Hi again,
i want to use GameEx not only for playing emulated games but also as a Video Entertainment System.
I have some merged .vobs ripped from the original DVD on my harddrive.
This files played well in fullscreen (great sound, great picture) but there is no sound available at the preview.
My xvid/divx files on the other hand works well, so i think there must be a problem with the .vob?
Any suggestions?
Sven
Hi svenk75 - can you provide a copy of your gameex.ini and your log.txt files? The gameex.ini is located under the \gameex\config path and log.txt under the \gameex\log path. It is possible you may be dealing with a codec issue so knowing what codecs you have installed and OS may be helpful as well.
18:32:34.5  26.07.2012:  Opening Configuration File
18:32:34.5 26.07.2012: GameEx: Version 12.78: Starting Log
18:32:34.5 26.07.2012: Operating System Platform: Win32NT
18:32:34.5 26.07.2012: Operating System Name: Windows 7
18:32:34.5 26.07.2012: Operating System Version: 6.1.7601
18:32:34.5 26.07.2012: Aero running
18:32:34.5 26.07.2012: Initializing Vista/Windows 7 volume control
18:32:34.5 26.07.2012: Getting CPU and RAM info
18:32:34.5 26.07.2012: AMD Phenom(tm) II X4 940 Processor, 8190MB
18:32:34.5 26.07.2012: 3Ghz - 4 Cores or CPU's
18:32:34.5 26.07.2012: Running Randomize()
18:32:34.5 26.07.2012: Loading PlugIns
18:32:34.5 26.07.2012: Checking for applications to Launch On Startup
18:32:34.5 26.07.2012: Running Misc startup tasks
18:32:34.5 26.07.2012: Setting Menu types
18:32:34.5 26.07.2012: Getting Configuration Values
18:32:34.5 26.07.2012: Using Theme: Default - Brokeh 1024x768
18:32:34.5 26.07.2012: Checking for alternate Image Directory for Theme: Default - Brokeh 1024x768
18:32:34.5 26.07.2012: Launching HideOS.exe
18:32:34.5 26.07.2012: Initialising Video/MNG DLL's
18:32:34.5 26.07.2012: GameEx will check for media insertion (may affect performance)
18:32:34.5 26.07.2012: Hiding Taskbar
18:32:34.5 26.07.2012: Is Media Center running?
18:32:34.5 26.07.2012: Checking/Creating LCD Registry values
18:32:34.5 26.07.2012: Check Media Center Exit/Start Mode
18:32:34.5 26.07.2012: Media Center Mode 2
18:32:34.5 26.07.2012: Video previews on. Warning: Only recommended on modern systems
18:32:34.5 26.07.2012: Custom Game Device Input enabled: Getting custom codes
18:32:34.5 26.07.2012: Snap Delay set to: 2
18:32:34.5 26.07.2012: Get other settings
18:32:34.5 26.07.2012: Desktop set to Hide ICONS and set Background to Black
18:32:34.5 26.07.2012: Set: Find emulator artwork on best match basis
18:32:34.5 26.07.2012: Start work for Form
18:32:34.5 26.07.2012: Getting Original Screen Size
18:32:34.5 26.07.2012: Opening Database Connection
18:32:34.6 26.07.2012: Initializing Component
18:32:34.7 26.07.2012: MAME Path is: D:\GameEx
18:32:34.7 26.07.2012: MAME EXE file is: Mame Mapping Magician.exe
18:32:34.7 26.07.2012: ROM Path is: D:\GameEx\DEMO
18:32:34.7 26.07.2012: Catver.ini is located at: D:\GameEx\DATA\catver.ini
18:32:34.7 26.07.2012: controls.ini is located at: D:\GameEx\DATA\controls.ini
18:32:34.7 26.07.2012: History.dat is located at: D:\GameEx\DATA\history.dat
18:32:34.7 26.07.2012: nplayers.ini is located at: D:\GameEx\DATA\nplayers.ini
18:32:34.7 26.07.2012: command.dat is located at: D:\GameEx\DATA\command.dat
18:32:34.7 26.07.2012: MAMEinfo.dat is located at: D:\GameEx\DATA\mameinfo.dat
18:32:34.8 26.07.2012: Loading Controls.ini map file
18:32:34.8 26.07.2012: Snap Path is: D:\GameEx\DEMO\MAME\snaps
18:32:34.8 26.07.2012: Background Snap Path: Not Found
18:32:34.8 26.07.2012: AVI Snap Path is: D:\GameEx\DEMO\MAME\video
18:32:34.8 26.07.2012: Flyer Path is: D:\GameEx\DEMO\MAME\flyers
18:32:34.8 26.07.2012: Cabinet Path is: D:\GameEx\DEMO\MAME\cabinets
18:32:34.8 26.07.2012: Cabinet 3D Path is: D:\GameEx\DEMO\MAME\cabinets3d
18:32:34.8 26.07.2012: Title Path is: D:\GameEx\DEMO\MAME itles
18:32:34.8 26.07.2012: PCB Path: Not Found
18:32:34.8 26.07.2012: Artwork Preview Path: Not Found
18:32:34.8 26.07.2012: Panel Path is: D:\GameEx\DEMO\MAME\cpanel
18:32:34.8 26.07.2012: Manual Path is: D:\GameEx\DEMO\MAME\manual
18:32:34.8 26.07.2012: Icon Path is: D:\GameEx\DEMO\MAME\icons
18:32:34.8 26.07.2012: Marquee Path is: D:\GameEx\DEMO\MAME\marquees
18:32:34.8 26.07.2012: Applying Language/Text
18:32:34.8 26.07.2012: Text/Language: English
18:32:34.8 26.07.2012: Loading Language/Text
18:32:34.8 26.07.2012: Loading Custom Emulators
18:32:34.8 26.07.2012: Loading Emulator 1: [Arcade] Arcade (MAME)
18:32:34.8 26.07.2012: Loading Emulator 2: Commodore Amiga
18:32:34.8 26.07.2012: Loading Emulator 3: Microsoft MSX
18:32:34.8 26.07.2012: Loading Emulator 4: Nintendo N64
18:32:34.8 26.07.2012: Loading Emulator 5: Nintendo NES
18:32:34.8 26.07.2012: Loading Emulator 6: Nintendo SNES
18:32:34.8 26.07.2012: Loading Emulator 7: Nintendo Wii
18:32:34.8 26.07.2012: Using Version 3 Themes Animations
18:32:34.8 26.07.2012: Retrieving resolution setting
18:32:34.8 26.07.2012: Using General Font: Trebuchet MS
18:32:34.8 26.07.2012: Using Title Font: Trebuchet MS
18:32:34.8 26.07.2012: GameEx will try to reduce CPU usage
18:32:34.9 26.07.2012: Initialising Direct3D
18:32:35.0 26.07.2012: Applying GameEx is Loading Image
18:32:35.0 26.07.2012: Setting Resolution to 1680x1050 32 bit color
18:32:35.0 26.07.2012: Creating Surfaces
18:32:35.3 26.07.2012: Creating Primary Surface - Full Screen Mode
18:32:35.3 26.07.2012: Creating Back Buffer
18:32:35.3 26.07.2012: Version 2 Theme being used. Loading.
18:32:35.3 26.07.2012: Loading Button Data
18:32:35.3 26.07.2012: Loading Font Data
18:32:35.3 26.07.2012: Loading Layout Data
18:32:35.3 26.07.2012: Loading Taskbar Data
18:32:35.3 26.07.2012: Loading graphic Surfaces
18:32:35.3 26.07.2012: Display is running at: 1680x1050 32bit color, 59hz
18:32:35.3 26.07.2012: Adapter: ATI Radeon HD 4800 Series
18:32:35.3 26.07.2012: Max texture size: 8192x8192
18:32:35.3 26.07.2012: Available texture memory: 736MB
18:32:35.4 26.07.2012: Initialising Bass Audio Library
18:32:35.4 26.07.2012: Creating Surfaces Misc and Dialogs
18:32:35.5 26.07.2012: Creating Surfaces Volume
18:32:35.5 26.07.2012: Creating Surfaces Arrows
18:32:35.5 26.07.2012: Creating Surfaces GameEXlogo Text
18:32:35.5 26.07.2012: Creating Surfaces Toolbar
18:32:35.5 26.07.2012: Creating Surfaces Toolbar Controls
18:32:35.5 26.07.2012: Creating Surfaces Backgrounds
18:32:35.5 26.07.2012: Creating Surfaces GameEx Logo
18:32:35.6 26.07.2012: Creating Surface Unselected
18:32:35.6 26.07.2012: Creating Surfaces Snaps
18:32:35.6 26.07.2012: Creating Surfaces Menu and List Bars
18:32:35.6 26.07.2012: Creating Fonts
18:32:35.6 26.07.2012: Creating Game Font
18:32:35.7 26.07.2012: Creating Game Font Faded
18:32:35.8 26.07.2012: Creating Title Font
18:32:35.8 26.07.2012: Restoring Title Font From Cache
18:32:36.1 26.07.2012: Creating Font Black
18:32:36.1 26.07.2012: Creating Font Black Small
18:32:36.2 26.07.2012: Fonts Created Succesfully
18:32:36.2 26.07.2012: 7MB Video Memory Used
18:32:36.6 26.07.2012: Attempting to load game list
18:32:36.6 26.07.2012: Running: Mame Mapping Magician.exe -help
18:32:36.7 26.07.2012: Running: D: D:\GameEx\Mame Mapping Magician.exe -help > D:\GameEx\help.txt
18:32:36.7 26.07.2012: 32 bit MAME version detected on 64 bit windows
18:32:36.7 26.07.2012: MAME CMD options: -nowindow -joy -skip_gameinfo
18:32:36.7 26.07.2012: Initialising DirectInput for Gamepad support
18:32:36.8 26.07.2012: Using Device MotioninJoy Virtual Game Controller
18:32:36.8 26.07.2012: Loading Start Page
18:32:36.8 26.07.2012: Initializing MCE Remote
18:32:36.8 26.07.2012: Initialization OK! Starting GameEx!
