here is my log
20:51:42.3 24/07/2012: Opening Configuration File
20:51:42.3 24/07/2012: GameEx: Version 12.77: Starting Log
20:51:42.3 24/07/2012: Operating System Platform: Win32NT
20:51:42.3 24/07/2012: Operating System Name: Windows XP
20:51:42.3 24/07/2012: Operating System Version: 5.1.2600
20:51:42.3 24/07/2012: Getting CPU and RAM info
20:51:42.3 24/07/2012: Intel® Core2 Quad CPU Q9550 @ 2.83GHz, 3071MB
20:51:42.3 24/07/2012: 2.83Ghz - 4 Cores or CPU's
20:51:42.3 24/07/2012: Running Randomize()
20:51:42.4 24/07/2012: Loading PlugIns
20:51:42.4 24/07/2012: Checking for applications to Launch On Startup
20:51:42.4 24/07/2012: Running Misc startup tasks
20:51:42.4 24/07/2012: Setting Menu types
20:51:42.4 24/07/2012: Getting Configuration Values
20:51:42.4 24/07/2012: Launching HideOS.exe
20:51:42.4 24/07/2012: Initialising Video/MNG DLL's
20:51:42.4 24/07/2012: GameEx will check for media insertion (may affect performance)
20:51:42.4 24/07/2012: Hiding Taskbar
20:51:42.4 24/07/2012: Is Media Center running?
20:51:42.4 24/07/2012: Checking/Creating LCD Registry values
20:51:42.4 24/07/2012: Check Media Center Exit/Start Mode
20:51:42.4 24/07/2012: Media Center Mode 2
20:51:42.5 24/07/2012: Video previews on. Warning: Only recommended on modern systems
20:51:42.5 24/07/2012: Snap Delay set to: 5
20:51:42.5 24/07/2012: Get other settings
20:51:42.5 24/07/2012: Desktop set to Hide ICONS and set Background to Black
20:51:42.5 24/07/2012: Set: Find emulator artwork on best match basis
20:51:42.5 24/07/2012: Using DirectInput for keyboard input
20:51:42.5 24/07/2012: Start work for Form
20:51:42.5 24/07/2012: Getting Original Screen Size
20:51:42.5 24/07/2012: Opening Database Connection
20:51:42.8 24/07/2012: Initializing Component
20:51:42.9 24/07/2012: MAME Path is: D:\MameUI32
20:51:42.9 24/07/2012: MAME EXE file is: groovymame32.exe
20:51:43.0 24/07/2012: ROM Path is: D:\MameUI32\roms
20:51:43.0 24/07/2012: Catver.ini is located at: C:\GameEx\DATA\catver.ini
20:51:43.0 24/07/2012: controls.ini is located at: C:\GameEx\DATA\controls.ini
20:51:43.0 24/07/2012: History.dat is located at: C:\GameEx\DATA\history.dat
20:51:43.0 24/07/2012: nplayers.ini is located at: C:\GameEx\DATA\nplayers.ini
20:51:43.0 24/07/2012: command.dat is located at: C:\GameEx\DATA\command.dat
20:51:43.1 24/07/2012: MAMEinfo.dat is located at: C:\GameEx\DATA\mameinfo.dat
20:51:43.1 24/07/2012: Loading Controls.ini map file
20:51:43.1 24/07/2012: Snap Path is: D:\MameUI32\snap
20:51:43.1 24/07/2012: Background Snap Path is: D:\MameUI32\snap
20:51:43.1 24/07/2012: AVI Snap Path is: D:\MameUI32\video
20:51:43.1 24/07/2012: Flyer Path is: D:\MameUI32\flyers
20:51:43.1 24/07/2012: Cabinet Path is: D:\MameUI32\cabinets
20:51:43.1 24/07/2012: Cabinet 3D Path: Not Found
20:51:43.1 24/07/2012: Title Path is: D:\MameUI32\titles
20:51:43.1 24/07/2012: PCB Path is: D:\MameUI32\pcb
20:51:43.1 24/07/2012: Artwork Preview Path is: D:\MameUI32\artwork preview
20:51:43.1 24/07/2012: Panel Path is: D:\MameUI32\cpanel
20:51:43.1 24/07/2012: Manual Path is: D:\MameUI32\manuals
20:51:43.1 24/07/2012: Icon Path is: D:\MameUI32\icons
20:51:43.1 24/07/2012: Marquee Path is: D:\MameUI32\marquees
20:51:43.1 24/07/2012: Applying Language/Text
20:51:43.1 24/07/2012: Text/Language: English
20:51:43.1 24/07/2012: Loading Language/Text
20:51:43.2 24/07/2012: Loading Custom Emulators
20:51:43.2 24/07/2012: Loading Emulator 1: Atari 5200
20:51:43.2 24/07/2012: Loading Emulator 2: Nintendo SNES
20:51:43.2 24/07/2012: Loading Emulator 3: Nintendo N64
20:51:43.2 24/07/2012: Using Version 3 Themes Animations
20:51:43.2 24/07/2012: Retrieving resolution setting
20:51:43.2 24/07/2012: Using General Font: Trebuchet MS
20:51:43.2 24/07/2012: Using Title Font: Trebuchet MS
20:51:43.2 24/07/2012: Initialising Direct3D
20:51:43.3 24/07/2012: Applying GameEx is Loading Image
20:51:43.3 24/07/2012: ERROR when loading Image. Probably does not exist.
