Sorry to bring back an old topic but I have something to add to this as I have the same issue (would prefer to stay away from mess as I always have issues with that.)
The reason this does not work from command line is because there is a direct input error that occurs when run like this, see below prosystem.log file
[Sat Oct 06 18:20:02 2012][ERROR] Direct sound has not been initialized.
[Sat Oct 06 18:20:02 2012][ERROR] Direct draw has not been initialized.
[Sat Oct 06 18:20:02 2012][ERROR] Direct draw offscreen surface is invalid.
[Sat Oct 06 18:20:02 2012][INFO ] Opening cartridge file C:\Users\Ultima\AppData\Local\Temp\Unzipped7-Zip\3D Asteroids (1987) (Atari) (Prototype).a78
[Sat Oct 06 18:20:02 2012][INFO ] It is not a valid zip file: C:\Users\Ultima\AppData\Local\Temp\Unzipped7-Zip\3D Asteroids (1987) (Atari) (Prototype).a78
[Sat Oct 06 18:20:02 2012][INFO ] Accessing database ProSystem.dat
[Sat Oct 06 18:20:20 2012][ERROR] Direct sound has not been initialized.
[Sat Oct 06 18:20:20 2012][ERROR] Direct input has not been initialized.
If anyone has a fix for this it would be great,
This was split from the original 2011 thread found here. Please provide more info. Is this occurring only from ProSystem outside of GameEx or within? If within, can you provide the requisite GameEx log and configuration files? Thanks!
Thanks,
The controls work perfect outside game ex but when its launched from game ex the only buttons that work is the directional controls.
I use xpadder in conjunction with this so the keys are not mapped directly to my controller.
gameex.ini attached
log
23:36:48.0 06/10/2012: Opening Configuration File
23:36:48.1 06/10/2012: GameEx: Version 12.85: Starting Log
23:36:48.1 06/10/2012: Operating System Platform: Win32NT
23:36:48.1 06/10/2012: Operating System Name: Windows 7
23:36:48.1 06/10/2012: Operating System Version: 6.1.7601
23:36:48.1 06/10/2012: Aero running
23:36:48.1 06/10/2012: Initializing Vista/Windows 7 volume control
23:36:48.1 06/10/2012: Getting CPU and RAM info
23:36:48.1 06/10/2012: Intel® Core™ i7 CPU 870 @ 2.93GHz, 8151MB
23:36:48.1 06/10/2012: 2.93Ghz - 8 Cores or CPU's
23:36:48.1 06/10/2012: Running Randomize()
23:36:48.1 06/10/2012: Loading PlugIns
23:36:48.2 06/10/2012: Checking for applications to Launch On Startup
23:36:48.2 06/10/2012: Running Misc startup tasks
23:36:48.2 06/10/2012: Setting Menu types
23:36:48.2 06/10/2012: Getting Configuration Values
23:36:48.2 06/10/2012: Using Theme: Dark Champion - Carbon 720p
23:36:48.2 06/10/2012: Checking for alternate Image Directory for Theme: Dark Champion - Carbon 720p
23:36:48.2 06/10/2012: Launching HideOS.exe
23:36:48.2 06/10/2012: Initialising Video/MNG DLL's
23:36:48.2 06/10/2012: GameEx will check for media insertion (may affect performance)
23:36:48.2 06/10/2012: Hiding Taskbar
23:36:48.3 06/10/2012: Is Media Center running?
23:36:48.3 06/10/2012: Checking/Creating LCD Registry values
23:36:48.3 06/10/2012: Check Media Center Exit/Start Mode
23:36:48.3 06/10/2012: Media Center Mode 2
23:36:48.3 06/10/2012: Video previews on. Warning: Only recommended on modern systems
23:36:48.3 06/10/2012: Custom Game Device Input enabled: Getting custom codes
23:36:48.3 06/10/2012: Snap Delay set to: 7
23:36:48.3 06/10/2012: Get other settings
23:36:48.3 06/10/2012: Desktop set to Hide ICONS and set Background to Black
23:36:48.3 06/10/2012: Set: Find emulator artwork on best match basis
23:36:48.3 06/10/2012: Start work for Form
23:36:48.3 06/10/2012: Getting Original Screen Size
23:36:48.3 06/10/2012: Opening Database Connection
23:36:48.5 06/10/2012: Initializing Component
23:36:48.5 06/10/2012: MAME Path is: D:\Games\emulated\MAME64
