I had to updated my Visual Pinball to vp7 (which fixes a lot of audio problems, by the way), but now the Autoexec script hangs up when I exit a table out of GameEx. It seems to exit fine, but the table is still loaded and I have to exit GameEx to close the table. When I try to play another pinball table, it hangs up GameEx. Does anybody have any suggestions? Thanks.
  • 1 month later...
Is VP 7 a good choice to use? I have all the pinball games, but need a good from end.
Well, yes as far as how the games run. It seemed to run the newer games a lot smoother and seemed to solve some of the sound issues, but I still have a problem with it hanging up when I am trying to exit the Pinball game and no one has posted a response about an answer (which I am unable to find on my own). Sorry, that's not much of an answer. Yes it makes tables work better, but No, it still has problems with GameEX.
I guess I am missing some of the basics on the Pinball..I am still having problems getting my pinball stuff to work!
It's kind of a pain in the rear to get going. They have a config pinned on the forum and I just copied it, changing the drive letters to match mine.
Pinned: Topic has attachmentsUser Submitted Configs and Databases (Uploads) * 123
It's at the top of the GameEX forum...
Great! Thank you!!
Great! Thank you!!
hmmm..I looked all over for it..are my eyes failing me?? I did not see it? Any help would be greatly appreciated.
