Hi guys, just looking for a bit of help with a problem.
When I try and launch an emulator, GameEx fades to black, however the emulator does not load at all. GameEx is still running, as you can move the mouse and hear the buttons coming in and out of focus (pressing Esc exits GameEx).
This happens with all my emulators, and they all have Show Desktop enabled.
I looked through the forum but could not find a solution.
Hoping to hear words of wisdom from somebody
Hiya Sax - you may need to give us some information first. Please provide us with a copy of your gameex.ini and log.txt files. They are located within \gameex\config\ and gameex\log\ paths respectively.
Thanks!
Can you run an emulator and then post the log?
Um... no its not. :)
An important distinction to make is that your log will be overwritten every time you run GameEx. Typically when you're experiencing a problem like this you'll want to start GameEx, reproduce the problem, and immediately post your log before running GameEx again.
We'll get you set right, but we need the log to reflect the error before we can determine what the issue is. :)
I guarantee that it is. If I delete the log file it does not regenerate. I'm also confused as to how I installed the software 2 days ago, but the log was apparently last modified 3 weeks ago.
11:13:05.7 29/07/2012: Opening Configuration File
11:13:05.7 29/07/2012: GameEx: Version 12.78: Starting Log
11:13:05.7 29/07/2012: Operating System Platform: Win32NT
11:13:05.7 29/07/2012: Operating System Name: Windows 7
11:13:05.7 29/07/2012: Operating System Version: 6.1.7601
11:13:05.7 29/07/2012: Aero running
11:13:05.7 29/07/2012: Running under Remote Desktop
11:13:05.7 29/07/2012: Initializing Vista/Windows 7 volume control
11:13:05.7 29/07/2012: Getting CPU and RAM info
11:13:05.7 29/07/2012: Intel® Core™ i7-3820 CPU @ 3.60GHz, 16308MB
11:13:05.7 29/07/2012: 3.6Ghz - 8 Cores or CPU's
11:13:05.7 29/07/2012: Running Randomize()
11:13:05.8 29/07/2012: Loading PlugIns
11:13:05.8 29/07/2012: Checking for applications to Launch On Startup
11:13:05.8 29/07/2012: Running Misc startup tasks
11:13:05.8 29/07/2012: Setting Menu types
11:13:05.8 29/07/2012: Getting Configuration Values
11:13:05.8 29/07/2012: Using Theme: Default - Media Center
11:13:05.8 29/07/2012: Checking for alternate Image Directory for Theme: Default - Media Center
11:13:05.8 29/07/2012: Using Images from theme: Default - Media Center V1\MEDIA\
11:13:05.8 29/07/2012: Initialising Video/MNG DLL's
11:13:05.8 29/07/2012: GameEx will check for media insertion (may affect performance)
11:13:05.8 29/07/2012: Is Media Center running?
11:13:05.8 29/07/2012: Checking/Creating LCD Registry values
11:13:05.8 29/07/2012: Check Media Center Exit/Start Mode
11:13:05.8 29/07/2012: Media Center Mode 2
11:13:05.8 29/07/2012: Video previews on. Warning: Only recommended on modern systems
11:13:05.8 29/07/2012: Snap Delay set to: 2
11:13:05.8 29/07/2012: Get other settings
11:13:05.8 29/07/2012: Desktop set to Hide ICONS and set Background to Black
11:13:05.8 29/07/2012: Set: Find emulator artwork on best match basis
11:13:05.8 29/07/2012: Start work for Form
11:13:05.8 29/07/2012: Getting Original Screen Size
11:13:05.8 29/07/2012: Opening Database Connection
11:13:05.8 29/07/2012: Initializing Component
11:13:05.9 29/07/2012: MAME Path is: G:\Mame32
11:13:05.9 29/07/2012: MAME EXE file is: mame.exe
11:13:05.9 29/07/2012: ROM Path is: G:\Mame32\roms
11:13:05.9 29/07/2012: Catver.ini is located at: G:\-DATA-\- SVN PROJECTS -\- GameEx -\Gameex_Core\bin\DATA\catver.ini
11:13:05.9 29/07/2012: controls.ini is located at: G:\-DATA-\- SVN PROJECTS -\- GameEx -\Gameex_Core\bin\DATA\controls.ini
11:13:05.9 29/07/2012: History.dat is located at: G:\-DATA-\- SVN PROJECTS -\- GameEx -\Gameex_Core\bin\DATA\history.dat
