ok so i have everything installed but GameEx wont launch crappy part is its the one I want. Have installed and tested out every other frontend out there for mame and want GameEx but it wont open. Installs properly and configs and then open the program to launch the front end and it crashes does not even load the program have tried everything I know to get it going and cant seem to get it to go so any ideas would be great.
cause really M$ would probably have gotten 1million error reports from me already if I keep this up! lol
please help guys.
That does indeed suck. Let's start with some basic stuff. Have you tried uninstalling GameEx and reinstalling from a fresh download of the installer? That would be my first suggestion. If you try that, but it still doesn't work lets check and see if the application is getting far enough to generate a log file. If a log file is present, please post the contents of the log here, and we'll see what we can see.
Here's some instructions on where to find the log file.
[GUIDE] How to ask for Help
Thanks! I'm fairly sure we'll get you sorted out. Welcome to the forums!
yup 5 fresh installs....don't ask...lol
log file ya i found that looking around here it is.
04:51:54.0 04/09/2012: Opening Configuration File
04:51:54.0 04/09/2012: GameEx: Version 12.80: Starting Log
04:51:54.0 04/09/2012: Operating System Platform: Win32NT
04:51:54.0 04/09/2012: Operating System Name: Windows Vista
04:51:54.0 04/09/2012: Operating System Version: 6.2.9200
04:51:54.0 04/09/2012: Aero running
04:51:54.0 04/09/2012: Running under Remote Desktop
04:51:54.0 04/09/2012: Initializing Vista/Windows 7 volume control
04:51:54.0 04/09/2012: Getting CPU and RAM info
04:51:54.0 04/09/2012: Intel® Core i7-3820 CPU @ 3.60GHz, 16308MB
04:51:54.0 04/09/2012: 3.6Ghz - 8 Cores or CPU's
04:51:54.0 04/09/2012: Running Randomize()
04:51:54.0 04/09/2012: Loading PlugIns
04:51:54.0 04/09/2012: Checking for applications to Launch On Startup
04:51:54.0 04/09/2012: Running Misc startup tasks
04:51:54.0 04/09/2012: Setting Menu types
04:51:54.0 04/09/2012: Getting Configuration Values
04:51:54.0 04/09/2012: Using Theme: Default - Media Center
04:51:54.0 04/09/2012: Checking for alternate Image Directory for Theme: Default - Media Center
04:51:54.0 04/09/2012: Using Images from theme: Default - Media Center V1\MEDIA\
04:51:54.0 04/09/2012: Initialising Video/MNG DLL's
04:51:54.0 04/09/2012: GameEx will check for media insertion (may affect performance)
04:51:54.0 04/09/2012: Is Media Center running?
04:51:54.0 04/09/2012: Checking/Creating LCD Registry values
04:51:54.0 04/09/2012: Check Media Center Exit/Start Mode
04:51:54.0 04/09/2012: Media Center Mode 2
04:51:54.1 04/09/2012: Video previews on. Warning: Only recommended on modern systems
04:51:54.1 04/09/2012: Snap Delay set to: 2
04:51:54.1 04/09/2012: Get other settings
04:51:54.1 04/09/2012: Desktop set to Hide ICONS and set Background to Black
04:51:54.1 04/09/2012: Set: Find emulator artwork on best match basis
04:51:54.1 04/09/2012: Start work for Form
04:51:54.1 04/09/2012: Getting Original Screen Size
