I'm trying to play Ocarina of Time, and I would like to know the best configuration for my controller(specified above)
Thankss
Oh BTW the Profiler didn't include the one for Zelda. :/
Please help ASAP
Welcome to the forums. Before we can attempt to help you out, would you care to let us know what emulator you are using? Did you get it configured to work as expected outside of GameEx? Are you using any 3rd party profiling software (i.e. Logitech Profiler, Xpadder, Joy2Key, etc.)?
If your talking about Project64, it's pretty simple steps that can be found here. I don't use a Logitech but I do use a 360 controller and I'm pretty sure after you have your controller connected, open the emulator and then it should show it in the drop down menu in Configure Input.
Im a fan of doing things old school. If I don't find what I want, I just load the game and customize the profile untill it feels good.
Or you can try looking at profiles for a PS3 controller and layer it over the logitech profile.
Edited by Draco1962
