Hello everyone!!!1
i am back,
And i have been busy!!!!!!! its all almost complete and do i have some treats for you all as promised!
However i have a small issue.
After installing my Corsair h100i (Yes a water cooled arcade machine)
It required me to install a net.framewaork (think it was 4.0) and now gameex wont load, black screen then nothing.
Any ideas for trouble shooting.
System
Windows XP64
1100wat Antec
6GHZ Dual core 775 at 21deg full load
8gb Hyperx Ram
Asus Rampage x48 Formula
2x HR-05 SLI IFX Chipset Cooler Southbridge and Northbridge
h100i cooler with modified custom bracked to fit 775 as its unspoorted!
Radieon HD4890 with Hack Drivers
Arcade VGA3000
Two Gcards you say???
(a custom switching circut that will be revealed soon!!!!)
26 Relays 2 Contactors and more ("Will provide a schmatic for anyone silly enough to make it")
I would go through the list in the log.txt errors and confirm as indicated:
19:40:04.0 27/01/2013: Error: Attempted to read or write protected memory. This is often an indication that other memory is corrupt. Test your memory (RAM)
19:40:04.0 27/01/2013: at Microsoft.DirectX.DirectInput.Manager.GetDevices(DeviceClass deviceType, EnumDevicesFlags flags)
19:40:04.0 27/01/2013: at GameEx.GameEx.keyboard.InitDirectInput()
19:40:04.0 27/01/2013: at GameEx.GameEx.mainform.a(Boolean A_0, String A_1, Boolean A_2)
19:40:04.0 27/01/2013: at GameEx.GameEx.mainform..ctor()
19:40:04.0 27/01/2013: It was detected you experienced a DirectX error.
19:40:04.0 27/01/2013: Please note the following for possible solutions to your problem:
19:40:04.0 27/01/2013: 1. Ensure you have the latest version of DirectX installed. Latest version here.
19:40:04.0 27/01/2013: 2. Ensure you have the latest Manufacturer provided video card drivers.
19:40:04.0 27/01/2013: NOTE: Windows/Microsoft Update does not contain the latest.
19:40:04.0 27/01/2013: NOTE: Manufacturer normally means ATI, NVidia, or Intel. Not the brand.
19:40:04.0 27/01/2013: www.ati.com www.nvidia.com Go to the manufacturer's site for your cards, download and install. Not sure what "hack drivers" are but if they are not sanctioned or approved for use by the manufacturer for your video card(s) then may be your problem.
19:40:04.0 27/01/2013: 3. If you do not have a modern video card try the following. 1. Turn off advanced Graphics. 2. Try a lower resolution. 3. Try turning on and using 16-bit colour
19:40:04.0 27/01/2013: 4. Ensure any required video codecs are installed. Shark007 recommended
19:40:04.0 27/01/2013: 5. Try a different theme, or try running the theme at the resolution it was designed for
19:40:04.0 27/01/2013: 6. Try the latest version of GameEx. GameEx is updated all the time.
19:40:04.0 27/01/2013: 7. If you performed an auto update to this version. Try performing a manual download and install. Download and install from www.gameex.com
Go through each of these and report back the results.
awesome Gameex will load 1/12 times rest of the time it just crashes log doesnt read any errors what so ever.
new HDD is in the machine as i wanted a backup of my roms. (so HDD is not the issue)
Ram has been tested.
Has a new graphics card in it.
New install of Windows 64 Genuine no cracked fully updated....
can anyone shed some light?
if i load the setup and get to configure input setup crashes......
really lost here guys can somone help?
Since you have made these changes, please provide a new copy of your gameex.ini and log.txt file immediately post crash. Thanks!
07:26:19.6  7/02/2013:  Opening Configuration File07:26:19.6  7/02/2013:  GameEx: Version 12.98: Starting Log07:26:19.6  7/02/2013:  Operating System Platform: Win32NT07:26:19.6  7/02/2013:  Operating System Name: Windows XP x6407:26:19.6  7/02/2013:  Operating System Version: 5.2.379007:26:19.6  7/02/2013:  Getting CPU and RAM info07:26:19.6  7/02/2013:  Intel® Xeon® CPU E3120 @ 3.16GHz, 8191MB07:26:19.6  7/02/2013:  3.16Ghz - 2 Cores or CPU's07:26:19.6  7/02/2013:  Running Randomize()07:26:19.6  7/02/2013:  Loading PlugIns07:26:19.7  7/02/2013:  Checking for applications to Launch On Startup07:26:19.7  7/02/2013:  Running Misc startup tasks07:26:19.7  7/02/2013:  Setting Menu types07:26:19.7  7/02/2013:  Getting Configuration Values07:26:19.7  7/02/2013:  Using Theme: Simple Mode ArcadeVGA 352x25607:26:19.7  7/02/2013:  Checking for alternate Image Directory for Theme: Simple Mode ArcadeVGA 352x25607:26:19.7  7/02/2013:  Launching HideOS.exe07:26:19.7  7/02/2013:  Initialising Video/MNG DLL's07:26:19.7  7/02/2013:  GameEx will check for media insertion (may affect performance)07:26:19.7  7/02/2013:  Hiding Taskbar07:26:19.7  7/02/2013:  Is Media Center running?07:26:19.7  7/02/2013:  Checking/Creating LCD Registry values07:26:19.7  7/02/2013:  Check Media Center Exit/Start Mode07:26:19.7  7/02/2013:  Media Center Mode 207:26:19.7  7/02/2013:  Video previews on. Warning: Only recommended on modern systems07:26:19.7  7/02/2013:  Snap Delay set to: 407:26:19.7  7/02/2013:  Get other settings07:26:19.7  7/02/2013:  Desktop set to Hide ICONS and set Background to Black07:26:19.7  7/02/2013:  Set: Find emulator artwork on best match basis07:26:19.7  7/02/2013:  Start work for Form07:26:19.7  7/02/2013:  Getting Original Screen Size07:26:19.7  7/02/2013:  Opening Database Connection07:26:19.8  7/02/2013:  Initializing Component07:26:19.8  7/02/2013:  MAME Path is: C:\Emulators\groovy07:26:19.8  7/02/2013:  MAME EXE file is: mame64.exe07:26:19.9  7/02/2013:  ROM Path is: C:\Roms\mame\roms07:26:19.9  7/02/2013:  Catver.ini is located at: C:\GameEx\DATA\catver.ini07:26:19.9  7/02/2013:  controls.ini is located at: C:\GameEx\DATA\controls.ini07:26:19.9  7/02/2013:  History.dat is located at: C:\GameEx\DATA\history.dat07:26:19.9  7/02/2013:  nplayers.ini is located at: C:\GameEx\DATA\nplayers.ini07:26:19.9  7/02/2013:  command.dat is located at: C:\GameEx\DATA\command.dat07:26:19.9  7/02/2013:  MAMEinfo.dat is located at: C:\GameEx\DATA\mameinfo.dat07:26:19.9  7/02/2013:  Loading Controls.ini map file07:26:19.9  7/02/2013:  Snap Path: Not Found07:26:19.9  7/02/2013:  Background Snap Path: Not Found07:26:19.9  7/02/2013:  AVI Snap Path: Not Found07:26:19.9  7/02/2013:  Flyer Path: Not Found07:26:19.9  7/02/2013:  Cabinet Path: Not Found07:26:19.9  7/02/2013:  Cabinet 3D Path: Not Found07:26:19.9  7/02/2013:  Title Path: Not Found07:26:19.9  7/02/2013:  PCB Path: Not Found07:26:19.9  7/02/2013:  Artwork Preview Path: Not Found07:26:19.9  7/02/2013:  Panel Path: Not Found07:26:19.9  7/02/2013:  Manual Path: Not Found07:26:19.9  7/02/2013:  Icon Path: Not Found07:26:19.9  7/02/2013:  Marquee Path: Not Found07:26:19.9  