Is there anyway to change, or remove the < > brackets on the Menu items? I think it would look a lot nicer without them.
+1 to the suggestion. Since the menu category is highlighted with the selection bar, the <> kinda detracts from the appearance.
That's exactly what I was thinking.
maybe i am the only one here, but i dont have a selection bar on this stuff, only in the list menu. basically i dont even know, how you guys achieved this effect :rolleyes: so at least for me, the brackets have a sense/meaning. not that i would miss them ;) , as i still have the bigger size if stuff is selected.
ok i found out, how you get the selection bar on the menue. if you put a "zero" in Y-coordinates for the menue, you dont have a selection bar on the menue anymore. that is my experience. if you put positive values in Y-coordinates, you bring back the selection bar. in my case, i am happy for not having a selection bar. because it is differently stretched for every selection you make in the menue and this would look ugly, as i have a somehow "different" selection bar :P .
i just wanted to mention this, maybe some other theme-creators are interested in this :rolleyes:
I thought the < and > were used to indicate that when selected, you could move the cursor to the left or the right... a bit redundant it you're familiar with the interface, but helpful for new people using your system that don't know.
Edited by Draco1962
