After so many computer issues today I just decided to do a clean fresh GameEx install of 12.79 and when I try to config Daphne it won't let me configure all the games only the first emulator within Daphne? Anyone else having the same issue at all? I did manage to configure it manually by editing the config file by hand.
I do ... just seeing if it's just my system or if it's an issue with the latest GameEx Setup Wizard. I got Daphne running but within the setup wizard you can't make many changes to Daphne.
I just never noticed before as I already had Daphne configured correctly, but now all my directories have changed and I needed to modify them so I manually did it and got it working.
I have attached a screenshot of it. When I click on the green arrow it skips to the verify setup screen.
You add a new game by clicking on the pull-down menu of Select Daphne Game. It will show 2,3,4 .etc
Select 2 for example, then fill in the fields for the new game.
Good one Bigby. I was just about to point that out. :)
That green arrow is for jumping to the next category, everything is single page now.
Thanks guys never thought about that as the last time I even used to configure Daphne was way back when before the setup wizard (Advanced configuration) believe it or not.
I haven't even bothered trying to set up Daphne because it looks hard! And I'm lazy... Lol!
I thought the same thing until I did a search on youtube and found a video of someone explaining on how to set it up using a frontend.
Framefiles, god what a head ache Daphne can be.
Edited by Draco1962
This thread is marked as Resolved and is now closed. If the problem re-occurs, please start a new thread.