7/02/2013:  Applying Language/Text07:26:19.9  7/02/2013:  Text/Language: English07:26:19.9  7/02/2013:  Loading Language/Text07:26:19.9  7/02/2013:  Loading Custom Emulators07:26:19.9  7/02/2013:  Checking if Steam enabled07:26:19.9  7/02/2013:  Cannot find steam path07:26:20.0  7/02/2013:  Using Version 3 Themes Animations07:26:20.0  7/02/2013:  Retrieving resolution setting07:26:20.0  7/02/2013:  Using General Font: Arial07:26:20.0  7/02/2013:  Using Title Font: Arial07:26:20.0  7/02/2013:  GameEx will try to reduce CPU usage07:26:20.0  7/02/2013:  Initialising Direct3D07:26:20.1  7/02/2013:  Applying GameEx is Loading Image07:26:20.2  7/02/2013:  Setting Resolution to 640x480 32 bit color07:26:20.2  7/02/2013:  Creating Surfaces07:26:20.5  7/02/2013:  Creating Primary Surface - Full Screen Mode07:26:20.5  7/02/2013:  Creating Back Buffer07:26:20.6  7/02/2013:  Version 2 Theme being used. Loading.07:26:20.6  7/02/2013:  Loading Button Data07:26:20.6  7/02/2013:  Loading Font Data07:26:20.6  7/02/2013:  Loading Layout Data07:26:20.6  7/02/2013:  Loading Taskbar Data07:26:20.6  7/02/2013:  Loading graphic Surfaces07:26:20.6  7/02/2013:  Display is running at: 640x480 32bit color, 60hz07:26:20.6  7/02/2013:  Adapter: ATI Radeon HD 489007:26:20.6  7/02/2013:  Max texture size: 8192x819207:26:20.6  7/02/2013:  Available texture memory: -1046MB07:26:20.6  7/02/2013:  Initialising Bass Audio Library07:26:20.6  7/02/2013:  Creating Surfaces Misc and Dialogs07:26:20.7  7/02/2013:  Creating Surfaces Volume07:26:20.7  7/02/2013:  Creating Surfaces Arrows07:26:20.7  7/02/2013:  Creating Surfaces GameEXlogo Text07:26:20.7  7/02/2013:  Creating Surfaces Toolbar07:26:20.7  7/02/2013:  Creating Surfaces Toolbar Controls07:26:20.7  7/02/2013:  Creating Surfaces Backgrounds07:26:20.7  7/02/2013:  Creating Surfaces GameEx Logo07:26:20.7  7/02/2013:  Creating Surface Unselected07:26:20.7  7/02/2013:  Creating Surfaces Snaps07:26:20.7  7/02/2013:  Creating Surfaces Menu and List Bars07:26:20.8  7/02/2013:  Creating Fonts07:26:20.8  7/02/2013:  Creating Game Font07:26:20.8  7/02/2013:  Creating Game Font Faded07:26:20.9  7/02/2013:  Creating Title Font07:26:20.9  7/02/2013:  Restoring Title Font From Cache07:26:21.0  7/02/2013:  Creating Font Black07:26:21.0  7/02/2013:  Creating Font Black Small07:26:21.1  7/02/2013:  Fonts Created Succesfully07:26:21.1  7/02/2013:  Attempting to load game list07:26:21.2  7/02/2013:  MAME CMD options: -nowindow -joy -skip_gameinfo07:26:21.2  7/02/2013:  Sound Disabled07:26:21.2  7/02/2013:  Initialising DirectInput for Gamepad support07:26:21.3  7/02/2013:  Loading Start Page
And here is the ini file
[General]Xresolution=800Yresolution=600DisplayOnSecondary=FalseMAMEPath=C:\Emulators\groovyMAMEEXE=mame64.exeROMPath=C:\Roms\mame\romsStartWait=FalseUSeAdvanceMame=FalseAdvanceMAMEEXE=advmame.exeAdvanceMAMEPATH=C:\Emulators\AdvanceMAMEADVANCEMAMEOptions=-device_video_output fullscreen -quiet -dir_rom "C:\Emulators\Mame32\roms"UseZinc=FalseZincEXE=zinc.exeZincPATH=C:\Emulators\ZiNcZincOptions=--renderer=.\renderer.zncFont=Trebuchet MSTitleText=MAME GamesOnlyWorking=TrueAllowImperfect=TrueVerifyRoms=TrueOnlyRoms=FalseNoGameInfo=FalseGameFilter=Japan;Korea;Asia;Hispanic;Bootleg;French;German;Hack;Prototype;Hardware;Spanish;(Easy;(harderGameFilterOn=TrueNoAdult=FalseNoClones=FalseMameOptions=-nowindow -joy -skip_gameinfoArcadeMode=TrueUseLargeFonts=TrueSnapPath=C:\Emulators\Mame32\snapAVISnapPath=C:\Emulators\Mame32\avisnapAVIFrameSkip=0flyerpath=C:\Emulators\Mame32\flyerscabinetpath=C:\Emulators\Mame32\cabinetsCatverLocation=\DATA\catver.ininplayerslocation=\DATA\nplayers.iniHistoryLocation=\DATA\history.datInfoLocation=\DATA\mameinfo.datCommandLocation=\DATA\command.datShowGameInfoPage=TrueEnableStartPage=TrueShowStartPageFirst=Trueskipintro=TrueAntiAliasFonts=TrueOutlineFonts=FalseDisplayBackgroundImage=TrueSnapBrightness=120MusicPlayList=C:\MusicMusicVolume=100MediaCenterMode=2PlayIntroSound=TrueAttractModeTimer=4AttractModeAudio=2UsingArcadeVGA=FalseStretchResToX=640StretchResToY=288TryToStretchto256=TrueNoWaitVSync=FalseSleep=TrueHideUpdateList=FalseDisableExit=FalseHideShutDown=TrueStartUpVideo=C:\VideoLaunchOnStart=LaunchOnStartNoWait=LaunchOnExit=LaunchOnExitNoWait=FontSize=0VectorResX=632VectorResY=264AlwaysStretch=410x256DisableEscape=FalseDisableRemoveGame=Falsetheme=Simple Mode ArcadeVGA 352x256Language=EnglishFlatStartPage=FalseDontSwitchRes=TrueSnapDelay=4AllowWindowResize=TrueShowLoadingScreen=TrueUse16BitColour=FalseWidescreen=FalseDisableMAME=FalseShellBeforeLaunch=ShellOnExit=EnableJukeBox=Truejukeboxplaylist=Live! (CD1)EnableMediaControls=TrueShufflePlayLists=TrueLoadPlayListAtStartup=FalseLoadPlayListThread=FalseDownloadArt=TrueTitleFont=Trebuchet MSDialogTextWhite=FalseTimeFormat=TrueHideToolBar=3DoNotFilterROMS=pacman;splatterMAMEAudioMode=1DisplayTitle=TrueAVIAudio=TrueMarqueePath=C:\Emulators\Mame32\marqueesPanelPath=C:\Emulators\Mame32\cpanelTitlePath=C:\Emulators\Mame32\titlesICONPath=C:\Emulators\Mame32\iconsCPEnabled=TrueCPPATH=\DATA\controls.iniShowVector=TrueShowNeoGeo=TrueShowOriginal=TrueShowAdult=TrueShowCPS=TrueShowVertical=TrueShowHorizontal=TrueEnableFavorites=TrueShowMulti=TrueShowAllMAME=TrueShowLastGame=TrueShowRandomGame=TrueShowListNumbers=TrueAlphaBlendVideos=TrueEnableSound=FalseMediaCenterOpenCheck=trueUseSharp=TrueCreateImageOnThread=FalseHideCreateSnaps=FalseHideLogoff=FalseHideStandBy=FalseDisableMouse=FalseShowVideos=TrueVideoPath=EnableAlphaPage=TrueEnableJoystick=TrueEnableSlikStik=FalseKeyboardDirectInput=FalseNoMahjong=TrueVIDEOFFDSHOW=0JoystickDevice=EnableCustomInput=FalseEnableCustomJoyInput=FalseAttractVideosEnabled=FalseAttractVideosRatio=1AttractVideosPath=C:\VideoAtractModeNewGameTimer=2AdvancedGFX=TrueHideZinc=FalseTransitionType=0Bypass=TrueDontBlitWait=FalseShowMostPlayed=TrueExcludedMAMERoms=DeadZoneX=0DeadZoneY=0JukeBoxMode=0EnableAmbiance=FalseHIDEDESKTOP=TrueUseSnapBestMatch=trueIngameVK=121EnableThemePicker=TrueDisablePleaseWaitAnimation=FalseEnableRipCD=TrueDumbyValue=DVDPath=G:\AttractOnlyFavs=Falserotateplus90=FalseShowButtons=TrueDisplayTitleText=TruePlayExitSaverSound=FalseShowAtari=TrueShowGolden=TrueShowHorizVert=0UseModel2=FalseModel2PATH=C:\Emulators\Model2ShowModel2=TrueShowLightGun=TrueEnableBezel=TrueAutoUpdate=1NoMAMEOnStartPage=FalseHideRestart=TrueEnableStartScreenSaver=TrueSortMAMEThE=TrueSortEmuThE=TrueShowMCEEXport=TrueNoRotationRestrictions=FalseMakeToolbarTextWhite=FalseExitGameAfter=0ShowTrackball=TrueShowSpinner=TrueLoadEmusOnThread=TrueLoadRadioOnThread=FalseStartPageAni=TrueEmusAttractMode=FalseMuteEmuAttractMode=FalseShow4Player=TrueCabControlFriendly=FalseManualPath=C:\Emulators\Mame32\manualsHideShowTaskbar=TrueCustomMAMEFolderPath=C:\Emulators\Mame32\CustomFoldersMAMEFavoritesini=C:\Emulators\Mame32\Folders\Favorites.iniMenuFontSameSize=FalsePreviewVideos=2ShowStatistics=TrueDisableMouseWheel=FalseErrorReporting=0ReduceCPU=TrueShowNotPlayed=TrueShowOnlineLists=TrueScreensaverMode=0AttractText=Touch