23:36:48.6 06/10/2012: Model 2 Path Path is: D:\Games\emulated\Model 2
23:36:48.6 06/10/2012: Multi Core/Hyper Threading detected. Looking for emulator_multicpu.exe
23:36:48.6 06/10/2012: Model 2 EXE file is: emulator_multicpu.exe
23:36:48.6 06/10/2012: Model 2 emulator with command line support detected
23:36:48.6 06/10/2012: Use Model 2 on. emulator_multicpu.exe will launch Sega Model 2 games
23:36:48.6 06/10/2012: MAME EXE file is: mame64.exe
23:36:48.7 06/10/2012: ROM Path is: D:\Games\ROMs\Mame\Rebuilt ROMs
23:36:48.7 06/10/2012: Catver.ini is located at: D:\GameEx\DATA\catver.ini
23:36:48.7 06/10/2012: controls.ini is located at: D:\GameEx\data\controls.ini
23:36:48.7 06/10/2012: History.dat is located at: D:\GameEx\DATA\history.dat
23:36:48.7 06/10/2012: nplayers.ini is located at: D:\GameEx\DATA\nplayers.ini
23:36:48.7 06/10/2012: command.dat is located at: D:\GameEx\DATA\command.dat
23:36:48.7 06/10/2012: MAMEinfo.dat is located at: D:\GameEx\DATA\mameinfo.dat
23:36:48.7 06/10/2012: Loading Controls.ini map file
23:36:48.8 06/10/2012: Snap Path is: D:\Games\emulated\Mame32\snap
23:36:48.8 06/10/2012: Background Snap Path: Not Found
23:36:48.8 06/10/2012: AVI Snap Path: Not Found
23:36:48.8 06/10/2012: Flyer Path is: D:\Games\emulated\Mame32\flyers
23:36:48.8 06/10/2012: Cabinet Path is: D:\Games\emulated\Mame32\cabinets
23:36:48.8 06/10/2012: Cabinet 3D Path is: D:\Games\emulated\Mame32\cabinets
23:36:48.8 06/10/2012: Title Path is: D:\Games\emulated\Mame32\titles
23:36:48.8 06/10/2012: PCB Path is: D:\Games\emulated\Mame32\pcb
23:36:48.8 06/10/2012: Artwork Preview Path is: D:\Games\emulated\Mame32\artwork
23:36:48.8 06/10/2012: Panel Path: Not Found
23:36:48.8 06/10/2012: Manual Path: Not Found
23:36:48.8 06/10/2012: Icon Path is: D:\Games\emulated\Mame32\icons
23:36:48.8 06/10/2012: Marquee Path is: D:\Games\emulated\Mame32\marquees
23:36:48.9 06/10/2012: Applying Language/Text
23:36:48.9 06/10/2012: Text/Language: English
23:36:48.9 06/10/2012: Loading Language/Text
23:36:48.9 06/10/2012: Loading Custom Emulators
23:36:48.9 06/10/2012: Loading Emulator 1: [Console] Panasonic 3DO
23:36:48.9 06/10/2012: Loading Emulator 3: [Console] Atari 2600 (Stella)
23:36:48.9 06/10/2012: Loading Emulator 4: [Console] Atari 5200 (MESS)
23:36:49.0 06/10/2012: Loading Emulator 5: [Console] Atari 7800 (ProSystem)
23:36:49.0 06/10/2012: Loading Emulator 6: [Console] Atari Jaguar
23:36:49.0 06/10/2012: Loading Emulator 7: [Handheld] Atari Lynx (Handy)
23:36:49.0 06/10/2012: Loading Emulator 8: [Handheld] Bandai WonderSwan Color (Oswan)
23:36:49.0 06/10/2012: Loading Emulator 9: [Console] Coleco Vision (MESS)
23:36:49.0 06/10/2012: Loading Emulator 10: [Console] Fairchild Channel F (MESS)
23:36:49.0 06/10/2012: Loading Emulator 12: [Handheld] Nintendo Game Boy Advance (VisualBoyAdvance)
23:36:49.0 06/10/2012: Loading Emulator 13: [Handheld] Nintendo DS (DeSmuME)
23:36:49.0 06/10/2012: Loading Emulator 14: [Console] Mattel Intellivision (MESS)
23:36:49.0 06/10/2012: Loading Emulator 16: [Handheld] SNK Neo-Geo Pocket (NeoPop)
23:36:49.1 06/10/2012: Loading Emulator 17: [Console] Nintendo N64 (Project64)
23:36:49.1 06/10/2012: Loading Emulator 18: [Console] Nintendo NES (Nestopia)
23:36:49.1 06/10/2012: Loading Emulator 19: [Console] Nintendo GameCube (Dolphin)
23:36:49.1 06/10/2012: Loading Emulator 20: [Handheld] Nintendo Virtual Boy (Red Dragon)
23:36:49.2 06/10/2012: Loading Emulator 21: [Console] Nintendo Wii (Dolphin)
23:36:49.2 06/10/2012: Loading Emulator 22: [Console] NEC TurboGrafx-16 (MagicEngine)
23:36:49.2 06/10/2012: Loading Emulator 23: [Console] Sony Playstation (ePSXe)
