[RESOLVED] WINUAE Loader Problem with Commodore Atari & GameEx
Hi
I have a little problem, when i launch a game from WinUAELoader a windows from WinUAE.exe appear, and i have to push start to launch the game. (see attached file)
The problème is that can't launch with my command line from GameEx.
My command line is:
WinUAELoader.exe -mode whdload -rom "[ROMFILE]"
I want to know if is it possible that the window does not appear, only launch the game, or an other command line to use for gameEx push start automatically the game.
Tanks
post-10149-0-54410900-1348946559_thumb.p
Are you trying to use GameBase and do you have it enabled in Setup Wizard? As always, when reporting an issue, please provide a copy of your log.txt file, GameEx,ini file, and the config.ini file for whatever emulator you are using so that we can help you faster.
[Emulator]
Command=WinUAELoader.exe -mode whdload -rom "[ROMFILE]"
StartPageLogo=Commodore Amiga
StartPageName=[PC] Commodore Amiga (WHDLoad)
TitleText=Amiga (WHDLoad)
Info=Amiga emulator
Website=http://www.winuae.net/
RequiredFiles=
DownloadUrl=http://www.gamesdbase.com/setupwizard/emulators/download/WinUAELoader.7z
Rating=8.1
Version=1.6.1
Emulator=WinUAE
Category=PC
System=Commodore Amiga (WHDLoad)
RomFilter=
Database=
ConfigFile=
MapFile=[PC] Commodore Amiga (WHDLoad)
RomsInFolders=False
ROMPath=E:\Commodore Amiga Roms\Commodore Amiga
SnapPath=E:\GameEx\GameEx\EmulateurAllCov\Commodore Amiga\Snaps\WHDLoad
TitlePath=E:\GameEx\GameEx\EmulateurAllCov\Commodore Amiga\Titles\WHDLoad
BoxPath=E:\GameEx\GameEx\EmulateurAllCov\Commodore Amiga\Boxes\WHDLoad
CartPath=E:\GameEx\GameEx\EmulateurAllCov\Commodore Amiga\Carts\WHDLoad
WorkingPath=E:\Commodore Amiga Emulators\Commodore Amiga\WinUAELoader
MapKeys=False
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
ShowDesktop=False
Debug=False
AlsoLaunch=
OLDatZip=
LaunchBefore=
LaunchAfter=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
GamesIn7Zips=
VideoSnapPath=E:\GameEx\GameEx\EmulateurAllCov\Commodore Amiga\Snaps\WHDLoad
ManualPath=
ControlPanelPath=
lastgame=
This is the ini file from the Commodore Amiga emulator. The games launched perfectly before the window (WinUAE Propreties) appears.
I don't use GameBase.
Thanks. While I do not use this program I am sure someone can provide instruction/feedback to assist.
I think this is caused by a tickbox in the miscellaneous tab of WinUAE. "Start into GUI" or something like that.
This box becomes ticked under certain circumstances, for example when using the edit config button in WinUAELoader.
Hope that helps.
Thanks for the assist, Wubble!
Edited by Draco1962