screen to start...GlaunchEnabled=FalsePCBPath=C:\Emulators\Mame32\pcbArtworkPath=C:\Emulators\Mame32\artworkpreviewLoadJukeTracksOnStartup=TrueEnableLetterSelect=TrueJukeQueueMode=0EnableBezelAttract=FalseForceDailyReboot=-1EnableSearch=TrueFixToEmuList=0ShowLastPlayed=TrueTwoThreeRes=EnableTouchScreen=TrueEnableMediaCheck=TrueEnableOtherSystems=TrueForceShutdown=FalseEnableHiScore=TrueDisplayImageList=FalseSortEmulators=TrueShowAllGames=TrueInactivityTimer=0EnableAdvCustomInput=FalseHideHibernate=FalseEnableKeyboardShutdown=FalseAutoRotateMAME=FalseEnableLaunchDialog=Truelastmusicpath=G:\-DATA-\-MP3-looplist=FalseTrackballSupport=FalseEnableVisualizations=TrueEnableVideoThumbs=Falsecabinet3dpath=C:\Emulators\Mame32\cabinets3dEnableClientServerMAME=FalseClientServerMAMEPath=C:\Emulators\ClientServerMAMEClientServerMAMEEXE=vmame.exeOnQueueEndMode=0MAMERemoveDupes=2CommnadLocation=\DATA\command.datAutoDownloadDescriptions=TrueGameExtenderCustomImageMAMEPath=C:\Emulators\Mame32\marqueesEnablepopupdescriptions=TrueSetPalRes=FalsePalRes=800x600x32x60SetNTCSRes=TrueNTSCRes=800x600x32x60SetNTSCRes=FalseSetTwoThreeRes=FalseAmbianceFolder=C:\ArcadeAmbianceEnableEscapeKeyExit=TrueDisableChangeView=FalseEnabledConfigurationApp=TrueResumeLastAtStartup=FalseHelpText=ShowHistoryAndMAMEInfo=Truebaksnappath=C:\Emulators\Mame32\backgroundsnapTVVideoPath=OtherVideoPath=C:\Video;[myvideos]ChangeMonitorFrequency=FalseChangeMonitorResolution=FalseNoCasino=FalseEnableDownloadService=TrueShowCHD=True[Daphne]UseDaphne=FalseDaphnePath=C:\Emulators\DaphneDaphneExe=Daphne.exeDaphneSnap=C:\Emulators\Daphne\imagesDaphneOptions=vldp -fullscreen -x 640 -y 480 -nohwaccelEnabled_1=TrueROMName_1=astronGameName_1=Astron BeltGameOptions_1=-framefile "C:\Roms\Laserdisc\Astron Belt\astron.txt"Enabled_2=TrueROMName_2=badlandsGameName_2=BadlandsGameOptions_2=-framefile "C:\Roms\Laserdisc\Badlands\badlands-r.txt"Enabled_3=TrueROMName_3=begaGameName_3=Bega's BattleGameOptions_3=-framefile "C:\Roms\Laserdisc\Bega's Battle\bega.txt"Enabled_4=TrueROMName_4=cliffGameName_4=Cliff HangerGameOptions_4=-framefile "C:\Roms\Laserdisc\Cliff Hanger\cliff-r.txt"Enabled_5=TrueROMName_5=cobraabGameName_5=Cobra CommandGameOptions_5=-framefile "C:\Roms\Laserdisc\Cobra Command\cc_framefile.txtEnabled_6=TrueROMName_6=lairGameName_6=Dragon's LairGameOptions_6=-framefile "C:\Roms\Laserdisc\Dragon's Lair\dl_framefile.txt"Enabled_7=TrueROMName_7=lair2GameName_7=Dragon's Lair II TimewarpGameOptions_7=-framefile "C:\Roms\Laserdisc\Dragon's Lair II Timewarp\DL2_single_framefile.txt"Enabled_8=TrueROMName_8=eshGameName_8=Esh's AurunmillaGameOptions_8=-framefile "C:\Roms\Laserdisc\Esh's Aurunmilla\esh.txt"Enabled_9=TrueROMName_9=firefoxGameName_9=FirefoxGameOptions_9=-framefile "C:\Roms\Laserdisc\Firefox\firefox.txt"Enabled_10=TrueROMName_10=ffrGameName_10=Freedom FighterGameOptions_10=-framefile "C:\Roms\Laserdisc\Freedom Fighter\ffr.txt"Enabled_11=TrueROMName_11=galaxyGameName_11=Galaxy RangerGameOptions_11=-framefile "C:\Roms\Laserdisc\Galaxy Ranger\galaxy-r.txt"Enabled_12=TrueROMName_12=gtgGameName_12=Goal to GoGameOptions_12=-framefile "C:\Roms\Laserdisc\Goal to Go\gtg.txt"Enabled_13=TrueROMName_13=interstellarGameName_13=Interstellar Laser FantasyGameOptions_13=-framefile "C:\Roms\Laserdisc\Interstellar Laser Fantasy\interstellar.txt"Enabled_14=TrueROMName_14=lgpGameName_14=Laser GPGameOptions_14=-framefile "C:\Roms\Laserdisc\Laser GP\lasergp.txt"Enabled_15=TrueROMName_15=mach3GameName_15=Mach 3GameOptions_15=-framefile "C:\Roms\Laserdisc\Mach 3\mach3.txt"Enabled_16=TrueROMName_16=roadblasterGameName_16=Road BlasterGameOptions_16=-framefile "C:\Roms\Laserdisc\Road Blaster\roadblaster.txt"Enabled_17=TrueROMName_17=aceGameName_17=Space AceGameOptions_17=-framefile "C:\Roms\Laserdisc\Space Ace\ace.txt"Enabled_18=TrueROMName_18=sdqGameName_18=Super Don Quix-oteGameOptions_18=-framefile "C:\Roms\Laserdisc\Super Don Quix-ote\sdq.txt"Enabled_19=TrueROMName_19=tqGameName_19=Thayer's QuestGameOptions_19=-framefile "C:\Roms\Laserdisc\Thayer's Quest\tq.txt"Enabled_20=TrueROMName_20=uvtGameName_20=Us vs ThemGameOptions_20=-framefile "C:\Roms\Laserdisc\Us vs Them\uvt.txt"UseGamepad=FalseDaphneFlyer=C:\Emulators\Daphne\flyersDaphneCabinet=C:\Emulators\Daphne\cabinetsDaphneTitle=C:\Emulators\Daphne\titlesDaphneMarquee=C:\Emulators\Daphne\marqueesDaphnePanel=C:\Emulators\Daphne\cpanelLaunchBefore=LaunchAfter=DaphneCustomGameExtenderCustomArtPath=C:\Emulators\Daphne\marqueesDaphneBakSNAP=C:\Emulators\Daphne\backgroundimages[DVD]EnableDVD=TrueCODEC=0DVDFFDSHOW=0EnableDVDDisk=TrueDVDPath=C:\DVDUseVMR9=TrueEnableExternalPlayer=FalseUse VMR9=FalseCMD=""C:\Program Files (x86)\Corel\DVD9\WinDVD.exe" "[dvd]""[Pictures]PicturesEnabled=TruePaths=C:\Pictures;[mypictures]UseAlphaBlend=TrueSlideDuration=12[News]URL_1=http://rss.news.yahoo.com/rss/topstoriesURL_2=URL_3=http://rss.news.yahoo.com/rss/techURL_4=http://slashdot.org/index.rssURL_5=URL_6=http://www.emulator-zone.com/rss_news.phpURL_7=http://www.spesoft.com/news.xmlURL_8=http://www.gameex.info/forums/index.php?app=core&module=global&section=rss&type=forums&id=1URL_9=http://www.hulu.com/feed/highest_rated/videosURL_10=http://www.hulu.com/feed/popular/videos/this_weekURL_11=http://www.hulu.com/feed/recent/moviesURL_12=URL_13=URL_14=URL_15=URL_16=URL_17=URL_18=URL_19=URL_20=URL_21=URL_22=URL_23=URL_24=URL_25=URL_26=URL_27=URL_28=URL_29=URL_30=Enabled=TrueURL_31=URL_32=URL_33=URL_34=URL_35=URL_36=[Radio]RadioEnabled=TrueEnabled_5=TrueName_5=Kohina - old school game & demoURL_5=http://www.kohina.com/kohinasolanum.m3uEnabled_6=TrueName_6=Capital LondonURL_6=http://vtuner.com/setupapp/guide/asp/func/dynampls.asp?link=1&id=660Enabled_7=TrueName_7=Kohina - Fresh TracksURL_7=http://anka.org:8080/fresh.ogg.m3uEnabled_4=TrueName_4=BBC Radio 2URL_4=http://vtuner.com/setupapp/guide/asp/func/dynampls.asp?link=1&id=3159Enabled_1=TrueName_1=Heart FMURL_1=http://vtuner.com/setupapp/guide/asp/func/dynampls.asp?link=1&id=9888Enabled_2=TrueName_2=XFM LondonURL_2=http://vtuner.com/setupapp/guide/asp/func/dynampls.asp?link=1&id=1065Enabled_3=TrueName_3=BBC Radio 1URL_3=http://vtuner.com/setupapp/guide/asp/func/dynampls.asp?link=1&id=1357Enabled_8=TrueName_8=Virgin