Relevant section of the debug frame.
08:03:18.1 1/29/2013: 21 Consecutive Exceptions Occured
08:03:18.1 1/29/2013: Method not found: 'Boolean NetVideoPlayer.CaptureVideoPlayer.GrabSampleToMemory(Int32, Int32)'.
08:03:18.1 1/29/2013: at GameEx.GameEx.mainform.a(Int32 A_0, Int32 A_1, String A_2, Boolean A_3, Boolean A_4, Int32 A_5, Int32 A_6)
08:03:18.1 1/29/2013: at GameEx.GameEx.mainform.i(Boolean A_0)
08:03:18.1 1/29/2013: at GameEx.GameEx.mainform.f(Boolean A_0, Boolean A_1)
08:03:18.1 1/29/2013: at GameEx.GameEx.mainform.d1()
08:03:18.1 1/29/2013: Trying reinitialising the display after sleeping for 4 seconds
08:03:18.1 1/29/2013: Exception count will be dropped to 15
08:03:23.3 1/29/2013: --**--
08:03:23.3 1/29/2013: 21 Consecutive Exceptions Occured: Exiting
08:03:23.3 1/29/2013: Closing database connection
08:03:23.3 1/29/2013: First Exception:
08:03:23.3 1/29/2013: Method not found: 'Boolean NetVideoPlayer.CaptureVideoPlayer.GrabSampleToMemory(Int32, Int32)'.
08:03:23.3 1/29/2013: at GameEx.GameEx.mainform.a(Int32 A_0, Int32 A_1, String A_2, Boolean A_3, Boolean A_4, Int32 A_5, Int32 A_6)
08:03:23.3 1/29/2013: at GameEx.GameEx.mainform.i(Boolean A_0)
08:03:23.3 1/29/2013: at GameEx.GameEx.mainform.f(Boolean A_0, Boolean A_1)
08:03:23.3 1/29/2013: at GameEx.GameEx.mainform.d1()
08:03:23.3 1/29/2013: Last Exception:
As I've said, I opened gameEx for the first time in a couple months and ran the automatic updates on startup. After the updates finished GameEx is now stuck in a crash loop. Thanks for any help in resolving this issue.
Please download the latest version directly from the site and install. No need to worry about it overwriting your current setup. Let us know if this resolves your issue. If not, please provide copies of your gameex.ini and log.txt file post crash. Thanks!