18:32:36.8 26.07.2012: Testing Main Loop Once: Processing Frame
18:32:37.1 26.07.2012: Testing Main Loop Once: Main Loop ran successfully
18:32:45.9 26.07.2012: Validating: Emulator_1: Snap Path: D:\Assets\MAME\Snaps
18:32:45.9 26.07.2012: Validating: Emulator_1: Control Panel Path: D:\Assets\MAME\Controls
18:32:45.9 26.07.2012: Validating: Emulator_1: Title Snap Path: D:\Assets\MAME\Titles
18:32:45.9 26.07.2012: Validating: Emulator_1: Box Art Path: D:\Assets\MAME\Boxes
18:32:45.9 26.07.2012: Validating: Emulator_1: Cart Art Path: D:\Assets\MAME\Cartridges
18:32:45.9 26.07.2012: Validating: Emulator_1: Manual Path: D:\Assets\MAME\Manuals
18:32:45.9 26.07.2012: Warning: Emulator_1: MAPFile Does Not Exist
18:32:45.9 26.07.2012: Validating: Emulator_2: Snap Path: D:\Assets\Commodore Amiga\Snaps
18:32:45.9 26.07.2012: Validating: Emulator_2: Control Panel Path: D:\Assets\Commodore Amiga\Controls
18:32:45.9 26.07.2012: Validating: Emulator_2: Database: [PC] Commodore Amiga
18:32:45.9 26.07.2012: Validating: Emulator_2: Title Snap Path: D:\Assets\Commodore Amiga\Titles
18:32:45.9 26.07.2012: Validating: Emulator_2: Box Art Path: D:\Assets\Commodore Amiga\Boxes
18:32:45.9 26.07.2012: Validating: Emulator_2: Cart Art Path: D:\Assets\Commodore Amiga\Cartridges
18:32:45.9 26.07.2012: Validating: Emulator_2: Manual Path: D:\Assets\Commodore Amiga\Manuals
18:32:45.9 26.07.2012: Validating: Emulator_3: Snap Path: D:\Assets\Microsoft MSX\Snaps
18:32:45.9 26.07.2012: Validating: Emulator_3: Control Panel Path: D:\Assets\Microsoft MSX\Controls
18:32:45.9 26.07.2012: Validating: Emulator_3: Database: [PC] Microsoft MSX
18:32:45.9 26.07.2012: Validating: Emulator_3: Title Snap Path: D:\Assets\Microsoft MSX\Titles
18:32:45.9 26.07.2012: Validating: Emulator_3: Box Art Path: D:\Assets\Microsoft MSX\Boxes
18:32:45.9 26.07.2012: Validating: Emulator_3: Cart Art Path: D:\Assets\Microsoft MSX\Cartridges
18:32:45.9 26.07.2012: Validating: Emulator_3: Manual Path: D:\Assets\Microsoft MSX\Manuals
18:32:45.9 26.07.2012: Validating: Emulator_4: Snap Path: D:\Assets\Nintendo N64\Snaps
18:32:45.9 26.07.2012: Validating: Emulator_4: Control Panel Path: D:\Assets\Nintendo N64\Controls
18:32:45.9 26.07.2012: Validating: Emulator_4: Database: [Console] Nintendo N64
18:32:45.9 26.07.2012: Validating: Emulator_4: Title Snap Path: D:\Assets\Nintendo N64\Titles
18:32:45.9 26.07.2012: Validating: Emulator_4: Box Art Path: D:\Assets\Nintendo N64\Boxes
18:32:45.9 26.07.2012: Validating: Emulator_4: Cart Art Path: D:\Assets\Nintendo N64\Cartridges
18:32:45.9 26.07.2012: Validating: Emulator_4: Manual Path: D:\Assets\Nintendo N64\Manuals
18:32:45.9 26.07.2012: Validating: Emulator_5: Snap Path: D:\Assets\Nintendo NES\Snaps
18:32:45.9 26.07.2012: Validating: Emulator_5: Control Panel Path: D:\Assets\Nintendo NES\Controls
18:32:45.9 26.07.2012: Validating: Emulator_5: Database: [Console] Nintendo NES
18:32:45.9 26.07.2012: Validating: Emulator_5: Title Snap Path: D:\Assets\Nintendo NES\Titles
18:32:45.9 26.07.2012: Validating: Emulator_5: Box Art Path: D:\Assets\Nintendo NES\Boxes
18:32:45.9 26.07.2012: Validating: Emulator_5: Cart Art Path: D:\Assets\Nintendo NES\Cartridges
18:32:45.9 26.07.2012: Validating: Emulator_5: Manual Path: D:\Assets\Nintendo NES\Manuals
18:32:45.9 26.07.2012: Validating: Emulator_6: Snap Path: D:\Assets\Nintendo SNES\Snaps
18:32:45.9 26.07.2012: Validating: Emulator_6: Control Panel Path: D:\Assets\Nintendo SNES\Controls
18:32:45.9 26.07.2012: Validating: Emulator_6: Database: [Console] Nintendo SNES
18:32:45.9 26.07.2012: Validating: Emulator_6: Title Snap Path: D:\Assets\Nintendo SNES\Titles
18:32:45.9 26.07.2012: Validating: Emulator_6: Box Art Path: D:\Assets\Nintendo SNES\Boxes
18:32:45.9 26.07.2012: Validating: Emulator_6: Cart Art Path: D:\Assets\Nintendo SNES\Cartridges
18:32:45.9 26.07.2012: Validating: Emulator_6: Manual Path: D:\Assets\Nintendo SNES\Manuals
18:32:45.9 26.07.2012: Validating: Emulator_7: Snap Path: D:\Assets\Nintendo Wii\Snaps
18:32:45.9 26.07.2012: Validating: Emulator_7: Control Panel Path: D:\Assets\Nintendo Wii\Controls
18:32:45.9 26.07.2012: Validating: Emulator_7: Database: [Console] Nintendo Wii
18:32:45.9 26.07.2012: Warning: Emulator_7: Database Does not exist
18:32:45.9 26.07.2012: Validating: Emulator_7: Title Snap Path: D:\Assets\Nintendo Wii\Titles
18:32:45.9 26.07.2012: Validating: Emulator_7: Box Art Path: D:\Assets\Nintendo Wii\Boxes
18:32:45.9 26.07.2012: Validating: Emulator_7: Cart Art Path: D:\Assets\Nintendo Wii\Cartridges
18:32:45.9 26.07.2012: Validating: Emulator_7: Manual Path: D:\Assets\Nintendo Wii\Manuals
18:32:45.9 26.07.2012: Restoring Emulator from Cache: 1
18:32:46.0 26.07.2012: Restoring Emulator from Cache: 2
18:32:46.0 26.07.2012: No Database Data: 2
18:32:46.0 26.07.2012: Restoring Emulator from Cache: 3
18:32:46.0 26.07.2012: Restoring Emulator Database From Cache: 3
18:32:46.0 26.07.2012: Restoring Emulator from Cache: 4
18:32:46.1 26.07.2012: Restoring Emulator Database From Cache: 4
18:32:46.1 26.07.2012: Restoring Emulator from Cache: 5
18:32:46.1 26.07.2012: Restoring Emulator Database From Cache: 5
18:32:46.2 26.07.2012: Restoring Emulator from Cache: 6
18:32:46.2 26.07.2012: Restoring Emulator Database From Cache: 6
18:32:52.9 26.07.2012: Starting Search for UPNP Media Servers
18:33:45.1 26.07.2012: Exiting GameEx!
18:33:45.1 26.07.2012: Disposing all videos
18:33:45.2 26.07.2012: Deleting temporary Karaoke videos
18:33:45.2 26.07.2012: Disposing Image List
18:33:45.2 26.07.2012: Disposing Fonts
18:33:45.2 26.07.2012: Disposing Surfaces
18:33:45.2 26.07.2012: Saving Settings
18:33:45.2 26.07.2012: Shutting down Bass
18:33:45.3 26.07.2012: Closing HideOS.exe
18:33:45.6 26.07.2012: Disposing Plugins
18:33:45.6 26.07.2012: Closing database connection
18:33:45.6 26.07.2012: Checking for applications to Launch On Exit
18:33:45.6 26.07.2012: Media Center was not open when starting GameEx, so not launching
18:33:45.8 26.07.2012: Bye
[General]
Xresolution=800
Yresolution=600
DisplayOnSecondary=False
mamepath=D:\GameEx
mameexe=Mame Mapping Magician.exe
rompath=D:\GameEx\DEMO
StartWait=False
USeAdvanceMame=False
AdvanceMAMEEXE=advmame.exe
AdvanceMAMEPATH=D:\Emulators\AdvanceMAME
ADVANCEMAMEOptions=-device_video_output fullscreen -quiet -dir_rom "C:\Emulators\Mame32\roms"
UseZinc=False
ZincEXE=zinc.exe
ZincPATH=D:\Emulators\ZiNc
ZincOptions=--renderer=.\renderer.znc
Font=Trebuchet MS
TitleText=MAME Games
OnlyWorking=True
AllowImperfect=True
VerifyRoms=True
OnlyRoms=False
NoGameInfo=False
GameFilter=Japan;Korea;Asia;Hispanic;Bootleg;French;German;Hack;Prototype;Hardware;Spanish;(Easy;(harder
GameFilterOn=True
NoAdult=True
NoClones=False
MameOptions=-nowindow -joy -skip_gameinfo
ArcadeMode=False
UseLargeFonts=True
snappath=D:\GameEx\DEMO\MAME\snaps
avisnappath=D:\GameEx\DEMO\MAME\video
AVIFrameSkip=0
flyerpath=D:\GameEx\DEMO\MAME\flyers
cabinetpath=D:\GameEx\DEMO\MAME\cabinets
CatverLocation=\DATA\catver.ini
nplayerslocation=\DATA\nplayers.ini
HistoryLocation=\DATA\history.dat
InfoLocation=\DATA\mameinfo.dat
CommandLocation=\DATA\command.dat
ShowGameInfoPage=True
EnableStartPage=True
ShowStartPageFirst=True
skipintro=False
AntiAliasFonts=True
OutlineFonts=False
DisplayBackgroundImage=False
SnapBrightness=120
MusicPlayList=
MusicVolume=85
MediaCenterMode=2
PlayIntroSound=False
AttractModeTimer=4
AttractModeAudio=2
UsingArcadeVGA=False
StretchResToX=640
StretchResToY=288
TryToStretchto256=True
NoWaitVSync=False
Sleep=True
HideUpdateList=False
DisableExit=False
HideShutDown=False
StartUpVideo=
LaunchOnStart=
LaunchOnStartNoWait=
LaunchOnExit=
LaunchOnExitNoWait=
FontSize=0
VectorResX=632
VectorResY=264
AlwaysStretch=410x256
DisableEscape=False
DisableRemoveGame=True
theme=Default - Brokeh 1024x768
Language=English
FlatStartPage=False
DontSwitchRes=True
SnapDelay=2
AllowWindowResize=True
ShowLoadingScreen=True
Use16BitColour=False
Widescreen=False
DisableMAME=False
ShellBeforeLaunch=
ShellOnExit=
EnableJukeBox=True
jukeboxplaylist=Live! (CD1)
EnableMediaControls=True
ShufflePlayLists=False
LoadPlayListAtStartup=False
LoadPlayListThread=False
DownloadArt=True
TitleFont=Trebuchet MS
DialogTextWhite=False
TimeFormat=False
HideToolBar=4
DoNotFilterROMS=pacman;splatter
MAMEAudioMode=1
DisplayTitle=True
AVIAudio=True
marqueepath=D:\GameEx\DEMO\MAME\marquees
panelpath=D:\GameEx\DEMO\MAME\cpanel
titlepath=D:\GameEx\DEMO\MAME itles
iconpath=D:\GameEx\DEMO\MAME\icons
CPEnabled=True
CPPATH=\DATA\controls.ini
ShowVector=True
ShowNeoGeo=True
ShowOriginal=True
ShowAdult=True
ShowCPS=True
ShowVertical=True
ShowHorizontal=True
EnableFavorites=True
ShowMulti=True
ShowAllMAME=True
ShowLastGame=True
ShowRandomGame=False
ShowListNumbers=True
AlphaBlendVideos=True
EnableSound=True
MediaCenterOpenCheck=true
UseSharp=True
CreateImageOnThread=False
HideCreateSnaps=True
HideLogoff=False
HideStandBy=False
DisableMouse=False
ShowVideos=True
VideoPath=M:\Movies\DIVX XVID
EnableAlphaPage=True
EnableJoystick=True
EnableSlikStik=False
KeyboardDirectInput=False
NoMahjong=True
VIDEOFFDSHOW=0
JoystickDevice=MotioninJoy Virtual Game Controller
EnableCustomInput=False
EnableCustomJoyInput=True
AttractVideosEnabled=True
attractvideosratio=-1
attractvideospath=D:\GameEx\DEMO\Videos
AtractModeNewGameTimer=2
AdvancedGFX=True
HideZinc=False
TransitionType=0
Bypass=True
DontBlitWait=False
ShowMostPlayed=True
ExcludedMAMERoms=
DeadZoneX=0
DeadZoneY=0
JukeBoxMode=2
AmbienceFile=L:\-DATA-\-MP3-\4 Non Blondes\4 Non Blondes - What's Up.mp3
AmbianceFile=C:\arcade.mp3
EnableAmbiance=False
HIDEDESKTOP=True
UseSnapBestMatch=true
IngameVK=121
EnableThemePicker=False
DisablePleaseWaitAnimation=False
EnableRipCD=False
DumbyValue=
DVDPath=G:\
AttractOnlyFavs=False
rotateplus90=False
ShowButtons=True
DisplayTitleText=True
PlayExitSaverSound=False
ShowAtari=True
ShowGolden=True
ShowHorizVert=0
UseModel2=False
Model2PATH=D:\Emulators\Model2
ShowModel2=True
ShowLightGun=True
EnableBezel=True
AutoUpdate=1
NoMAMEOnStartPage=False
HideRestart=False
EnableStartScreenSaver=False
SortMAMEThE=True
SortEmuThE=True
ShowMCEEXport=True
NoRotationRestrictions=False
MakeToolbarTextWhite=False
ExitGameAfter=0
ShowTrackball=True
ShowSpinner=True
LoadEmusOnThread=True
LoadRadioOnThread=False
StartPageAni=False
EmusAttractMode=False
MuteEmuAttractMode=False
Show4Player=True
CabControlFriendly=False
manualpath=D:\GameEx\DEMO\MAME\manual
HideShowTaskbar=True
CustomMAMEFolderPath=D:\Emulators\Mame32\CustomFolders
MAMEFavoritesini=D:\Emulators\Mame32\Folders\Favorites.ini
MenuFontSameSize=False
PreviewVideos=True
ShowStatistics=True
DisableMouseWheel=False
ErrorReporting=0
ReduceCPU=True
ShowNotPlayed=True
ShowOnlineLists=True
ScreensaverMode=0
AttractText=Touch screen to start...