23:36:49.2 06/10/2012: Loading Emulator 24: [Console] Sony Playstation 2 (PCSX2)
23:36:49.2 06/10/2012: Loading Emulator 25: [PC] Sam Coupe
23:36:49.2 06/10/2012: Loading Emulator 27: [Handheld] Sega Game Gear (Fusion)
23:36:49.2 06/10/2012: Loading Emulator 28: [Console] Sega Master System (Fusion)
23:36:49.2 06/10/2012: Loading Emulator 29: [Console] Sega Genesis (Fusion)
23:36:49.2 06/10/2012: Loading Emulator 30: [PC] Microsoft MSX (MESS)
23:36:49.3 06/10/2012: Loading Emulator 31: [PC] Microsoft MSX2 (MESS)
23:36:49.3 06/10/2012: Loading Emulator 32: [Console] Nintendo SNES (ZSNES)
23:36:49.3 06/10/2012: Loading Emulator 38: [Console] Sega Saturn (SSF)
23:36:49.3 06/10/2012: Loading Emulator 39: [PC] Microsoft Windows
23:36:49.4 06/10/2012: Loading Emulator 40: [Console] Sega 32X (Fusion)
23:36:49.4 06/10/2012: Loading Emulator 42: [PC] Microsoft Windows CD
23:36:49.4 06/10/2012: Loading Emulator 46: [PC GAME] M.U.G.E.N
23:36:49.4 06/10/2012: Loading Emulator 47: [Console] Sega Dreamcast (nullDC)
23:36:49.4 06/10/2012: Loading Emulator 48: [Arcade] Taito Type X
23:36:49.4 06/10/2012: Checking if Steam enabled
23:36:49.4 06/10/2012: Cannot find steam path
23:36:49.4 06/10/2012: Using 3D Alpha Blended Animations.
23:36:49.4 06/10/2012: Retrieving resolution setting
23:36:49.5 06/10/2012: Using General Font: Architext
23:36:49.5 06/10/2012: Using Title Font: Architext
23:36:49.6 06/10/2012: Initialising Direct3D
23:36:49.6 06/10/2012: Applying GameEx is Loading Image
23:36:49.6 06/10/2012: Setting Resolution to 1360x768 32 bit color
23:36:49.7 06/10/2012: Creating Surfaces
23:36:50.1 06/10/2012: Creating Primary Surface - Full Screen Mode
23:36:50.1 06/10/2012: Creating Back Buffer
23:36:50.1 06/10/2012: Version 2 Theme being used. Loading.
23:36:50.1 06/10/2012: Loading Button Data
23:36:50.1 06/10/2012: Loading Font Data
23:36:50.1 06/10/2012: Loading Layout Data
23:36:50.1 06/10/2012: Loading Taskbar Data
23:36:50.1 06/10/2012: Loading graphic Surfaces
23:36:50.1 06/10/2012: Display is running at: 1360x768 32bit color, 60hz
23:36:50.1 06/10/2012: Adapter: NVIDIA GeForce GTX 660
23:36:50.1 06/10/2012: Max texture size: 8192x8192
23:36:50.1 06/10/2012: Available texture memory: -66MB
23:36:50.1 06/10/2012: Initialising Bass Audio Library
23:36:50.1 06/10/2012: Creating Surfaces Misc and Dialogs
23:36:50.4 06/10/2012: Creating Surfaces Volume
23:36:50.4 06/10/2012: Creating Surfaces Arrows
23:36:50.4 06/10/2012: Creating Surfaces GameEXlogo Text
23:36:50.4 06/10/2012: Creating Surfaces Toolbar
23:36:50.4 06/10/2012: Creating Surfaces Toolbar Controls
23:36:50.5 06/10/2012: Creating Surfaces Backgrounds
23:36:50.5 06/10/2012: Creating Surfaces GameEx Logo
23:36:50.5 06/10/2012: Creating Surface Unselected
23:36:50.5 06/10/2012: Creating Surfaces Snaps
23:36:50.5 06/10/2012: Creating Surfaces Menu and List Bars
23:36:50.7 06/10/2012: Creating Fonts
23:36:50.7 06/10/2012: Creating Game Font
23:36:50.8 06/10/2012: Creating Game Font Faded
23:36:50.8 06/10/2012: Creating Title Font
23:36:50.9 06/10/2012: Restoring Title Font From Cache
23:36:51.1 06/10/2012: Creating Font Black
23:36:51.1 06/10/2012: Creating Font Black Small
23:36:51.2 06/10/2012: Fonts Created Succesfully
23:36:51.5 06/10/2012: Attempting to load game list
23:36:51.7 06/10/2012: MAME CMD options: -nowindow -joy -skip_gameinfo
23:36:51.7 06/10/2012: Initialising DirectInput for Gamepad support
23:36:51.7 06/10/2012: Using Device Controller (XBOX 360 For Windows)
23:36:51.8 06/10/2012: Loading Start Page
23:36:51.8 06/10/2012: Initializing MCE Remote
23:36:51.8 06/10/2012: Playing intro sound file
23:36:51.8 06/10/2012: Initialization OK! Starting GameEx!