11:13:05.9 29/07/2012: nplayers.ini is located at: G:\-DATA-\- SVN PROJECTS -\- GameEx -\Gameex_Core\bin\DATA\nplayers.ini
11:13:05.9 29/07/2012: command.dat is located at: G:\-DATA-\- SVN PROJECTS -\- GameEx -\Gameex_Core\bin\DATA\command.dat
11:13:05.9 29/07/2012: MAMEinfo.dat is located at: G:\-DATA-\- SVN PROJECTS -\- GameEx -\Gameex_Core\bin\DATA\mameinfo.dat
11:13:05.9 29/07/2012: Loading Controls.ini map file
11:13:05.9 29/07/2012: Snap Path: Not Found
11:13:05.9 29/07/2012: Background Snap Path: Not Found
11:13:05.9 29/07/2012: AVI Snap Path: Not Found
11:13:05.9 29/07/2012: Flyer Path is: G:\Mame32\flyers
11:13:05.9 29/07/2012: Cabinet Path is: G:\Mame32\cabinets
11:13:05.9 29/07/2012: Cabinet 3D Path: Not Found
11:13:05.9 29/07/2012: Title Path is: G:\Mame32\titles
11:13:05.9 29/07/2012: PCB Path: Not Found
11:13:05.9 29/07/2012: Artwork Preview Path: Not Found
11:13:05.9 29/07/2012: Panel Path is: G:\Mame32\cpanel
11:13:05.9 29/07/2012: Manual Path is: G:\Mame32\manuals
11:13:05.9 29/07/2012: Icon Path is: G:\Mame32\icons
11:13:05.9 29/07/2012: Marquee Path is: G:\Mame32\marquees
11:13:05.9 29/07/2012: Applying Language/Text
11:13:05.9 29/07/2012: Text/Language: English
11:13:05.9 29/07/2012: Loading Language/Text
11:13:06.0 29/07/2012: Loading Custom Emulators
11:13:06.0 29/07/2012: Loading Emulator 1: Nintendo N64 (Project 64)
11:13:06.0 29/07/2012: Loading Emulator 2: [Console] Nintendo SNES (ZSNES)
11:13:06.0 29/07/2012: gamebase support enabled.
11:13:06.0 29/07/2012: Using Version 3 Themes Animations
11:13:06.0 29/07/2012: Retrieving resolution setting
11:13:06.0 29/07/2012: Using General Font: Trebuchet MS
11:13:06.0 29/07/2012: Using Title Font: Trebuchet MS
11:13:06.0 29/07/2012: GameEx will try to reduce CPU usage
11:13:06.0 29/07/2012: Initialising Direct3D
11:13:06.1 29/07/2012: Applying GameEx is Loading Image
11:13:06.1 29/07/2012: Creating Surfaces
11:13:06.2 29/07/2012: Creating Primary Surface - Windowed Mode
11:13:06.2 29/07/2012: Creating Back Buffer
11:13:06.2 29/07/2012: Loading graphic Surfaces
11:13:06.2 29/07/2012: Display is running at: 1920x1080 32bit color, 60hz
11:13:06.2 29/07/2012: Adapter: RDPDD Chained DD
11:13:06.2 29/07/2012: Max texture size: 8192x8192
11:13:06.2 29/07/2012: Available texture memory: -1039MB
11:13:06.2 29/07/2012: Initialising Bass Audio Library
11:13:06.2 29/07/2012: Creating Surfaces Misc and Dialogs
11:13:06.3 29/07/2012: Creating Surfaces Volume
11:13:06.3 29/07/2012: Creating Surfaces Arrows
11:13:06.3 29/07/2012: Creating Surfaces GameEXlogo Text
11:13:06.3 29/07/2012: Creating Surfaces Toolbar
11:13:06.3 29/07/2012: Creating Surfaces Toolbar Controls
11:13:06.3 29/07/2012: Creating Surfaces Backgrounds
11:13:06.3 29/07/2012: Creating Surfaces GameEx Logo
11:13:06.3 29/07/2012: Creating Surface Unselected
11:13:06.3 29/07/2012: Creating Surfaces Snaps
11:13:06.3 29/07/2012: Creating Surfaces Menu and List Bars
11:13:06.4 29/07/2012: Creating Fonts
11:13:06.4 29/07/2012: Creating Game Font
11:13:06.5 29/07/2012: Creating Game Font Faded
11:13:06.5 29/07/2012: Creating Title Font
11:13:06.5 29/07/2012: Restoring Title Font From Cache
11:13:06.6 29/07/2012: Creating Font Black
11:13:06.6 29/07/2012: Creating Font Black Small
11:13:06.7 29/07/2012: Fonts Created Succesfully
11:13:06.8 29/07/2012: Attempting to load game list
11:13:06.9 29/07/2012: MAME CMD options: -nowindow -joy -skip_gameinfo
11:13:06.9 29/07/2012: Initialising DirectInput for Gamepad support
11:13:06.9 29/07/2012: Unable to create a joystick device
11:13:06.9 29/07/2012: Loading Start Page
11:13:06.9 29/07/2012: Initializing MCE Remote
11:13:06.9 29/07/2012: Playing intro sound file
11:13:07.0 29/07/2012: Initialization OK! Starting GameEx!