04:51:54.1 04/09/2012: Opening Database Connection
04:51:54.1 04/09/2012: Initializing Component
04:51:54.2 04/09/2012: MAME Path is: G:\Mame32
04:51:54.2 04/09/2012: MAME EXE file is: mame.exe
04:51:54.2 04/09/2012: ROM Path is: G:\Mame32\roms
04:51:54.2 04/09/2012: Catver.ini is located at: G:\-DATA-\- SVN PROJECTS -\- GameEx -\GameEx_Bin\bin\DATA\catver.ini
04:51:54.2 04/09/2012: controls.ini is located at: G:\-DATA-\- SVN PROJECTS -\- GameEx -\GameEx_Bin\bin\DATA\controls.ini
04:51:54.3 04/09/2012: History.dat is located at: G:\-DATA-\- SVN PROJECTS -\- GameEx -\GameEx_Bin\bin\DATA\history.dat
04:51:54.3 04/09/2012: nplayers.ini is located at: G:\-DATA-\- SVN PROJECTS -\- GameEx -\GameEx_Bin\bin\DATA\nplayers.ini
04:51:54.3 04/09/2012: command.dat is located at: G:\-DATA-\- SVN PROJECTS -\- GameEx -\GameEx_Bin\bin\DATA\command.dat
04:51:54.3 04/09/2012: MAMEinfo.dat is located at: G:\-DATA-\- SVN PROJECTS -\- GameEx -\GameEx_Bin\bin\DATA\mameinfo.dat
04:51:54.3 04/09/2012: Loading Controls.ini map file
04:51:54.3 04/09/2012: Snap Path: Not Found
04:51:54.3 04/09/2012: Background Snap Path: Not Found
04:51:54.3 04/09/2012: AVI Snap Path: Not Found
04:51:54.3 04/09/2012: Flyer Path is: G:\Mame32\flyers
04:51:54.3 04/09/2012: Cabinet Path is: G:\Mame32\cabinets
04:51:54.3 04/09/2012: Cabinet 3D Path: Not Found
04:51:54.3 04/09/2012: Title Path is: G:\Mame32 itles
04:51:54.3 04/09/2012: PCB Path: Not Found
04:51:54.3 04/09/2012: Artwork Preview Path: Not Found
04:51:54.3 04/09/2012: Panel Path is: G:\Mame32\cpanel
04:51:54.3 04/09/2012: Manual Path is: G:\Mame32\manuals
04:51:54.3 04/09/2012: Icon Path is: G:\Mame32\icons
04:51:54.3 04/09/2012: Marquee Path is: G:\Mame32\marquees
04:51:54.3 04/09/2012: Applying Language/Text
04:51:54.3 04/09/2012: Text/Language: English
04:51:54.3 04/09/2012: Loading Language/Text
04:51:54.3 04/09/2012: Loading Custom Emulators
04:51:54.3 04/09/2012: Loading Emulator 1: Nintendo N64 (Project 64)
04:51:54.3 04/09/2012: Loading Emulator 2: [Console] Nintendo SNES (ZSNES)
04:51:54.3 04/09/2012: gamebase support enabled.
04:51:54.3 04/09/2012: Using Version 3 Themes Animations
04:51:54.3 04/09/2012: Retrieving resolution setting
04:51:54.3 04/09/2012: Using General Font: Trebuchet MS
04:51:54.4 04/09/2012: Using Title Font: Trebuchet MS
04:51:54.4 04/09/2012: GameEx will try to reduce CPU usage
04:51:54.4 04/09/2012: Initialising Direct3D
04:51:54.4 04/09/2012: Applying GameEx is Loading Image
04:51:54.5 04/09/2012: Creating Surfaces
04:51:54.5 04/09/2012: Creating Primary Surface - Windowed Mode
04:51:54.5 04/09/2012: Creating Back Buffer
04:51:54.5 04/09/2012: Loading graphic Surfaces
04:51:54.5 04/09/2012: Display is running at: 1920x1080 32bit color, 32hz
04:51:54.5 04/09/2012: Adapter: ATI Radeon HD 2600 XT (Microsoft Corporation - WDDM v1.1)
04:51:54.5 04/09/2012: Max texture size: 8192x8192
04:51:54.5 04/09/2012: Available texture memory: -1039MB
04:51:54.5 04/09/2012: Initialising Bass Audio Library
04:51:54.6 04/09/2012: Creating Surfaces Misc and Dialogs
04:51:54.6 04/09/2012: Creating Surfaces Volume
04:51:54.6 04/09/2012: Creating Surfaces Arrows
