BN1_Soldier Posted December 28, 2012 Share Posted December 28, 2012 Hi, I'm new here.Just started using GameEx and I'm really enjoying it, I've set up 5 emulators so far and there working great.I'm now adding another emulator Nebula for the Neo Geo roms, but I'm having 2 problems.1. When I use ESC to exit Nebula I get a black screen, but gameex is still running (I can hear it using arrow keys)2. The rom names are abbreviated e.g ninjamas=Ninja Master's. The abbreviation comes up in gameex, so how do I get the full name (tried re-naming the rom but then nebula doesn't recognise it)Also any tips for setting up the Sega CD? Its working in Windows with fusion. The roms aren't visable in gameex.Many thanks in advance.GameEx.inilog.txtSNK Neo-Geo.ini Link to comment Share on other sites More sharing options...
KRC Posted December 28, 2012 Share Posted December 28, 2012 Hey, Welcome to the forums.In regards to question 2, you should use a map file that will show the full name of your roms within GameEx, as I didnt see one in your NeoGeo.iniIve attached a NeoGeo Map File which needs to be put in the Map Files folder in your GameEx directory then go into the setup wizard then advanced emulator setup for Nebula look for Map File on the settings and put the following Map File there.Thanks to fRequEnCy for the Map FileNeo-Geo 20091103.zip Link to comment Share on other sites More sharing options...
Tempest Posted December 28, 2012 Share Posted December 28, 2012 1. Try setting ShowDesktop=True Link to comment Share on other sites More sharing options...
BN1_Soldier Posted December 29, 2012 Author Share Posted December 29, 2012 Thanks for the welcome.I installed the Map file you provided and it worked wonders, and I learned something new. so cheers.As for question 1, I changed the setting to "true" but still getting black screen. Any other suggestions would be really helpful. So annoying using task manager + restarting gameex.And if someone could point me in the right direction for the Sega CD set up, I didn't see anything in the Command-Lines, and MAP files thread.Surely its supported by gameex, right? Link to comment Share on other sites More sharing options...
Censored Posted December 29, 2012 Share Posted December 29, 2012 Is the Rom-Folder for the SegaCD isos correct?Turn off the Rom-Filter, maybe this helps. Link to comment Share on other sites More sharing options...
fRequEnCy Posted December 29, 2012 Share Posted December 29, 2012 There's a Nebula map file in there too. Neo-Geo is more tailored for something else. As far as ESC being an issue, it's cuz ESC doesn't exit the emulator in fullscreen mode. An advanced config might be the way to go to close this emulator the way it was intended. Link to comment Share on other sites More sharing options...
KRC Posted December 29, 2012 Share Posted December 29, 2012 I think that ninjamas he mentioned is in the WinKawaks Map File you did. Link to comment Share on other sites More sharing options...
BN1_Soldier Posted December 30, 2012 Author Share Posted December 30, 2012 Thanks for your help I've got the neo-geo running up and running perfectly.But still have a problem with the sega cd, the roms aren't showing up in gameex.What is the correct way to set up the rom folder? I have it as: C:\Roms\Sega CD\Roms\Then each rom has its own folder and inside that i have .iso or.bin .cue & .mp3 or .apeSega CD.ini Link to comment Share on other sites More sharing options...
nullPointer Posted December 30, 2012 Share Posted December 30, 2012 So just to be clear, it sounds like your disc images are not compressed right? If that's correct, try setting the following field to true in the Setup Wizard (located on the Advanced Emulator Setup screen):Scan Sub Folders= YesI imagine that might get you on the right track. After that you'll probably want to tweak your ROM filter settings so that each game has a single entry in the game list (this could also be accomplished via a combination of the ROM filter and the Excluded Files settings). Link to comment Share on other sites More sharing options...
BN1_Soldier Posted January 2, 2013 Author Share Posted January 2, 2013 All sorted now thanks to you guys, much appreciated Loving gameex its a great program with top support, I'll definitely show my support by registering my copy.I got a question about that... I'm gonna set this up for a gaming cab but also want a copy on my laptop. So would I have to pay the registration fee twice? Link to comment Share on other sites More sharing options...
Tempest Posted January 2, 2013 Share Posted January 2, 2013 It is acceptable to run GameEx on more than one computer for your personal use. Link to comment Share on other sites More sharing options...
