hi there,
i saw a clip with Visual Pinball works on 2 screens.. One for the playfield and one for the backglass.. I installed vpinball and pinmame.. But when i start a table than is the 2. Screen not in use.. Starts vpinball automatical pinmame when a table is loading? What can i do to use Visual Pinball on 2 screens?
Thanks for help
René
Hi Rene - you might want to check out the thread started by TheDevilBunny. You will need to enable GameExtender and perhaps refer to some of the other notes in that thread to get it working for you.
Hi Draco. The gameextender isnt the Problem. The question is must pinmame starting automaticly with visual mame or must i starts separatly. I try to load a table in vp but pinmame isnt start.
