I just got my Daphne up and running outside GameEx(have Mame, Nes, Genesis working for months). I have an X-arcade Tankstick and it works fine controlling all other systems/emulators. I for the life of me after searching and reading here and ALL over the net, have had no success getting my Tankstick to control Daphne within GameEx.
I'm sure others have the Tankstick and have faced the issue of setting this up. I appreciate the help. Thanks!
You may want to refer to Celly's solution here.
  Quote
They can be edited within Daphne and the Daphne Loader 1.2. First open the DaphneLoader.exe. Select a game, say Dragon's Lair (US Enhancement 2.x). Then click the Game tab at the top of the menu and you should see Configure, click that. Now another window appears with the configuration for that game and at the bottom there is a Configure Keys and a Configure Buttons button at that bottom. Use those.
Odd, tried that before multiple times with no success as the conifigure options were easy to find in DaphneLoader. Tried again after getting your email, so far so good. I've only tried with two games since Daphne roms are hard to get working but I'll take it.
