thurmansevolution Posted July 16, 2012 Share Posted July 16, 2012 Hello all! I was very happy to see the new version of GameEx this morning, and all of its new features seems to be excellant! There is just one problem I am having though when trying to start up the new version of GameEx - It stops responding and Windows shuts it down. I have tried uninstalling it and then manually downloading it and reinstalling, but it still does the same thing. Is there anything in Windows that I have to update to get it to run correctly?I'm attaching the log file that was created after running the 12.71 version.- I've downgraded to the 12.65 version, lol its the only other version that was saved on my harddisk.Thanks in advance!! LC[EDIT] - Oh, lol, failed to mention before - I am running Windows 7.log.txt Link to comment Share on other sites More sharing options...
AlphaUMi Posted July 16, 2012 Share Posted July 16, 2012 Instead of opening a new thread I write here because I have the same issue with v12.71. There is a "Not Restoring Emulator Database From Cache" in the log, so i guess it has something to do with the new database format.I emptied my GameEx folder except for GameEx.ini and custominput.ini, in order to get a clean installation, and then ran the offline installer. GameEx starts loading the databases, then crashes to desktop: I mean, no error window, it crashes abruptly and gives me a black desktop. Curiously, the right click doesn't work, maybe because HideOS is still running, but I can't find it in the list of active processes.Running XP SP3.At the moment I am completely unable to run GameEx. Please help.Alpha.log.txtGameEx.txt Link to comment Share on other sites More sharing options...
Draco1962 Posted July 16, 2012 Share Posted July 16, 2012 Tom - will this possibly require that they install some version of SQLite or is that installed with the update? Link to comment Share on other sites More sharing options...
Tom Speirs Posted July 16, 2012 Share Posted July 16, 2012 It seems the .net SQLite library does not like nulls in date fileds. It should be fixed in 12.72. Now available.Thanks.PS: All libraries are included I guess there are just a few issues with it. Link to comment Share on other sites More sharing options...
AlphaUMi Posted July 16, 2012 Share Posted July 16, 2012 Tom - will this possibly require that they install some version of SQLite or is that installed with the update?In fact I don't have any SQLite installed on my PC. And, having followed the installation process, I can say that no SQLite installation took place.But, I ask, was it necessary to have Microsoft Office installed in order for GameEx to read mdb files? I can't say because I have MS Office installed.Thanks for you attention Draco, I hope this issue will be resolved soon. Link to comment Share on other sites More sharing options...
AlphaUMi Posted July 16, 2012 Share Posted July 16, 2012 Thanks Tom! I'm going to download and install the update! I'll let you know in a short time! Thanks again! Link to comment Share on other sites More sharing options...
AlphaUMi Posted July 16, 2012 Share Posted July 16, 2012 Sorry, I got an instant crash. It seems that GameEx can't find "C:\GameEx\DATA\EMULATORS". I installed GameEx in a different directory.log.txt Link to comment Share on other sites More sharing options...
Tom Speirs Posted July 16, 2012 Share Posted July 16, 2012 Sorry about that. Please do a manual install of the same version. Link to comment Share on other sites More sharing options...
AlphaUMi Posted July 16, 2012 Share Posted July 16, 2012 Sorry about that. Please do a manual install of the same version.I did, Tom. I ran the offline installer. Link to comment Share on other sites More sharing options...
thurmansevolution Posted July 16, 2012 Author Share Posted July 16, 2012 Hello again to all!Thanks Tom, Draco, as well as all other team members for all the hard work so far! I manually downloaded the 12.72 version, and coming up with the same errors as AlphaUMi...its automatically crashing and stating that it cannot find the C:\GameEx\DATA\EMULATORSI even messed up (for my part) and completely unstalled all of GameEx, settings, config....to give a full fresh install and it still shows the same error.log.txt Link to comment Share on other sites More sharing options...
AlphaUMi Posted July 16, 2012 Share Posted July 16, 2012 Hello again to all!Thanks Tom, Draco, as well as all other team members for all the hard work so far! I manually downloaded the 12.72 version, and coming up with the same errors as AlphaUMi...its automatically crashing and stating that it cannot find the C:\GameEx\DATA\EMULATORSI even messed up (for my part) and completely unstalled all of GameEx, settings, config....to give a full fresh install and it still shows the same error.It's not a matter of GameEx configuraton, I fear. I hope that you backed up at least GameEx.ini and custominput.ini, just to save your settings... Link to comment Share on other sites More sharing options...
thurmansevolution Posted July 16, 2012 Author Share Posted July 16, 2012 Yeah, I fear the same thing. Lol, and I didn't back up any files, but its cool - It'll only take an evening with an ice cold beer to reconfigure everything. I just hope that it will get fixed soon so I can start reconfiguring and have the cab back working 100% .This might just be a weird hunch, but I think it maybe that it's looking mainly toward C:\ that it's causing the error...my computer is set up that my harddisk is H:\ due to the amount of input drives on the front (eg. SD card slot, etc) - but I can't find a way for it to look at H:\GameEX\DATA\EMULATORS. Link to comment Share on other sites More sharing options...
thurmansevolution Posted July 16, 2012 Author Share Posted July 16, 2012 Is there a way I can get the 12.70 version that I can use until the newer version is fixed? Link to comment Share on other sites More sharing options...
Adultery Posted July 16, 2012 Share Posted July 16, 2012 /side note: Always good to see the vets drop in a bug on accident once in a while. Makes me feel better about letting the occasional bug get through in my own projects. @te: Tom fixes bugs fast. I wouldn't worry about getting stuck with a stagnant version for long. I suppose I better update and see if it works for me or not. 1 Link to comment Share on other sites More sharing options...
Draco1962 Posted July 16, 2012 Share Posted July 16, 2012 I just performed the straight download with no errors. I did notice that it went straight to updating all the DBs and started updating artwork, which is great, although I might be tempted to request that this be an optional update that can be enabled/disabled via Setup Wizard. Hopefully it will not do this automagically everytime I boot up GameEx. 1 Link to comment Share on other sites More sharing options...
AlphaUMi Posted July 16, 2012 Share Posted July 16, 2012 /side note: Always good to see the vets drop in a bug on accident once in a while. Makes me feel better about letting the occasional bug get through in my own projects. @te: Tom fixes bugs fast. I wouldn't worry about getting stuck with a stagnant version for long. I suppose I better update and see if it works for me or not. Yes, I missed the bugs from the bottom of my hearth! Link to comment Share on other sites More sharing options...
Adultery Posted July 16, 2012 Share Posted July 16, 2012 @Alpha: You have bugs in your fireplace? LOL! J/K. Link to comment Share on other sites More sharing options...
AlphaUMi Posted July 16, 2012 Share Posted July 16, 2012 @Adultery: actually my fireplace lighted my whole GameEx house! I need the Fireman!!! Link to comment Share on other sites More sharing options...