23:36:51.8 06/10/2012: Testing Main Loop Once: Processing Frame
23:36:52.0 06/10/2012: Testing Main Loop Once: Main Loop ran successfully
23:36:57.0 06/10/2012: Validating: Emulator_1: Snap Path: D:\Games\emulated\3DO\snaps\Video\Panasonic - 3DO.flv
23:36:57.0 06/10/2012: Warning: Emulator_1: Snap Path Does not exist
23:36:57.0 06/10/2012: Validating: Emulator_1: Database: [Console] Panasonic 3DO
23:36:57.0 06/10/2012: Validating: Emulator_3: Snap Path: D:\Games\emulated\Atari 2600\Snaps
23:36:57.0 06/10/2012: Validating: Emulator_3: Control Panel Path: D:\Games\emulated\Atari 2600\Controls\Atari 2600.png
23:36:57.0 06/10/2012: Validating: Emulator_3: Database: [Console] Atari 2600
23:36:57.0 06/10/2012: Validating: Emulator_4: Snap Path: D:\Games\emulated\Atari 5200\Snaps
23:36:57.0 06/10/2012: Validating: Emulator_4: Control Panel Path: D:\Games\emulated\Atari 5200\Controls\Atari 5200.png
23:36:57.0 06/10/2012: Validating: Emulator_4: Database: [Console] Atari 5200
23:36:57.0 06/10/2012: Validating: Emulator_5: Snap Path: D:\Games\emulated\Atari 7800\Snaps
23:36:57.0 06/10/2012: Validating: Emulator_5: Control Panel Path: D:\Games\emulated\Atari 7800\Controls\Atari 7800.png
23:36:57.0 06/10/2012: Validating: Emulator_5: Database: [Console] Atari 7800
23:36:57.0 06/10/2012: Validating: Emulator_6: Snap Path: D:\Games\emulated\Atari Jaguar\Snaps
23:36:57.1 06/10/2012: Validating: Emulator_6: Control Panel Path: D:\Games\emulated\Atari Jaguar\Controls\Atari Jaguar.png
23:36:57.1 06/10/2012: Validating: Emulator_6: Database: [Console] Atari Jaguar
23:36:57.1 06/10/2012: Validating: Emulator_7: Snap Path: D:\Games\emulated\atari lynx\Snaps
23:36:57.1 06/10/2012: Validating: Emulator_7: Control Panel Path: D:\Games\emulated\atari lynx\Controls\Atari Lynx.png
23:36:57.1 06/10/2012: Validating: Emulator_7: Database: [Handheld] Atari Lynx
23:36:57.1 06/10/2012: Validating: Emulator_8: Snap Path: D:\Games\emulated\Bandai Wonderswan\Snaps
23:36:57.1 06/10/2012: Validating: Emulator_8: Control Panel Path: D:\Games\emulated\Bandai Wonderswan\Controls\Bandai Wonderswan.png
23:36:57.2 06/10/2012: Validating: Emulator_8: Database: [Handheld] Bandai WonderSwan Color
23:36:57.2 06/10/2012: Validating: Emulator_9: Snap Path: D:\Games\emulated\Colecovision\Snaps
23:36:57.2 06/10/2012: Validating: Emulator_9: Database: [Console] Coleco Vision
23:36:57.2 06/10/2012: Validating: Emulator_10: Snap Path: D:\Games\emulated\Farchild Channel F\Snaps
23:36:57.2 06/10/2012: Validating: Emulator_10: Control Panel Path: D:\Games\emulated\Farchild Channel F\Controls\Channel F.png
23:36:57.2 06/10/2012: Validating: Emulator_10: Database: [Console] Fairchild Channel F
23:36:57.2 06/10/2012: Validating: Emulator_12: Snap Path: D:\Games\emulated\Nintendo game boy advance, DS\Snaps
23:36:57.2 06/10/2012: Validating: Emulator_12: Control Panel Path: D:\Games\emulated\Nintendo game boy advance, DS\GBA Controls\GBA.png
23:36:57.2 06/10/2012: Validating: Emulator_12: Database: [Handheld] Nintendo Game Boy Advance
23:36:57.2 06/10/2012: Validating: Emulator_13: Snap Path: D:\Games\emulated\Nintendo game boy advance, DS\Snaps\DS
23:36:57.3 06/10/2012: Validating: Emulator_13: Control Panel Path: D:\Games\emulated\Nintendo game boy advance, DS\DS Cntrols\Nintendo DS.png
23:36:57.3 06/10/2012: Validating: Emulator_13: Database: [Handheld] Nintendo DS
23:36:57.3 06/10/2012: Validating: Emulator_14: Snap Path: D:\Games\emulated\Intellivision\Snaps
23:36:57.3 06/10/2012: Validating: Emulator_14: Database: [Console] Mattel Intellivision
23:36:57.3 06/10/2012: Validating: Emulator_16: Snap Path: D:\Games\emulated\Neo Geo Pocket\Snaps
23:36:57.3 06/10/2012: Validating: Emulator_16: Control Panel Path: D:\Games\emulated\Neo Geo Pocket\Controls\Neo Geo Pocket.png
