When I First started gameex there was a screensaver that would start after a couple minutes or so but now i get this unhandled exception thing that pops up which closes gameex immediately and a log afterwards. if i turn it off it just plays the music and stays at the part i left it at. i really liked that attract thing and would really appreciate it if i could get some assistance.
Heres the log thing. my guess is the problem starts where it says starting attract mode
22:46:01.0 7/9/2012: Opening Configuration File
22:46:01.0 7/9/2012: GameEx: Version 12.70: Starting Log
22:46:01.0 7/9/2012: Operating System Platform: Win32NT
22:46:01.0 7/9/2012: Operating System Name: Windows XP
22:46:01.0 7/9/2012: Operating System Version: 5.1.2600
22:46:01.0 7/9/2012: Pentium® Dual-Core CPU E5300 @ 2.60GHz, 3317MB
22:46:01.0 7/9/2012: 2.59Ghz - 2 Cores or CPU's
22:46:01.0 7/9/2012: Running Randomize()
22:46:01.0 7/9/2012: Loading PlugIns
22:46:01.1 7/9/2012: Checking for applications to Launch On Startup
22:46:01.1 7/9/2012: Running Misc startup tasks
22:46:01.1 7/9/2012: Setting Menu types
22:46:01.1 7/9/2012: Getting Configuration Values
22:46:01.1 7/9/2012: Using Theme: Default - Media Center
22:46:01.1 7/9/2012: Checking for alternate Image Directory for Theme: Default - Media Center
22:46:01.1 7/9/2012: Using Images from theme: Default - Media Center V1\MEDIA\
22:46:01.1 7/9/2012: Launching HideOS.exe
22:46:01.1 7/9/2012: Initialising Video/MNG DLL's
22:46:01.1 7/9/2012: GameEx will check for media insertion (may affect performance)
22:46:01.1 7/9/2012: Hiding Taskbar
22:46:01.1 7/9/2012: Is Media Center running?
22:46:01.1 7/9/2012: Checking/Creating LCD Registry values
22:46:01.1 7/9/2012: Check Media Center Exit/Start Mode
22:46:01.1 7/9/2012: Media Center Mode 2
22:46:01.1 7/9/2012: Video previews on. Warning: Only recommended on modern systems
22:46:01.1 7/9/2012: Custom Keyboard Input enabled: Getting custom codes
22:46:01.1 7/9/2012: Snap Delay set to: 2
22:46:01.1 7/9/2012: Get other settings
22:46:01.1 7/9/2012: Desktop set to Hide ICONS and set Background to Black
22:46:01.1 7/9/2012: Set: Find emulator artwork on best match basis
22:46:01.1 7/9/2012: Using DirectInput for keyboard input
22:46:01.1 7/9/2012: Start work for Form
22:46:01.1 7/9/2012: Getting Original Screen Size
22:46:01.1 7/9/2012: Opening Database Connection
22:46:01.1 7/9/2012: Initializing Component
22:46:01.2 7/9/2012: MAME Path is: C:\Emulators\MAME
22:46:01.2 7/9/2012: daphne Path is: C:\Emulators\Daphne
22:46:01.2 7/9/2012: daphne EXE file is: Daphne.exe
22:46:01.2 7/9/2012: Use daphne on. Daphne.exe will launch games
22:46:01.2 7/9/2012: MAME EXE file is: MameUI32.exe
22:46:01.2 7/9/2012: ROM Path is: C:\Emulators\MAME\roms
22:46:01.2 7/9/2012: Catver.ini is located at: C:\GameEx\DATA\catver.ini
22:46:01.2 7/9/2012: controls.ini is located at: C:\GameEx\DATA\controls.ini
22:46:01.2 7/9/2012: History.dat is located at: C:\GameEx\DATA\history.dat
22:46:01.2 7/9/2012: nplayers.ini is located at: C:\GameEx\DATA\nplayers.ini
22:46:01.2 7/9/2012: command.dat is located at: C:\GameEx\DATA\command.dat
22:46:01.2 7/9/2012: MAMEinfo.dat is located at: C:\GameEx\DATA\mameinfo.dat
22:46:01.2 7/9/2012: Loading Controls.ini map file
22:46:01.2 7/9/2012: Snap Path is: C:\Emulators\MAME\snap
22:46:01.2 7/9/2012: Background Snap Path: Not Found
22:46:01.2 7/9/2012: AVI Snap Path is: C:\GameEx\DEMO\MAME\video
22:46:01.2 7/9/2012: Flyer Path is: C:\Emulators\MAME\flyers
22:46:01.2 7/9/2012: Cabinet Path is: C:\Emulators\MAME\cabinets
22:46:01.2 7/9/2012: Cabinet 3D Path is: C:\GameEx\DEMO\MAME\cabinets3d
22:46:01.2 7/9/2012: Title Path is: C:\Emulators\MAME itles
22:46:01.2 7/9/2012: PCB Path: Not Found
22:46:01.2 7/9/2012: Artwork Preview Path: Not Found
22:46:01.2 7/9/2012: Panel Path is: C:\Emulators\MAME\cpanel
22:46:01.2 7/9/2012: Manual Path is: C:\GameEx\DEMO\MAME\manual
22:46:01.2 7/9/2012: Icon Path is: C:\Emulators\MAME\icons
22:46:01.2 7/9/2012: Marquee Path is: C:\Emulators\MAME\marquees