Adultery Posted July 16, 2012 Share Posted July 16, 2012 Shoot. Same problem as mentioned above. Damn, I was gonna actually play a game for a change. 18:36:59.5 7/16/2012: Opening Configuration File18:36:59.6 7/16/2012: GameEx: Version 12.72: Starting Log18:36:59.6 7/16/2012: Operating System Platform: Win32NT18:36:59.6 7/16/2012: Operating System Name: Windows 718:36:59.6 7/16/2012: Operating System Version: 6.1.760118:36:59.6 7/16/2012: Aero running18:36:59.6 7/16/2012: Initializing Vista/Windows 7 volume control18:36:59.6 7/16/2012: Getting CPU and RAM info18:36:59.6 7/16/2012: Intel® Core2 Duo CPU E7500 @ 2.93GHz, 3327MB18:36:59.6 7/16/2012: 2.93Ghz - 2 Cores or CPU's18:36:59.6 7/16/2012: Running Randomize()18:36:59.6 7/16/2012: Loading PlugIns18:36:59.6 7/16/2012: Loaded Plugin:"Game Info Plugin" Version 1.0.0b3 By Adultery18:36:59.6 7/16/2012: PlugIn: "Game Info Plugin" Initialized OK18:36:59.6 7/16/2012: Using Plugin System Version: 1.418:36:59.6 7/16/2012: Loaded Plugin:"MAME Commander" Version 2.08 By Adultery18:36:59.6 7/16/2012: PlugIn: "MAME Commander" Initialized OK18:36:59.6 7/16/2012: Using Plugin System Version: 1.418:36:59.6 7/16/2012: Loaded Plugin:"Visual Pinball Plugin" Version 1.0.2 b2 By Adultery18:36:59.6 7/16/2012: PlugIn: "Visual Pinball Plugin" Initialized OK18:36:59.6 7/16/2012: Using Plugin System Version: 1.418:36:59.6 7/16/2012: Loaded Plugin:"Xpadder Plugin" Version 1.0.4 By Adultery18:36:59.7 7/16/2012: PlugIn: "Xpadder Plugin" Initialized OK18:36:59.7 7/16/2012: Using Plugin System Version: 1.418:36:59.7 7/16/2012: Checking for applications to Launch On Startup18:36:59.7 7/16/2012: Running Misc startup tasks18:36:59.7 7/16/2012: Setting Menu types18:36:59.7 7/16/2012: Getting Configuration Values18:36:59.7 7/16/2012: Using Theme: Default - MegaMame - 1680x105018:36:59.7 7/16/2012: Checking for alternate Image Directory for Theme: Default - MegaMame - 1680x105018:36:59.7 7/16/2012: Launching GameExtender.exe (GameExtender Viewer)18:36:59.9 7/16/2012: Launching HideOS.exe18:36:59.9 7/16/2012: Initialising Video/MNG DLL's18:36:59.9 7/16/2012: GameEx will check for media insertion (may affect performance)18:36:59.9 7/16/2012: Hiding Taskbar18:36:59.9 7/16/2012: Using Cabinet Friendly Control System18:36:59.9 7/16/2012: Is Media Center running?18:36:59.9 7/16/2012: Checking/Creating LCD Registry values18:36:59.9 7/16/2012: Check Media Center Exit/Start Mode18:36:59.9 7/16/2012: Media Center Mode 218:36:59.9 7/16/2012: Video previews on. Warning: Only recommended on modern systems18:36:59.9 7/16/2012: Custom Keyboard Input enabled: Getting custom codes18:37:00.0 7/16/2012: Advanced Custom Keyboard Input enabled: Getting custom codes18:37:00.0 7/16/2012: Snap Delay set to: 218:37:00.0 7/16/2012: Get other settings18:37:00.0 7/16/2012: Desktop set to Hide ICONS and set Background to Black18:37:00.0 7/16/2012: Set: Find emulator artwork on best match basis18:37:00.0 7/16/2012: Using DirectInput for keyboard input18:37:00.0 7/16/2012: Start work for Form18:37:00.0 7/16/2012: Getting Original Screen Size18:37:00.0 7/16/2012: Opening Database Connection18:37:00.1 7/16/2012: Initializing Component18:37:00.1 7/16/2012: MAME Path is: F:\Emulators\MAME18:37:00.1 7/16/2012: Client/Server MAME Path is: C:\MAMEHub\dist18:37:00.1 7/16/2012: Client/Server MAME EXE file is: vmame.exe18:37:00.1 7/16/2012: Use Client/Server MAME On. vmame.exe will launch NetPlay games18:37:00.1 7/16/2012: Model 2 Path Path is: F:\Emulators\M218:37:00.1 7/16/2012: Multi Core/Hyper Threading detected. Looking for emulator_multicpu.exe18:37:00.1 7/16/2012: Model 2 EXE file is: emulator_multicpu.exe18:37:00.1 7/16/2012: Model 2 emulator with command line support detected18:37:00.1 7/16/2012: Use Model 2 on. emulator_multicpu.exe will launch Sega Model 2 games18:37:00.1 7/16/2012: MAME EXE file is: mame.exe18:37:00.1 7/16/2012: ROM Path is: F:\Emulators\MAME\roms18:37:00.1 7/16/2012: Catver.ini is located at: F:\Emulators\MAME\Catver.ini18:37:00.1 7/16/2012: controls.ini is located at: F:\Emulators\MAME\controls.ini18:37:00.2 7/16/2012: History.dat is located at: F:\Emulators\MAME\history.dat18:37:00.2 7/16/2012: nplayers.ini is located at: F:\Emulators\MAME\nplayers.ini18:37:00.2 7/16/2012: command.dat is located at: F:\Emulators\MAME\command.dat18:37:00.2 7/16/2012: MAMEinfo.dat is located at: F:\Emulators\MAME\mameinfo.dat18:37:00.2 7/16/2012: Loading Controls.ini map file18:37:00.2 7/16/2012: Snap Path is: C:\Artwork\MAME\Snap18:37:00.2 7/16/2012: Background Snap Path: Not Found18:37:00.2 7/16/2012: AVI Snap Path is: C:\Artwork\MAME\Video_MP418:37:00.2 7/16/2012: Flyer Path is: C:\Artwork\MAME\Advert18:37:00.2 7/16/2012: Cabinet Path is: C:\Artwork\MAME\Cabinet18:37:00.2 7/16/2012: Cabinet 3D Path is: C:\Artwork\MAME\Cabinet_3D18:37:00.2 7/16/2012: Title Path is: C:\Artwork\MAME\Title18:37:00.2 7/16/2012: PCB Path is: C:\Artwork\MAME\PCB18:37:00.2 7/16/2012: Artwork Preview Path is: C:\Artwork\MAME\GameEx18:37:00.2 7/16/2012: Panel Path is: C:\Artwork\MAME\CP18:37:00.2 7/16/2012: Manual Path is: C:\Artwork\MAME\Manual18:37:00.2 7/16/2012: Icon Path is: C:\Artwork\MAME\Icon18:37:00.2 7/16/2012: Marquee Path is: C:\Artwork\MAME\Marquee18:37:00.2 7/16/2012: Applying Language/Text18:37:00.2 7/16/2012: Text/Language: Custom18:37:00.2 7/16/2012: Loading Language/Text18:37:00.2 7/16/2012: Loading Custom Emulators18:37:00.2 7/16/2012: Loading Emulator 1: NINTENDO N6418:37:00.2 7/16/2012: Loading Emulator 2: NINTENDO SNES18:37:00.2 7/16/2012: Loading Emulator 3: NINTENDO NES18:37:00.2 7/16/2012: Loading Emulator 4: NINTENDO GameBoy Advance18:37:00.2 7/16/2012: Loading Emulator 5: NINTENDO GameBoy Color18:37:00.2 7/16/2012: Loading Emulator 6: SEGA CD18:37:00.2 7/16/2012: Loading Emulator 7: SEGA Genesis18:37:00.2 7/16/2012: Loading Emulator 8: SEGA Master System18:37:00.2 7/16/2012: Loading Emulator 9: SEGA Game Gear18:37:00.3 7/16/2012: Loading Emulator 10: NEC TurboGrafx-1618:37:00.3 7/16/2012: Loading Emulator 11: ATARI 260018:37:00.3 7/16/2012: Loading Emulator 12: ATARI 520018:37:00.3 7/16/2012: Loading Emulator 13: ATARI 780018:37:00.3 7/16/2012: Loading Emulator 14: COLECO Vision18:37:00.3 7/16/2012: Loading Emulator 15: MATTEL Intellivision18:37:00.3 7/16/2012: Loading Emulator 17: VISUAL PinMAME18:37:00.3 7/16/2012: Loading Emulator 20: SONY Playstation18:37:00.3 7/16/2012: Loading Emulator 21: SEGA Saturn18:37:00.3 7/16/2012: Loading Emulator 22: NINTENDO Game Cube18:37:00.3 7/16/2012: Loading Emulator 23: MICROSOFT Windows18:37:00.3 7/16/2012: Loading Emulator 24: OPEN Beats Of Rage18:37:00.3 7/16/2012: Loading Emulator 25: MICROSOFT Windows18:37:00.3 7/16/2012: Loading Emulator 27: NINTENDO DS18:37:00.3 7/16/2012: Loading Emulator 28: SEGA Dreamcast18:37:00.3 7/16/2012: Loading Emulator 29: FUTURE Pinball18:37:00.3 7/16/2012: Loading Emulator 30: HOMEBREW Games18:37:00.3 7/16/2012: Loading Emulator 31: TAITO Type X18:37:00.3 7/16/2012: Loading Emulator 32: NINTENDO WiiWare18:37:00.3 7/16/2012: Loading Emulator Group 1: MICROSOFT Windows18:37:00.3 7/16/2012: Using Version 3 Themes Animations18:37:00.3 7/16/2012: Retrieving resolution setting18:37:00.3 7/16/2012: Using General Font: Tahoma18:37:00.3 7/16/2012: Using Title Font: Tahoma18:37:00.4 7/16/2012: Initialising Direct3D18:37:00.4 7/16/2012: Applying GameEx is Loading Image18:37:00.5 7/16/2012: Setting Resolution to 1680x1050 32 bit color18:37:00.6 7/16/2012: Creating Surfaces18:37:00.8 7/16/2012: Creating Primary Surface - Full Screen Mode18:37:00.9 7/16/2012: Creating Back Buffer18:37:00.9 7/16/2012: Version 2 Theme being used. Loading.18:37:00.9 7/16/2012: Loading Button Data18:37:00.9 7/16/2012: Loading Font Data18:37:00.9 7/16/2012: Loading Layout Data18:37:00.9 7/16/2012: Loading Taskbar Data18:37:00.9 7/16/2012: Loading graphic Surfaces18:37:00.9 7/16/2012: Display is running at: 1680x1050 32bit color, 59hz18:37:00.9 7/16/2012: Adapter: ATI Radeon HD 4600 Series18:37:00.9 7/16/2012: Max texture size: 8192x819218:37:00.9 7/16/2012: Available texture memory: -1691MB18:37:00.9 7/16/2012: Initialising Bass Audio Library18:37:01.0 7/16/2012: Creating Surfaces Misc and Dialogs18:37:01.1 7/16/2012: Creating Surfaces Volume18:37:01.1 7/16/2012: Creating Surfaces Arrows18:37:01.1 7/16/2012: Creating Surfaces GameEXlogo Text18:37:01.1 7/16/2012: Creating Surfaces Toolbar18:37:01.2 7/16/2012: Creating Surfaces Toolbar Controls18:37:01.2 7/16/2012: Creating Surfaces Backgrounds18:37:01.2 7/16/2012: Creating Surfaces GameEx Logo18:37:01.2 7/16/2012: Creating Surface Unselected18:37:01.2 7/16/2012: Creating Surfaces Snaps18:37:01.2 7/16/2012: Creating Surfaces Menu and List Bars18:37:01.3 7/16/2012: Creating Fonts18:37:01.3 7/16/2012: Creating Game Font18:37:01.3 7/16/2012: Creating Game Font Faded18:37:01.4 7/16/2012: Creating Title Font18:37:01.4 7/16/2012: Restoring Title Font From Cache18:37:01.6 7/16/2012: Creating Font Black18:37:01.6 7/16/2012: Creating Font Black Small18:37:01.7 7/16/2012: Fonts Created Succesfully18:37:01.8 7/16/2012: Loading News Feed: http://www.gameex.net/gameexnews.xml18:37:02.7 7/16/2012: Attempting to load game list18:37:02.8 7/16/2012: GameExtender Not found snap: F:\Images\no_img.png18:37:02.8 7/16/2012: Starting GameExtender on: 127.0.0.1:838318:37:02.8 7/16/2012: GameExtender using specific custom images for systems.18:37:02.8 7/16/2012: MAME CMD options: -nowindow -joy -mt -video d3d -mouse -noka18:37:02.8 7/16/2012: Initialising DirectInput for Gamepad support18:37:02.8 7/16/2012: GameEx will just check for activity on Gamepad18:37:02.9 7/16/2012: Unable to create a joystick device18:37:02.9 7/16/2012: Initialising DirectInput for Keyboard support18:37:02.9 7/16/2012: Loading Start Page18:37:02.9 7/16/2012: Initializing MCE Remote18:37:02.9 7/16/2012: Playing intro sound file18:37:03.0 7/16/2012: Initialization OK! Starting GameEx!18:37:03.0 7/16/2012: Testing Main Loop Once: Processing Frame18:37:03.0 7/16/2012: Validating: Emulator_1: Custom Background: back-nintendo_64.png18:37:03.0 7/16/2012: Validating: Emulator_1: Snap Path: C:\Artwork\Nintendo_N64\Snap18:37:03.0 7/16/2012: Validating: Emulator_1: Video Snap Path: C:\Artwork\Nintendo_N64\Video_AVI18:37:03.0 7/16/2012: Validating: Emulator_1: Not Found Image: C:\Artwork\no_img.png18:37:03.0 7/16/2012: Validating: Emulator_1: Custom Art Path 1: C:\Artwork\Nintendo_N64\Snap18:37:03.0 7/16/2012: Validating: Emulator_1: Custom Art Path 2: C:\Artwork\Nintendo_N64\Advert18:37:03.0 7/16/2012: Validating: Emulator_1: Control Panel Path: C:\Artwork\Controls\N64.png18:37:03.0 7/16/2012: Validating: Emulator_1: Database: [Console] Nintendo N6418:37:03.0 7/16/2012: Validating: Emulator_1: Title Snap Path: C:\Artwork\Nintendo_N64\Title18:37:03.0 7/16/2012: Validating: Emulator_1: Box Art Path: C:\Artwork\Nintendo_N64\Box18:37:03.0 7/16/2012: Validating: Emulator_1: Cart Art Path: C:\Artwork\Nintendo_N64\Cart18:37:03.0 7/16/2012: Validating: Emulator_1: TV Ad Path: C:\Artwork\Nintendo_N64\TV_Advert_AVI18:37:03.0 7/16/2012: Warning: Emulator_1: TV Ad Path Does not exist18:37:03.0 7/16/2012: Validating: Emulator_1: Manual Path: C:\Artwork\Nintendo_N64\Manual18:37:03.0 7/16/2012: Validating: Emulator_2: Custom Background: back-nintendo_snes.png18:37:03.1 7/16/2012: Validating: Emulator_2: Snap Path: C:\Artwork\Nintendo_SNES\Snap18:37:03.1 7/16/2012: Validating: Emulator_2: Video Snap Path: C:\Artwork\Nintendo_SNES\Video_MP418:37:03.1 7/16/2012: Validating: Emulator_2: Not Found Image: C:\Artwork\no_img.png18:37:03.1 7/16/2012: Validating: Emulator_2: Custom Art Path 1: C:\Artwork\Nintendo_SNES\Snap18:37:03.1 7/16/2012: Validating: Emulator_2: Custom Art Path 2: C:\Artwork\Nintendo_SNES\Advert18:37:03.1 7/16/2012: Validating: Emulator_2: Custom Art Path 3: C:\Artwork\Nintendo_SNES\Map18:37:03.1 7/16/2012: Validating: Emulator_2: Control Panel Path: C:\Artwork\Controls\Main\SNES.png18:37:03.1 7/16/2012: Validating: Emulator_2: Database: [Console] Nintendo SNES18:37:03.1 7/16/2012: Validating: Emulator_2: Title Snap Path: C:\Artwork\Nintendo_SNES\Title18:37:03.1 7/16/2012: Validating: Emulator_2: Box Art Path: C:\Artwork\Nintendo_SNES\Box_3D18:37:03.1 7/16/2012: Validating: Emulator_2: Cart Art Path: C:\Artwork\Nintendo_SNES\Cart18:37:03.1 7/16/2012: Validating: Emulator_2: Music Path: C:\Artwork\Nintendo_SNES\Music18:37:03.1 7/16/2012: Validating: Emulator_2: Manual Path: C:\Artwork\Nintendo_SNES\Manual18:37:03.1 7/16/2012: Validating: Emulator_3: Custom Background: back-nintendo_nes.png18:37:03.1 7/16/2012: Validating: Emulator_3: Snap Path: C:\Artwork\Nintendo_NES\Snap18:37:03.1 7/16/2012: Validating: Emulator_3: Video Snap Path: C:\Artwork\Nintendo_NES\Video_MP418:37:03.1 7/16/2012: Validating: Emulator_3: Not Found Image: C:\Artwork\no_img.png18:37:03.1 7/16/2012: Validating: Emulator_3: Custom Art Path 1: C:\Artwork\Nintendo_NES\Snap18:37:03.1 7/16/2012: Validating: Emulator_3: Custom Art Path 2: C:\Artwork\Nintendo_NES\Advert18:37:03.1 7/16/2012: Validating: Emulator_3: Control Panel Path: C:\Artwork\Controls\Main\NES.png18:37:03.1 7/16/2012: Validating: Emulator_3: Database: [Console] Nintendo NES18:37:03.1 7/16/2012: Validating: Emulator_3: Title Snap Path: C:\Artwork\Nintendo_NES\Title18:37:03.1 7/16/2012: Validating: Emulator_3: Box Art Path: C:\Artwork\Nintendo_NES\Box_3D18:37:03.1 7/16/2012: Validating: Emulator_3: Cart Art Path: C:\Artwork\Nintendo_NES\Cart18:37:03.1 7/16/2012: Validating: Emulator_3: Music Path: C:\Artwork\Nintendo_NES\Music18:37:03.1 7/16/2012: Validating: Emulator_3: TV Ad Path: C:\Artwork\Nintendo_NES\Video_Advert_MP418:37:03.1 7/16/2012: Validating: Emulator_3: Manual Path: C:\Artwork\Nintendo_NES\Manual18:37:03.1 7/16/2012: Validating: Emulator_4: Custom Background: back-nintendo_game_boy_advance.png18:37:03.1 7/16/2012: Validating: Emulator_4: Snap Path: C:\Artwork\Nintendo_Game_Boy_Advance\Snap18:37:03.1 7/16/2012: Validating: Emulator_4: Video Snap Path: C:\Artwork\Nintendo_Game_Boy_Advance\Video_AVI18:37:03.1 7/16/2012: Validating: Emulator_4: Not Found Image: C:\Artwork\no_img.png18:37:03.1 7/16/2012: Validating: Emulator_4: Custom Art Path 1: C:\Artwork\Nintendo_Game_Boy_Advance\Snap18:37:03.1 7/16/2012: Validating: Emulator_4: Custom Art Path 2: C:\Artwork\Nintendo_Game_Boy_Advance\Advert18:37:03.1 7/16/2012: Validating: Emulator_4: Control Panel Path: C:\Artwork\Controls\Main\GBA.png18:37:03.1 7/16/2012: Validating: Emulator_4: Database: [Handheld] Nintendo Game Boy Advance18:37:03.1 7/16/2012: Validating: Emulator_4: Title Snap Path: C:\Artwork\Nintendo_Game_Boy_Advance\Title18:37:03.1 7/16/2012: Validating: Emulator_4: Box Art Path: C:\Artwork\Nintendo_Game_Boy_Advance\Box_3D18:37:03.1 7/16/2012: Validating: Emulator_4: Cart Art Path: C:\Artwork\Nintendo_Game_Boy_Advance\Cart18:37:03.1 7/16/2012: Validating: Emulator_4: TV Ad Path: C:\Artwork\Nintendo_Game_Boy_Advance\Video_Advert_AVI18:37:03.1 7/16/2012: Validating: Emulator_5: Custom Background: back-nintendo_game_boy_color.png18:37:03.1 7/16/2012: Validating: Emulator_5: Snap Path: C:\Artwork\Nintendo_Game_Boy_Merged\Snap18:37:03.1 7/16/2012: Validating: Emulator_5: Video Snap Path: C:\Artwork\Nintendo_Game_Boy_Merged\Video_AVI18:37:03.1 7/16/2012: Validating: Emulator_5: Not Found Image: C:\Artwork\no_img.png18:37:03.1 7/16/2012: Validating: Emulator_5: Custom Art Path 1: C:\Artwork\Nintendo_Game_Boy_Merged\Snap18:37:03.1 7/16/2012: Validating: Emulator_5: Custom Art Path 2: C:\Artwork\Nintendo_Game_Boy_Merged\Advert18:37:03.1 7/16/2012: Validating: Emulator_5: Custom Art Path 3: C:\Artwork\Nintendo_Game_Boy_Merged\Map18:37:03.1 7/16/2012: Validating: Emulator_5: Control Panel Path: C:\Artwork\Controls\Main\GBC.png18:37:03.1 7/16/2012: Validating: Emulator_5: Database: [Handheld] Nintendo Game Boy Color18:37:03.1 7/16/2012: Validating: Emulator_5: Title Snap Path: C:\Artwork\Nintendo_Game_Boy_Merged\Title18:37:03.1 7/16/2012: Validating: Emulator_5: Box Art Path: C:\Artwork\Nintendo_Game_Boy_Merged\Box18:37:03.1 7/16/2012: Validating: Emulator_5: Cart Art Path: C:\Artwork\Nintendo_Game_Boy_Merged\Cart18:37:03.1 7/16/2012: Validating: Emulator_5: Music Path: C:\Artwork\Nintendo_Game_Boy_Merged\Music18:37:03.1 7/16/2012: Validating: Emulator_5: TV Ad Path: C:\Artwork\Nintendo_Game_Boy_Merged\Video_Advert_AVI18:37:03.1 7/16/2012: Validating: Emulator_5: Manual Path: C:\Artwork\Nintendo_Game_Boy_Merged\Manual18:37:03.1 7/16/2012: Validating: Emulator_6: Custom Background: back-sega_cd.png18:37:03.1 7/16/2012: Validating: Emulator_6: Snap Path: C:\Artwork\Sega_CD\Snap18:37:03.1 7/16/2012: Validating: Emulator_6: Video Snap Path: C:\Artwork\Sega_CD\Video_AVI18:37:03.1 7/16/2012: Validating: Emulator_6: Not Found Image: C:\Artwork\no_img.png18:37:03.1 7/16/2012: Validating: Emulator_6: Custom Art Path 1: C:\Artwork\Sega_CD\Snap18:37:03.1 7/16/2012: Validating: Emulator_6: Custom Art Path 2: C:\Artwork\Sega_CD\Advert18:37:03.1 7/16/2012: Validating: Emulator_6: Custom Art Path 3: C:\Artwork\Sega_CD\BoxBack18:37:03.1 7/16/2012: Validating: Emulator_6: Control Panel Path: C:\Artwork\Controls\Main\SCD.png18:37:03.1 7/16/2012: Validating: Emulator_6: Database: [Console] Sega CD18:37:03.1 7/16/2012: Validating: Emulator_6: Title Snap Path: C:\Artwork\Sega_CD\Title18:37:03.1 7/16/2012: Validating: Emulator_6: Box Art Path: C:\Artwork\Sega_CD\Box18:37:03.1 7/16/2012: Validating: Emulator_6: Cart Art Path: C:\Artwork\Sega_CD\CD18:37:03.1 7/16/2012: Validating: Emulator_6: TV Ad Path: C:\Artwork\Sega_CD\Video_Advert_AVI18:37:03.1 7/16/2012: Validating: Emulator_6: Manual Path: C:\Artwork\Sega_CD\Manual18:37:03.1 7/16/2012: Validating: Emulator_7: Custom Background: back-sega_genesis.png18:37:03.1 7/16/2012: Validating: Emulator_7: Snap Path: C:\Artwork\Sega_Genesis\Snap18:37:03.1 7/16/2012: Validating: Emulator_7: Video Snap Path: C:\Artwork\Sega_Genesis\Video_AVI18:37:03.1 7/16/2012: Validating: Emulator_7: Not Found Image: C:\Artwork\no_img.png18:37:03.1 7/16/2012: Validating: Emulator_7: Custom Art Path 1: C:\Artwork\Sega_Genesis\Snap18:37:03.1 7/16/2012: Validating: Emulator_7: Custom Art Path 2: C:\Artwork\Sega_Genesis\Advert18:37:03.1 7/16/2012: Validating: Emulator_7: Custom Art Path 3: C:\Artwork\Sega_Genesis\CartTop18:37:03.1 7/16/2012: Validating: Emulator_7: Control Panel Path: C:\Artwork\Controls\Main\GEN.png18:37:03.1 7/16/2012: Validating: Emulator_7: Database: [Console] Sega Genesis18:37:03.1 7/16/2012: Validating: Emulator_7: Title Snap Path: C:\Artwork\Sega_Genesis\Title18:37:03.1 7/16/2012: Validating: Emulator_7: Box Art Path: C:\Artwork\Sega_Genesis\Box_3D18:37:03.1 7/16/2012: Validating: Emulator_7: Cart Art Path: C:\Artwork\Sega_Genesis\Cart18:37:03.1 7/16/2012: Validating: Emulator_7: Music Path: C:\Artwork\Sega_Genesis\Music18:37:03.1 7/16/2012: Validating: Emulator_7: TV Ad Path: C:\Artwork\Sega_Genesis\Video_Advert_AVI18:37:03.1 7/16/2012: Validating: Emulator_7: Manual Path: C:\Artwork\Sega_Genesis\Manual18:37:03.1 