11:13:07.0 29/07/2012: Testing Main Loop Once: Processing Frame
11:13:07.1 29/07/2012: Testing Main Loop Once: Main Loop ran successfully
11:13:11.2 29/07/2012: Validating: Emulator_1: Database: [Console] Nintendo N64
11:13:11.2 29/07/2012: Validating: Emulator_2: Snap Path: C:\Assets\Nintendo SNES\Snaps
11:13:11.2 29/07/2012: Validating: Emulator_2: Control Panel Path: C:\Assets\Nintendo SNES\Controls
11:13:11.2 29/07/2012: Validating: Emulator_2: Database: [Handheld] Nintendo Game Boy Color
11:13:11.2 29/07/2012: Validating: Emulator_2: Title Snap Path: C:\Assets\Nintendo SNES\Titles
11:13:11.2 29/07/2012: Validating: Emulator_2: Box Art Path: C:\Assets\Nintendo SNES\Boxes
11:13:11.2 29/07/2012: Validating: Emulator_2: Cart Art Path: C:\Assets\Nintendo SNES\Cartridges
11:13:11.2 29/07/2012: Validating: Emulator_2: Manual Path: C:\Assets\Nintendo SNES\Manuals
11:13:11.2 29/07/2012: Provider=Microsoft.Jet.OLEDB.4.0; Data source=G:\GB64\Astrocade\Astrocade.mdb
11:13:11.2 29/07/2012: Provider=Microsoft.Jet.OLEDB.4.0; Data source=G:\GB64\GameBase Amiga\GameBase Amiga.mdb
11:13:11.5 29/07/2012: Provider=Microsoft.Jet.OLEDB.4.0; Data source=G:\GB64\GBC_v03\GBC_v03.mdb
11:13:12.5 29/07/2012: Provider=Microsoft.Jet.OLEDB.4.0; Data source=G:\GB64\SpeccyMania\SpeccyMania.mdb
11:13:13.1 29/07/2012: Restoring Emulator from Cache: 1
11:13:13.2 29/07/2012: Restoring Emulator Database From Cache: 1
11:13:13.3 29/07/2012: Restoring Emulator from Cache: 2
11:13:13.4 29/07/2012: Restoring Emulator Database From Cache: 2
11:13:33.0 29/07/2012: Exiting GameEx!
11:13:33.0 29/07/2012: Disposing all videos
11:13:33.0 29/07/2012: Deleting temporary Karaoke videos
11:13:33.0 29/07/2012: Disposing Image List
11:13:33.0 29/07/2012: Disposing Fonts
11:13:33.0 29/07/2012: Disposing Surfaces
11:13:33.0 29/07/2012: Saving Settings
11:13:33.0 29/07/2012: Shutting down Bass
11:13:33.0 29/07/2012: Disposing Plugins
11:13:33.0 29/07/2012: Closing database connection
11:13:33.0 29/07/2012: Checking for applications to Launch On Exit
11:13:33.0 29/07/2012: Media Center was not open when starting GameEx, so not launching
11:13:33.0 29/07/2012: Bye
Even after uninstalling the software and trying to run an emulator after reinstall, the log does not reflect this (as shown above).
As I finished writing this, I had a thought on it - I feel like an idiot for not realising sooner. Apparently all I had to do was change my security settings to run GameEx as an admin! :blink: Thanks everybody for helping me guide my thought process. It was such a simple error, I feel bad for wasting people's time. Haha
Don't feel bad. It happens. :)
Glad you got it sorted. :)
Edited by Draco1962
This thread is marked as Resolved and is now closed. If the problem re-occurs, please start a new thread.