GlaunchEnabled=False
PCBPath=D:\Emulators\Mame32\pcb
ArtworkPath=D:\Emulators\Mame32\artworkpreview
LoadJukeTracksOnStartup=False
EnableLetterSelect=True
JukeQueueMode=0
EnableBezelAttract=True
ForceDailyReboot=-1
EnableSearch=False
FixToEmuList=0
ShowLastPlayed=False
TwoThreeRes=
EnableTouchScreen=True
EnableMediaCheck=True
EnableOtherSystems=True
ForceShutdown=False
EnableHiScore=True
DisplayImageList=False
SortEmulators=True
ShowAllGames=True
InactivityTimer=0
EnableAdvCustomInput=False
HideHibernate=False
EnableKeyboardShutdown=False
AutoRotateMAME=False
EnableLaunchDialog=True
lastmusicpath=G:\-DATA-\-MP3-
looplist=False
TrackballSupport=False
EnableVisualizations=True
EnableVideoThumbs=False
cabinet3dpath=D:\GameEx\DEMO\MAME\cabinets3d
EnableClientServerMAME=False
ClientServerMAMEPath=D:\Emulators\ClientServerMAME
ClientServerMAMEEXE=vmame.exe
OnQueueEndMode=0
MAMERemoveDupes=2
CommnadLocation=\DATA\command.dat
AutoDownloadDescriptions=True
GameExtenderCustomImageMAMEPath=D:\Emulators\Mame32\marquees
Enablepopupdescriptions=False
SetPalRes=False
PalRes=800x600x32x60
SetNTCSRes=True
NTSCRes=800x600x32x60
SetNTSCRes=False
SetTwoThreeRes=False
AmbianceFolder=
EnableEscapeKeyExit=True
DisableChangeView=True
EnabledConfigurationApp=True
ResumeLastAtStartup=False
HelpText=
ShowHistoryAndMAMEInfo=True
baksnappath=D:\Emulators\Mame32\backgroundsnap
TVVideoPath=
othervideopath=M:\Movies\DVD
ChangeMonitorFrequency=False
ChangeMonitorResolution=False
NoCasino=True
EnableDownloadService=True
demoinstalledversion=1
[Daphne]
UseDaphne=False
DaphnePath=D:\Emulators\Daphne
DaphneExe=Daphne.exe
DaphneSnap=D:\Emulators\Daphne\images
DaphneOptions=vldp -fullscreen -x 640 -y 480 -nohwaccel
Enabled_1=True
ROMName_1=astron
GameName_1=Astron Belt
GameOptions_1=-framefile "D:\Roms\Laserdisc\Astron Belt\astron.txt"
Enabled_2=True
ROMName_2=badlands
GameName_2=Badlands
GameOptions_2=-framefile "C:\Roms\Laserdisc\Badlands\badlands-r.txt"
Enabled_3=True
ROMName_3=bega
GameName_3=Bega's Battle
GameOptions_3=-framefile "C:\Roms\Laserdisc\Bega's Battle\bega.txt"
Enabled_4=True
ROMName_4=cliff
GameName_4=Cliff Hanger
GameOptions_4=-framefile "C:\Roms\Laserdisc\Cliff Hanger\cliff-r.txt"
Enabled_5=True
ROMName_5=cobraab
GameName_5=Cobra Command
GameOptions_5=-framefile "C:\Roms\Laserdisc\Cobra Command\cc_framefile.txt
Enabled_6=True
ROMName_6=lair
GameName_6=Dragon's Lair
GameOptions_6=-framefile "C:\Roms\Laserdisc\Dragon's Lair\dl_framefile.txt"
Enabled_7=True
ROMName_7=lair2
GameName_7=Dragon's Lair II Timewarp
GameOptions_7=-framefile "C:\Roms\Laserdisc\Dragon's Lair II Timewarp\DL2_single_framefile.txt"
Enabled_8=True
ROMName_8=esh
GameName_8=Esh's Aurunmilla
GameOptions_8=-framefile "C:\Roms\Laserdisc\Esh's Aurunmilla\esh.txt"
Enabled_9=True
ROMName_9=firefox
GameName_9=Firefox
GameOptions_9=-framefile "C:\Roms\Laserdisc\Firefox\firefox.txt"
Enabled_10=True
ROMName_10=ffr
GameName_10=Freedom Fighter
GameOptions_10=-framefile "C:\Roms\Laserdisc\Freedom Fighter\ffr.txt"
Enabled_11=True
ROMName_11=galaxy
GameName_11=Galaxy Ranger
GameOptions_11=-framefile "C:\Roms\Laserdisc\Galaxy Ranger\galaxy-r.txt"
Enabled_12=True
ROMName_12=gtg
GameName_12=Goal to Go
GameOptions_12=-framefile "C:\Roms\Laserdisc\Goal to Go\gtg.txt"
Enabled_13=True
ROMName_13=interstellar
GameName_13=Interstellar Laser Fantasy
GameOptions_13=-framefile "C:\Roms\Laserdisc\Interstellar Laser Fantasy\interstellar.txt"
Enabled_14=True
ROMName_14=lgp
GameName_14=Laser GP
GameOptions_14=-framefile "C:\Roms\Laserdisc\Laser GP\lasergp.txt"
Enabled_15=True
ROMName_15=mach3
GameName_15=Mach 3
GameOptions_15=-framefile "C:\Roms\Laserdisc\Mach 3\mach3.txt"
Enabled_16=True
ROMName_16=roadblaster
GameName_16=Road Blaster
GameOptions_16=-framefile "C:\Roms\Laserdisc\Road Blaster\roadblaster.txt"
Enabled_17=True
ROMName_17=ace
GameName_17=Space Ace
GameOptions_17=-framefile "C:\Roms\Laserdisc\Space Ace\ace.txt"
Enabled_18=True
ROMName_18=sdq
GameName_18=Super Don Quix-ote
GameOptions_18=-framefile "C:\Roms\Laserdisc\Super Don Quix-ote\sdq.txt"
Enabled_19=True
ROMName_19=tq
GameName_19=Thayer's Quest
GameOptions_19=-framefile "C:\Roms\Laserdisc\Thayer's Quest q.txt"
Enabled_20=True
ROMName_20=uvt
GameName_20=Us vs Them
GameOptions_20=-framefile "C:\Roms\Laserdisc\Us vs Them\uvt.txt"
UseGamepad=False
DaphneFlyer=D:\Emulators\Daphne\flyers
DaphneCabinet=D:\Emulators\Daphne\cabinets
DaphneTitle=D:\Emulators\Daphne itles
DaphneMarquee=D:\Emulators\Daphne\marquees
DaphnePanel=D:\Emulators\Daphne\cpanel
LaunchBefore=
LaunchAfter=
DaphneCustomGameExtenderCustomArtPath=D:\Emulators\Daphne\marquees
DaphneBakSNAP=D:\Emulators\Daphne\backgroundimages
[DVD]
EnableDVD=True
CODEC=0
DVDFFDSHOW=1
EnableDVDDisk=True
DVDPath=M:\Movies\DVD
UseVMR9=True
EnableExternalPlayer=False
Use VMR9=False
CMD=
[Pictures]
PicturesEnabled=False
paths=
UseAlphaBlend=True
SlideDuration=12
[News]
URL_1=http://rss.news.yahoo.com/rss/topstories
URL_2=
URL_3=http://rss.news.yahoo.com/rss/tech
URL_4=http://slashdot.org/index.rss
URL_5=
URL_6=http://www.emulator-zone.com/rss_news.php
URL_7=http://www.spesoft.com/news.xml
URL_8=http://www.gameex.info/forums/index.php?app=core&module=global&section=rss&type=forums&id=1
URL_9=http://www.hulu.com/feed/highest_rated/videos
URL_10=http://www.hulu.com/feed/popular/videos/this_week
URL_11=http://www.hulu.com/feed/recent/movies
URL_12=
URL_13=
URL_14=
URL_15=
URL_16=
URL_17=
URL_18=
URL_19=
URL_20=
URL_21=
URL_22=
URL_23=
URL_24=
URL_25=
URL_26=
URL_27=
URL_28=
URL_29=
URL_30=
Enabled=False
URL_31=
URL_32=
URL_33=
URL_34=
URL_35=
URL_36=
[Radio]
RadioEnabled=False
Enabled_5=True
Name_5=Kohina - old school game & demo
URL_5=http://acamar.org:8000/listen.pls
Enabled_6=False
Name_6=Bangkok Radio
URL_6=http://64.62.253.55/bangkok64
Enabled_7=True
Name_7=Kohina - Fresh Tracks
URL_7=http://anka.org:8080/fresh.ogg.m3u
Enabled_4=False
Name_4=Delta Uno
URL_4=http://www.deltauno.it/home/delta1.asx
Enabled_1=False
Name_1=
URL_1=
Enabled_2=
Name_2=
URL_2=
Enabled_3=
Name_3=
URL_3=
Enabled_8=
Name_8=
URL_8=
Enabled_9=
Name_9=
URL_9=
Enabled_10=
Name_10=
URL_10=
Enabled_11=
Name_11=
URL_11=
Enabled_12=
Name_12=
URL_12=
Enabled_13=
Name_13=
URL_13=
Enabled_14=
Name_14=
URL_14=
Enabled_15=
Name_15=
URL_15=
Enabled_16=
Name_16=
URL_16=
Enabled_17=
Name_17=
URL_17=
Enabled_18=
Name_18=
URL_18=
Enabled_19=
Name_19=
URL_19=
Enabled_20=
Name_20=
URL_20=
Enabled_21=False
Name_21=Capital Gold
URL_21=mms://ms1.capitalinteractive.co.uk/gold_high
Enabled_22=True
Name_22=Slay Radio
URL_22=
http://relay4.slayradio.org:8000
Name_23=XFM
URL_23=http://rope.icgo.fimc.net/staticweb/onair_players/onair_xfm_abacast/player/onair_xfm.asx
Enabled_23=False
Name_24=Radio Woodstock
URL_24=http://nick8.surfernetwork.com/Media/RWST.asx
Enabled_25=True
Name_25=Club 977 Alternative
URL_25=http://www.977alt.com/977alt.asx
Enabled_26=True
Name_26=Radio Paradise
URL_26=http://www.changeip.com/radio/rp_128.asx
Enabled_27=True
Name_27=Hitz Radio
URL_27=http://www.hitzradio.com/hitzradio.asx
Enabled_28=True
Name_28=Club 977
URL_28=http://www.club977.com/club977.asx
Enabled_29=True
Name_29=9412 Rock Station
URL_29=http://www.9412.com/9412.asx
Enabled_30=True
Name_30=Power Hitz
URL_30=http://www.powerhitz.com/powerhitz.asx
Enabled_31=True
Name_31=Radio Wazee
URL_31=http://www.wazee.org/128.asx
Enabled_32=True
Name_32=The Edge Radio
URL_32=http://mfkrboard.com/edgeradio/edge.m3u
Enabled_33=True
Name_33=WFUV 90.7 FM Public Radio
URL_33=http://www.wfuv.org/wfuvlive.asx
Enabled_34=False
Name_34=Pirate Radio
URL_34=http://www.loudcity.net/Portals/0/LCPlayLists/90/123.asx
Enabled_35=True
Name_35=EYE 97
URL_35=http://www.loudcity.net/Portals/0/LCPlayLists/157/eye97.asx
Enabled_36=True
Name_36=Hit Music Station
URL_36=http://www.hitmusicstation.net/ecoute_haut_debit.m3u
Name_37=Radio IO 80's
URL_37=http://radioio.sc.llnwd.net:8240
Enabled_24=
Enabled_37=False
Enabled_80=True
Url_80=FAVREMOVE
Enabled_81=True
Url_81=FAVREMOVE
Enabled_82=True