22:46:01.2 7/9/2012: Applying Language/Text
22:46:01.2 7/9/2012: Text/Language: English
22:46:01.2 7/9/2012: Loading Custom Emulators
22:46:01.2 7/9/2012: Loading Emulator 1: [Console] Nintendo SNES (Snes9x)
22:46:01.2 7/9/2012: Loading Emulator 2: [Console] Sega 32x (Fusion)
22:46:01.3 7/9/2012: Loading Emulator 3: [Console] Nintendo NES (Jnes)
22:46:01.3 7/9/2012: Loading Emulator 4: [Console] Sega CD (Fusion)
22:46:01.3 7/9/2012: Loading Emulator 5: [Handheld] Sega Game Gear (Fusion)
22:46:01.3 7/9/2012: Loading Emulator 6: [Console] Sega Genesis (Fusion)
22:46:01.3 7/9/2012: Loading Emulator 7: [Handheld] Nintendo Game Boy Advance (VisualBoyAdvance)
22:46:01.3 7/9/2012: Loading Emulator 8: [Handheld] Nintendo Game Boy Color (VisualBoyAdvance)
22:46:01.3 7/9/2012: Loading Emulator 9: [Handheld] SNK Neo-Geo Pocket (NeoPop)
22:46:01.3 7/9/2012: Loading Emulator 10: [Console] NEC TurboGrafx-16 (MagicEngine)
22:46:01.3 7/9/2012: Loading Emulator 11: [Console] Sony Playstation 2 (PCSX2)
22:46:01.3 7/9/2012: Using Version 3 Themes Animations
22:46:01.3 7/9/2012: Retrieving resolution setting
22:46:01.3 7/9/2012: Using General Font: Trebuchet MS
22:46:01.3 7/9/2012: Using Title Font: Trebuchet MS
22:46:01.3 7/9/2012: GameEx will try to reduce CPU usage
22:46:01.3 7/9/2012: Initialising Direct3D
22:46:01.4 7/9/2012: Applying GameEx is Loading Image
22:46:01.4 7/9/2012: Setting Resolution to 1280x1024 32 bit color
22:46:01.5 7/9/2012: Creating Surfaces
22:46:01.5 7/9/2012: Creating Primary Surface - Full Screen Mode
22:46:01.5 7/9/2012: Creating Back Buffer
22:46:01.5 7/9/2012: Loading graphic Surfaces
22:46:01.5 7/9/2012: Display is running at: 1280x1024 32bit color, 60hz
22:46:01.5 7/9/2012: Adapter: Intel® G33/G31 Express Chipset Family
22:46:01.5 7/9/2012: Max texture size: 2048x2048
22:46:01.5 7/9/2012: Available texture memory: 79MB
22:46:01.6 7/9/2012: Initialising Bass Audio Library
22:46:01.6 7/9/2012: Creating Surfaces Misc and Dialogs
22:46:02.1 7/9/2012: Creating Surfaces Volume
22:46:02.1 7/9/2012: Creating Surfaces Arrows
22:46:02.2 7/9/2012: Creating Surfaces GameEXlogo Text
22:46:02.2 7/9/2012: Creating Surfaces Toolbar
22:46:02.2 7/9/2012: Creating Surfaces Toolbar Controls
22:46:02.2 7/9/2012: Creating Surfaces Backgrounds
22:46:02.2 7/9/2012: Creating Surfaces GameEx Logo
22:46:02.2 7/9/2012: Creating Surface Unselected
22:46:02.2 7/9/2012: Creating Surfaces Snaps
22:46:02.2 7/9/2012: Creating Surfaces Menu and List Bars
22:46:02.5 7/9/2012: Creating Fonts
22:46:02.5 7/9/2012: Creating Game Font
22:46:02.5 7/9/2012: Creating Game Font Faded
22:46:02.6 7/9/2012: Creating Title Font
22:46:02.6 7/9/2012: Restoring Title Font From Cache
22:46:02.9 7/9/2012: Creating Font Black
22:46:03.0 7/9/2012: Creating Font Black Small
22:46:03.1 7/9/2012: Fonts Created Succesfully
22:46:03.1 7/9/2012: 8MB Video Memory Used
22:46:03.5 7/9/2012: Attempting to load game list
22:46:03.7 7/9/2012: MAME CMD options: -nowindow -joy -skip_gameinfo
22:46:03.7 7/9/2012: Loading music
22:46:03.7 7/9/2012: Initialising Windows Media Player Component
22:46:03.8 7/9/2012: Error accessing Windows Media Player, check you are running Version 9 orelse above
22:46:03.8 7/9/2012: Value does not fall within the expected range.
22:46:03.8 7/9/2012: at WMPLib.IWMPPlaylistArray.Item(Int32 lIndex)
22:46:03.8 7/9/2012: at GameEx.GameEx.mainform.d(Boolean A_0, Boolean A_1, Boolean A_2)
22:46:03.8 7/9/2012: Creating DirectSound Device
22:46:03.8 7/9/2012: Trying: Primary Sound Driver
22:46:03.8 7/9/2012: Loading Sound Files
22:46:03.8 7/9/2012: DirectSound Device Created Successfully
22:46:03.8 7/9/2012: Initialising DirectInput for Gamepad support
22:46:03.9 7/9/2012: Using Device Controller (XBOX 360 For Windows)
22:46:04.0 7/9/2012: Initialising DirectInput for Keyboard support
22:46:04.2 7/9/2012: Loading Start Page
22:46:04.2 7/9/2012: Initializing MCE Remote
22:46:04.3 7/9/2012: Playing intro sound file
22:46:04.3 7/9/2012: Initialization OK! Starting GameEx!