RadioURL_8=http://vtuner.com/setupapp/guide/asp/func/dynampls.asp?link=1&id=14081Enabled_9=Name_9=URL_9=Enabled_10=Name_10=URL_10=Enabled_11=Name_11=URL_11=Enabled_12=Name_12=URL_12=Enabled_13=Name_13=URL_13=Enabled_14=Name_14=URL_14=Enabled_15=Name_15=URL_15=Enabled_16=Name_16=URL_16=Enabled_17=Name_17=URL_17=Enabled_18=Name_18=URL_18=Enabled_19=Name_19=URL_19=Enabled_20=Name_20=URL_20=Enabled_21=FalseName_21=Capital GoldURL_21=mms://ms1.capitalinteractive.co.uk/gold_highEnabled_22=TrueName_22=Slay RadioURL_22=http://relay4.slayradio.org:8000Name_23=URL_23=Enabled_23=FalseName_24=Radio WoodstockURL_24=http://nick8.surfernetwork.com/Media/RWST.asxEnabled_25=TrueName_25=977 Today's HitsURL_25=http://vtuner.com/setupapp/guide/asp/func/dynampls.asp?link=1&id=17163Enabled_26=TrueName_26=Radio ParadiseURL_26=http://vtuner.com/setupapp/guide/asp/func/dynampls.asp?link=1&id=13417Enabled_27=TrueName_27=Hitz RadioURL_27=http://www.hitzradio.com/hitzradio.asxEnabled_28=TrueName_28=977 AlternativeURL_28=http://vtuner.com/setupapp/guide/asp/func/dynampls.asp?link=1&id=24681Enabled_29=FalseName_29=9412 Rock StationURL_29=http://www.9412.com/9412.asxEnabled_30=TrueName_30=Power HitzURL_30=http://www.powerhitz.com/powerhitz.asxEnabled_31=TrueName_31=Radio WazeeURL_31=http://vtuner.com/setupapp/guide/asp/func/dynampls.asp?link=1&id=4629Enabled_32=TrueName_32=The Edge RadioURL_32=http://vtuner.com/setupapp/guide/asp/func/dynampls.asp?link=1&id=11509Enabled_33=TrueName_33=WFUV 90.7 FM Public RadioURL_33=http://vtuner.com/setupapp/guide/asp/func/dynampls.asp?link=1&id=8257Enabled_34=FalseName_34=Pirate RadioURL_34=http://www.loudcity.net/Portals/0/LCPlayLists/90/123.asxEnabled_35=TrueName_35=EYE 97URL_35=http://vtuner.com/setupapp/guide/asp/func/dynampls.asp?link=1&id=45504Enabled_36=TrueName_36=Hit Music StationURL_36=http://www.hitmusicstation.net/ecoute_haut_debit.m3uName_37=Radio IO 80'sURL_37=http://vtuner.com/setupapp/guide/asp/func/dynampls.asp?link=1&id=15068Enabled_24=Enabled_37=FalseEnabled_80=TrueUrl_80=FAVREMOVEEnabled_81=TrueUrl_81=FAVREMOVEEnabled_82=TrueUrl_82=FAVREMOVEEnabled_83=TrueUrl_83=FAVREMOVEenabled_84=Truename_84=radioio.com : 80s New Waveurl_84=http://vtuner.com/setupapp/guide/asp/func/dynampls.asp?link=1&id=15068Enabled_85=Name_85=Url_85=Enabled_38=TrueName_38=C64.COM's SID StreamURL_38=http://www.c64.com/sid.m3u[HTMLApplications]Enabled_1=TrueURL_1=http://10foot.cbuenger.com/mceWeather/index.php?start=1〈=2Name_1=WeatherLogo_1=WeatherMouseEmu_1=FalseEnabled_2=TrueURL_2=http://gameex.netName_2=GameEx homepageLogo_2=MouseEmu_2=FalseEnabled_3=FalseURL_3=http://10foot.cbuenger.com/mceWeather/index.php?start=1〈=2Name_3=WeatherLogo_3=WeatherMouseEmu_3=TrueEnabled_4=FalseURL_4=Name_4=Logo_4=MouseEmu_4=TrueEnabled_5=FalseURL_5=Name_5=Logo_5=MouseEmu_5=TrueEnabled_6=FalseURL_6=Name_6=Logo_6=MouseEmu_6=TrueUseHTMLApps=TrueHide_2=FalseHide_3=Hide_4=TrueHide_5=[ExternalApplications]Enabled_99=TrueName_99=ConfigurationPath_99=[apppath]CMD_99=GameExConfig.exeSnap_99=GameExTextShowDesktop_99=TrueMapKeys_99=FalseWaitBeforeKeys_99=SendKeys_99=Enabled_2=FalseName_2=NotepadPath_2=c:\windowsCMD_2=notepad.exeSnap_2=GameExTextShowDesktop_2=TrueMapKeys_2=TrueWaitBeforeKeys_2=SendKeys_2=Enabled_3=FalseName_3=Mad Dog McCreePath_3=G:\Mad_Dog_mcCreeCMD_3=G:\Mad_Dog_mcCree\mdm.exeSnap_3=GameExTextShowDesktop_3=TrueMapKeys_3=TrueWaitBeforeKeys_3=4000SendKeys_3=FEnabled_1=Falsename_1=Close And Restart GameExpath_1=G:\-DATA-\-MY PROJECTS-\GameEx - VB.net\bincmd_1=CloseAndRestartGameEx.batsnap_1=showdesktop_1=Truemapkeys_1=TrueWaitBeforeKeys_1=dSendKeys_1=Enabled_4=Falsename_4=path_4=cmd_4=snap_4=showdesktop_4=Truemapkeys_4=TrueWaitBeforeKeys_4=SendKeys_4=Enabled_5=Falsename_5=path_5=cmd_5=snap_5=showdesktop_5=Truemapkeys_5=TrueWaitBeforeKeys_5=SendKeys_5=Enabled_6=Falsename_6=path_6=cmd_6=snap_6=showdesktop_6=Truemapkeys_6=TrueWaitBeforeKeys_6=SendKeys_6=Enabled_7=Falsename_7=path_7=cmd_7=snap_7=showdesktop_7=Truemapkeys_7=TrueWaitBeforeKeys_7=SendKeys_7=Enabled_8=Falsename_8=path_8=cmd_8=snap_8=showdesktop_8=Truemapkeys_8=TrueWaitBeforeKeys_8=SendKeys_8=Enabled_9=Falsename_9=path_9=cmd_9=snap_9=showdesktop_9=Truemapkeys_9=TrueWaitBeforeKeys_9=SendKeys_9=Enabled_10=Falsename_10=path_10=cmd_10=snap_10=showdesktop_10=Truemapkeys_10=TrueWaitBeforeKeys_10=SendKeys_10=Enabled_11=Falsename_11=path_11=cmd_11=snap_11=showdesktop_11=Truemapkeys_11=TrueWaitBeforeKeys_11=SendKeys_11=Enabled_12=Falsename_12=path_12=cmd_12=snap_12=showdesktop_12=Truemapkeys_12=TrueWaitBeforeKeys_12=SendKeys_12=Enabled_13=Falsename_13=path_13=cmd_13=snap_13=showdesktop_13=Truemapkeys_13=TrueWaitBeforeKeys_13=SendKeys_13=Enabled_14=Falsename_14=path_14=cmd_14=snap_14=showdesktop_14=Truemapkeys_14=TrueWaitBeforeKeys_14=SendKeys_14=Enabled_15=Falsename_15=path_15=cmd_15=snap_15=showdesktop_15=Truemapkeys_15=TrueWaitBeforeKeys_15=SendKeys_15=Enabled_16=Falsename_16=path_16=cmd_16=snap_16=showdesktop_16=Truemapkeys_16=TrueWaitBeforeKeys_16=SendKeys_16=Enabled_17=name_17=path_17=cmd_17=snap_17=showdesktop_17=mapkeys_17=WaitBeforeKeys_17=SendKeys_17=Enabled_18=name_18=path_18=cmd_18=snap_18=showdesktop_18=mapkeys_18=WaitBeforeKeys_18=SendKeys_18=Enabled_19=name_19=path_19=cmd_19=snap_19=showdesktop_19=mapkeys_19=WaitBeforeKeys_19=SendKeys_19=Enabled_20=name_20=path_20=cmd_20=snap_20=showdesktop_20=mapkeys_20=WaitBeforeKeys_20=SendKeys_20=Enabled_21=name_21=path_21=cmd_21=snap_21=showdesktop_21=mapkeys_21=WaitBeforeKeys_21=SendKeys_21=Enabled_22=name_22=path_22=cmd_22=snap_22=showdesktop_22=mapkeys_22=WaitBeforeKeys_22=SendKeys_22=Enabled_24=name_24=path_24=cmd_24=snap_24=showdesktop_24=mapkeys_24=WaitBeforeKeys_24=SendKeys_24=Enabled_25=name_25=path_25=cmd_25=snap_25=showdesktop_25=mapkeys_25=WaitBeforeKeys_25=SendKeys_25=EmulateMouse_1=-1EmulateMouse_2=-1EmulateMouse_3=3EmulateMouse_4=EmulateMouse_5=EmulateMouse_6=EmulateMouse_7=EmulateMouse_8=EmulateMouse_9=EmulateMouse_10=EmulateMouse_11=EmulateMouse_12=EmulateMouse_13=EmulateMouse_14=EmulateMouse_15=EmulateMouse_16=EmulateMouse_17=EmulateMouse_18=EmulateMouse_19=EmulateMouse_20=EmulateMouse_21=EmulateMouse_22=EmulateMouse_24=EmulateMouse_25=-1LaunchBefore_16=LaunchAfter_16=AlsoLaunch_16=LaunchBefore_17=LaunchAfter_17=LaunchBefore_1=HelpText_1=[TEXT]SearchNetFlix=Search NetFlixByArtist=By ArtistNetFlix=NetFlixmameCHDlist=CHDmameCHDstart=MAME CHD Gamessteamlist=Steamsteamstart=Steam Gamesbanner=BannerDownloading=DownloadingSeeking=SeekingDownload=DownloadPlayBluRay=Play Blu RayGetMetaData=Get MetaDataTouch_Help_1=Control is located at bottom of screen.Touch_Help_2=Continuously tap bottom right for credits and top right to start.Touch_Help_3=Controls are located bottom and middle of