I finally have artwork for my CP (yeah!) and I would like to use the artwork as the CP background for CPWizard. When I try to select that PNG file as the background in the Edit --> Properties menu, nothing shows. Does the pic have to have a certain format or certain attributes to be used for that?
Hello
Had to edit my first answer lol...too early in the morning here and didn't read your question all the way through :P.
The format I use for my custom image of my control panel is .jpg, and it works fine that way. Also, (in case you run into this same issue), I had to scale my image down a little using basic microsoft paint in order for it to fit properly in CPWizard.
Hope this helps any! :)
The information was helpful. TY sir. :) I also found that I needed to have "Bak" in the name of the file in order for the image of my CP to show. So I actually replaced the file Bak.png that comes with CPWizard with the image of my CP. Everything is good to go now...
Edited by Draco1962
This thread is marked as Resolved and is now closed. If the problem re-occurs, please start a new thread.