22:46:04.3 7/9/2012: Testing Main Loop Once: Processing Frame
22:46:04.6 7/9/2012: Testing Main Loop Once: Main Loop ran successfully
22:47:07.3 7/9/2012: Starting Attract Mode
22:47:07.3 7/9/2012: Reading MAME hall of fame
22:47:07.5 7/9/2012: Shutting down display
22:47:08.1 7/9/2012: Warning: Display is running in full screen compatibility mode.
22:47:08.1 7/9/2012: Exception occured running Attract Mode
22:47:08.1 7/9/2012: Object reference not set to an instance of an object.
22:47:08.1 7/9/2012: at GameEx.GameEx.mainform.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4, Int32 A_5, Int32 A_6, Boolean A_7, Boolean A_8)
22:47:08.1 7/9/2012: at GameEx.GameEx.mainform.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4, Int32 A_5, Int32 A_6, Boolean A_7)
22:47:08.1 7/9/2012: at GameEx.GameEx.mainform.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4, Int32 A_5, Int32 A_6)
22:47:08.1 7/9/2012: at GameEx.GameEx.mainform.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4)
22:47:08.1 7/9/2012: at GameEx.GameEx.mainform.c(Boolean A_0, Boolean A_1)
22:47:08.1 7/9/2012: at GameEx.GameEx.mainform.k(Boolean A_0)
22:48:32.8 7/9/2012: 21 Consecutive Exceptions Occured
22:48:32.8 7/9/2012: Object reference not set to an instance of an object.
22:48:32.8 7/9/2012: at Direct2D.Direct2d.Device.BeginScene(Boolean Clear, Color ClearColour)
22:48:32.8 7/9/2012: at GameEx.GameEx.mainform.c(Boolean A_0)
22:48:32.8 7/9/2012: at GameEx.GameEx.mainform.du()
22:48:32.8 7/9/2012: Trying reinitialising the display after sleeping for 4 seconds
22:48:32.8 7/9/2012: Exception count will be dropped to 15
22:48:36.8 7/9/2012: Exception initializing display
22:48:36.8 7/9/2012: Object reference not set to an instance of an object.
22:48:36.8 7/9/2012: at GameEx.GameEx.mainform.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4, Int32 A_5, Int32 A_6, Boolean A_7, Boolean A_8)
22:48:36.8 7/9/2012: at GameEx.GameEx.mainform.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4, Int32 A_5, Int32 A_6, Boolean A_7)
22:48:36.8 7/9/2012: at GameEx.GameEx.mainform.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4, Int32 A_5, Int32 A_6)
22:48:36.8 7/9/2012: at GameEx.GameEx.mainform.c(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3)
22:48:36.8 7/9/2012: at GameEx.GameEx.mainform.du()
22:48:36.8 7/9/2012: --**--
22:48:36.8 7/9/2012: 21 Consecutive Exceptions Occured: Exiting
22:48:36.8 7/9/2012: Closing database connection
22:48:36.8 7/9/2012: First Exception:
22:48:36.8 7/9/2012: at Direct2D.Direct2d.Device.BeginScene(Boolean Clear, Color ClearColour)
22:48:36.8 7/9/2012: at GameEx.GameEx.mainform.c(Boolean A_0)
22:48:36.8 7/9/2012: Last Exception:
It means what it says. You don't have something set up right so it can't launch. Either your ROMs are in the wrong place, your MAME.EXE is named incorrectly, or your command line is fubared.
Is MAMEUI32.exe what they call MAME32 nowadays?
Is MAMEUI32.exe what they call MAME32 nowadays? ..... yes
"MAMEUI, formerly MAME32, is the GUI version of MAME. Originally authored in 1997 by Chris Kirmse, it was the first port of MAME™ to the Windows platform. MAMEUI is currently in maintenance mode with no active development taking place. The 64-bit version is still compiled and released when there is no breakage with the core."
totally agree with Adultery. all pathes are the default ones, but the MAME.exe used is not. you should start the setup-wizard and point at least your MAME-path and Rom-path to the right location.
the roms are already working in gameex so I....
Moved my roms to C\roms\mame\roms and changed mameui32.exe to mame.exe and set it up in the config
loaded gameex to make sure mame roms work still, i waited the minute to start attract and then this came up
If My Command line was fubar my roms wouldnt work right??
heres the log after the change
23:47:01.4 7/10/2012: Starting Attract Mode
23:47:01.5 7/10/2012: Reading MAME hall of fame
23:47:01.7 7/10/2012: Shutting down display
23:47:02.2 7/10/2012: Warning: Display is running in full screen compatibility mode.
23:47:02.2 7/10/2012: Exception occured running Attract Mode
23:47:02.2 7/10/2012: Object reference not set to an instance of an object.