23:36:57.3 06/10/2012: Validating: Emulator_16: Database: [Handheld] SNK Neo-Geo Pocket
23:36:57.3 06/10/2012: Validating: Emulator_17: Snap Path: D:\Games\emulated\Nintendo 64\Snaps
23:36:57.3 06/10/2012: Validating: Emulator_17: Control Panel Path: D:\Games\emulated\Nintendo 64\Controls\N64.png
23:36:57.3 06/10/2012: Validating: Emulator_17: Database: [Console] Nintendo N64
23:36:57.3 06/10/2012: Validating: Emulator_18: Snap Path: D:\Games\emulated\NES\Snaps
23:36:57.3 06/10/2012: Validating: Emulator_18: Control Panel Path: D:\Games\emulated\NES\Controls\NES.png
23:36:57.3 06/10/2012: Validating: Emulator_18: Database: [Console] Nintendo NES
23:36:57.3 06/10/2012: Validating: Emulator_19: Snap Path: D:\Games\emulated\Nintendo game cube, Wii\Snaps\Video\Nintendo GameCube.avi
23:36:57.3 06/10/2012: Warning: Emulator_19: Snap Path Does not exist
23:36:57.3 06/10/2012: Validating: Emulator_19: Control Panel Path: D:\Games\emulated\Nintendo game cube, Wii\Controls\Gamecube.png
23:36:57.3 06/10/2012: Validating: Emulator_19: Database: [Console] Nintendo GameCube
23:36:57.3 06/10/2012: Validating: Emulator_20: Snap Path: D:\Games\emulated\Nintendo Virtual Boy\Snaps
23:36:57.4 06/10/2012: Validating: Emulator_20: Control Panel Path: D:\Games\emulated\Nintendo Virtual Boy\Controls\Virtual boy.png
23:36:57.4 06/10/2012: Validating: Emulator_20: Database: [Handheld] Nintendo Virtual Boy
23:36:57.4 06/10/2012: Validating: Emulator_21: Snap Path: D:\Games\emulated\Nintendo game cube, Wii\Snaps
23:36:57.4 06/10/2012: Validating: Emulator_21: Control Panel Path: D:\Games\emulated\Nintendo game cube, Wii\Controls
23:36:57.4 06/10/2012: Validating: Emulator_21: Database: [Console] Nintendo GameCube
23:36:57.4 06/10/2012: Validating: Emulator_22: Snap Path: D:\Games\emulated\PC Engine\Snaps
23:36:57.4 06/10/2012: Validating: Emulator_22: Control Panel Path: D:\Games\emulated\PC Engine\Controls\PC Engine.png
23:36:57.4 06/10/2012: Validating: Emulator_22: Database: [Console] NEC TurboGrafx-16
23:36:57.4 06/10/2012: Validating: Emulator_23: Snap Path: D:\Games\emulated\Sony Playstation\snap\Sony PlayStation].flv
23:36:57.4 06/10/2012: Warning: Emulator_23: Snap Path Does not exist
23:36:57.4 06/10/2012: Validating: Emulator_23: Control Panel Path: D:\Games\emulated\Sony Playstation\Controls\PS1.png
23:36:57.4 06/10/2012: Validating: Emulator_23: Database: [Console] Sony Playstation
23:36:57.5 06/10/2012: Warning: Emulator_23: MAPFile Does Not Exist
23:36:57.5 06/10/2012: Validating: Emulator_24: Snap Path: D:\Games\emulated\Sony Playstation 2\snaps
23:36:57.5 06/10/2012: Validating: Emulator_24: Control Panel Path: D:\Games\emulated\Sony Playstation 2\Controls\PS2.png
23:36:57.5 06/10/2012: Validating: Emulator_24: Database: [Console] Sony PlayStation 2
23:36:57.5 06/10/2012: Warning: Emulator_24: MAPFile Does Not Exist
23:36:57.5 06/10/2012: Validating: Emulator_25: Snap Path: D:\Games\emulated\Sam Coupe\Snaps
23:36:57.5 06/10/2012: Validating: Emulator_25: Database: Template
23:36:57.5 06/10/2012: Validating: Emulator_27: Snap Path: D:\Games\emulated\sega megadrive, Game Gear, Master system\Snaps\Game gear
23:36:57.6 06/10/2012: Validating: Emulator_27: Control Panel Path: D:\Games\emulated\sega megadrive, Game Gear, Master system\GG Controls\Game Gear.png
23:36:57.6 06/10/2012: Validating: Emulator_27: Database: [Handheld] Sega Game Gear
23:36:57.6 06/10/2012: Validating: Emulator_28: Snap Path: D:\Games\emulated\sega megadrive, Game Gear, Master system\Snaps\Mastersystem
23:36:57.6 06/10/2012: Validating: Emulator_28: Control Panel Path: D:\Games\emulated\sega megadrive, Game Gear, Master system\MS Controls\Mastersystem.png
23:36:57.6 06/10/2012: Validating: Emulator_28: Database: [Console] Sega Master System
23:36:57.6 06/10/2012: Validating: Emulator_29: Snap Path: D:\Games\emulated\sega megadrive, Game Gear, Master system\Snaps\Megadrive