7/16/2012: Validating: Emulator_8: Custom Background: back-sega_master_system.png18:37:03.1 7/16/2012: Validating: Emulator_8: Snap Path: C:\Artwork\Sega_Master_System\Snap18:37:03.1 7/16/2012: Validating: Emulator_8: Video Snap Path: C:\Artwork\Sega_Master_System\Video_MP418:37:03.1 7/16/2012: Validating: Emulator_8: Not Found Image: C:\Artwork\no_img.png18:37:03.1 7/16/2012: Validating: Emulator_8: Custom Art Path 1: C:\Artwork\Sega_Master_System\Snap18:37:03.1 7/16/2012: Validating: Emulator_8: Control Panel Path: C:\Artwork\Controls\Main\SMS.png18:37:03.1 7/16/2012: Validating: Emulator_8: Database: [Console] Sega Master System18:37:03.1 7/16/2012: Validating: Emulator_8: Title Snap Path: C:\Artwork\Sega_Master_System\Title18:37:03.1 7/16/2012: Validating: Emulator_8: Box Art Path: C:\Artwork\Sega_Master_System\Box_3D18:37:03.1 7/16/2012: Validating: Emulator_8: Cart Art Path: C:\Artwork\Sega_Master_System\Cart18:37:03.1 7/16/2012: Validating: Emulator_8: Music Path: C:\Artwork\Sega_Master_System\Music18:37:03.1 7/16/2012: Validating: Emulator_8: TV Ad Path: C:\Artwork\Sega_Master_System\Video_Advert_AVI18:37:03.1 7/16/2012: Validating: Emulator_8: Manual Path: C:\Artwork\Sega_Master_System\Manual18:37:03.1 7/16/2012: Validating: Emulator_9: Custom Background: back-sega_game_gear.png18:37:03.1 7/16/2012: Validating: Emulator_9: Snap Path: C:\Artwork\Sega_Game_Gear\Snap18:37:03.1 7/16/2012: Validating: Emulator_9: Video Snap Path: C:\Artwork\Sega_Game_Gear\Video_AVI18:37:03.1 7/16/2012: Validating: Emulator_9: Not Found Image: C:\Artwork\no_img.png18:37:03.1 7/16/2012: Validating: Emulator_9: Custom Art Path 1: C:\Artwork\Sega_Game_Gear\Snap18:37:03.1 7/16/2012: Validating: Emulator_9: Custom Art Path 2: C:\Artwork\Sega_Game_Gear\Advert18:37:03.1 7/16/2012: Validating: Emulator_9: Control Panel Path: C:\Artwork\Controls\Main\GG.png18:37:03.1 7/16/2012: Validating: Emulator_9: Database: [Handheld] Sega Game Gear18:37:03.1 7/16/2012: Validating: Emulator_9: Title Snap Path: C:\Artwork\Sega_Game_Gear\Title18:37:03.1 7/16/2012: Validating: Emulator_9: Box Art Path: C:\Artwork\Sega_Game_Gear\Box18:37:03.1 7/16/2012: Validating: Emulator_9: Cart Art Path: C:\Artwork\Sega_Game_Gear\Cart18:37:03.1 7/16/2012: Validating: Emulator_9: Music Path: C:\Artwork\Sega_Game_Gear\Music18:37:03.1 7/16/2012: Validating: Emulator_9: TV Ad Path: C:\Artwork\Sega_Game_Gear\Video_Advert_AVI18:37:03.1 7/16/2012: Validating: Emulator_9: Manual Path: C:\Artwork\Sega_Game_Gear\Manual18:37:03.1 7/16/2012: Validating: Emulator_10: Custom Background: back-nec_tg16.png18:37:03.1 7/16/2012: Validating: Emulator_10: Snap Path: C:\Artwork\NEC_TurboGrafx_16\Snap18:37:03.1 7/16/2012: Validating: Emulator_10: Video Snap Path: C:\Artwork\NEC_TurboGrafx_16\Video_MP418:37:03.1 7/16/2012: Validating: Emulator_10: Not Found Image: C:\Artwork\no_img.png18:37:03.1 7/16/2012: Validating: Emulator_10: Custom Art Path 1: C:\Artwork\NEC_TurboGrafx_16\Snap18:37:03.1 7/16/2012: Validating: Emulator_10: Custom Art Path 2: C:\Artwork\NEC_TurboGrafx_16\Advert18:37:03.1 7/16/2012: Validating: Emulator_10: Control Panel Path: C:\Artwork\Controls\Main\TG16.png18:37:03.1 7/16/2012: Validating: Emulator_10: Database: [Console] NEC TurboGrafx-1618:37:03.1 7/16/2012: Validating: Emulator_10: Title Snap Path: C:\Artwork\NEC_TurboGrafx_16\Title18:37:03.1 7/16/2012: Warning: Emulator_10: Title Snap Path Does not exist18:37:03.1 7/16/2012: Validating: Emulator_10: Box Art Path: C:\Artwork\NEC_TurboGrafx_16\Box18:37:03.1 7/16/2012: Validating: Emulator_10: Cart Art Path: C:\Artwork\NEC_TurboGrafx_16\Cart18:37:03.1 7/16/2012: Validating: Emulator_10: Music Path: C:\Artwork\NEC_TurboGrafx_16\Music18:37:03.1 7/16/2012: Validating: Emulator_10: Manual Path: C:\Artwork\NEC_TurboGrafx_16\Manual18:37:03.1 7/16/2012: Validating: Emulator_11: Custom Background: back-atari_2600.png18:37:03.1 7/16/2012: Validating: Emulator_11: Snap Path: C:\Artwork\Atari_2600\Snap18:37:03.1 7/16/2012: Validating: Emulator_11: Video Snap Path: C:\Artwork\Atari_2600\Video_AVI18:37:03.1 7/16/2012: Validating: Emulator_11: Not Found Image: C:\Artwork\no_img.png18:37:03.1 7/16/2012: Validating: Emulator_11: Custom Art Path 1: C:\Artwork\Atari_2600\Snap18:37:03.1 7/16/2012: Validating: Emulator_11: Custom Art Path 2: C:\Artwork\Atari_2600\Overlay18:37:03.1 7/16/2012: Validating: Emulator_11: Control Panel Path: C:\Artwork\Controls\Main\2600.png18:37:03.1 7/16/2012: Validating: Emulator_11: Database: [Console] Atari 260018:37:03.1 7/16/2012: Validating: Emulator_11: Box Art Path: C:\Artwork\Atari_2600\Box_3D18:37:03.1 7/16/2012: Validating: Emulator_11: Cart Art Path: C:\Artwork\Atari_2600\Cart18:37:03.1 7/16/2012: Validating: Emulator_11: TV Ad Path: C:\Artwork\Atari_2600\Video_Advert_AVI18:37:03.1 7/16/2012: Validating: Emulator_11: Manual Path: C:\Artwork\Atari_2600\Manual18:37:03.1 7/16/2012: Validating: Emulator_12: Custom Background: back-atari_5200.png18:37:03.1 7/16/2012: Validating: Emulator_12: Snap Path: C:\Artwork\Atari_5200\Snap18:37:03.1 7/16/2012: Validating: Emulator_12: Video Snap Path: C:\Artwork\Atari_5200\Video_MP418:37:03.1 7/16/2012: Validating: Emulator_12: Not Found Image: C:\Artwork\no_img.png18:37:03.1 7/16/2012: Validating: Emulator_12: Custom Art Path 1: C:\Artwork\Atari_5200\BoxBack18:37:03.1 7/16/2012: Validating: Emulator_12: Custom Art Path 2: C:\Artwork\Atari_5200\Overlay18:37:03.1 7/16/2012: Validating: Emulator_12: Control Panel Path: C:\Artwork\Controls\Main\5200.png18:37:03.1 7/16/2012: Validating: Emulator_12: Database: [Console] Atari 520018:37:03.1 7/16/2012: Validating: Emulator_12: Title Snap Path: C:\Artwork\Atari_5200\Title18:37:03.1 7/16/2012: Validating: Emulator_12: Box Art Path: C:\Artwork\Atari_5200\Box_3D18:37:03.1 7/16/2012: Validating: Emulator_12: Cart Art Path: C:\Artwork\Atari_5200\Cart18:37:03.1 7/16/2012: Validating: Emulator_12: Music Path: C:\Artwork\Atari_5200\Music18:37:03.1 7/16/2012: Validating: Emulator_12: TV Ad Path: C:\Artwork\Atari_5200\Video_Advert_MP418:37:03.1 7/16/2012: Validating: Emulator_12: Manual Path: C:\Artwork\Atari_5200\Manual18:37:03.1 7/16/2012: Validating: Emulator_13: Custom Background: back-atari_7800.png18:37:03.1 7/16/2012: Validating: Emulator_13: Snap Path: C:\Artwork\Atari_7800\Snap18:37:03.1 7/16/2012: Validating: Emulator_13: Video Snap Path: C:\Artwork\Atari_7800\Video_MP418:37:03.1 7/16/2012: Validating: Emulator_13: Not Found Image: C:\Artwork\no_img.png18:37:03.1 7/16/2012: Validating: Emulator_13: Custom Art Path 1: C:\Artwork\Atari_7800\Snap18:37:03.1 7/16/2012: Validating: Emulator_13: Control Panel Path: C:\Artwork\Controls\Main\7800.png18:37:03.1 7/16/2012: Validating: Emulator_13: Database: [Console] Atari 780018:37:03.1 7/16/2012: Validating: Emulator_13: Title Snap Path: C:\Artwork\Atari_7800\Title18:37:03.1 7/16/2012: Validating: Emulator_13: Box Art Path: C:\Artwork\Atari_7800\Box_3D18:37:03.1 7/16/2012: Validating: Emulator_13: Cart Art Path: C:\Artwork\Atari_7800\Cart18:37:03.1 7/16/2012: Validating: Emulator_13: TV Ad Path: C:\Artwork\Atari_7800\Video_Advert_MP418:37:03.1 7/16/2012: Validating: Emulator_13: Manual Path: C:\Artwork\Atari_7800\Manual18:37:03.1 7/16/2012: Validating: Emulator_14: Custom Background: back-colecovision.png18:37:03.1 7/16/2012: Validating: Emulator_14: Snap Path: C:\Artwork\Coleco_Vision\Snap18:37:03.1 7/16/2012: Validating: Emulator_14: Video Snap Path: C:\Artwork\Coleco_Vision\Video_AVI18:37:03.1 7/16/2012: Validating: Emulator_14: Not Found Image: C:\Artwork\no_img.png18:37:03.1 7/16/2012: Validating: Emulator_14: Custom Art Path 1: C:\Artwork\Coleco_Vision\Snap18:37:03.1 7/16/2012: Validating: Emulator_14: Custom Art Path 2: C:\Artwork\Coleco_Vision\Overlay18:37:03.1 7/16/2012: Validating: Emulator_14: Control Panel Path: C:\Artwork\Controls\Colecovision.png18:37:03.1 7/16/2012: Validating: Emulator_14: Database: [Console] Coleco Vision18:37:03.1 7/16/2012: Validating: Emulator_14: Title Snap Path: C:\Artwork\Coleco_Vision\Title18:37:03.1 7/16/2012: Validating: Emulator_14: Box Art Path: C:\Artwork\Coleco_Vision\Box18:37:03.1 7/16/2012: Validating: Emulator_14: Cart Art Path: C:\Artwork\Coleco_Vision\Cart18:37:03.1 7/16/2012: Validating: Emulator_14: TV Ad Path: C:\Artwork\Coleco_Vision\Video_Advert_AVI18:37:03.2 7/16/2012: Validating: Emulator_14: Manual Path: C:\Artwork\Coleco_Vision\Manual18:37:03.2 7/16/2012: Validating: Emulator_15: Custom Background: back-mattell_intellivision.png18:37:03.2 7/16/2012: Validating: Emulator_15: Snap Path: C:\Artwork\Mattel_Intellivision\Snap18:37:03.2 7/16/2012: Validating: Emulator_15: Video Snap Path: C:\Artwork\Mattel_Intellivision\Video_MP418:37:03.2 7/16/2012: Validating: Emulator_15: Not Found Image: C:\Artwork\no_img.png18:37:03.2 7/16/2012: Validating: Emulator_15: Custom Art Path 1: C:\Artwork\Mattel_Intellivision\Overlay18:37:03.2 7/16/2012: Validating: Emulator_15: Custom Art Path 2: C:\Artwork\Mattel_Intellivision\CartTop18:37:03.2 7/16/2012: Validating: Emulator_15: Control Panel Path: C:\Artwork\Controls\Intellivision.png18:37:03.2 7/16/2012: Validating: Emulator_15: Database: [Console] Mattel Intellivision18:37:03.2 7/16/2012: Validating: Emulator_15: Title Snap Path: C:\Artwork\Mattel_Intellivision\Title18:37:03.2 7/16/2012: Validating: Emulator_15: Box Art Path: C:\Artwork\Mattel_Intellivision\Box_3D18:37:03.2 7/16/2012: Validating: Emulator_15: Cart Art Path: C:\Artwork\Mattel_Intellivision\Cart18:37:03.2 7/16/2012: Validating: Emulator_15: TV Ad Path: C:\Artwork\Mattel_Intellivision\Video_Advert_MP418:37:03.2 7/16/2012: Validating: Emulator_15: Manual Path: C:\Artwork\Mattel_Intellivision\Manual18:37:03.2 7/16/2012: Validating: Emulator_17: Custom Background: back-visual_pinball.png18:37:03.2 7/16/2012: Validating: Emulator_17: Snap Path: E:\Pinball\artwork\Snap18:37:03.2 7/16/2012: Validating: Emulator_17: Not Found Image: F:\Images\no_img.png18:37:03.2 7/16/2012: Validating: Emulator_17: Custom Art Path 1: F:\Pinball\artwork\Backglass18:37:03.2 7/16/2012: Warning: Emulator_17: Custom Art Path 1 Does not exist18:37:03.2 7/16/2012: Validating: Emulator_17: Custom Art Path 2: F:\Pinball\artwork\Playfield18:37:03.2 7/16/2012: Warning: Emulator_17: Custom Art Path 2 Does not exist18:37:03.2 7/16/2012: Validating: Emulator_17: Custom Art Path 3: F:\Pinball\artwork\Flyer18:37:03.2 7/16/2012: Warning: Emulator_17: Custom Art Path 3 Does not exist18:37:03.2 7/16/2012: Validating: Emulator_17: Control Panel Path: C:\Artwork\Controls\Main\VPIN.png18:37:03.2 7/16/2012: Validating: Emulator_17: Database: [Pinball] Visual Pinball18:37:03.2 7/16/2012: Validating: Emulator_17: Manual Path: E:\Pinball\artwork\Manual18:37:03.2 7/16/2012: Validating: Emulator_20: Custom Background: back-sony_playstation.png18:37:03.2 7/16/2012: Validating: Emulator_20: Snap Path: C:\Artwork\Sony_Playstation\Snap18:37:03.2 7/16/2012: Validating: Emulator_20: Video Snap Path: C:\Artwork\Sony_Playstation\Video_AVI18:37:03.2 7/16/2012: Validating: Emulator_20: Not Found Image: F:\Images\no_img.png18:37:03.2 7/16/2012: Validating: Emulator_20: Custom Art Path 1: C:\Artwork\Sony_Playstation\Snap18:37:03.2 7/16/2012: Validating: Emulator_20: Control Panel Path: C:\Artwork\Controls\PSX.png18:37:03.2 7/16/2012: Validating: Emulator_20: Database: [Console] Sony Playstation18:37:03.2 7/16/2012: Validating: Emulator_20: Title Snap Path: C:\Artwork\Sony_Playstation\Title18:37:03.2 7/16/2012: Validating: Emulator_20: Box Art Path: C:\Artwork\Sony_Playstation\Box18:37:03.2 7/16/2012: Validating: Emulator_20: TV Ad Path: C:\Artwork\Sony_Playstation\Video_Advert_AVI18:37:03.2 7/16/2012: Validating: Emulator_20: Manual Path: C:\Artwork\Sony_Playstation\Manual18:37:03.2 7/16/2012: Validating: Emulator_21: Custom Background: back-sega_saturn.png18:37:03.2 7/16/2012: Validating: Emulator_21: Snap Path: F:\Emulators\SSF\Artwork\Snap18:37:03.2 7/16/2012: Validating: Emulator_21: Not Found Image: F:\Images\no_img.png18:37:03.2 7/16/2012: Validating: Emulator_21: Custom Art Path 1: F:\Emulators\SSF\Artwork\BoxBack18:37:03.2 7/16/2012: Validating: Emulator_21: Custom Art Path 2: F:\Emulators\SSF\Artwork\Advert18:37:03.2 7/16/2012: Validating: Emulator_21: Control Panel Path: F:\Images\Controls\Emulators\Saturn.png18:37:03.2 7/16/2012: Validating: Emulator_21: Database: [Console] Sega Saturn18:37:03.2 7/16/2012: Validating: Emulator_21: Title Snap Path: F:\Emulators\SSF\Artwork\Title18:37:03.2 7/16/2012: Validating: Emulator_21: Box Art Path: F:\Emulators\SSF\Artwork\Box18:37:03.2 7/16/2012: Validating: Emulator_21: Cart Art Path: F:\Emulators\SSF\Artwork\CD18:37:03.2 