23:47:02.2 7/10/2012: at GameEx.GameEx.mainform.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4, Int32 A_5, Int32 A_6, Boolean A_7, Boolean A_8)
23:47:02.2 7/10/2012: at GameEx.GameEx.mainform.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4, Int32 A_5, Int32 A_6, Boolean A_7)
23:47:02.2 7/10/2012: at GameEx.GameEx.mainform.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4, Int32 A_5, Int32 A_6)
23:47:02.2 7/10/2012: at GameEx.GameEx.mainform.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4)
23:47:02.2 7/10/2012: at GameEx.GameEx.mainform.c(Boolean A_0, Boolean A_1)
23:47:02.2 7/10/2012: at GameEx.GameEx.mainform.k(Boolean A_0)
23:47:12.6 7/10/2012: 21 Consecutive Exceptions Occured
23:47:12.6 7/10/2012: Object reference not set to an instance of an object.
23:47:12.6 7/10/2012: at Direct2D.Direct2d.Device.BeginScene(Boolean Clear, Color ClearColour)
23:47:12.6 7/10/2012: at GameEx.GameEx.mainform.c(Boolean A_0)
23:47:12.6 7/10/2012: at GameEx.GameEx.mainform.du()
23:47:12.6 7/10/2012: Trying reinitialising the display after sleeping for 4 seconds
23:47:12.6 7/10/2012: Exception count will be dropped to 15
23:47:16.6 7/10/2012: Exception initializing display
23:47:16.6 7/10/2012: Object reference not set to an instance of an object.
23:47:16.6 7/10/2012: at GameEx.GameEx.mainform.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4, Int32 A_5, Int32 A_6, Boolean A_7, Boolean A_8)
23:47:16.6 7/10/2012: at GameEx.GameEx.mainform.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4, Int32 A_5, Int32 A_6, Boolean A_7)
23:47:16.6 7/10/2012: at GameEx.GameEx.mainform.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4, Int32 A_5, Int32 A_6)
23:47:16.6 7/10/2012: at GameEx.GameEx.mainform.c(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3)
23:47:16.6 7/10/2012: at GameEx.GameEx.mainform.du()
23:47:16.6 7/10/2012: --**--
23:47:16.6 7/10/2012: 21 Consecutive Exceptions Occured: Exiting
23:47:16.6 7/10/2012: Closing database connection
23:47:16.7 7/10/2012: First Exception:
23:47:16.7 7/10/2012: Object reference not set to an instance of an object.
23:47:16.7 7/10/2012: at Direct2D.Direct2d.Device.BeginScene(Boolean Clear, Color ClearColour)
23:47:16.7 7/10/2012: at GameEx.GameEx.mainform.c(Boolean A_0)
23:47:16.7 7/10/2012: at GameEx.GameEx.mainform.du()
23:47:16.7 7/10/2012: Last Exception:
Can you post the whole log?
Also copy your GameEx directory somewhere else, reinstall Gameex and copy the folder back (overwrite any matching files).
OK That Worked!!! Screensavers back!!! but when i reinstalled gameex i put everything back like i did the 1st time but now Mame Emu Mapping Magician keeps popping up when i start gameex minimizing the program and bringing that up. its very annoying forcing me have to click on it on the bar at bottom to bring up gameex. im using windows 7 if that helps any. i dont think i even use that program. Is there a tab that lets me disable that from popping up?
Heres the log.
05:46:17.4 7/11/2012: Opening Configuration File
05:46:17.4 7/11/2012: GameEx: Version 12.70: Starting Log
05:46:17.4 7/11/2012: Operating System Platform: Win32NT
05:46:17.4 7/11/2012: Operating System Name: Windows 7
05:46:17.4 7/11/2012: Operating System Version: 6.1.7600
05:46:17.4 7/11/2012: Aero NOT running
05:46:17.4 7/11/2012: Initializing Vista/Windows 7 volume control
05:46:17.4 7/11/2012: Pentium® Dual-Core CPU E5300 @ 2.60GHz, 3317MB
05:46:17.4 7/11/2012: 2.59Ghz - 2 Cores or CPU's
05:46:17.4 7/11/2012: Running Randomize()
05:46:17.4 7/11/2012: Loading PlugIns
05:46:17.4 7/11/2012: Checking for applications to Launch On Startup
05:46:17.4 7/11/2012: Running Misc startup tasks
05:46:17.4 7/11/2012: Setting Menu types
05:46:17.4 7/11/2012: Getting Configuration Values
05:46:17.4 7/11/2012: Using Theme: Default - Media Center
05:46:17.4 7/11/2012: Checking for alternate Image Directory for Theme: Default - Media Center
05:46:17.4 7/11/2012: Using Images from theme: Default - Media Center V1\MEDIA\
05:46:17.4 7/11/2012: Launching HideOS.exe
05:46:17.4 7/11/2012: Initialising Video/MNG DLL's
05:46:17.4 7/11/2012: GameEx will check for media insertion (may affect performance)
05:46:17.4 7/11/2012: Hiding Taskbar
05:46:17.4 7/11/2012: Is Media Center running?
