[RESOLVED] Why does "Mame Emu Map" always pops up when starting GameEx?
Hi Sven, I am the developer of GameEx. Unfortunatly that does not say it all to help me fix your issue. Could you please post your log file and let me know more about how it pops up or what it looks like?
Thanks.
Tom.
Hi Tom,
thanks for the fast reply.
I hope my problem is no big deal for you.
I doubleklick on "GameEx" and the screen gets into fullscreen, for a short second the GameEx Logo appears but then i'm back to the desktop and an new window opens (MameEmuMap Magician).
The GameEx program ist still running in the taskbar and i can open it.
I don't really know what that tool does. I already hit the save configuration button but it appears the next GameEx start again.
Below i posted you the Log, hope that helps. :o)
PS: and sorry for the weird English, i hope its not that bad! ;o)
10:20:57.7 26.07.2012: Opening Configuration File
10:20:57.7 26.07.2012: GameEx: Version 12.78: Starting Log
10:20:57.7 26.07.2012: Operating System Platform: Win32NT
10:20:57.7 26.07.2012: Operating System Name: Windows 7
10:20:57.7 26.07.2012: Operating System Version: 6.1.7601
10:20:57.7 26.07.2012: Aero running
10:20:57.7 26.07.2012: Initializing Vista/Windows 7 volume control
10:20:57.7 26.07.2012: Getting CPU and RAM info
10:20:57.7 26.07.2012: AMD Phenom™ II X4 940 Processor, 8190MB
10:20:57.7 26.07.2012: 3Ghz - 4 Cores or CPU's
10:20:57.7 26.07.2012: Running Randomize()
10:20:57.7 26.07.2012: Loading PlugIns
10:20:57.7 26.07.2012: Checking for applications to Launch On Startup
10:20:57.7 26.07.2012: Running Misc startup tasks
10:20:57.7 26.07.2012: Setting Menu types
10:20:57.7 26.07.2012: Getting Configuration Values
10:20:57.7 26.07.2012: Using Theme: Default - Media Center - Background
10:20:57.7 26.07.2012: Checking for alternate Image Directory for Theme: Default - Media Center - Background
10:20:57.7 26.07.2012: Using Images from theme: Default - Media Center V1\MEDIA\
10:20:57.7 26.07.2012: Launching HideOS.exe
10:20:57.7 26.07.2012: Initialising Video/MNG DLL's
10:20:57.7 26.07.2012: GameEx will check for media insertion (may affect performance)
10:20:57.7 26.07.2012: Hiding Taskbar
10:20:57.8 26.07.2012: Is Media Center running?
10:20:57.8 26.07.2012: Checking/Creating LCD Registry values
10:20:57.8 26.07.2012: Check Media Center Exit/Start Mode
10:20:57.8 26.07.2012: Media Center Mode 2
10:20:57.8 26.07.2012: Video previews on. Warning: Only recommended on modern systems
10:20:57.8 26.07.2012: Custom Game Device Input enabled: Getting custom codes
10:20:57.8 26.07.2012: Snap Delay set to: 2
10:20:57.8 26.07.2012: Get other settings
10:20:57.8 26.07.2012: Desktop set to Hide ICONS and set Background to Black
10:20:57.8 26.07.2012: Set: Find emulator artwork on best match basis
10:20:57.8 26.07.2012: Start work for Form
10:20:57.8 26.07.2012: Getting Original Screen Size
10:20:57.8 26.07.2012: Opening Database Connection
10:20:57.9 26.07.2012: Initializing Component
10:20:57.9 26.07.2012: MAME Path is: D:\GameEx
10:20:57.9 26.07.2012: MAME EXE file is: Mame Mapping Magician.exe
10:20:57.9 26.07.2012: ROM Paths are: D:\GameEx\DEMO;D:\GameEx\DEMO\MAME
10:20:57.9 26.07.2012: Catver.ini is located at: D:\GameEx\DATA\catver.ini