screen.Touch_Help_4=Control is located at bottom of screen.GameExArcadeStart=ArcadeGameExArcadeList=ArcadeRipDVD=Rip DVDSearchMusic=Search MusicDialog_RippingCD=Ripping CDDialog_PleaseWait=Please WaitDialog_ScanningFolders=Scanning FoldersDialog_ScanningFiles=Scanning FilesDialog_LoadingDatabases=Loading DatabasesDialog_LoadingSettings=Loading SettingsStatus_ListUpdated=List UpdatedStatus_FavRemoved=Removed from favoritesStatus_FavAdded=Added to favoritesStatus_ItemRemoved=Item removedStatus_NextTrack=Next trackStatus_PreviousTrack=Previous trackStatus_Pause=PauseStatus_play=PlayStatus_AddedToQ=Added to queueStatus_NetPlayReq=Requested NetPlayStatus_NetPlayCan=Cancelled NetPlayYouTube=YouTubeNews=NewsSearchYouTube=Search YouTubeRequestNetPlay=Request NetPlayCancelNetPlay=Cancel NetPlay RequestMAMENetPlayStart=MAME NetPlayNetPlayList=NetPlayAccept=AcceptNow=NowNext=NextGameMusic=Game MusicTVAdvert=TV AdvertCommands=CommandsRecordVideo=Record VideoResumeGame=Resume GameExitGame=Exit GameInGame=In GameStopped=StoppedPlay=PlayResumeDVD=Resume DVDNoItems=- NO ITEMS FOUND -Hibernate=HibernateMenuMore=MoreAllGamesStart=All GamesAllGamesList=All GamesNotAvailable=Not AvailableHiScore=High ScoreGetLyrics=Get LyricsOtherSystems=Other SystemsOpenMedia=Open MediaBiography=BiographyMenuView=Change ViewMenuBack=BackMenuExit=ExitMenuHome=HomeLastPlayedList=Last PlayedLastPlayedStart=Last PlayedSEARCHTITLE=Enter criteria then select menuSEARCHTITLE2=Press select to release cursorSearchList=SearchSearchStart=SearchSearchMedia=Search MediaSearchJukebox=Search JukeboxItems=ItemsMediaPlayerStart=LibraryMediaPlayerList=LibraryNoMediaFound=- NO MEDIA FOUND -eBookViewerStart=eBookseBookViewerList=eBooksArtwork=ArtworkPCB=PCBStatistics=StatisticsInsertCD=Insert CD:SearchGames=Search GamesGameManual=ManualPlayStation=Playstationmame2simlist=2 Playersmame2simstart=2 Player Simultaneousmame4simlist=4 Playersmame4simstart=4 Player SimultaneousMCEEXPORT=Export To MCEStartScreenSaver=Start ScreensaverVisualize=VisualizeSelectVisualize=Select VisualizationAbout1=Windows Emulator Front End and HTPCAbout2=Written By:About3=For Latest Version, please visit:byalbum=By Albumbyartistalbum=By Artist/Albumbycat=By Categorybygenre=By Genrebymanu=By Manufacturerbysys=By Systembyname=By Namebytitle=By Titlebyyear=By YearSelectplaylist=Play list / Morecreatesnaps=Create SnapsCreateSnaps1A=You are about to create snap shots or videos for every game in the [EMULATOR] Games List. This option can be removed from GameEx, by enabling the Hide Create Snaps option in the configuration.CreateSnaps2=You should be aware this is a lengthy processCreateSnaps3=With your current settings it is estimated that it will take at least:CreateSnaps4=[MINUTES] Minutes to complete this process if you use a 20 second pause between snaps.CreateSnaps5=You should also be warned that the SNAP shots will be saved in the SNAP Path defined for this emulatorCreateSnaps6=This process is not recommended on Windows 98CreateSnaps7=To exit this process once run HOLD down ESCAPE.CreateSnaps8=Do you want to proceed?Exit=Exit GameExHTMLPleaseWait=Please WaitIsUpdatingList=GameEx is updating the MAME game list:jukelist=Jukeboxjukestart=JukeboxKaraokelist=KaraokeKaraokestart=KaraokeStartKaraoke=Start Karaoke PlayerLaaunchingGame=Launching:laserlist=Laserdisclaserstart=Laserdisc Gameslogoff=Log Offfavlist=Favoritesfavstart=Favoritesmamealllist=MAME Gamesmameallstart=All MAME Gamesmamecpslist=CPS Gamesmamecpsstart=CPS GamesmameAtarilist=Atari GamesmameAtaristart=Atari GamesmameGunlist=LightgunmameGunstart=Lightgun GamesmameTrackballlist=TrackballmameTrackballstart=Trackball GamesmameSpinnerlist=SpinnermameSpinnerstart=Spinner GamesmameModel2list=Model 2mameModel2start=Sega Model 2 GamesmameGoldenlist=Golden EramameGoldenstart=Golden Era Of Arcademameneolist=Neo-GeomameNEostart=Neo-Geo Gamesmamemultilist=MAME Multiplaymamemultistart=MAME Multiplayer Gamesmamevectorlist=MAME Vectormamevectorstart=MAME Vector GamesOf=ofshutdown=Turn Off Systemstandby=Stand By SystemRestart=Restart SystemStart=Start..updatelist=Update ListUpdatingList=Updating Game List:UpdatingPleaseWait=Please Wait......videoslist=Videosvideostart=VideosLaunchingGame=Launching Game:PlayThisGame=Play This GameRecommended=Recommended Games:Series=Games in Series:Title=TitleFlyer=FlyerCabinet=CabinetCabinet3d=3D CabinetPanel=PanelBox=BoxCartridge=CartridgeMarquee=MarqueeFavoritesAdd=Add To FavoritesFavoritesRemove=Remove From FavoritesNoVideosFound=- NO VIDEOS FOUND -NoPicturesFound=- NO PICTURES FOUND -NoMusicFound=- NO MUSIC FOUND -NoArtistsFound=- NO ARTISTS FOUND -NoAlbumsFound=- NO ALBUMS FOUND -NoGenresFound=- NO GENRES FOUND -NoGamesFound=- NO GAMES FOUND -NoStationsFound=- NO STATIONS FOUND -NoNewsFound=- NO NEWS FOUND -CannotCreateSnaps1=Cannot Create SnapsCannotCreateSnaps2=Emulator '[EMULATOR]' Does not have a valid Snap path, so Snaps cannot be created. Setup a valid snap path in the configuration and try again.ViewControls=View ControlsInstructions=InstructionsViewControlsKey=Press '[KEY]' to view in game.AllMusic=All MusicClearCurrentPlaylist=Clear Current PlaylistShufflePlaylist=Shuffle Current PlaylistPlayLastGame=Last MAME GameViewSlideShow=View Slide ShowPictures=PicturesRadio=RadioPlayDVD=Play DVDPlayCD=Play CDDVDonDiskStart=DVDsDVDonDiskList=DVDsDemo=Demo:Playing=Playing:MAMEOriginal=MAME Original GamesMAMEOriginallist=OriginalsMAMEAdult=MAME Adult GamesMAMEAdultlist=AdultClearAndQueueAll=Clear and Queue AllAddAndQueueAll=Add all to QueueRandomGame=Play Random GameStartMAME=MAMEStartApps=More Games & ProgramsStartEMU=Emulated GamesStartControl=Exit/ShutdownStartMedia=MultimediaListMAME=MAMEListApps=Games & AppsListEMU=GamesListControl=ExitListMedia=MediaTimesPlayed=Times PlayedLastPlayed=Last PlayedDeleteFavs=Delete FavoritesDeleteMost=Delete Most PlayedChapter=ChapterAspect=AspectAspect0=Original Aspect - Not ZoomedAspect4=Widescreen on 4:3 - StretchedAspect5=Fill ScreenAspect3a=Widescreen to 4:3 - ZoomedAspect3b=Letterbox to Widescreen - ZoomedAspect2=Original Aspect - ZoomedAspect1a=Widescreen to 4:3 - ShrunkAspect1b=4:3 to Widescreen - StretchedPaused=PausedPlayVideo=Play VideoResumeVideo=Resume VideoRestartVideo=Restart VideoVideoQueue=Play AllQueueAllRandom=Play RandomlyMore=More..MostPlayed=Most PlayedMostPlayedList=Most PlayedVariousArtists=Various ArtistsConfirmDialog1=Select To Confirm.ConfirmDialog2=Back To Cancel.RemoveGame=Remove Game?LocalDisk=Local DiskSystemDisk=System DiskCDDVD=CD/DVD DriveNetworkDrive=Network DriveRamDisk=Ram DiskFloppyDisk=Floppy DiskRemovableDisk=Removable DiskUpdateGameList=Update