Url_82=FAVREMOVE
Enabled_83=True
Url_83=FAVREMOVE
enabled_84=True
name_84=radioio.com : 80s New Wave
url_84=http://www.shoutcast.com/sbin/shoutcast-playlist.pls?rn=1269943&file=filename.pls
Enabled_85=
Name_85=
Url_85=
Enabled_38=True
Name_38=C64.COM's SID Stream
URL_38=http://www.c64.com/sid.m3u
[HTMLApplications]
Enabled_1=True
URL_1=http://10foot.cbuenger.com/mceWeather/index.php?start=1〈=2
Name_1=Weather
Logo_1=Weather
MouseEmu_1=False
Enabled_2=True
URL_2=http://gameex.net
Name_2=GameEx homepage
Logo_2=
MouseEmu_2=False
Enabled_3=False
URL_3=http://10foot.cbuenger.com/mceWeather/index.php?start=1〈=2
Name_3=Weather
Logo_3=Weather
MouseEmu_3=True
Enabled_4=False
URL_4=
Name_4=
Logo_4=
MouseEmu_4=True
Enabled_5=False
URL_5=
Name_5=
Logo_5=
MouseEmu_5=True
Enabled_6=False
URL_6=
Name_6=
Logo_6=
MouseEmu_6=True
UseHTMLApps=True
Hide_2=False
Hide_3=
Hide_4=True
Hide_5=
[ExternalApplications]
Enabled_99=True
Name_99=Configuration
Path_99=[apppath]
CMD_99=GameExConfig.exe
Snap_99=GameExText
ShowDesktop_99=True
MapKeys_99=False
WaitBeforeKeys_99=
SendKeys_99=
Enabled_2=False
Name_2=Notepad
Path_2=c:\windows
CMD_2=notepad.exe
Snap_2=GameExText
ShowDesktop_2=True
MapKeys_2=True
WaitBeforeKeys_2=
SendKeys_2=
Enabled_3=False
Name_3=Mad Dog McCree
Path_3=G:\Mad_Dog_mcCree
CMD_3=G:\Mad_Dog_mcCree\mdm.exe
Snap_3=GameExText
ShowDesktop_3=True
MapKeys_3=True
WaitBeforeKeys_3=4000
SendKeys_3=F
Enabled_1=False
name_1=Close And Restart GameEx
path_1=G:\-DATA-\-MY PROJECTS-\GameEx - VB.net\bin
cmd_1=CloseAndRestartGameEx.bat
snap_1=
showdesktop_1=True
mapkeys_1=True
WaitBeforeKeys_1=d
SendKeys_1=
Enabled_4=False
name_4=
path_4=
cmd_4=
snap_4=
showdesktop_4=True
mapkeys_4=True
WaitBeforeKeys_4=
SendKeys_4=
Enabled_5=False
name_5=
path_5=
cmd_5=
snap_5=
showdesktop_5=True
mapkeys_5=True
WaitBeforeKeys_5=
SendKeys_5=
Enabled_6=False
name_6=
path_6=
cmd_6=
snap_6=
showdesktop_6=True
mapkeys_6=True
WaitBeforeKeys_6=
SendKeys_6=
Enabled_7=False
name_7=
path_7=
cmd_7=
snap_7=
showdesktop_7=True
mapkeys_7=True
WaitBeforeKeys_7=
SendKeys_7=
Enabled_8=False
name_8=
path_8=
cmd_8=
snap_8=
showdesktop_8=True
mapkeys_8=True
WaitBeforeKeys_8=
SendKeys_8=
Enabled_9=False
name_9=
path_9=
cmd_9=
snap_9=
showdesktop_9=True
mapkeys_9=True
WaitBeforeKeys_9=
SendKeys_9=
Enabled_10=False
name_10=
path_10=
cmd_10=
snap_10=
showdesktop_10=True
mapkeys_10=True
WaitBeforeKeys_10=
SendKeys_10=
Enabled_11=False
name_11=
path_11=
cmd_11=
snap_11=
showdesktop_11=True
mapkeys_11=True
WaitBeforeKeys_11=
SendKeys_11=
Enabled_12=False
name_12=
path_12=
cmd_12=
snap_12=
showdesktop_12=True
mapkeys_12=True
WaitBeforeKeys_12=
SendKeys_12=
Enabled_13=False
name_13=
path_13=
cmd_13=
snap_13=
showdesktop_13=True
mapkeys_13=True
WaitBeforeKeys_13=
SendKeys_13=
Enabled_14=False
name_14=
path_14=
cmd_14=
snap_14=
showdesktop_14=True
mapkeys_14=True
WaitBeforeKeys_14=
SendKeys_14=
Enabled_15=False
name_15=
path_15=
cmd_15=
snap_15=
showdesktop_15=True
mapkeys_15=True
WaitBeforeKeys_15=
SendKeys_15=
Enabled_16=False
name_16=
path_16=
cmd_16=
snap_16=
showdesktop_16=True
mapkeys_16=True
WaitBeforeKeys_16=
SendKeys_16=
Enabled_17=
name_17=
path_17=
cmd_17=
snap_17=
showdesktop_17=
mapkeys_17=
WaitBeforeKeys_17=
SendKeys_17=
Enabled_18=
name_18=
path_18=
cmd_18=
snap_18=
showdesktop_18=
mapkeys_18=
WaitBeforeKeys_18=
SendKeys_18=
Enabled_19=
name_19=
path_19=
cmd_19=
snap_19=
showdesktop_19=
mapkeys_19=
WaitBeforeKeys_19=
SendKeys_19=
Enabled_20=
name_20=
path_20=
cmd_20=
snap_20=
showdesktop_20=
mapkeys_20=
WaitBeforeKeys_20=
SendKeys_20=
Enabled_21=
name_21=
path_21=
cmd_21=
snap_21=
showdesktop_21=
mapkeys_21=
WaitBeforeKeys_21=
SendKeys_21=
Enabled_22=
name_22=
path_22=
cmd_22=
snap_22=
showdesktop_22=
mapkeys_22=
WaitBeforeKeys_22=
SendKeys_22=
Enabled_24=
name_24=
path_24=
cmd_24=
snap_24=
showdesktop_24=
mapkeys_24=
WaitBeforeKeys_24=
SendKeys_24=
Enabled_25=
name_25=
path_25=
cmd_25=
snap_25=
showdesktop_25=
mapkeys_25=
WaitBeforeKeys_25=
SendKeys_25=
EmulateMouse_1=-1
EmulateMouse_2=-1
EmulateMouse_3=3
EmulateMouse_4=
EmulateMouse_5=
EmulateMouse_6=
EmulateMouse_7=
EmulateMouse_8=
EmulateMouse_9=
EmulateMouse_10=
EmulateMouse_11=
EmulateMouse_12=
EmulateMouse_13=
EmulateMouse_14=
EmulateMouse_15=
EmulateMouse_16=
EmulateMouse_17=
EmulateMouse_18=
EmulateMouse_19=
EmulateMouse_20=
EmulateMouse_21=
EmulateMouse_22=
EmulateMouse_24=
EmulateMouse_25=-1
LaunchBefore_16=
LaunchAfter_16=
AlsoLaunch_16=
LaunchBefore_17=
LaunchAfter_17=
LaunchBefore_1=
HelpText_1=
[TEXT]
Downloading=Downloading
Seeking=Seeking
Download=Download
PlayBluRay=Play Blu Ray
GetMetaData=Get MetaData
Touch_Help_1=Control is located at bottom of screen.
Touch_Help_2=Continuously tap bottom right for credits and top right to start.
Touch_Help_3=Controls are located bottom and middle of screen.
Touch_Help_4=Control is located at bottom of screen.
GameExArcadeStart=Arcade
GameExArcadeList=Arcade
RipDVD=Rip DVD
SearchMusic=Search Music
Dialog_RippingCD=Ripping CD
Dialog_PleaseWait=Please Wait
Dialog_ScanningFolders=Scanning Folders
Dialog_ScanningFiles=Scanning Files
Dialog_LoadingDatabases=Loading Databases
Dialog_LoadingSettings=Loading Settings
Status_ListUpdated=List Updated
Status_FavRemoved=Removed from favorites
Status_FavAdded=Added to favorites
Status_ItemRemoved=Item removed
Status_NextTrack=Next track
Status_PreviousTrack=Previous track
Status_Pause=Pause
Status_play=Play
Status_AddedToQ=Added to queue
Status_NetPlayReq=Requested NetPlay
Status_NetPlayCan=Cancelled NetPlay
YouTube=YouTube
News=News
SearchYouTube=Search YouTube
RequestNetPlay=Request NetPlay
CancelNetPlay=Cancel NetPlay Request
MAMENetPlayStart=MAME NetPlay
NetPlayList=NetPlay
Accept=Accept
Now=Now
Next=Next
GameMusic=Game Music
TVAdvert=TV Advert
Commands=Commands
RecordVideo=Record Video
ResumeGame=Resume Game
ExitGame=Exit Game
InGame=In Game
Stopped=Stopped
Play=Play
ResumeDVD=Resume DVD
NoItems=- NO ITEMS FOUND -
Hibernate=Hibernate
MenuMore=More
AllGamesStart=All Games
AllGamesList=All Games
NotAvailable=Not Available
HiScore=High Score
GetLyrics=Get Lyrics
OtherSystems=Other Systems
OpenMedia=Open Media
Biography=Biography
MenuView=Change View
MenuBack=Back
MenuExit=Exit
MenuHome=Home
LastPlayedList=Last Played
LastPlayedStart=Last Played
SEARCHTITLE=Enter criteria then select menu
SEARCHTITLE2=Press select to release cursor
SearchList=Search
SearchStart=Search
SearchMedia=Search Media
SearchJukebox=Search Jukebox
Items=Items
MediaPlayerStart=Library
MediaPlayerList=Library
NoMediaFound=- NO MEDIA FOUND -
eBookViewerStart=eBooks
eBookViewerList=eBooks
Artwork=Artwork
PCB=PCB
Statistics=Statistics
InsertCD=Insert CD:
SearchGames=Search Games
GameManual=Manual
PlayStation=Playstation
mame2simlist=2 Players
mame2simstart=2 Player Simultaneous
mame4simlist=4 Players
mame4simstart=4 Player Simultaneous
MCEEXPORT=Export To MCE
StartScreenSaver=Start Screensaver
Visualize=Visualize
SelectVisualize=Select Visualization
About1=Windows Emulator Front End and HTPC
About2=Written By:
About3=For Latest Version, please visit:
byalbum=By Album
byartistalbum=By Artist/Album
byartist=By Artist
bycat=By Category
bygenre=By Genre
bymanu=By Manufacturer
bysys=By System
byname=By Name
bytitle=By Title
byyear=By Year
Selectplaylist=Play list / More
createsnaps=Create Snaps
CreateSnaps1A=You are about to create snap shots or videos for every game in the [EMULATOR] Games List. This option can be removed from GameEx, by enabling the Hide Create Snaps option in the configuration.
CreateSnaps2=You should be aware this is a lengthy process
CreateSnaps3=With your current settings it is estimated that it will take at least:
CreateSnaps4=[MINUTES] Minutes to complete this process if you use a 20 second pause between snaps.
CreateSnaps5=You should also be warned that the SNAP shots will be saved in the SNAP Path defined for this emulator
CreateSnaps6=This process is not recommended on Windows 98
CreateSnaps7=To exit this process once run HOLD down ESCAPE.