20:51:43.3 24/07/2012: Setting Resolution to 640x480 32 bit color
20:51:43.4 24/07/2012: Creating Surfaces
20:51:43.5 24/07/2012: Creating Primary Surface - Full Screen Mode
20:51:43.5 24/07/2012: Creating Back Buffer
20:51:43.5 24/07/2012: Loading graphic Surfaces
20:51:43.5 24/07/2012: Display is running at: 640x480 32bit color, 60hz
20:51:43.5 24/07/2012: Adapter: ATI Radeon HD 4800 Series
20:51:43.5 24/07/2012: Max texture size: 8192x8192
20:51:43.5 24/07/2012: Available texture memory: 1137MB
20:51:43.5 24/07/2012: Initialising Bass Audio Library
20:51:43.5 24/07/2012: Creating Surfaces Misc and Dialogs
20:51:43.7 24/07/2012: Creating Surfaces Volume
20:51:43.7 24/07/2012: Creating Surfaces Arrows
20:51:43.7 24/07/2012: Creating Surfaces GameEXlogo Text
20:51:43.7 24/07/2012: Creating Surfaces Toolbar
20:51:43.7 24/07/2012: Creating Surfaces Toolbar Controls
20:51:43.7 24/07/2012: Creating Surfaces Backgrounds
20:51:43.7 24/07/2012: Creating Surfaces GameEx Logo
20:51:43.7 24/07/2012: Creating Surface Unselected
20:51:43.7 24/07/2012: Creating Surfaces Snaps
20:51:43.7 24/07/2012: Creating Surfaces Menu and List Bars
20:51:43.7 24/07/2012: Creating Fonts
20:51:43.7 24/07/2012: Creating Game Font
20:51:44.3 24/07/2012: Creating Game Font Faded
20:51:44.4 24/07/2012: Creating Title Font
20:51:44.4 24/07/2012: Restoring Title Font From Cache
20:51:44.5 24/07/2012: Creating Font Black
20:51:44.5 24/07/2012: Creating Font Black Small
20:51:44.6 24/07/2012: Fonts Created Succesfully
20:51:44.6 24/07/2012: 1MB Video Memory Used
20:51:44.7 24/07/2012: Attempting to load game list
20:51:45.5 24/07/2012: MAME CMD options: -nowindow -joy -skip_gameinfo
20:51:45.7 24/07/2012: --**--
20:51:45.7 24/07/2012: Error: A generic error occurred in GDI+.
20:51:45.7 24/07/2012: at System.Drawing.Image.Save(String filename, ImageCodecInfo encoder, EncoderParameters encoderParams)
20:51:45.7 24/07/2012: at System.Drawing.Image.Save(String filename, ImageFormat format)
20:51:45.7 24/07/2012: at System.Drawing.Image.Save(String filename)
20:51:45.7 24/07/2012: at GameEx.GameEx.mainform.a(String A_0, String[] A_1)
20:51:45.7 24/07/2012: at GameEx.GameEx.mainform.ax()
20:51:45.7 24/07/2012: at GameEx.GameEx.mainform.a(Boolean A_0, String A_1, Boolean A_2)
20:51:45.7 24/07/2012: at GameEx.GameEx.mainform..ctor()
20:51:45.7 24/07/2012: Closing database connection
20:51:45.7 24/07/2012: Disposing Plugins
20:51:45.7 24/07/2012: GameEx is exiting with errors
20:51:45.7 24/07/2012: Deleting search cache
20:51:46.0 24/07/2012: ERRORS DETECTED: EXITING
20:51:46.1 24/07/2012: Bye
Hi hafeez, and welcome to the GameEx forums!
You’ve made a good start by posting the contents of your log. Obviously there’s something going on here, but a bit more information regarding the nature of this error is going be of great value in determining the actual cause of the error. Perhaps you could provide some (or all) of the following details.
  • What are you doing when the error occurs? Can you reliably duplicate the error or does it seem to occur randomly?
  • Does this error occur when starting an emulator? Does this error appear to be realted to a specific emulator, and if so do you have that emulator running outside of GameEx?
  • What appears to happen in relation to GameEx when this error occurs (does GameEx crash, does the emulator appear to crash and return to GameEx, etc.)?
The above questions should hopefully provide some level of additional detail to work with. Depending on your answers to the questions above, we may ask that you post some additional GameEx system files. With your patience and perserverance I’m sure we’ll be able to determine the cause of your error. :D
Thanks!
I reviewed the log file and noted the following errors:
Can you tell us what theme you are using? Also, please take a look under that theme's MEDIA folder and confirm if there is a image file gameexisloading.png there. If not, copy one from another theme into that folder and try again.