List?VideoQueueAll=playstationstart=Playstationthemepickerlist=Themesthemepickerstart=Theme Pickerplaystationlist=PlaystationmameVertList=VerticalmameVertStart=MAME Vertical GamesmameHorizlist=HorizontalmameHorizstart=MAME Horizontal Gamesmamenotplayedlist=Not Playedmamenotplayedstart=MAME Not Playedmamemawslist=Live - MAWSmameMAWSstart=Live - MAWS Hall Of FamemameGameExlist=Live - GameExmameGamEexstart=Live - GameEx Favoritesripcd=Rip CDripthiscd=Rip This CD Nowcantrip=- No CD, Invalid CD, or no CDDB data -ViewPlaylist=View PlaylistKaraokAllSongs=All SongsKaraokaMode1Click=Instant Play ModeKaraokaModeQueue=Queue ModeKaraokePlaylist=View/Edit PlaylistKaraokeStartMenu=Start Karaokemammodel2list=CreateSnaps1=You are about to create snap shots for every game in the [EMULATOR] Games List.NoeBooksFound=- NO EBOOKS FOUND -QueueAll=Queue All[Favorites]ReplaceDash=TrueReplaceUnder=TrueCapitals=TrueRemoveBrackets=True[DVRMS]DVRFFDSHOW=0CODEC=[AtractModeNewGameTimer]When in attract mode start a new random game or video each time this value is reached.=2[AttractVideosPath]The folder your videos are located.=L:\GameAds[GameExTender]RemoteGameExLocation=\\workstation1\g$\-DATA-\-MY PROJECTS-\GameEx - VB.net\binEnabled=FalseWindowed=FalseDisplayOnSecondary=FalseRemoteExtenderLocation=G:\-DATA-\-MY PROJECTS-\GameEx - VB.net\binIPADDRESS=127.0.0.1Port=8383RefreshRate=20SysUserName=ArcadeUsername=User33549ComputerName=ARCADE-UNITPublish=FalseUserInfo=GameExtenderCustomImage=FalseGameExtenderImageNotFound=[GameExtenderViewer]Server=90.0.0.13PORT=8383DisplayOnSecondary=FalseRefreshRate=7StartWithGameEx=FalseExitWithGameEx=FalseWindowed=False[Karaoke]Enabled=FalsePath=C:\Karaokemode=False[CachedImages]bak=100652res=307200videobak=100652jukeboxbak=100652radiobak=100652picturesbak=100652emubak=100652startbak=100652daphnebak=100652mamebak=100652themedir=titlefont=Trebuchet MStitlefontsize=0outlinefonts=Falseantialiasfonts=Truewindowed=Trueuse16bitcolour=Falsegradienttitlefont=Truelowercasetitlefont=TrueFont=Trebuchet MSFontSize=0titlefontres=275808bakres=307200theme=startbak_Foreground=386810bak_Foreground=386810videobak_Foreground=386810jukeboxbak_Foreground=386810radiobak_Foreground=386810picturesbak_Foreground=386810daphnebak_Foreground=386810titlefontstyle=0bakresbak=921600mameselectbak=465213lastplayedbak=290516mostplayedbak=199198favoritesbak=283065allgamesbak=375154emulatorselectbak=100444themepickerbak=621253[Plugin_1]Enabled=FalseName=CursorHider.dll[Plugin_2]Enabled=FalseName=PlugInCallerID.dll[Plugin_3]Enabled=FalseName=PlugInDigDug.dll[Plugin_4]Enabled=FalseName=PlugInExit.dll[Plugin_5]Enabled=FalseName=PlugInLaunch.dll[ArcadeSoundPlugin]Volume=8[Plugin_6]Enabled=FalseName=PlugInLCD.dll[CachedImagesMenuFont]themedir=\themes\Default - BlueEx - Arcade640x288\MEDIA\res=307200font=Trebuchet MSfontsize=0outlinefonts=Trueuse16bitcolour=Falseantialiasfonts=Falsewindowed=Falsemenufontsamesize=Falsefontstyle=1[CachedImagesBak]bak=214295videobak=214295jukeboxbak=214295radiobak=214295picturesbak=214295emubak=214295startbak=214295daphnebak=214295[Emulator_]SelectionMusicFolder=C:\Music[eBook]Enabled=TruePaths=C:\eBooksQuality=0fittopage=False[Plugin_7]Enabled=FalseName=PlugInRotate.dll[MediaPlayer]Enabled=TrueAudioMode=0[CachedImagesGameFont]res=307200[CachedImagesGameFontFaded]res=307200[CachedImagesFontBlack]Res=277056[CPWizard]CPWizardEnable=FalseCPWizardPath=C:\Program Files\CPWizard\CPWizard.exeCPWizardStarted=TrueCPWizardStartup=True[VIDEO]EnableExternalPlayer=FalseUseWMPWMV=CMD=[ADVKEYBOARD]Forward=60Rewind=61PageUp=62PageDown=63VolumeDown=64VolumeUp=65Stop=66Play=67[Plugin_8]Enabled=FalseName=PlugInSpeech.dll[CursorHider]DoNotHide=DoNotHideInGameEX=False[Plugin_9]Enabled=FalseName=PlugInUltraStik.dll[DefaultPaths]EmuPath1=C:\EmulatorsAssetPath1=C:\AssetsRomPath1=C:\Roms[YouTube]Enabled=True[GameBase]Enabled=FalsePath=MapBack=FalseShowDesktop=True[CachedImages3d]themedir=\themes\Simple Mode ArcadeVGA 352x256\MEDIA\titlefontres=307200titlefont=Arialtitlefontstyle=1titlefontsize=18outlinefonts=Falseuse16bitcolour=Falsegradienttitlefont=Truelowercasetitlefont=Trueantialiasfonts=Truewindowed=Falseres=0bakres=0startbak_foreground=386810theme=BlueBoxbak_foreground=39023jukeboxbak_foreground=23206[CachedImagesGameFontFadedFalse]res=921600[CachedImagesMenuFont3d]res=0[DVDRIP]Format=MP4DVDRIPFOLDER=C:\DVD RIPSProfile=NormalCUSTOMCMD=[GameExArcade]Enabled=False[Touchscreen]Touchscreen_Enabled=2Touchscreen_HidePointer=TrueTouchScreen_ShowHelpScreens=TrueTouchScreen_SingleClick=TrueTouchScreen_OnlyCompatibleGames=TrueTouchScreen_CheckForExit=TrueTouchScreen_SendCredit=TrueTouchScreen_ShowMouseAnimations=True[LastStatus]specialfilter=oldspecialfilter=curemulator=0listtype=7curbak=bakmaxgames=4608gamename=[Plugin_10]Enabled=FalseName=RandomArcadeSound.dll[Plugin_11]Enabled=FalseName=Xpadder Plugin.dll[LIST_SETTINGS_20_EMU_1002]displaybackgroundimage=Truedisplaybackgroundimageemu=Falsedisplaystartpagemenuimage=Falsedisplaystartpagemenuimage2=Falsedisplaystartpagelistnotforcebaksnap=Truedisplayimagelist=False[LIST_SETTINGS_20_EMU_503]displaybackgroundimage=Snapdisplaybackgroundimageemu=Falsedisplaystartpagemenuimage=Falsedisplaystartpagemenuimage2=Falsedisplaystartpagelistnotforcebaksnap=Falsedisplayimagelist=True[steam]LaunchBefore=LaunchAfter=[NetFlix]Enabled=True[INTERNAL]currentstation=VGenre=---OPTIMIZED=0version=12.98timesruncount=9lastglaunchlist=0glaunchlistselected_0=1glaunchlisttop_0=1viewalbumtype=0windowed=Falseselectedgame=1gamelisttop=1catfilter=manufilter=yearfilter=listtype=7emulator=0yearlisttop=1catlisttop=1namelisttop=97manulisttop=1yearselectedgame=1catselectedgame=1manuselectedgame=1nameselectedgame=101romname=avspuromname2=avspuspecialfilter=currentstationurl=mameexe=mame64.exemamepath=C:\Emulators\groovymamefilemodified=25/11/2012 1:42:34 AMmamefilesize=111639040mamepromptupdate=Falsemameis32bit=Falsebezelversion=3mameversion=0.147startpagethumbscount=1[SetupWizard]EmuPath1=C:\EmulatorsAssetPath1=C:\AssetsRomPath1=C:\RomsDefaultPathPrompt=TrueDownloadDatabasePrompt=TrueDownloadEmulatorPrompt=TrueWizardMode=2CustomArray=Text / Language|Download Themes|Theme Selection|Display Settings|Audio Settings|GameBase Settings|Automatic artwork download|Karaoke Settings|Attract / Screensaver|Steam|GameExtender Settings|GameEx Arcade|Download Emulators|MAME Settings|Client / Server MAME|AdvanceMAME|Zinc|Model 2|Daphne|Emulator Selection|Emulator Setup|Advanced Emulator Setup|Emulator Groups|HTML Applications|External Applications|Radio Stations|News Feeds|Enable / Disable Features|Tweaks / PerformanceSearchArray=SavePosition=FalseSectionIndex=38SearchText=EmulatorIndex=0EmulatorGroupIndex=0DaphneIndex=0HTMLAppsIndex=0ExternalAppsIndex=0RadioStationsIndex=0NewsFeedsIndex=0ShowPanel=TrueFontSize=1WindowState=0WindowSize=643,474WindowLocation=0,0