CreateSnaps8=Do you want to proceed?
Exit=Exit GameEx
HTMLPleaseWait=Please Wait
IsUpdatingList=GameEx is updating the MAME game list:
jukelist=Jukebox
jukestart=Jukebox
Karaokelist=Karaoke
Karaokestart=Karaoke
StartKaraoke=Start Karaoke Player
LaaunchingGame=Launching:
laserlist=Laserdisc
laserstart=Laserdisc Games
logoff=Log Off
favlist=Favorites
favstart=Favorites
mamealllist=MAME Games
mameallstart=All MAME Games
mamecpslist=CPS Games
mamecpsstart=CPS Games
mameAtarilist=Atari Games
mameAtaristart=Atari Games
mameGunlist=Lightgun
mameGunstart=Lightgun Games
mameTrackballlist=Trackball
mameTrackballstart=Trackball Games
mameSpinnerlist=Spinner
mameSpinnerstart=Spinner Games
mameModel2list=Model 2
mameModel2start=Sega Model 2 Games
mameGoldenlist=Golden Era
mameGoldenstart=Golden Era Of Arcade
mameneolist=Neo-Geo
mameNEostart=Neo-Geo Games
mamemultilist=MAME Multiplay
mamemultistart=MAME Multiplayer Games
mamevectorlist=MAME Vector
mamevectorstart=MAME Vector Games
Of=of
shutdown=Turn Off System
standby=Stand By System
Restart=Restart System
Start=Start..
updatelist=Update List
UpdatingList=Updating Game List:
UpdatingPleaseWait=Please Wait......
videoslist=Videos
videostart=Videos
LaunchingGame=Launching Game:
PlayThisGame=Play This Game
Recommended=Recommended Games:
Series=Games in Series:
Title=Title
Flyer=Flyer
Cabinet=Cabinet
Cabinet3d=3D Cabinet
Panel=Panel
Box=Box
Cartridge=Cartridge
Marquee=Marquee
FavoritesAdd=Add To Favorites
FavoritesRemove=Remove From Favorites
NoVideosFound=- NO VIDEOS FOUND -
NoPicturesFound=- NO PICTURES FOUND -
NoMusicFound=- NO MUSIC FOUND -
NoArtistsFound=- NO ARTISTS FOUND -
NoAlbumsFound=- NO ALBUMS FOUND -
NoGenresFound=- NO GENRES FOUND -
NoGamesFound=- NO GAMES FOUND -
NoStationsFound=- NO STATIONS FOUND -
NoNewsFound=- NO NEWS FOUND -
CannotCreateSnaps1=Cannot Create Snaps
CannotCreateSnaps2=Emulator '[EMULATOR]' Does not have a valid Snap path, so Snaps cannot be created. Setup a valid snap path in the configuration and try again.
ViewControls=View Controls
Instructions=Instructions
ViewControlsKey=Press '[KEY]' to view in game.
AllMusic=All Music
ClearCurrentPlaylist=Clear Current Playlist
ShufflePlaylist=Shuffle Current Playlist
PlayLastGame=Last MAME Game
ViewSlideShow=View Slide Show
Pictures=Pictures
Radio=Radio
PlayDVD=Play DVD
PlayCD=Play CD
DVDonDiskStart=DVDs
DVDonDiskList=DVDs
Demo=Demo:
Playing=Playing:
MAMEOriginal=MAME Original Games
MAMEOriginallist=Originals
MAMEAdult=MAME Adult Games
MAMEAdultlist=Adult
ClearAndQueueAll=Clear and Queue All
AddAndQueueAll=Add all to Queue
RandomGame=Play Random Game
StartMAME=MAME
StartApps=More Games & Programs
StartEMU=Emulated Games
StartControl=Exit/Shutdown
StartMedia=Multimedia
ListMAME=MAME
ListApps=Games & Apps
ListEMU=Games
ListControl=Exit
ListMedia=Media
TimesPlayed=Times Played
LastPlayed=Last Played
DeleteFavs=Delete Favorites
DeleteMost=Delete Most Played
Chapter=Chapter
Aspect=Aspect
Aspect0=Original Aspect - Not Zoomed
Aspect4=Widescreen on 4:3 - Stretched
Aspect5=Fill Screen
Aspect3a=Widescreen to 4:3 - Zoomed
Aspect3b=Letterbox to Widescreen - Zoomed
Aspect2=Original Aspect - Zoomed
Aspect1a=Widescreen to 4:3 - Shrunk
Aspect1b=4:3 to Widescreen - Stretched
Paused=Paused
PlayVideo=Play Video
ResumeVideo=Resume Video
RestartVideo=Restart Video
VideoQueue=Play All
QueueAllRandom=Play Randomly
More=More..
MostPlayed=Most Played
MostPlayedList=Most Played
VariousArtists=Various Artists
ConfirmDialog1=Select To Confirm.
ConfirmDialog2=Back To Cancel.
RemoveGame=Remove Game?
LocalDisk=Local Disk
SystemDisk=System Disk
CDDVD=CD/DVD Drive
NetworkDrive=Network Drive
RamDisk=Ram Disk
FloppyDisk=Floppy Disk
RemovableDisk=Removable Disk
UpdateGameList=Update List?
VideoQueueAll=
playstationstart=Playstation
themepickerlist=Themes
themepickerstart=Theme Picker
playstationlist=Playstation
mameVertList=Vertical
mameVertStart=MAME Vertical Games
mameHorizlist=Horizontal
mameHorizstart=MAME Horizontal Games
mamenotplayedlist=Not Played
mamenotplayedstart=MAME Not Played
mamemawslist=Live - MAWS
mameMAWSstart=Live - MAWS Hall Of Fame
mameGameExlist=Live - GameEx
mameGamEexstart=Live - GameEx Favorites
ripcd=Rip CD
ripthiscd=Rip This CD Now
cantrip=- No CD, Invalid CD, or no CDDB data -
ViewPlaylist=View Playlist
KaraokAllSongs=All Songs
KaraokaMode1Click=Instant Play Mode
KaraokaModeQueue=Queue Mode
KaraokePlaylist=View/Edit Playlist
KaraokeStartMenu=Start Karaoke
mammodel2list=
CreateSnaps1=You are about to create snap shots for every game in the [EMULATOR] Games List.
NoeBooksFound=- NO EBOOKS FOUND -
QueueAll=Queue All
[Favorites]
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
[DVRMS]
DVRFFDSHOW=0
CODEC=
[AtractModeNewGameTimer]
When in attract mode start a new random game or video each time this value is reached.=2
[AttractVideosPath]
The folder your videos are located.=L:\GameAds
[GameExTender]
RemoteGameExLocation=\\workstation1\g$\-DATA-\-MY PROJECTS-\GameEx - VB.net\bin
Enabled=False
Windowed=False
RemoteExtenderLocation=G:\-DATA-\-MY PROJECTS-\GameEx - VB.net\bin
IPADDRESS=127.0.0.1
Port=8383
RefreshRate=20
SysUserName=Sven
Username=User33549
ComputerName=SVEN-PC
Publish=False
UserInfo=
GameExtenderCustomImage=False
GameExtenderImageNotFound=
[GameExtenderViewer]
Server=90.0.0.13
PORT=8383
RefreshRate=7
StartWithGameEx=False
ExitWithGameEx=False
Windowed=False
[Karaoke]
Enabled=False
Path=
mode=False
[CachedImages]
bak=100652
res=1764000
videobak=100652
jukeboxbak=100652
radiobak=100652
picturesbak=100652
emubak=100652
startbak=100652
daphnebak=100652
mamebak=100652
themedir=
titlefont=Trebuchet MS
titlefontsize=0
outlinefonts=False
antialiasfonts=True
windowed=True
use16bitcolour=False
gradienttitlefont=True
lowercasetitlefont=True
Font=Trebuchet MS
FontSize=0
titlefontres=275808
bakres=1764000
theme=
startbak_Foreground=386810
videobak_Foreground=386810
jukeboxbak_Foreground=386810
radiobak_Foreground=386810
picturesbak_Foreground=386810
daphnebak_Foreground=386810
titlefontstyle=0
bakresbak=921600
mameselectbak=465213
lastplayedbak=290516
mostplayedbak=199198
favoritesbak=283065
allgamesbak=375154
emulatorselectbak=100444
themepickerbak=621253
[Plugin_1]
Enabled=False
Name=CursorHider.dll
[Plugin_2]
Enabled=False
Name=PlugInCallerID.dll
[Plugin_3]
Enabled=False
Name=PlugInDigDug.dll
[Plugin_4]
Enabled=False
Name=PlugInExit.dll
[Plugin_5]
Enabled=False
Name=PlugInLaunch.dll
[ArcadeSoundPlugin]
Volume=8
[Plugin_6]
Enabled=False
Name=PlugInLCD.dll
[CachedImagesMenuFont]
themedir= hemes\Default - RedEx - MCE1024x768\MEDIA\
res=0
font=Trebuchet MS
fontsize=0
outlinefonts=False
antialiasfonts=True
windowed=False
menufontsamesize=False
fontstyle=1
[CachedImagesBak]
bak=214295
videobak=214295
jukeboxbak=214295
radiobak=214295
picturesbak=214295
emubak=214295
startbak=214295
daphnebak=214295
[Emulator_]
SelectionMusicFolder=C:\Music
[eBook]
Enabled=False
Paths=
Quality=0
fittopage=False
[Plugin_7]
Enabled=False
Name=PlugInRotate.dll
[MediaPlayer]
Enabled=False
AudioMode=0
[CachedImagesGameFont]
res=1764000
[CachedImagesGameFontFaded]
res=1764000
[CachedImagesFontBlack]
Res=277056
[CPWizard]
CPWizardEnable=False
CPWizardPath=C:\Program Files\CPWizard\CPWizard.exe
CPWizardStarted=True
CPWizardStartup=True
[VIDEO]
UseWMPWMV=
CMD=C:\Program Files (x86)\VideoLAN\VLC\vlc.exe "[VIDEO]" --fullscreen
[ADVKEYBOARD]
Forward=60
Rewind=61
PageUp=62
PageDown=63
VolumeDown=64
VolumeUp=65
Stop=66
Play=67
[Plugin_8]
Enabled=False
Name=PlugInSpeech.dll
[CursorHider]
DoNotHide=
DoNotHideInGameEX=False
[Plugin_9]
Enabled=False
Name=PlugInUltraStik.dll
[DefaultPaths]
EmuPath1=C:\Emulators
AssetPath1=C:\Assets
RomPath1=C:\Roms
[YouTube]
Enabled=False
[GameBase]
Enabled=False
Path=
MapBack=False
ShowDesktop=True
[CachedImages3d]
themedir= hemes\Default - Brokeh 1024x768\MEDIA\
titlefontres=1764000
titlefontstyle=0
titlefontsize=36
outlinefonts=False
gradienttitlefont=False
lowercasetitlefont=False
antialiasfonts=True
windowed=False
res=0
bakres=0
startbak_foreground=386810
theme=BlueBox
bak_foreground=39023
jukeboxbak_foreground=23206
[CachedImagesGameFontFadedFalse]
res=921600
[CachedImagesMenuFont3d]
res=0
[DVDRIP]
Format=MP4
DVDRIPFOLDER=
Profile=Normal
CUSTOMCMD=
[GameExArcade]
Enabled=False
[Touchscreen]
Touchscreen_Enabled=False
Touchscreen_HidePointer=True
TouchScreen_ShowHelpScreens=True
TouchScreen_SingleClick=True
TouchScreen_OnlyCompatibleGames=True
TouchScreen_CheckForExit=True
TouchScreen_SendCredit=True
TouchScreen_ShowMouseAnimations=True
[LastStatus]
specialfilter=VIDEO
oldspecialfilter=VIDEO
