9 10/05/2013: Closing MAME window
16:19:49.9 10/05/2013: Waiting for MAME to exit
16:19:50.0 10/05/2013: MAME has exited
16:19:50.4 10/05/2013: Shutting down RawInput Hook
16:19:50.4 10/05/2013: Writing MAME stats
16:19:50.4 10/05/2013: Plugin: Game Exit
16:19:50.4 10/05/2013: Plugin: Process Commands
16:19:50.5 10/05/2013: Restoring Window
16:19:50.5 10/05/2013: Reinitializing Graphics System
16:19:52.2 10/05/2013: Returning to GameEx
16:20:03.5 10/05/2013: Setting Up RawInput Hook
16:20:03.5 10/05/2013: Launching RawInputHook.exe
16:20:04.7 10/05/2013: Running: cmd.exe /c C: C:\Emulators GameEx\MAME\mame.exe nwarru -rompath C:\Roms\MAME -nowindow -joy -skip_gameinfo
16:20:04.7 10/05/2013: Shutting down display
16:21:53.7 10/05/2013: Exiting game
16:21:53.7 10/05/2013: Closing MAME window
16:21:53.7 10/05/2013: Waiting for MAME to exit
16:21:53.8 10/05/2013: MAME has exited
16:21:54.2 10/05/2013: Shutting down RawInput Hook
16:21:54.2 10/05/2013: Writing MAME stats
16:21:54.2 10/05/2013: Plugin: Game Exit
16:21:54.2 10/05/2013: Plugin: Process Commands
16:21:54.2 10/05/2013: Restoring Window
16:21:54.2 10/05/2013: Reinitializing Graphics System
16:21:56.0 10/05/2013: Returning to GameEx
16:22:34.9 10/05/2013: Setting Up RawInput Hook
16:22:34.9 10/05/2013: Launching RawInputHook.exe
16:22:36.0 10/05/2013: Running: cmd.exe /c C: C:\Emulators GameEx\MAME\mame.exe sfz2alb -rompath C:\Roms\MAME -nowindow -joy -skip_gameinfo
16:22:36.1 10/05/2013: Shutting down display
16:25:46.1 10/05/2013: Exiting game
16:25:46.5 10/05/2013: Shutting down RawInput Hook
16:25:46.5 10/05/2013: Writing MAME stats
16:25:46.5 10/05/2013: Plugin: Game Exit
16:25:46.5 10/05/2013: Plugin: Process Commands
16:25:46.6 10/05/2013: Restoring Window
16:25:46.6 10/05/2013: Reinitializing Graphics System
16:25:47.0 10/05/2013: 21 Consecutive Exceptions Occured
16:25:47.0 10/05/2013: Object reference not set to an instance of an object.
16:25:47.1 10/05/2013: at GameEx.GameEx.mainform.f(Boolean A_0, Boolean A_1)
16:25:47.1 10/05/2013: at GameEx.GameEx.mainform.d4()
16:25:47.1 10/05/2013: Trying reinitialising the display after sleeping for 4 seconds
16:25:47.1 10/05/2013: Exception count will be dropped to 15
16:25:51.3 10/05/2013: Exception initializing display
16:25:51.3 10/05/2013: Object is currently in use elsewhere.