so i get no load a few times then i get this
09:01:09.3  7/02/2013:  Opening Configuration File09:01:09.3  7/02/2013:  GameEx: Version 12.98: Starting Log09:01:09.3  7/02/2013:  Operating System Platform: Win32NT09:01:09.3  7/02/2013:  Operating System Name: Windows XP x6409:01:09.3  7/02/2013:  Operating System Version: 5.2.379009:01:09.3  7/02/2013:  Getting CPU and RAM info09:01:09.3  7/02/2013:  Intel® Xeon® CPU E3120 @ 3.16GHz, 8191MB09:01:09.3  7/02/2013:  3.16Ghz - 2 Cores or CPU's09:01:09.3  7/02/2013:  Running Randomize()09:01:09.3  7/02/2013:  Loading PlugIns09:01:09.3  7/02/2013:  Checking for applications to Launch On Startup09:01:09.3  7/02/2013:  Running Misc startup tasks09:01:09.3  7/02/2013:  Setting Menu types09:01:09.3  7/02/2013:  Getting Configuration Values09:01:09.3  7/02/2013:  Using Theme: Simple Mode ArcadeVGA 352x25609:01:09.3  7/02/2013:  Checking for alternate Image Directory for Theme: Simple Mode ArcadeVGA 352x25609:01:09.3  7/02/2013:  Launching HideOS.exe09:01:09.3  7/02/2013:  Initialising Video/MNG DLL's09:01:09.3  7/02/2013:  GameEx will check for media insertion (may affect performance)09:01:09.3  7/02/2013:  Hiding Taskbar09:01:09.3  7/02/2013:  Is Media Center running?09:01:09.3  7/02/2013:  Checking/Creating LCD Registry values09:01:09.3  7/02/2013:  Check Media Center Exit/Start Mode09:01:09.3  7/02/2013:  Media Center Mode 209:01:09.3  7/02/2013:  Video previews on. Warning: Only recommended on modern systems09:01:09.3  7/02/2013:  Snap Delay set to: 409:01:09.3  7/02/2013:  Get other settings09:01:09.3  7/02/2013:  Desktop set to Hide ICONS and set Background to Black09:01:09.3  7/02/2013:  Set: Find emulator artwork on best match basis09:01:09.3  7/02/2013:  Start work for Form09:01:09.3  7/02/2013:  Getting Original Screen Size09:01:09.3  7/02/2013:  Opening Database Connection09:01:09.4  7/02/2013:  Initializing Component09:01:09.5  7/02/2013:  MAME Path is: C:\Emulators\groovy09:01:09.5  7/02/2013:  MAME EXE file is: mame64.exe09:01:09.5  7/02/2013:  ROM Path is: C:\Roms\mame\roms09:01:09.5  7/02/2013:  Catver.ini is located at: C:\GameEx\DATA\catver.ini09:01:09.5  7/02/2013:  controls.ini is located at: C:\GameEx\DATA\controls.ini09:01:09.6  7/02/2013:  History.dat is located at: C:\GameEx\DATA\history.dat09:01:09.6  7/02/2013:  nplayers.ini is located at: C:\GameEx\DATA\nplayers.ini09:01:09.6  7/02/2013:  command.dat is located at: C:\GameEx\DATA\command.dat09:01:09.6  7/02/2013:  MAMEinfo.dat is located at: C:\GameEx\DATA\mameinfo.dat09:01:09.6  7/02/2013:  Loading Controls.ini map file09:01:09.6  7/02/2013:  Snap Path: Not Found09:01:09.6  7/02/2013:  Background Snap Path: Not Found09:01:09.6  7/02/2013:  AVI Snap Path: Not Found09:01:09.6  7/02/2013:  Flyer Path: Not Found09:01:09.6  7/02/2013:  Cabinet Path: Not Found09:01:09.6  7/02/2013:  Cabinet 3D Path: Not Found09:01:09.6  7/02/2013:  Title Path: Not Found09:01:09.6  7/02/2013:  PCB Path: Not Found09:01:09.6  7/02/2013:  Artwork Preview Path: Not Found09:01:09.6  7/02/2013:  Panel Path: Not Found09:01:09.6  7/02/2013:  Manual Path: Not Found09:01:09.6  7/02/2013:  Icon Path: Not Found09:01:09.6  7/02/2013:  Marquee Path: Not Found09:01:09.6  7/02/2013:  Applying Language/Text09:01:09.6  7/02/2013:  Text/Language: English09:01:09.6  7/02/2013:  Loading Language/Text09:01:09.6  7/02/2013:  Loading Custom Emulators09:01:09.6  7/02/2013:  Checking if Steam enabled09:01:09.6  7/02/2013:  Cannot find steam path09:01:09.6  7/02/2013:  Using Version 3 Themes Animations09:01:09.6  7/02/2013:  Retrieving resolution setting09:01:09.6  7/02/2013:  Using General Font: Arial09:01:09.6  7/02/2013:  Using Title Font: Arial09:01:09.6  7/02/2013:  GameEx will try to reduce CPU usage09:01:09.7  7/02/2013:  Initialising Direct3D09:01:09.7  7/02/2013:  Applying GameEx is Loading Image09:01:09.7  7/02/2013:  Setting Resolution to 640x480 32 bit color09:01:09.8  7/02/2013:  Creating Surfaces09:01:09.8  7/02/2013:  Creating Primary Surface - Full Screen Mode09:01:09.8  7/02/2013:  Creating Back Buffer09:01:09.8  7/02/2013:  Version 2 Theme being used. Loading.09:01:09.8  7/02/2013:  Loading Button Data09:01:09.8  7/02/2013:  Loading Font Data09:01:09.8  7/02/2013:  Loading Layout Data09:01:09.8  7/02/2013:  Loading Taskbar Data09:01:09.8  7/02/2013:  Loading graphic Surfaces09:01:09.8  7/02/2013:  Display is running at: 640x480 32bit color, 60hz09:01:09.8  7/02/2013:  Adapter: ATI Radeon HD 489009:01:09.8  7/02/2013:  Max texture size: 8192x819209:01:09.8  7/02/2013:  Available texture memory: -1046MB09:01:09.8  7/02/2013:  Initialising Bass Audio Library09:01:09.9  7/02/2013:  Creating Surfaces Misc and Dialogs09:01:09.9  7/02/2013:  Creating Surfaces Volume09:01:09.9  7/02/2013:  Creating Surfaces Arrows09:01:09.9  7/02/2013:  Creating Surfaces GameEXlogo Text09:01:09.9  7/02/2013:  Creating Surfaces Toolbar09:01:09.9  7/02/2013:  Creating Surfaces Toolbar Controls09:01:09.9  7/02/2013:  Creating Surfaces Backgrounds09:01:09.9  7/02/2013:  Creating Surfaces GameEx Logo09:01:09.9  7/02/2013:  Creating Surface Unselected09:01:10.0  7/02/2013:  Creating Surfaces Snaps09:01:10.0  7/02/2013:  Creating Surfaces Menu and List Bars09:01:10.0  7/02/2013:  Creating Fonts09:01:10.0  7/02/2013:  Creating Game Font09:01:10.0  7/02/2013:  Creating Game Font Faded09:01:10.1  7/02/2013:  Creating Title Font09:01:10.1  7/02/2013:  Restoring Title Font From Cache09:01:10.2  7/02/2013:  Creating Font Black09:01:10.2  7/02/2013:  Creating Font Black Small09:01:10.2  7/02/2013:  Fonts Created Succesfully09:01:10.5  7/02/2013:  Attempting to load game list09:01:10.5  7/02/2013:  MAME CMD options: -nowindow -joy -skip_gameinfo09:01:10.5  7/02/2013:  Sound Disabled09:01:10.5  7/02/2013:  Initialising DirectInput for Gamepad support09:01:10.6  7/02/2013:  Loading Start Page09:01:10.6  7/02/2013:  --**--09:01:10.6  7/02/2013:  Error: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.09:01:10.7  7/02/2013:     at GameEx.GameEx.mainform.n(Int32 A_0)09:01:10.7  7/02/2013:     at GameEx.GameEx.mainform.a(Boolean A_0, String A_1, Boolean A_2)09:01:10.7  7/02/2013:     at GameEx.GameEx.mainform..ctor()09:01:10.7  7/02/2013:  Closing database connection09:01:10.7  7/02/2013:  Error occured closing database connection09:01:10.7  7/02/2013:  Disposing Plugins09:01:10.7  7/02/2013:  GameEx is exiting with errors09:01:10.7  7/02/2013:  Deleting search cache
Then try a few more times and it will start......