curemulator=0
listtype=40
curbak=video
maxgames=16
gamename=Burn after reading
[Plugin_10]
Enabled=False
Name=RandomArcadeSound.dll
[Plugin_11]
Enabled=False
Name=Xpadder Plugin.dll
[INTERNAL]
currentstation=
VGenre=---
OPTIMIZED=0
AudioLanguage=german
version=12.78
timesruncount=16
startpagethumbscount=4
mamevideolists_reset18_most=False
mamevideolists_lastmodified_most=16.08.2010 17:32:17
mamevideolists_lastmodifiedlist_most=25.07.2012 22:44:04
emu_2lastfolderwrite=26.07.2012 15:20:39
emu_2lastromfilter=*.*
emu_3lastfolderwrite=26.07.2012 15:20:55
emu_3lastromfilter=*.*
emu_5lastfolderwrite=25.07.2012 23:35:00
emu_5lastromfilter=*.*
emu_6lastfolderwrite=25.07.2012 23:36:04
emu_6lastromfilter=*.*
mamevideolists_list_most=
mamevideolists_reset18_mamef=False
mamevideolists_lastmodified_mamef=16.08.2010 17:32:17
mamevideolists_lastmodifiedlist_mamef=25.07.2012 22:44:04
mamevideolists_list_mamef=
lastglaunchlist=0
glaunchlistselected_0=1
glaunchlisttop_0=1
viewalbumtype=1
windowed=False
selectedgame=1
gamelisttop=1
catfilter=
manufilter=
yearfilter=
listtype=8
emulator=0
yearlisttop=1
catlisttop=1
namelisttop=1
manulisttop=1
yearselectedgame=1
catselectedgame=1
manuselectedgame=1
nameselectedgame=1
romname=mrdrillr
romname2=mrdrillr
specialfilter=LIST
currentstationurl=
emu_6_dbcachemodified=10.07.2012 19:29:34
emu_6_lastnumgames=17
emu_6_dbcachelastname=[Console] Nintendo SNES
emu_6_dbcacheinicreated36=True
mamevideolists_reset18_mamemulti=False
mamevideolists_lastmodified_mamemulti=16.08.2010 17:32:17
mamevideolists_lastmodifiedlist_mamemulti=25.07.2012 22:44:04
mamevideolists_list_mamemulti=
mamevideolists_reset18_fourplayer=False
mamevideolists_lastmodified_fourplayer=16.08.2010 17:32:17
mamevideolists_lastmodifiedlist_fourplayer=24.07.2010 20:06:58
mamevideolists_list_fourplayer=
mamevideolists_reset18_original=False
mamevideolists_lastmodified_original=16.08.2010 17:32:17
mamevideolists_lastmodifiedlist_original=25.07.2012 22:44:04
mamevideolists_list_original=smashtv.avi|tempest.avi|mrdrillr.avi
mamepath=D:\GameEx
mamefilemodified=20.03.2011 00:23:14
mamefilesize=440560
mamepromptupdate=True
mameis32bit=True
emu_6_cdcheckfile=
emu_6_cdcheck=False
emu_6_randommostplayed=True
emu_6_showmostplayed=True
emu_6_playinscreensaver=False
emu_6_gamesin7zips=False
emu_6_pcgame=False
emu_6_selectionmusicfolder=
emu_6_playselectionmusic=False
emu_6_dontshowinfo=
emu_6_playmusic=False
emu_6_custombackground=
emu_6_excludedfiles=
emu_6_launchafter=
emu_6_launchbefore=
emu_6_oldatzip=
emu_6_alsolaunch=
emu_6_debug=False
emu_6_showdesktop=True
emu_6_removebrackets=True
emu_6_capitals=False
emu_6_replaceunder=True
emu_6_replacedash=False
emu_6_sendkeys=
emu_6_waitbeforekeys=
emu_6_mapkeys=True
emu_6_workingpath=D:\Emulators\Snes9x
emu_6_controlpanelpath=D:\Assets\Nintendo SNES\Controls
emu_6_manualpath=D:\Assets\Nintendo SNES\Manuals
emu_6_cartpath=D:\Assets\Nintendo SNES\Cartridges
emu_6_boxpath=D:\Assets\Nintendo SNES\Boxes
emu_6_titlepath=D:\Assets\Nintendo SNES\Titles
emu_6_snappath=D:\Assets\Nintendo SNES\Snaps
emu_6_rompath=D:\Roms\Nintendo SNES\Roms
emu_6_mapfile=
emu_6_configfile=[Mapping Off] Exit (Process Close)
emu_6_enabled=True
emu_6_system=Nintendo SNES
emu_6_category=Console
emu_6_emulator=Snes9x
emu_6_version=1.53
emu_6_rating=9.0
emu_6_downloadurl=http://www.gamesdbase.com/setupwizard/emulators/download/snes9x.7z
emu_6_requiredfiles=
emu_6_website=http://www.snes9x.com/
emu_6_info=Super Nintendo emulator
emu_6_titletext=Nintendo SNES
emu_6_startpagename=Nintendo SNES
emu_6_startpagelogo=Nintendo SNES
emu_6_command=snes9x.exe -fullscreen [QUOTE][ROMPATH]\[ROMFILE][QUOTE]
emu_6_romfilter=
emu_6_database=[Console] Nintendo SNES
emu_4lastfolderwrite=25.07.2012 21:57:04
emu_4lastromfilter=*.*
emu_4_dbcachemodified=10.07.2012 19:29:12
emu_4_lastnumgames=49
emu_4_dbcachelastname=[Console] Nintendo N64
emu_4_dbcacheinicreated36=True
emu_4_enabled=True
emu_4_system=Nintendo N64
emu_4_category=Console
emu_4_emulator=Project64k
emu_4_version=0.39
emu_4_rating=8.9
emu_4_downloadurl=http://www.gamesdbase.com/setupwizard/emulators/download/Project64k.7z
emu_4_requiredfiles=
emu_4_website=http://pj64k.blogspot.com/
emu_4_info=Nintendo 64 emulator
emu_4_titletext=Nintendo N64
emu_4_startpagename=Nintendo N64
emu_4_startpagelogo=Nintendo N64
emu_4_command=Project64.exe [ROMPATH]\[ROMFILE]
emu_4_romfilter=
emu_4_database=[Console] Nintendo N64
emu_4_configfile=[Mapping Off] Exit (Process Close)
emu_4_mapfile=
emu_4_rompath=D:\Roms\Nintendo N64\Roms
emu_4_snappath=D:\Assets\Nintendo N64\Snaps
emu_4_titlepath=D:\Assets\Nintendo N64\Titles
emu_4_boxpath=D:\Assets\Nintendo N64\Boxes
emu_4_cartpath=D:\Assets\Nintendo N64\Cartridges
emu_4_manualpath=D:\Assets\Nintendo N64\Manuals
emu_4_controlpanelpath=D:\Assets\Nintendo N64\Controls
emu_4_workingpath=D:\Emulators\Project64
emu_4_mapkeys=True
emu_4_waitbeforekeys=
emu_4_sendkeys=
emu_4_replacedash=False
emu_4_replaceunder=True
emu_4_capitals=False
emu_4_removebrackets=True
emu_4_showdesktop=True
emu_4_debug=False
emu_4_alsolaunch=
emu_4_oldatzip=
emu_4_launchbefore=
emu_4_launchafter=
emu_4_excludedfiles=
emu_4_custombackground=
emu_4_playmusic=False
emu_4_dontshowinfo=
emu_4_playselectionmusic=False
emu_4_selectionmusicfolder=
emu_4_pcgame=False
emu_4_gamesin7zips=False
emu_4_playinscreensaver=False
emu_4_showmostplayed=True
emu_4_randommostplayed=True
emu_4_cdcheck=False
emu_4_cdcheckfile=
donemenulistviewinitialchange2=true
lasticonpath=D:\GameEx\DEMO\MAME\icons
mamevideolists_reset18_cps=False
mamevideolists_lastmodified_cps=16.08.2010 17:32:17
mamevideolists_lastmodifiedlist_cps=25.07.2012 22:44:04
mamevideolists_list_cps=
mamevideolists_reset18_maws=False
mamevideolists_lastmodified_maws=16.08.2010 17:32:17
mamevideolists_lastmodifiedlist_maws=25.07.2012 22:44:04
mamevideolists_list_maws=
mamevideolists_reset18_vertical=False
mamevideolists_lastmodified_vertical=16.08.2010 17:32:17
mamevideolists_lastmodifiedlist_vertical=25.07.2012 22:44:04
mamevideolists_list_vertical=puckman.avi|tempest.avi|dkong.avi
mamevideolists_reset18_horizontal=False
mamevideolists_lastmodified_horizontal=16.08.2010 17:32:17
mamevideolists_lastmodifiedlist_horizontal=25.07.2012 22:44:04
mamevideolists_list_horizontal=mrdrillr.avi|smashtv.avi
mamevideolists_reset18_notplayed=False
mamevideolists_lastmodified_notplayed=16.08.2010 17:32:17
mamevideolists_lastmodifiedlist_notplayed=25.07.2012 22:44:04
mamevideolists_list_notplayed=smashtv.avi|tempest.avi|puckman.avi|mrdrillr.avi
mamevideolists_reset18_vector=False
mamevideolists_lastmodified_vector=16.08.2010 17:32:17
mamevideolists_lastmodifiedlist_vector=25.07.2012 22:44:04
mamevideolists_list_vector=
emu_1lastfolderwrite=25.07.2012 21:28:25
emu_1lastromfilter=*.*
emu_1_dbcacheinicreated36=True
videoaspect=0
emu_8lastfolderwrite=25.07.2012 21:57:04
emu_8lastromfilter=*.*
emu_8_dbcachemodified=10.07.2012 19:29:12
emu_8_lastnumgames=49
emu_8_dbcachelastname=[Console] Nintendo N64
emu_8_dbcacheinicreated36=True
emu_8_enabled=True
emu_8_system=Nintendo N64
emu_8_category=Console
emu_8_emulator=1964
emu_8_version=1.1
emu_8_rating=8.0
emu_8_downloadurl=http://www.gamesdbase.com/setupwizard/emulators/download/1964.7z
emu_8_requiredfiles=
emu_8_website=http://1964emu.emulation64.com/
emu_8_info=Nintendo 64 emulator
emu_8_titletext=Nintendo N64
emu_8_startpagename=[Console] Nintendo N64 (1964)
emu_8_startpagelogo=Nintendo N64
emu_8_command=1964.exe -f -g [QUOTE][ROMPATH]\[ROMFILE][QUOTE]
emu_8_romfilter=
emu_8_database=[Console] Nintendo N64
emu_8_configfile=[Mapping Off] Exit (Process Close)
emu_8_mapfile=
emu_8_rompath=D:\Roms\Nintendo N64\Roms
emu_8_snappath=D:\Assets\Nintendo N64\Snaps
emu_8_titlepath=D:\Assets\Nintendo N64\Titles
emu_8_boxpath=D:\Assets\Nintendo N64\Boxes
emu_8_cartpath=D:\Assets\Nintendo N64\Cartridges
emu_8_manualpath=D:\Assets\Nintendo N64\Manuals
emu_8_controlpanelpath=D:\Assets\Nintendo N64\Controls
emu_8_workingpath=D:\Emulators\1964
emu_8_mapkeys=True
emu_8_waitbeforekeys=
emu_8_sendkeys=
emu_8_replacedash=False
emu_8_replaceunder=True
emu_8_capitals=False
emu_8_removebrackets=True
emu_8_showdesktop=True
emu_8_debug=False
emu_8_alsolaunch=
emu_8_oldatzip=
emu_8_launchbefore=
emu_8_launchafter=
emu_8_excludedfiles=
emu_8_custombackground=
emu_8_playmusic=False
emu_8_dontshowinfo=
emu_8_playselectionmusic=False
emu_8_selectionmusicfolder=
emu_8_pcgame=False
emu_8_gamesin7zips=False
emu_8_playinscreensaver=False
emu_8_showmostplayed=True
emu_8_randommostplayed=True
emu_8_cdcheck=False
emu_8_cdcheckfile=
