Hi. I've had a look though the forums & help but can't find how to define my joystick in Daphne. I've enabled use/map joypad in the GameEx setup & some controls work, but I don't know where to customise them. Any help would be appreciated. Thanks.
They can be edited within Daphne and the Daphne Loader 1.2. First open the DaphneLoader.exe. Select a game, say Dragon's Lair (US Enhancement 2.x). Then click the Game tab at the top of the menu and you should see Configure, click that. Now another window appears with the configuration for that game and at the bottom there is a Configure Keys and a Configure Buttons button at that bottom. Use those.
Thanks for the reply. Couldn't get this working, but tried again because you mentioned it, but this time actually ran a game through Daphne first. Daphne updated & now it works. Thanks again.