04:51:54.6 04/09/2012: Creating Surfaces GameEXlogo Text
04:51:54.6 04/09/2012: Creating Surfaces Toolbar
04:51:54.6 04/09/2012: Creating Surfaces Toolbar Controls
04:51:54.6 04/09/2012: Creating Surfaces Backgrounds
04:51:54.6 04/09/2012: Creating Surfaces GameEx Logo
04:51:54.6 04/09/2012: Creating Surface Unselected
04:51:54.6 04/09/2012: Creating Surfaces Snaps
04:51:54.6 04/09/2012: Creating Surfaces Menu and List Bars
04:51:54.7 04/09/2012: Creating Fonts
04:51:54.7 04/09/2012: Creating Game Font
04:51:54.8 04/09/2012: Creating Game Font Faded
04:51:54.8 04/09/2012: Creating Title Font
04:51:54.8 04/09/2012: Restoring Title Font From Cache
04:51:54.8 04/09/2012: Creating Font Black
04:51:54.9 04/09/2012: Creating Font Black Small
04:51:54.9 04/09/2012: Fonts Created Succesfully
04:51:55.1 04/09/2012: Attempting to load game list
04:51:55.2 04/09/2012: MAME CMD options: -nowindow -joy -skip_gameinfo
04:51:55.2 04/09/2012: Initialising DirectInput for Gamepad support
04:51:55.2 04/09/2012: Unable to create a joystick device
04:51:55.2 04/09/2012: Loading Start Page
04:51:55.2 04/09/2012: Initializing MCE Remote
04:51:55.2 04/09/2012: Playing intro sound file
04:51:55.3 04/09/2012: Initialization OK! Starting GameEx!
04:51:55.3 04/09/2012: Testing Main Loop Once: Processing Frame
04:51:55.4 04/09/2012: Testing Main Loop Once: Main Loop ran successfully
04:52:02.0 04/09/2012: Validating: Emulator_2: Snap Path: C:\Assets\Nintendo SNES\Snaps
04:52:02.0 04/09/2012: Warning: Emulator_2: Snap Path Does not exist
04:52:02.0 04/09/2012: Validating: Emulator_2: Control Panel Path: C:\Assets\Nintendo SNES\Controls
04:52:02.0 04/09/2012: Warning: Emulator_2: Control Panel Path Does not exist
04:52:02.0 04/09/2012: Validating: Emulator_2: Database: [Handheld] Nintendo Game Boy Color
04:52:02.0 04/09/2012: Validating: Emulator_2: Title Snap Path: C:\Assets\Nintendo SNES\Titles
04:52:02.0 04/09/2012: Warning: Emulator_2: Title Snap Path Does not exist
04:52:02.0 04/09/2012: Validating: Emulator_2: Box Art Path: C:\Assets\Nintendo SNES\Boxes
04:52:02.0 04/09/2012: Warning: Emulator_2: Box Art Path Does not exist
04:52:02.0 04/09/2012: Validating: Emulator_2: Cart Art Path: C:\Assets\Nintendo SNES\Cartridges
04:52:02.0 04/09/2012: Warning: Emulator_2: Cart Art Path Does not exist
04:52:02.0 04/09/2012: Validating: Emulator_2: Manual Path: C:\Assets\Nintendo SNES\Manuals
04:52:02.0 04/09/2012: Warning: Emulator_2: Manual Path Does not exist
04:52:02.0 04/09/2012: Provider=Microsoft.Jet.OLEDB.4.0; Data source=G:\GB64\Astrocade\Astrocade.mdb
04:52:02.1 04/09/2012: Provider=Microsoft.Jet.OLEDB.4.0; Data source=G:\GB64\GameBase Amiga\GameBase Amiga.mdb
04:52:02.4 04/09/2012: Provider=Microsoft.Jet.OLEDB.4.0; Data source=G:\GB64\GBC_v03\GBC_v03.mdb
04:52:03.3 04/09/2012: Provider=Microsoft.Jet.OLEDB.4.0; Data source=G:\GB64\SpeccyMania\SpeccyMania.mdb
04:52:04.0 04/09/2012: Restoring Emulator from Cache: 2
04:52:04.2 04/09/2012: Restoring Emulator Database From Cache: 2
04:52:16.1 04/09/2012: Restoring Cached ICONS from File
04:53:04.1 04/09/2012: Exiting GameEx!