emu_5_dbcachemodified=10.07.2012 19:29:24
emu_5_lastnumgames=27
emu_5_dbcachelastname=[Console] Nintendo NES
emu_5_dbcacheinicreated36=True
emu_5_cdcheckfile=
emu_5_cdcheck=False
emu_5_randommostplayed=True
emu_5_showmostplayed=True
emu_5_playinscreensaver=False
emu_5_gamesin7zips=False
emu_5_pcgame=False
emu_5_selectionmusicfolder=
emu_5_playselectionmusic=False
emu_5_dontshowinfo=
emu_5_playmusic=False
emu_5_custombackground=
emu_5_excludedfiles=
emu_5_launchafter=
emu_5_launchbefore=
emu_5_oldatzip=
emu_5_alsolaunch=
emu_5_debug=False
emu_5_showdesktop=True
emu_5_removebrackets=True
emu_5_capitals=False
emu_5_replaceunder=True
emu_5_replacedash=False
emu_5_sendkeys=
emu_5_waitbeforekeys=
emu_5_mapkeys=True
emu_5_workingpath=D:\Emulators\Nestopia
emu_5_controlpanelpath=D:\Assets\Nintendo NES\Controls
emu_5_manualpath=D:\Assets\Nintendo NES\Manuals
emu_5_cartpath=D:\Assets\Nintendo NES\Cartridges
emu_5_boxpath=D:\Assets\Nintendo NES\Boxes
emu_5_titlepath=D:\Assets\Nintendo NES\Titles
emu_5_snappath=D:\Assets\Nintendo NES\Snaps
emu_5_rompath=D:\Roms\Nintendo NES\Roms
emu_5_mapfile=
emu_5_configfile=[Mapping Off] Exit (Process Close)
emu_5_enabled=True
emu_5_system=Nintendo NES
emu_5_category=Console
emu_5_emulator=Nestopia
emu_5_version=1.41.1
emu_5_rating=8.6
emu_5_downloadurl=http://www.gamesdbase.com/setupwizard/emulators/download/Nestopia.7z
emu_5_requiredfiles=
emu_5_website=http://nestopia.sourceforge.net/
emu_5_info=Nintendo NES 8bit emulator
emu_5_titletext=Nintendo NES
emu_5_startpagename=Nintendo NES
emu_5_startpagelogo=Nintendo NES
emu_5_command=Nestopia.exe [QUOTE][ROMPATH]\[ROMFILE][QUOTE]
emu_5_romfilter=
emu_5_database=[Console] Nintendo NES
emu_1_customartpath3=
emu_1_customartname3=
emu_1_customartpath2=
emu_1_customartname2=
emu_1_customartpath1=
emu_1_customartname1=
emu_1_cdcheckfile=
emu_1_cdcheck=
emu_1_randommostplayed=
emu_1_showmostplayed=
emu_1_playinscreensaver=
emu_1_mergesets=
emu_1_gamesin7zips=
emu_1_usedbname=
emu_1_pcgame=
emu_1_selectionmusicfolder=
emu_1_playselectionmusic=
emu_1_dontshowinfo=
emu_1_playmusic=
emu_1_custombackground=
emu_1_excludedfiles=
emu_1_launchafter=
emu_1_launchbefore=
emu_1_alsolaunch=
emu_1_debug=
emu_1_showdesktop=
emu_1_removebrackets=
emu_1_capitals=
emu_1_replaceunder=
emu_1_replacedash=
emu_1_sendkeys=
emu_1_waitbeforekeys=
emu_1_mapkeys=
emu_1_workingpath=D:\Emulators\MAME
emu_1_controlpanelpath=D:\Assets\MAME\Controls
emu_1_manualpath=D:\Assets\MAME\Manuals
emu_1_cartpath=D:\Assets\MAME\Cartridges
emu_1_boxpath=D:\Assets\MAME\Boxes
emu_1_titlepath=D:\Assets\MAME\Titles
emu_1_snappath=D:\Assets\MAME\Snaps
emu_1_rompath=D:\Roms\MAME\Roms
emu_1_mapfile=[APP]\Map Files\[Arcade] MAME.map
emu_1_configfile=[Mapping Off] Exit (Process Close)
emu_1_enabled=True
emu_1_system=Arcade
emu_1_category=Arcade
emu_1_emulator=MAME
emu_1_version=0.145
emu_1_rating=8.4
emu_1_downloadurl=http://www.gamesdbase.com/setupwizard/emulators/download/mame.7z
emu_1_requiredfiles=
emu_1_website=http://mamedev.org/
emu_1_info=MAME stands for Multiple Arcade Machine Emulator. When used in conjunction with images of the original arcade game's ROM and disk data, MAME attempts to reproduce that game as faithfully as possible on a more modern general-purpose computer. MAME can currently emulate several thousand different classic arcade video games from the late 1970s through the modern era.
emu_1_titletext=Mame
emu_1_startpagename=MAME
emu_1_startpagelogo=MAME
emu_1_command=mame.exe [ROM] -rompath [QUOTE][ROMPATH][QUOTE]
emu_1_romfilter=
emu_1_database=
emu_7lastfolderwrite=25.07.2012 20:42:38
emu_7lastromfilter=*.*
mamevideolists_reset18_startemu=False
mamevideolists_lastmodified_startemu=16.08.2010 17:32:17
mamevideolists_lastmodifiedlist_startemu=25.07.2012 22:44:04
mamevideolists_list_startemu=
emu_2_dbcachemodified=10.07.2012 19:32:45
emu_2_lastnumgames=2
emu_2_dbcachelastname=[PC] Commodore Amiga
emu_2_dbcacheinicreated36=True
emu_3_dbcachemodified=10.07.2012 19:33:07
emu_3_lastnumgames=8
emu_3_dbcachelastname=[PC] Microsoft MSX
emu_3_dbcacheinicreated36=True
emu_2_enabled=True
emu_2_system=Commodore Amiga
emu_2_category=PC
emu_2_emulator=WinUAE
emu_2_version=2.4.0
emu_2_rating=8.1
emu_2_downloadurl=http://www.gamesdbase.com/setupwizard/emulators/download/WinUAE.7z
emu_2_requiredfiles=
emu_2_website=http://www.winuae.net/
emu_2_info=Amiga emulator
emu_2_titletext=Commodore Amiga
emu_2_startpagename=Commodore Amiga
emu_2_startpagelogo=Commodore Amiga
emu_2_command=winuae.exe -f [ROMFILE]
emu_2_romfilter=
emu_2_database=[PC] Commodore Amiga
emu_2_configfile=[Mapping Off] Exit (Process Close)
emu_2_mapfile=
emu_2_rompath=D:\Roms\Commodore Amiga\Roms
emu_2_snappath=D:\Assets\Commodore Amiga\Snaps
emu_2_titlepath=D:\Assets\Commodore Amiga\Titles
emu_2_boxpath=D:\Assets\Commodore Amiga\Boxes
emu_2_cartpath=D:\Assets\Commodore Amiga\Cartridges
emu_2_manualpath=D:\Assets\Commodore Amiga\Manuals
emu_2_controlpanelpath=D:\Assets\Commodore Amiga\Controls
emu_2_workingpath=D:\Emulators\WinUAE
emu_2_mapkeys=True
emu_2_waitbeforekeys=3000
emu_2_sendkeys={enter}
emu_2_replacedash=False
emu_2_replaceunder=True
emu_2_capitals=False
emu_2_removebrackets=True
emu_2_showdesktop=True
emu_2_debug=False
emu_2_alsolaunch=
emu_2_oldatzip=
emu_2_launchbefore=
emu_2_launchafter=
emu_2_excludedfiles=
emu_2_custombackground=
emu_2_playmusic=False
emu_2_dontshowinfo=
emu_2_playselectionmusic=False
emu_2_selectionmusicfolder=
emu_2_pcgame=False
emu_2_gamesin7zips=False
emu_2_playinscreensaver=False
emu_2_showmostplayed=True
emu_2_randommostplayed=True
emu_2_cdcheck=False
emu_2_cdcheckfile=
emu_3_enabled=True
emu_3_system=Microsoft MSX
emu_3_category=PC
emu_3_emulator=blueMSX
emu_3_version=2.8.2
emu_3_rating=8.8
emu_3_downloadurl=http://www.gamesdbase.com/setupwizard/emulators/download/blueMSX.7z
emu_3_requiredfiles=
emu_3_website=http://www.bluemsx.com/
emu_3_info=Support for SG-1000,SC-3000,SF-7000,ColecoVision,SVI318/328, MSX, MSX2, MSX2+, and turboR with machine customization, emulator
emu_3_titletext=Microsoft MSX
emu_3_startpagename=Microsoft MSX
emu_3_startpagelogo=MSX
emu_3_command=blueMSX.exe /machine [QUOTE]MSX[QUOTE] /fullscreen /rom1 [QUOTE][ROMPATH]\[ROMFILE][QUOTE]
emu_3_romfilter=
emu_3_database=[PC] Microsoft MSX
emu_3_configfile=[Mapping Off] Exit (Process Close)
emu_3_mapfile=
emu_3_rompath=D:\Roms\Microsoft MSX\Roms
emu_3_snappath=D:\Assets\Microsoft MSX\Snaps
emu_3_titlepath=D:\Assets\Microsoft MSX\Titles
emu_3_boxpath=D:\Assets\Microsoft MSX\Boxes
emu_3_cartpath=D:\Assets\Microsoft MSX\Cartridges
emu_3_manualpath=D:\Assets\Microsoft MSX\Manuals
emu_3_controlpanelpath=D:\Assets\Microsoft MSX\Controls
emu_3_workingpath=D:\Emulators\blueMSX
emu_3_mapkeys=True
emu_3_waitbeforekeys=
emu_3_sendkeys=
emu_3_replacedash=False
emu_3_replaceunder=True
emu_3_capitals=False
emu_3_removebrackets=True
emu_3_showdesktop=True
emu_3_debug=False
emu_3_alsolaunch=
emu_3_oldatzip=
emu_3_launchbefore=
emu_3_launchafter=
emu_3_excludedfiles=
emu_3_custombackground=
emu_3_playmusic=False
emu_3_dontshowinfo=
emu_3_playselectionmusic=False
emu_3_selectionmusicfolder=
emu_3_pcgame=False
emu_3_gamesin7zips=False
emu_3_playinscreensaver=False
emu_3_showmostplayed=True
emu_3_randommostplayed=True
emu_3_cdcheck=False
emu_3_cdcheckfile=
[Emulator_1]
CustomArtPath3=
CustomArtName3=
CustomArtPath2=
CustomArtName2=
CustomArtPath1=
CustomArtName1=
CDCheckFile=
CDCheck=
RandomMostPlayed=
ShowMostPlayed=
PlayInScreenSaver=
MergeSets=
GamesIn7Zips=
UseDbName=
PCGame=
PlaySelectionMusic=
DontShowInfo=
PlayMusic=
CustomBackground=
ExcludedFiles=
LaunchAfter=
LaunchBefore=
AlsoLaunch=
Debug=
ShowDesktop=
RemoveBrackets=
Capitals=
ReplaceUnder=
ReplaceDash=
SendKeys=
WaitBeforeKeys=
MapKeys=
WorkingPath=D:\Emulators\MAME
ControlPanelPath=D:\Assets\MAME\Controls
ManualPath=D:\Assets\MAME\Manuals
CartPath=D:\Assets\MAME\Cartridges
BoxPath=D:\Assets\MAME\Boxes
TitlePath=D:\Assets\MAME\Titles
SnapPath=D:\Assets\MAME\Snaps
RomPath=D:\Roms\MAME\Roms
MapFile=[APP]\Map Files\[Arcade] MAME.map
ConfigFile=[Mapping Off] Exit (Process Close)
Database=
RomFilter=
Command=mame.exe [ROM] -rompath "[ROMPATH]"
StartPageLogo=MAME
StartPageName=[Arcade] Arcade (MAME)
TitleText=Mame
Info=MAME stands for Multiple Arcade Machine Emulator. When used in conjunction with images of the original arcade game's ROM and disk data, MAME attempts to reproduce that game as faithfully as possible on a more modern general-purpose computer. MAME can currently emulate several thousand different classic arcade video games from the late 1970s through the modern era.
