Hi i trying to get NO$GBA to work with NO$ZOOMER
It seems to work as it should but after launching it, it always goes back to gamex and the emulator is running fine in the background?? havnt had this problem with others
Please help thanks
edit
It seems to be similar to this problem
http://www.gameex.in...emulator-issue/
NO$Zoomer.exe doesnt seem to have any processes , since GameEx doesn't see NO$Zoomer.exe it thinks its closed which is why it takes back focus to Gameex
Ok i got it working
i had to make the command line point to a fresh folder of NO$Zoomer without NO$Zoomer.ini file
Command Line=NO$Zoomer.exe
This would popup a window trying to search for no$gba.exe, while this window is active NO$Zoomer.exe will show and stay in processes
On Advanced Emulator Setup i used "Also Launch"
E:\GameEx\Emulators\No$GBA\NO$Zoomer2.3.0.2\NO$Zoomer.exe "[ROMPATH]\[ROMFILE]"
Ill put as Resolved but if anyone has a better method please let me know, thanks
Edited by Draco1962