04:53:04.1 04/09/2012: Disposing all videos
04:53:04.1 04/09/2012: Deleting temporary Karaoke videos
04:53:04.1 04/09/2012: Disposing Image List
04:53:04.1 04/09/2012: Disposing Fonts
04:53:04.1 04/09/2012: Disposing Surfaces
04:53:04.1 04/09/2012: Saving Settings
04:53:04.1 04/09/2012: Shutting down Bass
04:53:04.2 04/09/2012: Disposing Plugins
04:53:04.2 04/09/2012: Closing database connection
04:53:04.2 04/09/2012: Checking for applications to Launch On Exit
04:53:04.2 04/09/2012: Bye
think thats the one you mean....
thanks for helping me out
Hmm, this looks OK to me...
Can you try and run it with GameBase disabled and see if it runs? If you are getting an error window before the crash can you post a snapshot of it?
That's definitely the log file. According to this log file, GameEx was running for a about 1 minute and 10 secs. It also doesn't show any glaring errors one might expect form an application crash. What was happening during the time that GameEx was running here? Did it look like GameEx was loading? Did the application seem to hang up somewhere? Maybe you wouldn't mind providing a bit more details related the the behavior you're observing?
Tried with gamebase disabled same result.
I click on the icon to launch the program nothing actually shows on screen just quickly tosses a Microsoft error reporting window up and that is it.
and no error window at all just m$ error reporting junk. no actual gameex error is produced or anything for that matter.
going to install on another computer maybe something with the install I dont know but worth a shot.
I gotta ask, since I’ve been wondering. This line of your log is pretty odd:
The line itself isn’t odd, it’s in all GameEx logs. The directory is what seems to be pretty odd. Have you specified the above directory as the location of catver.ini in your GameEx settings? Have you installed GameEx to a custom location? You’re not running GameEx though WINE or anything are you? And finally you’re not doing anything strange like running a test build of GameEx are you?
Sorry about the deluge of questions! That directory thing has been bugging me since I first saw it last night. ;)
the thing is its under C:\ everything is installed under C:\ and when checking values through the program they are C:\ as well so not sure where G:\ is getting in there and is there a file I can edit that instead of through the program or setup file?
Here are the default locations for the specific files referenced in your log:
CatverLocation=\DATA\catver.ini
CPPATH=\DATA\controls.ini
HistoryLocation=\DATA\history.dat
nplayerslocation=\DATA\nplayers.ini
CommandLocation=\DATA\command.dat
InfoLocation=\DATA\mameinfo.dat
You can double check these settings in your GameEx.ini located in the following directory by default:
C:\GameEx\CONFIG\
I would search for the file names above (catver.ini, controls.ini, etc), and double check where they are pointing to. If they are pointed at a weird location (they are), you can change the locations to those I’ve listed above. Back up your GameEx.ini before making any changes! (I typically copy it and rename the copy to GameEx.BAK, but that’s just me). This may or may not be contributing to your error, but either way it’s certainly not helping.
I’m also going to notify Tom about this thread. The G:\ directory listed in your log looks suspiciously like a Subversion build directory, and if you’re not attempting to do your own build of GameEx (pretty sure it would be impossible), then those locations may have slipped in inadvertently during Tom's build process.
well G:\ would be pointing at my DVD drive
and all files are where they are suppose to be and checked to see if everything was was pointing where it should seems everything looks good on my end
log file from other PC:
Okie dokie. I have a suspicion that this may be something for Tom to look at. I notified him about this thread via PM. At this point we may just need to sit tight and wait for additional input from him.
Edit:
It’s a bit hard to say from the partial log above, but yeah, the provider listed for the GameBase databases also looks to be a bit suspect. I’m relatively sure Tom will have a magical solution for this issue. ;)
I would make sure that GameEx is set under the gameex.exe properties to run as administrator and that all .net framework updates have been made. Vista can be cranky about admin rights.
Not according to this...
Are you running this within a virtual machine?
Can anyone else running XP pull a copy of their log.txt and see what OS is being reported? Thanks!