10:20:57.9 26.07.2012: controls.ini is located at: D:\GameEx\DATA\controls.ini
10:20:58.0 26.07.2012: History.dat is located at: D:\GameEx\DATA\history.dat
10:20:58.0 26.07.2012: nplayers.ini is located at: D:\GameEx\DATA\nplayers.ini
10:20:58.0 26.07.2012: command.dat is located at: D:\GameEx\DATA\command.dat
10:20:58.0 26.07.2012: MAMEinfo.dat is located at: D:\GameEx\DATA\mameinfo.dat
10:20:58.0 26.07.2012: Loading Controls.ini map file
10:20:58.0 26.07.2012: Snap Path is: D:\GameEx\DEMO\MAME\snaps
10:20:58.0 26.07.2012: Background Snap Path: Not Found
10:20:58.0 26.07.2012: AVI Snap Path is: D:\GameEx\DEMO\MAME\video
10:20:58.0 26.07.2012: Flyer Path is: D:\GameEx\DEMO\MAME\flyers
10:20:58.0 26.07.2012: Cabinet Path is: D:\GameEx\DEMO\MAME\cabinets
10:20:58.0 26.07.2012: Cabinet 3D Path is: D:\GameEx\DEMO\MAME\cabinets3d
10:20:58.0 26.07.2012: Title Path is: D:\GameEx\DEMO\MAME\titles
10:20:58.0 26.07.2012: PCB Path: Not Found
10:20:58.0 26.07.2012: Artwork Preview Path: Not Found
10:20:58.0 26.07.2012: Panel Path is: D:\GameEx\DEMO\MAME\cpanel
10:20:58.0 26.07.2012: Manual Path is: D:\GameEx\DEMO\MAME\manual
10:20:58.0 26.07.2012: Icon Path is: D:\GameEx\DEMO\MAME\icons
10:20:58.0 26.07.2012: Marquee Path is: D:\GameEx\DEMO\MAME\marquees
10:20:58.0 26.07.2012: Applying Language/Text
10:20:58.0 26.07.2012: Text/Language: English
10:20:58.0 26.07.2012: Loading Language/Text
10:20:58.0 26.07.2012: Loading Custom Emulators
10:20:58.0 26.07.2012: Loading Emulator 1: MAME
10:20:58.0 26.07.2012: Loading Emulator 2: Commodore Amiga
10:20:58.0 26.07.2012: Loading Emulator 3: Microsoft MSX
10:20:58.0 26.07.2012: Loading Emulator 4: Nintendo N64
10:20:58.0 26.07.2012: Loading Emulator 5: Nintendo NES
10:20:58.0 26.07.2012: Loading Emulator 6: Nintendo SNES
10:20:58.0 26.07.2012: Loading Emulator 7: Nintendo Wii
10:20:58.0 26.07.2012: Loading Emulator 8: [Console] Nintendo N64 (1964)
10:20:58.0 26.07.2012: Using Version 3 Themes Animations
10:20:58.0 26.07.2012: Retrieving resolution setting
10:20:58.0 26.07.2012: Using General Font: HandelGothic BT
10:20:58.0 26.07.2012: Using Title Font: HandelGothic BT
10:20:58.0 26.07.2012: GameEx will try to reduce CPU usage
10:20:58.1 26.07.2012: Initialising Direct3D
10:20:58.2 26.07.2012: Applying GameEx is Loading Image
10:20:58.2 26.07.2012: Setting Resolution to 1680x1050 32 bit color
10:20:58.2 26.07.2012: Creating Surfaces
10:20:58.4 26.07.2012: Creating Primary Surface - Full Screen Mode
10:20:58.4 26.07.2012: Creating Back Buffer
10:20:58.4 26.07.2012: Loading graphic Surfaces
10:20:58.4 26.07.2012: Display is running at: 1680x1050 32bit color, 59hz
10:20:58.4 26.07.2012: Adapter: ATI Radeon HD 4800 Series
10:20:58.4 26.07.2012: Max texture size: 8192x8192
10:20:58.4 26.07.2012: Available texture memory: 736MB
10:20:58.4 26.07.2012: Initialising Bass Audio Library
10:20:58.5 26.07.2012: Creating Surfaces Misc and Dialogs
10:20:58.6 26.07.2012: Creating Surfaces Volume
10:20:58.6 26.07.2012: Creating Surfaces Arrows
10:20:58.6 26.07.2012: Creating Surfaces GameEXlogo Text
10:20:58.6 26.07.2012: Creating Surfaces Toolbar
10:20:58.6 26.07.2012: Creating Surfaces Toolbar Controls
10:20:58.6 26.07.2012: Creating Surfaces Backgrounds
