Tom,
Your program is great I have an old Bas arcade machine which I have converted in to a mame and jukebox using gameex. Was wondering if it is possible to make it compatible with a spotify subscription or similar.
Chris
You should be able to run Spotify as an External Application through GameEx without much issue. Others have done so successfully with Pandora or Slacker so shouldn't be much different.
Edited by Draco1962
Your thread was moved as it was in the Games Database forum, which is not correct for the topic.