There is no hardware problems all drivers are uptodate.....
then again i get a Gameex has stopped working
09:03:23.9  7/02/2013:  Opening Configuration File09:03:23.9  7/02/2013:  GameEx: Version 12.98: Starting Log09:03:23.9  7/02/2013:  Operating System Platform: Win32NT09:03:23.9  7/02/2013:  Operating System Name: Windows XP x6409:03:23.9  7/02/2013:  Operating System Version: 5.2.379009:03:23.9  7/02/2013:  Getting CPU and RAM info09:03:23.9  7/02/2013:  Intel® Xeon® CPU E3120 @ 3.16GHz, 8191MB09:03:23.9  7/02/2013:  3.16Ghz - 2 Cores or CPU's09:03:23.9  7/02/2013:  Running Randomize()09:03:23.9  7/02/2013:  Loading PlugIns09:03:23.9  7/02/2013:  Checking for applications to Launch On Startup09:03:23.9  7/02/2013:  Running Misc startup tasks09:03:23.9  7/02/2013:  Setting Menu types09:03:23.9  7/02/2013:  Getting Configuration Values09:03:23.9  7/02/2013:  Using Theme: Simple Mode ArcadeVGA 352x25609:03:23.9  7/02/2013:  Checking for alternate Image Directory for Theme: Simple Mode ArcadeVGA 352x25609:03:23.9  7/02/2013:  Launching HideOS.exe09:03:23.9  7/02/2013:  Initialising Video/MNG DLL's09:03:23.9  7/02/2013:  GameEx will check for media insertion (may affect performance)09:03:24.0  7/02/2013:  Hiding Taskbar09:03:24.0  7/02/2013:  Is Media Center running?09:03:24.0  7/02/2013:  Checking/Creating LCD Registry values09:03:24.0  7/02/2013:  Check Media Center Exit/Start Mode09:03:24.0  7/02/2013:  Media Center Mode 209:03:24.0  7/02/2013:  Video previews on. Warning: Only recommended on modern systems09:03:24.0  7/02/2013:  Snap Delay set to: 409:03:24.0  7/02/2013:  Get other settings09:03:24.0  7/02/2013:  Desktop set to Hide ICONS and set Background to Black09:03:24.0  7/02/2013:  Set: Find emulator artwork on best match basis09:03:24.0  7/02/2013:  Start work for Form09:03:24.0  7/02/2013:  Getting Original Screen Size09:03:24.0  7/02/2013:  Opening Database Connection09:03:24.1  7/02/2013:  Initializing Component09:03:24.1  7/02/2013:  MAME Path is: C:\Emulators\groovy09:03:24.1  7/02/2013:  MAME EXE file is: mame64.exe09:03:24.1  7/02/2013:  ROM Path is: C:\Roms\mame\roms09:03:24.1  7/02/2013:  Catver.ini is located at: C:\GameEx\DATA\catver.ini09:03:24.1  7/02/2013:  controls.ini is located at: C:\GameEx\DATA\controls.ini09:03:24.1  7/02/2013:  History.dat is located at: C:\GameEx\DATA\history.dat09:03:24.1  7/02/2013:  nplayers.ini is located at: C:\GameEx\DATA\nplayers.ini09:03:24.1  7/02/2013:  command.dat is located at: C:\GameEx\DATA\command.dat09:03:24.1  7/02/2013:  MAMEinfo.dat is located at: C:\GameEx\DATA\mameinfo.dat09:03:24.1  7/02/2013:  Loading Controls.ini map file09:03:24.1  7/02/2013:  Snap Path: Not Found09:03:24.1  7/02/2013:  Background Snap Path: Not Found09:03:24.1  7/02/2013:  AVI Snap Path: Not Found09:03:24.1  7/02/2013:  Flyer Path: Not Found09:03:24.1  7/02/2013:  Cabinet Path: Not Found09:03:24.1  7/02/2013:  Cabinet 3D Path: Not Found09:03:24.1  7/02/2013:  Title Path: Not Found09:03:24.1  7/02/2013:  PCB Path: Not Found09:03:24.1  7/02/2013:  Artwork Preview Path: Not Found09:03:24.1  7/02/2013:  Panel Path: Not Found09:03:24.1  7/02/2013:  Manual Path: Not Found09:03:24.1  7/02/2013:  Icon Path: Not Found09:03:24.1  7/02/2013:  Marquee Path: Not Found09:03:24.1  7/02/2013:  Applying Language/Text09:03:24.1  7/02/2013:  Text/Language: English09:03:24.1  7/02/2013:  Loading Language/Text09:03:24.2  7/02/2013:  Loading Custom Emulators09:03:24.2  7/02/2013:  Checking if Steam enabled09:03:24.2  7/02/2013:  Cannot find steam path09:03:24.2  7/02/2013:  Using Version 3 Themes Animations09:03:24.2  7/02/2013:  Retrieving resolution setting09:03:24.2  7/02/2013:  Using General Font: Arial09:03:24.2  7/02/2013:  Using Title Font: Arial09:03:24.2  7/02/2013:  GameEx will try to reduce CPU usage09:03:24.2  7/02/2013:  Initialising Direct3D09:03:24.3  7/02/2013:  Applying GameEx is Loading Image09:03:24.3  7/02/2013:  Setting Resolution to 640x480 32 bit color09:03:24.3  7/02/2013:  Creating Surfaces09:03:24.3  7/02/2013:  Creating Primary Surface - Full Screen Mode09:03:24.3  7/02/2013:  Creating Back Buffer09:03:24.3  7/02/2013:  Version 2 Theme being used. Loading.09:03:24.3  7/02/2013:  Loading Button Data09:03:24.3  7/02/2013:  Loading Font Data09:03:24.3  7/02/2013:  Loading Layout Data09:03:24.3  7/02/2013:  Loading Taskbar Data09:03:24.3  7/02/2013:  Loading graphic Surfaces09:03:24.3  7/02/2013:  Display is running at: 640x480 32bit color, 60hz09:03:24.3  7/02/2013:  Adapter: ATI Radeon HD 489009:03:24.3  7/02/2013:  Max texture size: 8192x819209:03:24.3  7/02/2013:  Available texture memory: -1046MB09:03:24.4  7/02/2013:  Initialising Bass Audio Library09:03:24.4  7/02/2013:  Creating Surfaces Misc and Dialogs09:03:24.4  7/02/2013:  Creating Surfaces Volume09:03:24.4  7/02/2013:  Creating Surfaces Arrows09:03:24.4  7/02/2013:  Creating Surfaces GameEXlogo Text09:03:24.4  7/02/2013:  Creating Surfaces Toolbar09:03:24.5  7/02/2013:  Creating Surfaces Toolbar Controls09:03:24.5  7/02/2013:  Creating Surfaces Backgrounds09:03:24.5  7/02/2013:  Creating Surfaces GameEx Logo09:03:24.5  7/02/2013:  Creating Surface Unselected09:03:24.5  7/02/2013:  Creating Surfaces Snaps09:03:24.5  7/02/2013:  Creating Surfaces Menu and List Bars09:03:24.6  7/02/2013:  Creating Fonts09:03:24.6  7/02/2013:  Creating Game Font09:03:24.6  7/02/2013:  Creating Game Font Faded09:03:24.7  7/02/2013:  Creating Title Font09:03:24.7  7/02/2013:  Restoring Title Font From Cache09:03:24.7  7/02/2013:  Creating Font Black09:03:24.8  7/02/2013:  Creating Font Black Small09:03:24.8  7/02/2013:  Fonts Created Succesfully09:03:24.8  7/02/2013:  Attempting to load game list09:03:25.0  7/02/2013:  MAME CMD options: -nowindow -joy -skip_gameinfo09:03:25.0  7/02/2013:  Sound Disabled09:03:25.0  7/02/2013:  Initialising DirectInput for Gamepad support09:03:25.0  7/02/2013:  Loading Start Page
And now its running again.....
perfectly no hiccups.....
Any ideas i really dont wanna have to reinstall and go to linux and change everything as i love having 7zip abaility and being able to run windows games aswell
The only thing I can think of is that it is because you are running WIn XP x64. I know that, not necessarily with GameEx, but other applications that this version was problemativ for driver and application support.If you have done all that you can to update your drivers, checked out your RAM, ensured that you have the latest .net framework and DirectX installed, I am stumped. Have you checked your Event Viewer to see if there are any other apps or drivers that are generating a warning or stop errors about the same time as when the crashes occur? I noticed in a few of your error logs that it indicated Sound disabled... are your audio drivers the most recent/up to date?
Hrm appears to be a net runtime error, ill uninstall and reninstall it see what happens.
Event Type: Information
Event Source: .NET Runtime 2.0 Error Reporting
Event Category: None
Event ID: 1001
Date: 7/02/2013
Time: 9:31:42 AM
User: N/A
Computer: ARCADE-UNIT
Description:
Bucket -894266667, bucket table 1, faulting application gameex.exe, version 1.0.0.0, stamp 5109960f, faulting module mscorwks.dll, version 2.0.50727.3643, stamp 50405371, debug? 0, fault address 0x0000eda6.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Data:
0000: 42 00 75 00 63 00 6b 00 B.u.c.k.
0008: 65 00 74 00 3a 00 20 00 e.t.:. .
0010: 2d 00 38 00 39 00 34 00 -.8.9.4.
0018: 32 00 36 00 36 00 36 00 2.6.6.6.
0020: 36 00 37 00 0d 00 0a 00 6.7.....
0028: 42 00 75 00 63 00 6b 00 B.u.c.k.
0030: 65 00 74 00 54 00 61 00 e.t.T.a.
0038: 62 00 6c 00 65 00 20 00 b.l.e. .
0040: 31 00 0d 00 0a 00 1.....
Just wanted to chip in something here. I notice the directx error is from Direct Input not Direct 3d. That would indicate an issue with a keyboard or game pad. So try messing with that stuff.
Hey tom i have uninstalled my Ipac,
the unit does not have a keybaord or mouse connected to it i am not sure where to go from here.
I had this same issue before the reintsall
Well Tom you are one smart cookie.
I sat back and staired at the machine and i noticed that there was one usb device left hooked to the machine.
The Corsair h100i has a direct USB header on the baord i removed that and everything is running fine.
It appears that there is an issue there with that....
Is this a Windows issue or a Gameex issue
Any thoughts on where to start!!!
Thankyou so much guys i am so stoked i dont have to use linux or hyperspin GAMEEX for life!
I am not really sure to cause but glad you got it sorted. All I can say is based on what I've seen even in 2013 USB can be a strange beast and on a separate note I've personally had various issues with USB 3 with various motherboards.