10:20:58.6 26.07.2012: Creating Surfaces GameEx Logo
10:20:58.6 26.07.2012: Creating Surface Unselected
10:20:58.7 26.07.2012: Creating Surfaces Snaps
10:20:58.7 26.07.2012: Creating Surfaces Menu and List Bars
10:20:58.9 26.07.2012: Creating Fonts
10:20:58.9 26.07.2012: Creating Game Font
10:20:59.0 26.07.2012: Creating Game Font Faded
10:20:59.1 26.07.2012: Creating Title Font
10:20:59.1 26.07.2012: Restoring Title Font From Cache
10:20:59.4 26.07.2012: Creating Font Black
10:20:59.4 26.07.2012: Creating Font Black Small
10:20:59.5 26.07.2012: Fonts Created Succesfully
10:20:59.6 26.07.2012: 7MB Video Memory Used
10:20:59.9 26.07.2012: Attempting to load game list
10:21:00.0 26.07.2012: Running: Mame Mapping Magician.exe -help
10:21:00.0 26.07.2012: Running: D: D:\GameEx\Mame Mapping Magician.exe -help > D:\GameEx\help.txt
10:21:00.1 26.07.2012: 32 bit MAME version detected on 64 bit windows
10:21:00.1 26.07.2012: MAME CMD options: -nowindow -joy -skip_gameinfo
10:21:00.1 26.07.2012: Initialising DirectInput for Gamepad support
10:21:00.1 26.07.2012: Using Device MotioninJoy Virtual Game Controller
10:21:00.2 26.07.2012: Loading Start Page
10:21:00.2 26.07.2012: Initializing MCE Remote
10:21:00.2 26.07.2012: Initialization OK! Starting GameEx!
10:21:00.2 26.07.2012: Testing Main Loop Once: Processing Frame
10:21:00.4 26.07.2012: Testing Main Loop Once: Main Loop ran successfully
10:21:22.9 26.07.2012: Exiting GameEx!
10:21:22.9 26.07.2012: Disposing all videos
10:21:22.9 26.07.2012: Deleting temporary Karaoke videos
10:21:22.9 26.07.2012: Disposing Image List
10:21:22.9 26.07.2012: Disposing Fonts
10:21:22.9 26.07.2012: Disposing Surfaces
10:21:23.0 26.07.2012: Saving Settings
10:21:23.0 26.07.2012: Shutting down Bass
10:21:23.1 26.07.2012: Closing HideOS.exe
10:21:23.3 26.07.2012: Disposing Plugins
10:21:23.3 26.07.2012: Closing database connection
10:21:23.3 26.07.2012: Checking for applications to Launch On Exit
10:21:23.3 26.07.2012: Media Center was not open when starting GameEx, so not launching
10:21:24.1 26.07.2012: Bye
Seems mame mapping magician is set to run in setup somewhere. I would look for that command-line in setup wizard and then remove it.
I found in MAME Settings, the Mame Exe leads to "Mame Mapping Magician.exe".
I changed it to "D:\Emulators\MAME\mame.exe" but on the next start the Magician showed up again. :o(
After that i checked the setup and it shows under MAME Settings the "Mame Mapping Magician.exe" once again.
Very strange.
Try editing the gameex.ini file directly. It has the appearance of an admin rights issue on your drive that is keeping you Setup Wizard from overwriting the changes. You may want to edit the properties for setupwizard.exe to Run as Administrator.
Problem solved. Thank you.
Maybe i should buy some glasses.
In the configuration for MAME i missed an entry that points to a directory that doesn't exists.
So every time i start GameEx it will overwrite the gameex.ini to bring up that magician.
Again thanks for the fast reply's and your help. :lol:
Cheers,
Sven
Glad you got it sorted! Happy gaming!
Edited by Draco1962
This thread is now marked as Resolved and has been closed. If the problem re-occurs, please start a new thread.