05:46:17.4 7/11/2012: Checking/Creating LCD Registry values
05:46:17.4 7/11/2012: Check Media Center Exit/Start Mode
05:46:17.4 7/11/2012: Media Center Mode 2
05:46:17.4 7/11/2012: Video previews on. Warning: Only recommended on modern systems
05:46:17.4 7/11/2012: Custom Keyboard Input enabled: Getting custom codes
05:46:17.4 7/11/2012: Snap Delay set to: 2
05:46:17.4 7/11/2012: Get other settings
05:46:17.4 7/11/2012: Desktop set to Hide ICONS and set Background to Black
05:46:17.4 7/11/2012: Set: Find emulator artwork on best match basis
05:46:17.4 7/11/2012: Using DirectInput for keyboard input
05:46:17.5 7/11/2012: Start work for Form
05:46:17.5 7/11/2012: Getting Original Screen Size
05:46:17.5 7/11/2012: Opening Database Connection
05:46:17.5 7/11/2012: Initializing Component
05:46:17.6 7/11/2012: MAME Path is: C:\GameEx
05:46:17.6 7/11/2012: daphne Path is: C:\Emulators\Daphne
05:46:17.6 7/11/2012: daphne EXE file is: Daphne.exe
05:46:17.6 7/11/2012: Use daphne on. Daphne.exe will launch games
05:46:17.6 7/11/2012: MAME EXE file is: Mame Mapping Magician.exe
05:46:17.6 7/11/2012: ROM Path is: C:\Emulators\MAME\roms
05:46:17.6 7/11/2012: Catver.ini is located at: C:\GameEx\DATA\catver.ini
05:46:17.6 7/11/2012: controls.ini is located at: C:\GameEx\DATA\controls.ini
05:46:17.6 7/11/2012: History.dat is located at: C:\GameEx\DATA\history.dat
05:46:17.6 7/11/2012: nplayers.ini is located at: C:\GameEx\DATA\nplayers.ini
05:46:17.6 7/11/2012: command.dat is located at: C:\GameEx\DATA\command.dat
05:46:17.6 7/11/2012: MAMEinfo.dat is located at: C:\GameEx\DATA\mameinfo.dat
05:46:17.6 7/11/2012: Loading Controls.ini map file
05:46:17.6 7/11/2012: Snap Path is: C:\Emulators\MAME\snap
05:46:17.6 7/11/2012: Background Snap Path: Not Found
05:46:17.6 7/11/2012: AVI Snap Path is: C:\GameEx\DEMO\MAME\video
05:46:17.6 7/11/2012: Flyer Path is: C:\GameEx\DEMO\MAME\flyers
05:46:17.6 7/11/2012: Cabinet Path is: C:\GameEx\DEMO\MAME\cabinets
05:46:17.6 7/11/2012: Cabinet 3D Path is: C:\GameEx\DEMO\MAME\cabinets3d
05:46:17.6 7/11/2012: Title Path is: C:\GameEx\DEMO\MAME\titles
05:46:17.6 7/11/2012: PCB Path: Not Found
05:46:17.6 7/11/2012: Artwork Preview Path: Not Found
05:46:17.6 7/11/2012: Panel Path is: C:\GameEx\DEMO\MAME\cpanel
05:46:17.6 7/11/2012: Manual Path is: C:\GameEx\DEMO\MAME\manual
05:46:17.6 7/11/2012: Icon Path is: C:\GameEx\DEMO\MAME\icons
05:46:17.6 7/11/2012: Marquee Path is: C:\GameEx\DEMO\MAME\marquees
05:46:17.6 7/11/2012: Applying Language/Text
05:46:17.6 7/11/2012: Text/Language: English
05:46:17.6 7/11/2012: Loading Custom Emulators
05:46:17.6 7/11/2012: Loading Emulator 1: [Console] Nintendo SNES (Snes9x)
05:46:17.6 7/11/2012: Loading Emulator 2: [Console] Sega 32x (Fusion)
05:46:17.6 7/11/2012: Loading Emulator 3: [Console] Nintendo NES (Jnes)
05:46:17.6 7/11/2012: Loading Emulator 4: [Console] Sega CD (Fusion)
05:46:17.7 7/11/2012: Loading Emulator 5: [Handheld] Sega Game Gear (Fusion)
05:46:17.7 7/11/2012: Loading Emulator 6: [Console] Sega Genesis (Fusion)
05:46:17.7 7/11/2012: Loading Emulator 7: [Handheld] Nintendo Game Boy Advance (VisualBoyAdvance)
05:46:17.7 7/11/2012: Loading Emulator 8: [Handheld] Nintendo Game Boy Color (VisualBoyAdvance)
05:46:17.7 7/11/2012: Loading Emulator 9: [Handheld] SNK Neo-Geo Pocket (NeoPop)
05:46:17.7 7/11/2012: Loading Emulator 10: [Console] NEC TurboGrafx-16 (MagicEngine)
05:46:17.7 7/11/2012: Using Version 3 Themes Animations
05:46:17.7 7/11/2012: Retrieving resolution setting
05:46:17.7 7/11/2012: Using General Font: Trebuchet MS
05:46:17.7 7/11/2012: Using Title Font: Trebuchet MS
05:46:17.7 7/11/2012: GameEx will try to reduce CPU usage
05:46:17.7 7/11/2012: Initialising Direct3D
05:46:17.8 7/11/2012: Applying GameEx is Loading Image
05:46:17.9 7/11/2012: Setting Resolution to 1280x1024 32 bit color
05:46:17.9 7/11/2012: Creating Surfaces
05:46:17.9 7/11/2012: Creating Primary Surface - Full Screen Mode