Website=http://mamedev.org/
RequiredFiles=
DownloadUrl=http://www.gamesdbase.com/setupwizard/emulators/download/mame.7z
Rating=8.4
Version=0.145
Emulator=MAME
Category=Arcade
System=Arcade
[Emulator_2]
System=Commodore Amiga
Category=PC
Emulator=WinUAE
Version=2.4.0
Rating=8.1
DownloadUrl=http://www.gamesdbase.com/setupwizard/emulators/download/WinUAE.7z
RequiredFiles=
Website=http://www.winuae.net/
Info=Amiga emulator
TitleText=Commodore Amiga
StartPageName=Commodore Amiga
StartPageLogo=Commodore Amiga
Command=winuae.exe -f [ROMFILE]
RomFilter=
Database=[PC] Commodore Amiga
MapFile=
RomPath=D:\Roms\Commodore Amiga\Roms
SnapPath=D:\Assets\Commodore Amiga\Snaps
TitlePath=D:\Assets\Commodore Amiga\Titles
BoxPath=D:\Assets\Commodore Amiga\Boxes
CartPath=D:\Assets\Commodore Amiga\Cartridges
ManualPath=D:\Assets\Commodore Amiga\Manuals
ControlPanelPath=D:\Assets\Commodore Amiga\Controls
WorkingPath=D:\Emulators\WinUAE
MapKeys=True
WaitBeforeKeys=3000
SendKeys={enter}
ReplaceDash=False
ReplaceUnder=True
Capitals=False
RemoveBrackets=True
ShowDesktop=True
Debug=False
AlsoLaunch=
OLDatZip=
LaunchBefore=
LaunchAfter=
ExcludedFiles=
CustomBackground=
PlayMusic=False
DontShowInfo=
PlaySelectionMusic=False
PCGame=False
GamesIn7Zips=False
PlayInScreenSaver=False
ShowMostPlayed=True
RandomMostPlayed=True
CDCheck=False
CDCheckFile=
lastgame=
[Emulator_3]
CDCheckFile=
CDCheck=False
ShowMostPlayed=True
GamesIn7Zips=False
PCGame=False
DontShowInfo=
PlayMusic=False
CustomBackground=
ExcludedFiles=
LaunchAfter=
LaunchBefore=
OLDatZip=
AlsoLaunch=
Debug=False
ShowDesktop=True
RemoveBrackets=True
Capitals=False
ReplaceUnder=True
ReplaceDash=False
SendKeys=
WaitBeforeKeys=
MapKeys=True
WorkingPath=D:\Emulators\blueMSX
ControlPanelPath=D:\Assets\Microsoft MSX\Controls
ManualPath=D:\Assets\Microsoft MSX\Manuals
CartPath=D:\Assets\Microsoft MSX\Cartridges
BoxPath=D:\Assets\Microsoft MSX\Boxes
TitlePath=D:\Assets\Microsoft MSX\Titles
SnapPath=D:\Assets\Microsoft MSX\Snaps
RomPath=D:\Roms\Microsoft MSX\Roms
MapFile=
Database=[PC] Microsoft MSX
RomFilter=
Command=blueMSX.exe /machine "MSX" /fullscreen /rom1 "[ROMPATH]\[ROMFILE]"
StartPageLogo=MSX
StartPageName=Microsoft MSX
TitleText=Microsoft MSX
Info=Support for SG-1000,SC-3000,SF-7000,ColecoVision,SVI318/328, MSX, MSX2, MSX2+, and turboR with machine customization, emulator
Website=http://www.bluemsx.com/
RequiredFiles=
DownloadUrl=http://www.gamesdbase.com/setupwizard/emulators/download/blueMSX.7z
Rating=8.8
Version=2.8.2
Emulator=blueMSX
Category=PC
System=Microsoft MSX
lastgame=
[Emulator_4]
System=Nintendo N64
Category=Console
Emulator=Project64k
Version=0.39
Rating=8.9
DownloadUrl=http://www.gamesdbase.com/setupwizard/emulators/download/Project64k.7z
RequiredFiles=
Website=http://pj64k.blogspot.com/
Info=Nintendo 64 emulator
TitleText=Nintendo N64
StartPageName=Nintendo N64
StartPageLogo=Nintendo N64
Command=Project64.exe [ROMPATH]\[ROMFILE]
RomFilter=
Database=[Console] Nintendo N64
MapFile=
RomPath=D:\Roms\Nintendo N64\Roms
SnapPath=D:\Assets\Nintendo N64\Snaps
TitlePath=D:\Assets\Nintendo N64\Titles
BoxPath=D:\Assets\Nintendo N64\Boxes
CartPath=D:\Assets\Nintendo N64\Cartridges
ManualPath=D:\Assets\Nintendo N64\Manuals
ControlPanelPath=D:\Assets\Nintendo N64\Controls
WorkingPath=D:\Emulators\Project64
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=False
ReplaceUnder=True
Capitals=False
RemoveBrackets=True
ShowDesktop=True
Debug=False
AlsoLaunch=
OLDatZip=
LaunchBefore=
LaunchAfter=
ExcludedFiles=
CustomBackground=
PlayMusic=False
DontShowInfo=
PCGame=False
GamesIn7Zips=False
ShowMostPlayed=True
CDCheck=False
CDCheckFile=
lastgame=
[Emulator_5]
CDCheckFile=
CDCheck=False
ShowMostPlayed=True
GamesIn7Zips=False
PCGame=False
DontShowInfo=
PlayMusic=False
CustomBackground=
ExcludedFiles=
LaunchAfter=
LaunchBefore=
OLDatZip=
AlsoLaunch=
Debug=False
ShowDesktop=True
RemoveBrackets=True
Capitals=False
ReplaceUnder=True
ReplaceDash=False
SendKeys=
WaitBeforeKeys=
MapKeys=True
WorkingPath=D:\Emulators\Nestopia
ControlPanelPath=D:\Assets\Nintendo NES\Controls
ManualPath=D:\Assets\Nintendo NES\Manuals
CartPath=D:\Assets\Nintendo NES\Cartridges
BoxPath=D:\Assets\Nintendo NES\Boxes
TitlePath=D:\Assets\Nintendo NES\Titles
SnapPath=D:\Assets\Nintendo NES\Snaps
RomPath=D:\Roms\Nintendo NES\Roms
MapFile=
System=Nintendo NES
Category=Console
Emulator=Nestopia
Version=1.41.1
Rating=8.6
DownloadUrl=http://www.gamesdbase.com/setupwizard/emulators/download/Nestopia.7z
RequiredFiles=
Website=http://nestopia.sourceforge.net/
Info=Nintendo NES 8bit emulator
TitleText=Nintendo NES
StartPageName=Nintendo NES
StartPageLogo=Nintendo NES
Command=Nestopia.exe "[ROMPATH]\[ROMFILE]"
RomFilter=
Database=[Console] Nintendo NES
lastgame=
[Emulator_6]
CDCheckFile=
CDCheck=False
ShowMostPlayed=True
GamesIn7Zips=False
PCGame=False
DontShowInfo=
PlayMusic=False
CustomBackground=
ExcludedFiles=
LaunchAfter=
LaunchBefore=
OLDatZip=
AlsoLaunch=
Debug=False
ShowDesktop=True
RemoveBrackets=True
Capitals=False
ReplaceUnder=True
ReplaceDash=False
SendKeys=
WaitBeforeKeys=
MapKeys=True
WorkingPath=D:\Emulators\Snes9x
ControlPanelPath=D:\Assets\Nintendo SNES\Controls
ManualPath=D:\Assets\Nintendo SNES\Manuals
CartPath=D:\Assets\Nintendo SNES\Cartridges
BoxPath=D:\Assets\Nintendo SNES\Boxes
TitlePath=D:\Assets\Nintendo SNES\Titles
SnapPath=D:\Assets\Nintendo SNES\Snaps
RomPath=D:\Roms\Nintendo SNES\Roms
MapFile=
System=Nintendo SNES
Category=Console
Emulator=Snes9x
Version=1.53
Rating=9.0
DownloadUrl=http://www.gamesdbase.com/setupwizard/emulators/download/snes9x.7z
RequiredFiles=
Website=http://www.snes9x.com/
Info=Super Nintendo emulator
TitleText=Nintendo SNES
StartPageName=Nintendo SNES
StartPageLogo=Nintendo SNES
Command=snes9x.exe -fullscreen "[ROMPATH]\[ROMFILE]"
RomFilter=
Database=[Console] Nintendo SNES
lastgame=
[Emulator_7]
System=Nintendo Wii
Category=Console
Emulator=Dolphin
Version=3.0-631
Rating=7.9
DownloadUrl=http://www.gamesdbase.com/setupwizard/emulators/download/Dolphin.7z
RequiredFiles=DirectX Runtime, Microsoft Visual C++ 2010 Redistributable Package
Website=http://www.dolphin-emulator.com
Info=Nintendo Gamecube and Wii emulator
TitleText=Nintendo Wii
StartPageName=Nintendo Wii
StartPageLogo=Nintendo Wii
Command=Dolphin.exe -e "[ROMPATH]\[ROMFILE]"
RomFilter=
Database=[Console] Nintendo Wii
MapFile=
RomPath=D:\Roms\Nintendo Wii\Roms
SnapPath=D:\Assets\Nintendo Wii\Snaps
TitlePath=D:\Assets\Nintendo Wii\Titles
BoxPath=D:\Assets\Nintendo Wii\Boxes
CartPath=D:\Assets\Nintendo Wii\Cartridges
ManualPath=D:\Assets\Nintendo Wii\Manuals
ControlPanelPath=D:\Assets\Nintendo Wii\Controls
WorkingPath=D:\Emulators\Dolphin
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=False
ReplaceUnder=True
Capitals=False
RemoveBrackets=True
ShowDesktop=True
Debug=False
AlsoLaunch=
LaunchBefore=
LaunchAfter=
ExcludedFiles=
CustomBackground=
PlayMusic=False
DontShowInfo=
PCGame=False
GamesIn7Zips=False
ShowMostPlayed=True
CDCheck=False
CDCheckFile=
[Emulator_8]
ControlPanelPath=
configFile=
MAPFile=
ManualPath=
CartPath=
BoxPath=
TitlePath=
SnapPath=
Command=
RomPath=
WorkingPath=
StartPageLogo=
TITLETEXT=
STARTPAGENAME=
Enabled=False
[Emulator_9]
[Emulator_11]
STARTPAGENAME=
TITLETEXT=
StartPageLogo=
WorkingPath=
RomPath=
Command=
SnapPath=
TitlePath=
BoxPath=
CartPath=
ManualPath=
[SetupWizard]
EmuPath1=D:\Emulators
AssetPath1=D:\Assets
RomPath1=D:\Roms
DefaultPathPrompt=True
DownloadDatabasePrompt=True
DownloadEmulatorPrompt=True
WizardMode=2
CustomArray=MAME Settings
SearchArray=
SavePosition=False
SectionIndex=19
SearchText=
EmulatorIndex=2
EmulatorGroupIndex=0
DaphneIndex=0
HTMLAppsIndex=0
ExternalAppsIndex=0
RadioStationsIndex=23
NewsFeedsIndex=0
ShowPanel=True
FontSize=1
WindowState=2
WindowSize=650,647
WindowLocation=515,271
[Weather]
Location=Stuttgart, Germany
Code=GMXX0128
Centigrade=True
[LIST_SETTINGS_8]
displaybackgroundimage=True
displaybackgroundimageemu=False
displaystartpagemenuimage=False
displaystartpagemenuimage2=False
displaystartpagelistnotforcebaksnap=False
displayimagelist=False
[LIST_SETTINGS_20_EMU_4]
displaystartpagemenuimage=True
displaystartpagelistnotforcebaksnap=True
displayimagelist=1
[LIST_SETTINGS_1001]
displaybackgroundimageemu=True
displayimagelist=True
Hi, I am aware there is no audio in VOBS. GameEx is like this because if it tries to play a VOB from a DVD it often has the wrong audio track. Its a limitation I am afraid.
Edited by Draco1962
