i have everything perfect with gameex and am afraid to lose my settings, although I would like to fix the playcount problem too. I just did an ingame update to 12.70 and that didnt fix it. How did you fix it exactly and did you lose anything at all, controller stuff. emulator settings etc? thanks
I always recommend making a backup of your stuff just in case something happens. However, when GameEx updates or you download and then install, your settings are retained.
whats the best way to ensure Ive backed EVERYTHING up? Is zipping a copy of the gameex folder up enough? thx
I was just wondering if there were any settings outside of the GameEx folder like in the registry or AppData or something that I might need to restore my settings if they got lost in anupdate. I guess that means it's all in that one folder- so thats cool. Thanks :)
I'm still having problems with these counts not being updated and not working at all. I am using the Blue Glass theme. On closer examination it is possible that it only is broken for any emulator which uses cd images, like gamecube, saturn, playstation etc.
Is there any news on this? thx :)