05:46:17.9 7/11/2012: Creating Back Buffer
05:46:17.9 7/11/2012: Loading graphic Surfaces
05:46:17.9 7/11/2012: Display is running at: 1280x1024 32bit color, 60hz
05:46:17.9 7/11/2012: Adapter: Intel® G33/G31 Express Chipset Family
05:46:17.9 7/11/2012: Max texture size: 2048x2048
05:46:17.9 7/11/2012: Available texture memory: 241MB
05:46:18.0 7/11/2012: Initialising Bass Audio Library
05:46:18.0 7/11/2012: Creating Surfaces Misc and Dialogs
05:46:18.1 7/11/2012: Creating Surfaces Volume
05:46:18.1 7/11/2012: Creating Surfaces Arrows
05:46:18.1 7/11/2012: Creating Surfaces GameEXlogo Text
05:46:18.1 7/11/2012: Creating Surfaces Toolbar
05:46:18.1 7/11/2012: Creating Surfaces Toolbar Controls
05:46:18.1 7/11/2012: Creating Surfaces Backgrounds
05:46:18.1 7/11/2012: Creating Surfaces GameEx Logo
05:46:18.1 7/11/2012: Creating Surface Unselected
05:46:18.1 7/11/2012: Creating Surfaces Snaps
05:46:18.1 7/11/2012: Creating Surfaces Menu and List Bars
05:46:18.4 7/11/2012: Creating Fonts
05:46:18.4 7/11/2012: Creating Game Font
05:46:18.5 7/11/2012: Creating Game Font Faded
05:46:18.5 7/11/2012: Creating Title Font
05:46:18.6 7/11/2012: Restoring Title Font From Cache
05:46:18.8 7/11/2012: Creating Font Black
05:46:18.9 7/11/2012: Creating Font Black Small
05:46:19.0 7/11/2012: Fonts Created Succesfully
05:46:19.0 7/11/2012: 5MB Video Memory Used
05:46:19.3 7/11/2012: Attempting to load game list
05:46:19.3 7/11/2012: Running: Mame Mapping Magician.exe -help
05:46:19.4 7/11/2012: Running: C: C:\GameEx\Mame Mapping Magician.exe -help > C:\GameEx\help.txt
05:46:19.4 7/11/2012: MAME CMD options: -nowindow -joy -skip_gameinfo
05:46:19.4 7/11/2012: Loading music
05:46:19.5 7/11/2012: Initialising Windows Media Player Component
05:46:19.5 7/11/2012: Error accessing Windows Media Player, check you are running Version 9 orelse above
05:46:19.5 7/11/2012: Value does not fall within the expected range.
05:46:19.5 7/11/2012: at WMPLib.IWMPPlaylistArray.Item(Int32 lIndex)
05:46:19.5 7/11/2012: at GameEx.GameEx.mainform.d(Boolean A_0, Boolean A_1, Boolean A_2)
05:46:19.6 7/11/2012: Creating DirectSound Device
05:46:19.6 7/11/2012: Trying: Primary Sound Driver
05:46:19.6 7/11/2012: Loading Sound Files
05:46:19.6 7/11/2012: DirectSound Device Created Successfully
05:46:19.6 7/11/2012: Initialising DirectInput for Gamepad support
05:46:19.8 7/11/2012: Using Device XBOX 360 For Windows (Controller)
05:46:20.0 7/11/2012: Initialising DirectInput for Keyboard support
05:46:20.1 7/11/2012: Loading Start Page
05:46:20.2 7/11/2012: Initializing MCE Remote
05:46:20.2 7/11/2012: Initialization OK! Starting GameEx!
05:46:20.2 7/11/2012: Testing Main Loop Once: Processing Frame
05:46:20.5 7/11/2012: Testing Main Loop Once: Main Loop ran successfully
05:50:02.7 7/11/2012: Validating: Emulator_1: Snap Path: C:\Assets\Nintendo SNES\Snaps
05:50:02.7 7/11/2012: Validating: Emulator_1: Control Panel Path: C:\Assets\Nintendo SNES\Controls
05:50:02.7 7/11/2012: Validating: Emulator_1: Database: [Console] Nintendo SNES
05:50:02.7 7/11/2012: Validating: Emulator_1: Title Snap Path: C:\Assets\Nintendo SNES\Titles
05:50:02.7 7/11/2012: Validating: Emulator_1: Box Art Path: C:\Assets\Nintendo SNES\Boxes
05:50:02.7 7/11/2012: Validating: Emulator_1: Cart Art Path: C:\Assets\Nintendo SNES\Cartridges
05:50:02.7 7/11/2012: Validating: Emulator_1: Manual Path: C:\Assets\Nintendo SNES\Manuals
05:50:02.7 7/11/2012: Validating: Emulator_2: Snap Path: C:\Assets\Sega 32x\Snaps
05:50:02.7 7/11/2012: Validating: Emulator_2: Control Panel Path: C:\Assets\Sega 32x\Controls
05:50:02.7 7/11/2012: Validating: Emulator_2: Database: [Console] Sega 32X
05:50:02.7 7/11/2012: Validating: Emulator_2: Title Snap Path: C:\Assets\Sega 32x\Titles
05:50:02.7 7/11/2012: Validating: Emulator_2: Box Art Path: C:\Assets\Sega 32x\Boxes
05:50:02.7 7/11/2012: Validating: Emulator_2: Cart Art Path: C:\Assets\Sega 32x\Cartridges