23:36:57.6 06/10/2012: Validating: Emulator_29: Control Panel Path: D:\Games\emulated\sega megadrive, Game Gear, Master system\MD Controls\Sega Megadrive.png
23:36:57.6 06/10/2012: Validating: Emulator_29: Database: [Console] Sega Genesis
23:36:57.6 06/10/2012: Validating: Emulator_30: Snap Path: D:\Games\emulated\MSX\Snaps
23:36:57.6 06/10/2012: Validating: Emulator_30: Control Panel Path: D:\Games\emulated\MSX\Controls\MSX.png
23:36:57.6 06/10/2012: Validating: Emulator_30: Database: [PC] Microsoft MSX
23:36:57.6 06/10/2012: Validating: Emulator_31: Snap Path: D:\Games\emulated\MSX2\Snaps
23:36:57.6 06/10/2012: Validating: Emulator_31: Control Panel Path: D:\Games\emulated\MSX2\Controls\MSX 2.png
23:36:57.6 06/10/2012: Validating: Emulator_31: Database: [PC] Microsoft MSX 2
23:36:57.6 06/10/2012: Validating: Emulator_32: Snap Path: D:\Games\emulated\super nintendo\Snaps
23:36:57.6 06/10/2012: Validating: Emulator_32: Control Panel Path: D:\Games\emulated\super nintendo\Layout\Snes layout.png
23:36:57.6 06/10/2012: Validating: Emulator_32: Database: [Console] Nintendo SNES
23:36:57.6 06/10/2012: Validating: Emulator_38: Snap Path: D:\Games\emulated\sega saturn\Snaps
23:36:57.6 06/10/2012: Validating: Emulator_38: Database: [Console] Sega Saturn
23:36:57.6 06/10/2012: Validating: Emulator_39: Snap Path: D:\Games\PC Games\Shortcuts\Snaps
23:36:57.6 06/10/2012: Validating: Emulator_40: Snap Path: D:\Games\emulated\sega megadrive, Game Gear, Master system\Snaps\32X
23:36:57.6 06/10/2012: Validating: Emulator_40: Database: [Console] Sega 32X
23:36:57.6 06/10/2012: Validating: Emulator_42: Snap Path: D:\Games\PC Games\Snaps
23:36:57.6 06/10/2012: Validating: Emulator_47: Snap Path: D:\Games\emulated\Sega Dreamcast\Snaps
23:36:57.6 06/10/2012: Validating: Emulator_47: Control Panel Path: D:\Games\emulated\Sega Dreamcast\Controls
23:36:57.6 06/10/2012: Validating: Emulator_47: Database: [Console] Sega Dreamcast
23:36:57.6 06/10/2012: Validating: Emulator_48: Snap Path: D:\Games\emulated\Taito Type X\Snaps
23:36:57.6 06/10/2012: Restoring Emulator from Cache: 1
23:36:57.7 06/10/2012: Restoring Emulator Database From Cache: 1
23:36:57.8 06/10/2012: Restoring Emulator from Cache: 3
23:36:57.8 06/10/2012: Restoring Emulator Database From Cache: 3
23:36:57.9 06/10/2012: Restoring Emulator from Cache: 4
23:36:57.9 06/10/2012: Restoring Emulator Database From Cache: 4
23:36:58.0 06/10/2012: Restoring Emulator from Cache: 5
23:36:58.0 06/10/2012: Restoring Emulator Database From Cache: 5
23:36:58.0 06/10/2012: Restoring Emulator from Cache: 6
23:36:58.0 06/10/2012: Restoring Emulator Database From Cache: 6
23:36:58.1 06/10/2012: Restoring Emulator from Cache: 7
23:36:58.1 06/10/2012: Restoring Emulator Database From Cache: 7
23:36:58.2 06/10/2012: Restoring Emulator from Cache: 8
23:36:58.2 06/10/2012: Restoring Emulator Database From Cache: 8
23:36:58.2 06/10/2012: Restoring Emulator from Cache: 9
23:36:58.2 06/10/2012: Restoring Emulator Database From Cache: 9
23:36:58.3 06/10/2012: Restoring Emulator from Cache: 10
23:36:58.3 06/10/2012: Restoring Emulator Database From Cache: 10
23:36:58.4 06/10/2012: Restoring Emulator from Cache: 12
23:36:58.6 06/10/2012: Restoring Emulator Database From Cache: 12
23:36:58.9 06/10/2012: Restoring Emulator from Cache: 13
23:36:58.9 06/10/2012: Restoring Emulator Database From Cache: 13
23:36:59.0 06/10/2012: Restoring Emulator from Cache: 14
23:36:59.0 06/10/2012: Restoring Emulator Database From Cache: 14
23:36:59.0 06/10/2012: Restoring Emulator from Cache: 16
23:36:59.1 06/10/2012: Restoring Emulator Database From Cache: 16
23:36:59.1 06/10/2012: Restoring Emulator from Cache: 17
23:36:59.1 06/10/2012: Restoring Emulator Database From Cache: 17
23:36:59.2 06/10/2012: Restoring Emulator from Cache: 18
