hi - when I load gameEx - it reboots the PC! I see the welcome screen for about 1 second, then it just reboots......I've gone through pretty much all the configuration pages trying to see why this happens - but I cannot find why!
I have windows XP Pro
mame32
any ideas what might be causing it? I'm really keen to get this working as it looks a brilliant tool!
thanks
the same happens to me about 2-3 times within the last days. in my case it reboots when coming back to gameex from daphne. if it appears more often, i'll try to search what happens
Please post logs after this happens.
Thanks.
EDIT: This is most likely hardware related, unless somehow its trigerring the reboot command in GameEx. I may be wrong and it could be a bug but I would check your PC is not overheating for starters. Need the log though.
Thanks.
I've just noticed you have a new version available - I've downloaded that and it loads fine now!!
As a result, I no longer have the log files for showing the errors... but I remember that last entry in it was something like hide toolbar if that helps?
this is a really great bit of software Tom - excellent work :)
- on another note, when I "press 1" to goto the donate page from within the software, it shows that the security certificate has expired or something! Mabye I'd be good to go to a page on your site with more info about donating, then offer the link? Just a thought! ;)