16:25:51.5 10/05/2013: at System.Drawing.Graphics.CheckErrorStatus(Int32 status)
16:25:51.5 10/05/2013: at System.Drawing.Graphics.DrawImage(Image image, Rectangle destRect, Int32 srcX, Int32 srcY, Int32 srcWidth, Int32 srcHeight, GraphicsUnit srcUnit, ImageAttributes imageAttrs, DrawImageAbort callback, IntPtr callbackData)
16:25:51.5 10/05/2013: at System.Drawing.Graphics.DrawImage(Image image, Rectangle destRect, Int32 srcX, Int32 srcY, Int32 srcWidth, Int32 srcHeight, GraphicsUnit srcUnit, ImageAttributes imageAttr, DrawImageAbort callback)
16:25:51.5 10/05/2013: at System.Drawing.Graphics.DrawImage(Image image, Rectangle destRect, Int32 srcX, Int32 srcY, Int32 srcWidth, Int32 srcHeight, GraphicsUnit srcUnit, ImageAttributes imageAttr)
16:25:51.5 10/05/2013: at GameEx.M_DirectDraw.GetBlackFreeBitmap(Bitmap b, Boolean NoDispose)
16:25:51.5 10/05/2013: at GameEx.GameEx.mainform.a(Surface& A_0, String A_1, SurfaceDescription A_2, Boolean A_3, Boolean A_4, Int32 A_5)
16:25:51.5 10/05/2013: at GameEx.GameEx.mainform.e(Boolean A_0, Boolean A_1, Boolean A_2)
16:25:51.5 10/05/2013: at GameEx.GameEx.mainform.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4, Int32 A_5, Int32 A_6, Boolean A_7, Boolean A_8)
16:25:51.5 10/05/2013: at GameEx.GameEx.mainform.d4()
16:25:51.5 10/05/2013: --**--
16:25:51.5 10/05/2013: 21 Consecutive Exceptions Occured: Exiting
16:25:51.5 10/05/2013: Closing database connection
16:25:51.5 10/05/2013: First Exception:
16:25:51.5 10/05/2013: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
16:25:51.5 10/05/2013: at GameEx.GameEx.mainform.c2()
16:25:51.5 10/05/2013: at GameEx.GameEx.mainform.u(String A_0)
16:25:51.5 10/05/2013: at GameEx.GameEx.mainform.r(Boolean A_0)
16:25:51.5 10/05/2013: Last Exception:
16:25:51.5 10/05/2013: Object reference not set to an instance of an object.
16:25:51.5 10/05/2013: at GameEx.GameEx.mainform.f(Boolean A_0, Boolean A_1)
What's going on at the time of this error? Your log makes it look like your machine is in attract mode at the time, but it would be good to verify that. Also we still need to have a look at your GameEx.ini.
Are you running any non-standard codecs on your machine? Are your video card drivers up to date (always best to check this through the manufacturer of your video card). Do you have DirectX up to date on this machine?
The more detail you can provide, the more likely we will be able to provide useful information regarding the nature of your error. Thanks man!
It looks like DirectX is crashing when trying to draw GameEx after you exit MAME. I've had this happen to me a few times. Are you trying to run GameEx windowed and MAME full screen, or vice versa? I've found that this kind of error goes away when you're using either both full screen or both windowed, but not mixed. You can go full screen / windowed by pressing [ALT]+[ENTER].
Something else you could try is making sure you have the latest drivers for your video card, and the latest updates to DirectX. Check those things out and then report back.
Hi Goron
It would help if you can confirm that this error seems specifically related to attract mode (as your log seems to indicate). Does MAME run well when not running in attract mode?
Based on the text of your error message I turned up two results within the forums, and both of them were related to attract mode:
One was resolved by acquiring a new copy of MAME:
Attract video problem?
And the other one seems to be an issue related to Joystick Input settings:
Gameex crashes after attaching gamepads, attract mode root cause?
I'd take a look at both of those threads to determine if your issue is similar (I'd be more ineterested to know if it's related to your Joystick Input settings, as that seems to be a pretty close match to the settings you posted here. On the other hand a new copy of MAME certainly wouldn't hurt either).
Thanks and Good Luck!
According to the second link I posted in my previous post, this was the cause of his problem (where the error was identical to yours):
  On 5/10/2013 at 4:26 PM, Your GameEx.ini said:
EnableCustomJoyInput=True
So I guess I'd take a look at that first. If that doesn't work I'd "reinstall" MAME which essentially means that you get a new copy of MAME and try that out (as suggested in the first link I posted above).
Edit:
Also you've never answered whether this problem seems to be related to Attract Mode. That information would be helpful.
Tom just updated to 13.11 that fixes the fullscreen in a window. Please install this latest version and report back. Thanks!
The problem persist... I update gameex, mame but the system crash after 20 seconds when i start to play mame game...
It' s terrible...:(
Just a thought, I wonder if one of your controls in MAME is conflicting with the in game key in GameEx. This brings up the game info page while MAME is running. Check that setting under input settings and set it to something not used.
Excuse me Tom... I'm italian user and I did not understand what to do to solve the problem ... What comes into conflict? which settings should I change?