23:36:59.3 06/10/2012: Restoring Emulator Database From Cache: 18
23:36:59.4 06/10/2012: Restoring Emulator from Cache: 19
23:36:59.4 06/10/2012: No Database Data: 19
23:36:59.4 06/10/2012: Restoring Emulator from Cache: 20
23:36:59.4 06/10/2012: Restoring Emulator Database From Cache: 20
23:36:59.4 06/10/2012: Restoring Emulator from Cache: 21
23:36:59.4 06/10/2012: No Database Data: 21
23:36:59.5 06/10/2012: Restoring Emulator from Cache: 22
23:36:59.5 06/10/2012: Restoring Emulator Database From Cache: 22
23:36:59.5 06/10/2012: Restoring Emulator from Cache: 23
23:36:59.6 06/10/2012: No Database Data: 23
23:36:59.6 06/10/2012: Restoring Emulator from Cache: 24
23:36:59.6 06/10/2012: Restoring Emulator Database From Cache: 24
23:36:59.6 06/10/2012: Restoring Emulator from Cache: 25
23:36:59.6 06/10/2012: No Database Data: 25
23:36:59.6 06/10/2012: Restoring Emulator from Cache: 27
23:36:59.7 06/10/2012: Restoring Emulator Database From Cache: 27
23:36:59.7 06/10/2012: Restoring Emulator from Cache: 28
23:36:59.8 06/10/2012: Restoring Emulator Database From Cache: 28
23:36:59.8 06/10/2012: Restoring Emulator from Cache: 29
23:37:00.1 06/10/2012: Restoring Emulator Database From Cache: 29
23:37:00.4 06/10/2012: Restoring Emulator from Cache: 30
23:37:00.4 06/10/2012: Restoring Emulator Database From Cache: 30
23:37:00.5 06/10/2012: Restoring Emulator from Cache: 31
23:37:00.5 06/10/2012: Restoring Emulator Database From Cache: 31
23:37:00.6 06/10/2012: Restoring Emulator from Cache: 32
23:37:00.7 06/10/2012: Restoring Emulator Database From Cache: 32
23:37:00.9 06/10/2012: Restoring Emulator from Cache: 38
23:37:00.9 06/10/2012: Restoring Emulator Database From Cache: 38
23:37:01.0 06/10/2012: Restoring Emulator from Cache: 39
23:37:01.1 06/10/2012: Restoring Emulator from Cache: 40
23:37:01.1 06/10/2012: Restoring Emulator Database From Cache: 40
23:37:01.1 06/10/2012: Restoring Emulator from Cache: 42
23:37:01.2 06/10/2012: Restoring Emulator from Cache: 46
23:37:01.2 06/10/2012: Restoring Emulator from Cache: 47
23:37:01.2 06/10/2012: Restoring Emulator Database From Cache: 47
23:37:01.3 06/10/2012: Restoring Emulator from Cache: 48
23:37:15.2 06/10/2012: Creating instance of global keyboard hook
23:37:15.2 06/10/2012: Running: cmd.exe /c D: ProSystem.exe -Fullscreen 1 -MenuEnabled 0 "D:\Games\ROMs\Atari 7800\3D Asteroids (1987) (Atari) (Prototype).a78"
23:37:15.3 06/10/2012: Shutting down display
23:37:15.5 06/10/2012: Also Launching: "D:\Games\Ultils\xpadder\xpadder.bat"
23:37:42.8 06/10/2012: Exiting Game
23:37:42.8 06/10/2012: Closing Process
23:37:45.5 06/10/2012: Writing Stats
23:37:45.5 06/10/2012: Plugin: Game Exit
23:37:45.5 06/10/2012: Plugin: Process Commands
23:37:45.5 06/10/2012: Refreshing Keyboard
23:37:45.6 06/10/2012: Initialising Audio
23:37:45.8 06/10/2012: Restoring Window
23:37:45.8 06/10/2012: Reinitializing Graphics System
23:37:46.8 06/10/2012: Reloading Game Info Page
23:37:47.0 06/10/2012: Returning to GameEx
23:38:04.6 06/10/2012: Running: cmd.exe /c D: ProSystem.exe -Fullscreen 1 -MenuEnabled 0 "C:\Users\Ultima\AppData\Local\Temp\Unzipped7-Zip\Double Dragon (1989) (Activision) (PAL).a78"
23:38:04.7 06/10/2012: Shutting down display
23:38:04.9 06/10/2012: Also Launching: "D:\Games\Ultils\xpadder\xpadder.bat"
23:38:12.9 06/10/2012: Exiting Game
23:38:12.9 06/10/2012: Closing Process
23:38:15.6 06/10/2012: Writing Stats
23:38:15.6 06/10/2012: Plugin: Game Exit
23:38:15.6 06/10/2012: Plugin: Process Commands
23:38:15.6 06/10/2012: Refreshing Keyboard
23:38:15.7 06/10/2012: Initialising Audio
23:38:15.9 06/10/2012: Restoring Window
23:38:15.9 06/10/2012: Reinitializing Graphics System
23:38:17.0 06/10/2012: Reloading Game Info Page
23:38:17.3 06/10/2012: Returning to GameEx
23:38:18.8 06/10/2012: Exiting GameEx!