05:50:02.7 7/11/2012: Validating: Emulator_2: Manual Path: C:\Assets\Sega 32x\Manuals
05:50:02.7 7/11/2012: Validating: Emulator_3: Snap Path: C:\Assets\Nintendo NES\Snaps
05:50:02.7 7/11/2012: Validating: Emulator_3: Background Snap Path: C:\Emulators\Jnes\Background images
05:50:02.7 7/11/2012: Validating: Emulator_3: Video Snap Path: C:\Assets\Nintendo NES\Video Snaps
05:50:02.7 7/11/2012: Validating: Emulator_3: Control Panel Path: C:\Assets\Nintendo NES\Controls
05:50:02.7 7/11/2012: Validating: Emulator_3: Database: [Console] Nintendo NES
05:50:02.7 7/11/2012: Validating: Emulator_3: Title Snap Path: C:\Assets\Nintendo NES\Titles
05:50:02.7 7/11/2012: Validating: Emulator_3: Box Art Path: C:\Assets\Nintendo NES\Boxes
05:50:02.7 7/11/2012: Validating: Emulator_3: Cart Art Path: C:\Assets\Nintendo NES\Cartridges
05:50:02.7 7/11/2012: Validating: Emulator_3: Manual Path: C:\Assets\Nintendo NES\Manuals
05:50:02.7 7/11/2012: Validating: Emulator_4: Snap Path: C:\Assets\Sega CD\Snaps
05:50:02.7 7/11/2012: Validating: Emulator_4: Control Panel Path: C:\Assets\Sega CD\Controls
05:50:02.7 7/11/2012: Validating: Emulator_4: Database: [Console] Sega CD
05:50:02.7 7/11/2012: Validating: Emulator_4: Title Snap Path: C:\Assets\Sega CD\Titles
05:50:02.7 7/11/2012: Validating: Emulator_4: Box Art Path: C:\Assets\Sega CD\Boxes
05:50:02.7 7/11/2012: Validating: Emulator_4: Cart Art Path: C:\Assets\Sega CD\Cartridges
05:50:02.7 7/11/2012: Validating: Emulator_4: Manual Path: C:\Assets\Sega CD\Manuals
05:50:02.7 7/11/2012: Validating: Emulator_5: Snap Path: C:\Assets\Sega Game Gear\Snaps
05:50:02.7 7/11/2012: Validating: Emulator_5: Control Panel Path: C:\Assets\Sega Game Gear\Controls
05:50:02.7 7/11/2012: Validating: Emulator_5: Database: [Handheld] Sega Game Gear
05:50:02.7 7/11/2012: Validating: Emulator_5: Title Snap Path: C:\Assets\Sega Game Gear\Titles
05:50:02.7 7/11/2012: Validating: Emulator_5: Box Art Path: C:\Assets\Sega Game Gear\Boxes
05:50:02.7 7/11/2012: Validating: Emulator_5: Cart Art Path: C:\Assets\Sega Game Gear\Cartridges
05:50:02.7 7/11/2012: Validating: Emulator_5: Manual Path: C:\Assets\Sega Game Gear\Manuals
05:50:02.7 7/11/2012: Validating: Emulator_6: Snap Path: C:\Assets\Sega Genesis\Snaps
05:50:02.7 7/11/2012: Validating: Emulator_6: Background Snap Path: C:\Assets\Sega Genesis\Backgrounds
05:50:02.7 7/11/2012: Validating: Emulator_6: Video Snap Path: C:\Assets\Sega Genesis\Video Snaps
05:50:02.7 7/11/2012: Validating: Emulator_6: Control Panel Path: C:\Assets\Sega Genesis\Controls
05:50:02.7 7/11/2012: Validating: Emulator_6: Database: [Console] Sega Genesis
05:50:02.7 7/11/2012: Validating: Emulator_6: Title Snap Path: C:\Assets\Sega Genesis\Titles
05:50:02.7 7/11/2012: Validating: Emulator_6: Box Art Path: C:\Assets\Sega Genesis\Boxes
05:50:02.7 7/11/2012: Validating: Emulator_6: Cart Art Path: C:\Assets\Sega Genesis\Cartridges
05:50:02.7 7/11/2012: Validating: Emulator_6: Manual Path: C:\Assets\Sega Genesis\Manuals
05:50:02.7 7/11/2012: Validating: Emulator_7: Snap Path: C:\Assets\Nintendo Game Boy Advance\Snaps
05:50:02.7 7/11/2012: Validating: Emulator_7: Control Panel Path: C:\Assets\Nintendo Game Boy Advance\Controls
05:50:02.7 7/11/2012: Validating: Emulator_7: Database: [Handheld] Nintendo Game Boy Advance
05:50:02.7 7/11/2012: Validating: Emulator_7: Title Snap Path: C:\Assets\Nintendo Game Boy Advance\Titles
05:50:02.7 7/11/2012: Validating: Emulator_7: Box Art Path: C:\Assets\Nintendo Game Boy Advance\Boxes
05:50:02.7 7/11/2012: Validating: Emulator_7: Cart Art Path: C:\Assets\Nintendo Game Boy Advance\Cartridges
05:50:02.7 7/11/2012: Validating: Emulator_7: Manual Path: C:\Assets\Nintendo Game Boy Advance\Manuals
05:50:02.7 7/11/2012: Validating: Emulator_8: Snap Path: C:\Assets\Nintendo Game Boy Color\Snaps
05:50:02.7 7/11/2012: Validating: Emulator_8: Control Panel Path: C:\Assets\Nintendo Game Boy Color\Controls