7/16/2012: Validating: Emulator_21: Manual Path: F:\Emulators\SSF\Artwork\Manual18:37:03.2 7/16/2012: Validating: Emulator_22: Custom Background: back-nintendo_gamecube.png18:37:03.2 7/16/2012: Validating: Emulator_22: Snap Path: F:\Emulators\Dolphin\Artwork\Snap18:37:03.2 7/16/2012: Validating: Emulator_22: Not Found Image: F:\Images\no_img.png18:37:03.2 7/16/2012: Validating: Emulator_22: Control Panel Path: F:\Images\Controls\Emulators\Game Cube.png18:37:03.2 7/16/2012: Validating: Emulator_22: Database: [Console] Nintendo GameCube18:37:03.2 7/16/2012: Validating: Emulator_22: Title Snap Path: F:\Emulators\Dolphin\Artwork\Title18:37:03.2 7/16/2012: Validating: Emulator_22: Box Art Path: F:\Emulators\Dolphin\Artwork\Box18:37:03.2 7/16/2012: Validating: Emulator_22: Cart Art Path: F:\Emulators\Dolphin\Artwork\Cart18:37:03.2 7/16/2012: Validating: Emulator_22: Manual Path: F:\Emulators\Dolphin\Artwork\Manual18:37:03.2 7/16/2012: Validating: Emulator_23: Custom Background: back-windows_games.png18:37:03.2 7/16/2012: Validating: Emulator_23: Snap Path: E:\WinGames\Artwork\Snaps18:37:03.2 7/16/2012: Validating: Emulator_23: Video Snap Path: E:\WinGames\Artwork\Video_MP418:37:03.2 7/16/2012: Validating: Emulator_23: Not Found Image: F:\Images\no_img.png18:37:03.2 7/16/2012: Validating: Emulator_23: Custom Art Path 1: E:\WinGames\Artwork\Snaps18:37:03.2 7/16/2012: Validating: Emulator_23: Control Panel Path: F:\Images\Controls\Windows18:37:03.2 7/16/2012: Validating: Emulator_23: Title Snap Path: E:\WinGames\Artwork\Titles18:37:03.2 7/16/2012: Validating: Emulator_23: Box Art Path: E:\WinGames\Artwork\Boxes18:37:03.2 7/16/2012: Validating: Emulator_23: Cart Art Path: E:\WinGames\Artwork\Discs18:37:03.2 7/16/2012: Validating: Emulator_23: Manual Path: E:\WinGames\Artwork\Manuals18:37:03.2 7/16/2012: Validating: Emulator_24: Custom Background: back-beats_of_rage.png18:37:03.2 7/16/2012: Validating: Emulator_24: Snap Path: F:\Emulators\OpenBOR\Artwork\Snap18:37:03.2 7/16/2012: Validating: Emulator_24: Control Panel Path: F:\Images\Controls\Emulators\Open BOR.png18:37:03.2 7/16/2012: Validating: Emulator_24: Title Snap Path: F:\Emulators\OpenBOR\Artwork\Title18:37:03.2 7/16/2012: Validating: Emulator_25: Custom Background: back-windows_games.png18:37:03.2 7/16/2012: Validating: Emulator_25: Snap Path: E:\WinGames\Artwork\Snaps18:37:03.2 7/16/2012: Validating: Emulator_25: Video Snap Path: E:\WinGames\Artwork\Video_MP418:37:03.2 7/16/2012: Validating: Emulator_25: Not Found Image: F:\Images\no_img.png18:37:03.2 7/16/2012: Validating: Emulator_25: Control Panel Path: F:\Images\Controls\Windows18:37:03.2 7/16/2012: Validating: Emulator_25: Title Snap Path: E:\WinGames\Artwork\Titles18:37:03.2 7/16/2012: Validating: Emulator_25: Box Art Path: E:\WinGames\Artwork\Boxes18:37:03.2 7/16/2012: Validating: Emulator_25: Cart Art Path: E:\WinGames\Artwork\Discs18:37:03.2 7/16/2012: Validating: Emulator_25: Manual Path: E:\WinGames\Artwork\Manuals18:37:03.2 7/16/2012: Validating: Emulator_27: Custom Background: back-nintendo_ds.png18:37:03.2 7/16/2012: Validating: Emulator_27: Not Found Image: F:\Images\no_img.png18:37:03.2 7/16/2012: Validating: Emulator_27: Control Panel Path: F:\Images\Controls\Emulators\Nintendo DS.png18:37:03.2 7/16/2012: Validating: Emulator_27: Database: [Handheld] Nintendo DS18:37:03.2 7/16/2012: Validating: Emulator_28: Custom Background: back-sega_dreamcast.png18:37:03.2 7/16/2012: Validating: Emulator_28: Snap Path: F:\Emulators\NullDC\artwork\Snaps18:37:03.2 7/16/2012: Validating: Emulator_28: Not Found Image: F:\Images\no_img.png18:37:03.2 7/16/2012: Validating: Emulator_28: Database: [Console] Sega Dreamcast18:37:03.2 7/16/2012: Validating: Emulator_28: Title Snap Path: F:\Emulators\NullDC\artwork\Titles18:37:03.2 7/16/2012: Validating: Emulator_29: Custom Background: back-future_pinball.png18:37:03.2 7/16/2012: Validating: Emulator_29: Snap Path: E:\Future Pinball\Artwork\Snaps18:37:03.2 7/16/2012: Validating: Emulator_29: Not Found Image: F:\Images\no_img.png18:37:03.2 7/16/2012: Validating: Emulator_29: Database: [Pinball] Future Pinball18:37:03.2 7/16/2012: Validating: Emulator_30: Custom Background: back-homebrew_games.png18:37:03.2 7/16/2012: Validating: Emulator_30: Snap Path: E:\WinGames\Artwork\Snaps18:37:03.2 7/16/2012: Validating: Emulator_30: Not Found Image: F:\Images\no_img.png18:37:03.2 7/16/2012: Validating: Emulator_30: Control Panel Path: F:\Images\Controls\Windows18:37:03.2 7/16/2012: Validating: Emulator_30: Title Snap Path: E:\WinGames\Artwork\Titles18:37:03.2 7/16/2012: Validating: Emulator_30: Box Art Path: E:\WinGames\Artwork\Boxes18:37:03.2 7/16/2012: Validating: Emulator_30: Cart Art Path: E:\WinGames\Artwork\Discs18:37:03.2 7/16/2012: Validating: Emulator_30: Manual Path: E:\WinGames\Artwork\Manuals18:37:03.2 7/16/2012: Validating: Emulator_31: Custom Background: back-taito_type_x.png18:37:03.2 7/16/2012: Validating: Emulator_31: Snap Path: C:\Artwork\Taito_Type_X_Merged\Snap18:37:03.2 7/16/2012: Validating: Emulator_31: Video Snap Path: C:\Artwork\Taito_Type_X_Merged\Video_MP418:37:03.2 7/16/2012: Validating: Emulator_31: Not Found Image: C:\Artwork\no_img.png18:37:03.2 7/16/2012: Validating: Emulator_31: Custom Art Path 1: C:\Artwork\Taito_Type_X_Merged\Snap18:37:03.2 7/16/2012: Validating: Emulator_31: Title Snap Path: C:\Artwork\Taito_Type_X_Merged\Title18:37:03.2 7/16/2012: Validating: Emulator_32: Custom Background: back-nintendo_wiiware.png18:37:03.2 7/16/2012: Validating: Emulator_32: Snap Path: C:\Artwork\Nintendo_WiiWare\Snap18:37:03.2 7/16/2012: Validating: Emulator_32: Not Found Image: C:\Artwork\no_img.png18:37:03.2 7/16/2012: Validating: Emulator_32: Title Snap Path: C:\Artwork\Nintendo_WiiWare\Title18:37:03.2 7/16/2012: Validating: Emulator_32: Manual Path: C:\Artwork\Nintendo_WiiWare\Manual18:37:03.2 7/16/2012: Restoring Emulator from Cache: 118:37:03.3 7/16/2012: Restoring Emulator Database From Cache: 118:37:03.4 7/16/2012: Restoring Emulator from Cache: 218:37:03.4 7/16/2012: Restoring Emulator Database From Cache: 218:37:03.5 7/16/2012: Restoring Emulator from Cache: 318:37:03.6 7/16/2012: Restoring Emulator Database From Cache: 318:37:03.7 7/16/2012: Restoring Emulator from Cache: 418:37:03.7 7/16/2012: Restoring Emulator Database From Cache: 