I have a new problem with the custom menu program. when I open it the the left folder style window is quite big and the right selection window is too small and is cutting off parts of it where selection need to be chosen. So about 1/3 of the selection pane is hidden beyond the right window frame. There seems to be now way to drag the divider bar between the two pane to change their sizes. Not sure if this has anything to do with the update.
That is weird! Works ok here after just updating. Changed your windows theme or anything recently?
For your information, you can scroll through the tree list using the keyboard - it's not a solution i know but atleast you'll hopefully be able to still sort your Menu's in the meantime
Good call on the windows theme Dazzle. I just started using a android remote desktop app so my kids can watch their cartoon while im messing around with configuring GameEx. It works great but automatically makes windows drop out of areo theme. Switched back and s all now back to normal guess i just need to remember to switch it back when im going to main computer after using RD.
thanks
Heh yeah Windows doesn't like themes being messed with - or even taken away it seems! Can really screw with the form layout.
Glad you're back to Normalville now though sir - and can focus on laying out your awesome custom menus instead :)