05:50:02.7 7/11/2012: Validating: Emulator_8: Database: [Handheld] Nintendo Game Boy Color
05:50:02.8 7/11/2012: Validating: Emulator_8: Title Snap Path: C:\Assets\Nintendo Game Boy Color\Titles
05:50:02.8 7/11/2012: Validating: Emulator_8: Box Art Path: C:\Assets\Nintendo Game Boy Color\Boxes
05:50:02.8 7/11/2012: Validating: Emulator_8: Cart Art Path: C:\Assets\Nintendo Game Boy Color\Cartridges
05:50:02.8 7/11/2012: Validating: Emulator_8: Manual Path: C:\Assets\Nintendo Game Boy Color\Manuals
05:50:02.8 7/11/2012: Validating: Emulator_9: Snap Path: C:\Assets\SNK Neo-Geo Pocket\Snaps
05:50:02.8 7/11/2012: Validating: Emulator_9: Control Panel Path: C:\Assets\SNK Neo-Geo Pocket\Controls
05:50:02.8 7/11/2012: Validating: Emulator_9: Database: [Handheld] SNK Neo-Geo Pocket
05:50:02.8 7/11/2012: Validating: Emulator_9: Title Snap Path: C:\Assets\SNK Neo-Geo Pocket\Titles
05:50:02.8 7/11/2012: Validating: Emulator_9: Box Art Path: C:\Assets\SNK Neo-Geo Pocket\Boxes
05:50:02.8 7/11/2012: Validating: Emulator_9: Cart Art Path: C:\Assets\SNK Neo-Geo Pocket\Cartridges
05:50:02.8 7/11/2012: Validating: Emulator_9: Manual Path: C:\Assets\SNK Neo-Geo Pocket\Manuals
05:50:02.8 7/11/2012: Validating: Emulator_10: Snap Path: C:\Assets\NEC TurboGrafx-16\Snaps
05:50:02.8 7/11/2012: Validating: Emulator_10: Control Panel Path: C:\Assets\NEC TurboGrafx-16\Controls
05:50:02.8 7/11/2012: Validating: Emulator_10: Database: [Console] NEC TurboGrafx-16
05:50:02.8 7/11/2012: Validating: Emulator_10: Title Snap Path: C:\Assets\NEC TurboGrafx-16\Titles
05:50:02.8 7/11/2012: Validating: Emulator_10: Box Art Path: C:\Assets\NEC TurboGrafx-16\Boxes
05:50:02.8 7/11/2012: Validating: Emulator_10: Cart Art Path: C:\Assets\NEC TurboGrafx-16\Cartridges
05:50:02.8 7/11/2012: Validating: Emulator_10: Manual Path: C:\Assets\NEC TurboGrafx-16\Manuals
05:50:02.8 7/11/2012: Restoring Emulator from Cache: 1
05:50:02.8 7/11/2012: Restoring Emulator Database From Cache: 1
05:50:02.8 7/11/2012: Restoring Emulator from Cache: 2
05:50:02.9 7/11/2012: No Database Data: 2
05:50:02.9 7/11/2012: Restoring Emulator from Cache: 3
05:50:02.9 7/11/2012: Restoring Emulator Database From Cache: 3
05:50:02.9 7/11/2012: Restoring Emulator from Cache: 4
05:50:03.0 7/11/2012: Restoring Emulator Database From Cache: 4
05:50:03.0 7/11/2012: Restoring Emulator from Cache: 5
05:50:03.0 7/11/2012: Restoring Emulator Database From Cache: 5
05:50:03.1 7/11/2012: Restoring Emulator from Cache: 6
05:50:03.1 7/11/2012: Restoring Emulator Database From Cache: 6
05:50:03.1 7/11/2012: Restoring Emulator from Cache: 7
05:50:03.1 7/11/2012: Restoring Emulator Database From Cache: 7
05:50:03.2 7/11/2012: Restoring Emulator from Cache: 8
05:50:03.2 7/11/2012: Restoring Emulator Database From Cache: 8
05:50:03.3 7/11/2012: Restoring Emulator from Cache: 9
05:50:03.3 7/11/2012: No Database Data: 9
05:50:03.3 7/11/2012: Restoring Emulator from Cache: 10
05:50:03.4 7/11/2012: Restoring Emulator Database From Cache: 10
05:50:12.7 7/11/2012: Exiting GameEx!
05:50:12.7 7/11/2012: Disposing all videos
05:50:12.7 7/11/2012: Deleting temporary Karaoke videos
05:50:12.7 7/11/2012: Disposing Image List
05:50:12.7 7/11/2012: Disposing Fonts
05:50:12.7 7/11/2012: Disposing Surfaces
05:50:12.7 7/11/2012: Saving Settings
05:50:12.7 7/11/2012: Shutting down Bass
05:50:12.8 7/11/2012: Closing HideOS.exe
05:50:13.0 7/11/2012: Disposing Plugins
05:50:13.0 7/11/2012: Closing database connection
05:50:13.1 7/11/2012: Checking for applications to Launch On Exit
05:50:13.8 7/11/2012: Bye
post-9942-0-50625000-1342000125_thumb.jp
Those two lines don't look right. :)
It's because they're not... LOL!
Should be like this based on your earlier log:
@csnells2000 - Were you able to resolve the errors based on the last response from Adultery? Please let us know one way or the other - thanks!
Edited by Draco1962
