I noticed with my latest Gameroom theme I have custom menu and when you start GameEx it centers the list in the middle which is fine, but when you select any menu option above the center list and exit it return to the center menu listing. However if you select any menu item below the center listing it returns to that same one you selected. For example:
ATARI 2600
ATARI 5200
ATARI 7800
COLECOVISION <==== CENTER
SEGA GENESIS
SEGA CD
SEGA 32X
So when you select any of the ATARI systems and exit back to the above menu it centers to the COLECOVISION menu item, but when you SELECT say SEGA CD and then return to thie above menu it will be on the SEGA CD item????
Not sure if it matters but I have the "Static Start Page List" checked in the Theme Editor. As this is the method I want to display the list.
Krak - you may want to provide copies of your gameex.ini, log.txt, and custommenu.ini files so as to minimize any second guessing. Thanks!
