hi - I think I am missing something - I understand from reading documentation on this site that I can create a set of "snaps" ?
I've set up the snap folders in each emulators folder, but I dont know where the actual program or option to create the snapshots is!!
probably a "cant see the wood for the trees" thing!!
Thanks for any help!
Here you go. Hope this helps.
lol! ... that'd be it then!
Only problem is that I cannot find that option anywhere!
Is there a setting in config somewhere that lets you create the snap shots? I have tried changing the theme also with no luck...
:S