23:38:18.8 06/10/2012: Disposing all videos
23:38:18.8 06/10/2012: Deleting temporary Karaoke videos
23:38:18.8 06/10/2012: Disposing Image List
23:38:18.8 06/10/2012: Disposing Fonts
23:38:18.8 06/10/2012: Disposing Surfaces
23:38:18.9 06/10/2012: Saving Settings
23:38:18.9 06/10/2012: Shutting down Bass
23:38:18.9 06/10/2012: Closing HideOS.exe
23:38:19.1 06/10/2012: Disposing Plugins
23:38:19.1 06/10/2012: Closing database connection
23:38:19.1 06/10/2012: Checking for applications to Launch On Exit
23:38:19.1 06/10/2012: Media Center was not open when starting GameEx, so not launching
23:38:19.9 06/10/2012: Bye
runitgame.bat
chcp 65001
D:
CD "D:\Games\emulated\Atari 7800"
taskkill /im xpadder.exe /f
GameEx.ini
Hi massop
I note that you're launching Xpadder as an 'Also Launch' rather than a 'Launch Before' parameter. Note that this can have some adverse effects depending on the application being launched (you'll notice in your log that your batch script is not running until after the emulator has already been launched). I would guess that's why your batch script is not showing up in your runitgame.bat. You might try entering the batch script as a Launch Before parameter and see how that goes.
Also this line makes it look like you're not loading any one particular xpadder profile:
Is that by design? (i.e do you utilize only one profile that's managed through the batch file?)
Ah I should have shown whats in that .bat.
I use this .bat in conjunction with any emu that needs keyboard mapped to pad, so xpadder.bat is just there to run and load my default profile, see below
@echo off
cd /D D:\games\Ultils\xpadder\
start "" xpadder.exe "xbox360 P1" "xbox360 P2" /M
@echo on
I just tried moving the "also launch" string to launch before but the emu fails to load with this.
This rings a bell actually as to why I never used launch before because I could not get my .bat files working in it.
Hi massop,
You mentioned that ProSystem is working fine outside of GameEx. Do the above errors listed above appear in the ProSystem log when you launch it from outside of GameEx? What about when you launch it outside of GameEx from the command line?
hmmm,
The keys do not work when launching via command line outside gameex.
What does this mean? this emu will never work with controllers via command line?
Hi massop
I'm not sure, but that shouldn't be the case? ProSystem supports DirectInput whereas those Xbox 360 controls only supprt XInput, but Xpadder is designed to alleviate that very concern. When you run from the command line, does Xpadder start up OK, and is it registering input? If that all looks good, does ProSystem still have the correct controller mapping when launched in this fashion?
I just noticed something else (possibly unrelated)
emu_5_gamesin7zips=True
ProSystem supports zipped roms (.zip), although this certainly wouldn't apply to 7-zipped (.7z). What happens if you disable the above setting in GameEx, and attempt to run either a zipped rom (.zip), or an uncompressed rom (.a78)? This may or may not duplicate the above command line test depending on your previous test.
Thanks for the feedback.
Xpadder does run from command line and I can see the inputs working while this is on.
The odd thing is if I go to the prosystem menu (after launching from command line) the config is correct but only the directional controls work.
Its as if its blocking those keys.
I ran the emu without 7z both in and outside game ex and the issue remains the same :(
1 thing I have not tried yet but will test later is running in compatability mode. I will update as soon as I get back from work.
Did a little "googling" and came up with this. It appears that ProSystem will not work with a 64-bit OS. So even in compatibility mode, it may not work. Keeping fingers crossed!
Compatability mode = No apples,
So I guess this emulator is dead in the water then,
Looks like ill have to get on mess with this.
Thanks for the help anyway.
Edited by Draco1962
