Here are some loading screen's I'm working on (1920x1080), these will be a full pack and I am using the same font (for the moment anyway) for consistency. Eventually I will make the loading screen's more in depth with font's that resemble the system and more graphics but for the moment these look ok.
NintendoFamicomDiskSystem_zps81f3a6c8.pn
Hey KRC! These are great!
I would love to use these on GameExtender. Any chance you could remove the "Now Loading" text? These would look stellar behind Game Info. :)
Thanks!
Yeah no worries I can remove the text, these aren't done a specific order at the moment but I will be putting them in packs soon for easier downloading.
Where does GameExtender look for the Custom Images when enabled? Is this specific to the theme's Media folder or the GameEx Media folder?
No there's a setting in each emulator's advanced config. What I do is point the Artwork folder at EmuMovies backgrounds and set the not found image to these. :)
  • 1 month later...