418:37:03.8 7/16/2012: Restoring Emulator from Cache: 518:37:03.8 7/16/2012: Restoring Emulator Database From Cache: 518:37:03.9 7/16/2012: Restoring Emulator Database From Cache: 618:37:04.0 7/16/2012: XPADDER PLUGIN: Xpadder Plugin [1.0.4] Initialized successfully!18:37:04.0 7/16/2012: XPADDER PLUGIN: Profile successfully loaded for GameEx Interface!18:37:04.0 7/16/2012: Restoring Emulator from Cache: 718:37:04.0 7/16/2012: Restoring Emulator Database From Cache: 718:37:04.2 7/16/2012: Restoring Emulator from Cache: 818:37:04.2 7/16/2012: Restoring Emulator Database From Cache: 818:37:04.2 7/16/2012: Restoring Emulator from Cache: 918:37:04.3 7/16/2012: Restoring Emulator Database From Cache: 918:37:04.3 7/16/2012: Restoring Emulator from Cache: 1018:37:04.3 7/16/2012: Restoring Emulator Database From Cache: 1018:37:04.3 7/16/2012: Restoring Emulator from Cache: 1118:37:04.4 7/16/2012: Restoring Emulator Database From Cache: 1118:37:04.5 7/16/2012: Restoring Emulator from Cache: 1218:37:04.5 7/16/2012: Restoring Emulator Database From Cache: 1218:37:04.5 7/16/2012: Restoring Emulator from Cache: 1318:37:04.6 7/16/2012: Restoring Emulator Database From Cache: 1318:37:04.6 7/16/2012: Restoring Emulator from Cache: 1418:37:04.6 7/16/2012: Restoring Emulator Database From Cache: 1418:37:04.6 7/16/2012: Restoring Emulator from Cache: 1518:37:04.7 7/16/2012: Restoring Emulator Database From Cache: 1518:37:04.7 7/16/2012: Restoring Emulator from Cache: 1718:37:04.7 7/16/2012: No Database Data: 1718:37:04.7 7/16/2012: Restoring Emulator from Cache: 2018:37:04.7 7/16/2012: No Database Data: 2018:37:04.8 7/16/2012: Restoring Emulator from Cache: 2118:37:04.8 7/16/2012: Restoring Emulator Database From Cache: 2118:37:04.8 7/16/2012: Restoring Emulator from Cache: 2218:37:04.8 7/16/2012: No Database Data: 2218:37:04.9 7/16/2012: Restoring Emulator from Cache: 2318:37:04.9 7/16/2012: Cache Diff: e:\batfiles\exitemu.bat - 18:37:04.9 7/16/2012: Not Restoring Emulator from Cache: 2418:37:05.0 7/16/2012: Restoring Emulator from Cache: 2518:37:05.0 7/16/2012: Restoring Emulator from Cache: 2718:37:05.0 7/16/2012: Restoring Emulator Database From Cache: 2718:37:05.0 7/16/2012: Restoring Emulator from Cache: 2818:37:05.0 7/16/2012: Restoring Emulator Database From Cache: 2818:37:05.0 7/16/2012: Restoring Emulator from Cache: 2918:37:05.0 7/16/2012: No Database Data: 2918:37:05.1 7/16/2012: Cache Diff: e:\batfiles\exitemu.bat - 18:37:05.1 7/16/2012: Not Restoring Emulator from Cache: 3018:37:05.2 7/16/2012: Restoring Emulator from Cache: 3118:37:05.2 7/16/2012: Restoring Emulator from Cache: 3218:37:06.2 7/16/2012: Testing Main Loop Once: Main Loop ran successfullyFatal crash, the menu doesn't load. Link to comment Share on other sites More sharing options...
Adultery Posted July 16, 2012 Share Posted July 16, 2012 Well I removed the BAT file it errored on in the log and it booted right up. Why was it trying to do anything to a BAT file as if it were a database? It doesn't matter, I don't use BAT files now that I have an Xpadder plugin. Who cares as long as it's working. Note the lines in red:18:37:04.9 7/16/2012: Cache Diff: e:\batfiles\exitemu.bat - 18:37:04.9 7/16/2012: Not Restoring Emulator from Cache: 2418:37:05.0 7/16/2012: Restoring Emulator from Cache: 2518:37:05.0 7/16/2012: Restoring Emulator from Cache: 2718:37:05.0 7/16/2012: Restoring Emulator Database From Cache: 2718:37:05.0 7/16/2012: Restoring Emulator from Cache: 2818:37:05.0 7/16/2012: Restoring Emulator Database From Cache: 2818:37:05.0 7/16/2012: Restoring Emulator from Cache: 2918:37:05.0 7/16/2012: No Database Data: 2918:37:05.1 7/16/2012: Cache Diff: e:\batfiles\exitemu.bat - 18:37:05.1 7/16/2012: Not Restoring Emulator from Cache: 30These made all the difference for me. I hope it helps others, too. Link to comment Share on other sites More sharing options...
Adultery Posted July 17, 2012 Share Posted July 17, 2012 Update: nope, it still crashes sometimes, other times it doesn't. It seems to be having issues on emulators that don't use a database, but sometimes it doesn't. I don't know what to say. 1 Link to comment Share on other sites More sharing options...
AlphaUMi Posted July 17, 2012 Share Posted July 17, 2012 In the meantime, I was able to revert to 12.70. LOL! I found the installer on my pendrive. Link to comment Share on other sites More sharing options...
hansolo77 Posted July 17, 2012 Share Posted July 17, 2012 Ew maybe I'll hold off on updating till this is all worked out. Go get 'em Tom! Link to comment Share on other sites More sharing options...
Krakerman Posted July 17, 2012 Share Posted July 17, 2012 Yup! Think I'll wait too... Link to comment Share on other sites More sharing options...
Adultery Posted July 17, 2012 Share Posted July 17, 2012 More problems... This time it came after pressing a key to exit attract mode:00:20:35.6 7/17/2012: Running: cmd.exe /c F: F:\Emulators\MAME\mame.exe twinbee -rompath F:\Emulators\MAME\roms -nowindow -joy -mt -video d3d -mouse -noka -volume -32 -bezel -artpath artworkgameex00:22:28.8 7/17/2012: Key/Joy press detected: Exiting Attract mode, closing MAME00:22:28.8 7/17/2012: XPADDER PLUGIN: Profile for MAME was not enabled!00:22:28.8 7/17/2012: XPADDER PLUGIN00:22:28.8 7/17/2012: XPADDER PLUGIN: Profile successfully loaded for GameEx Interface!00:22:31.7 7/17/2012: Shutting down RawInput Hook00:22:33.2 7/17/2012: Warning: Display is running in full screen compatibility mode.00:22:52.1 7/17/2012: 21 Consecutive Exceptions Occured00:22:52.1 7/17/2012: Object reference not set to an instance of an object.00:22:52.1 7/17/2012: at Direct2D.Direct2d.Device.BeginScene(Boolean Clear, Color ClearColour)00:22:52.1 7/17/2012: at GameEx.GameEx.mainform.c(Boolean A_0)00:22:52.1 7/17/2012: at GameEx.GameEx.mainform.dw()00:22:52.1 7/17/2012: Trying reinitialising the display after sleeping for 4 seconds00:22:52.1 7/17/2012: Exception count will be dropped to 15I ignored the error and it worked fine (although it crashed MAME).Then I exited and reloaded GameEx, and it took me 4 tries to get it to actually start. Then it took about 4 mins to get past the loading screen.I hope this can be fixed quickly... My cab's really kind of unplayable in its current state. Link to comment Share on other sites More sharing options...
