Hello all
I have this log file when i try to start Gameex :
02:12:46.4  11/02/2006:  GameEx: Version 5.55: Starting Log
02:12:46.4  11/02/2006:  Operating System Platform: Win32NT
02:12:46.4  11/02/2006:  Operating System Name: Windows 2000
02:12:46.4  11/02/2006:  Operating System Version: 5.0.2195
02:12:46.4  11/02/2006:  Checking for versions of .net Framework installed
02:12:46.4  11/02/2006:  .net Framework 1.1 Installed
02:12:46.4  11/02/2006:  .net Framework 2.0 Installed
02:12:46.4  11/02/2006:  Checking Registration
02:12:46.4  11/02/2006:  Running Randomize()
02:12:46.4  11/02/2006:  Initialising Video/MNG DLL's
02:12:46.4  11/02/2006:  Running Misc startup tasks
02:12:46.4  11/02/2006:  Setting Menu types
02:12:46.4  11/02/2006:  Opening Configuration File
02:12:46.4  11/02/2006:  Getting Configuration Values
02:12:46.4  11/02/2006:  Using Theme: Default - Default
02:12:46.4  11/02/2006:  Checking for alternate Image Directory for Theme: Default - Default
02:12:46.5  11/02/2006:  Text/Language: French
02:12:46.5  11/02/2006:  Applying Language/Text
02:12:46.5  11/02/2006:  Creating Scancodes.txt (List of DirectInput scan codes)
02:12:46.5  11/02/2006:  Snap Delay set to: 1
02:12:46.5  11/02/2006:  Is Media Center running?
02:12:46.5  11/02/2006:  Check Media Center Exit/Start Mode
02:12:46.5  11/02/2006:  Media Center Mode 2
02:12:46.5  11/02/2006:  Checking for applications to Launch On Startup
02:12:46.5  11/02/2006:  Get other settings
02:12:46.5  11/02/2006:  Using 2D Animations
02:12:46.5  11/02/2006:  Set: Find emulator artwork on best match basis
02:12:46.6  11/02/2006:  Launching HideOS.exe
02:12:46.6  11/02/2006:  Hiding Taskbar
02:12:46.6  11/02/2006:  Start work for Form
02:12:46.6  11/02/2006:  Getting Original Screen Size
02:12:46.6  11/02/2006:  Loading ICON
02:12:46.7  11/02/2006:  Initializing Component
02:12:46.7  11/02/2006:  Initialising Bass Audio Library
02:12:47.6  11/02/2006:  Loading default loading screen
02:12:47.6  11/02/2006:  The currency separator information specified in the NumberFormatInfo is ambiguous for parsing.
02:12:50.0  11/02/2006:  ERRORS DETECTED: EXITING
My config :
-AMD64 2800+
-Asus Motherboard
- Ati 9600 pro 256Mb
-1,5gb DDR400
- Azerty keyboard (Belgium)
-Dvd writer
-Cd writer
I have framework 1.1 and the last directX.
COULD YOU HELP ME PLEASE :(
thanks a lot
Cédric
Hello all
My config :
-AMD64 2800+
-Asus Motherboard
-1,5gb DDR400
-Dvd writer
-Cd writer
thanks a lot
Cédric
Not heard of that error before, and I am guessing this is a new install, so I suggest you uninstall GameEx and Delete the directory from \program files
then download and install again.
Hello all
My config :
-AMD64 2800+
-Asus Motherboard
-1,5gb DDR400
-Dvd writer
-Cd writer
thanks a lot
Cédric
might be a long shot, but check your regional settings under windows control panel. Make sure your currency format doesn't look screwy (not sure why gameex would use this??). Anyway, I saw a similar error some time back in a program i was writing, and turned out the currency format was screwed up on the pc i was using.
Thanks All
Problem SOLVED!!
I have changed my regional settings to English (United states) (French (Belgium) in the past).
Gameex work great.
A little modification of the soft can probably solve it!
Thanks a lot
Thanks All
Problem SOLVED!!
Gameex work great.
Thanks a lot
It runs fine for me under French (Belgium) and as far as I know I have quite a few other non english users, I think GameEx even works on Chinese systems and other systems like this so not really sure what the issue is.
It must have been some customizations to the regional settings (rather than just language) that caused it, and if you can pinpoint it down it would be helpful. GameEx really should not be using any special regional stuff such as currency, the error seems a really odd one to me.
Cheers.
Tom
