I had been playing on my machine last evening, all was good. I noticed the
notification of a new update available. Chose to update as I always had.
Left the room at the time to let it update, came back to an error message box.
It gave me the option to report the error, and send the info which I did.
Rebooted the computer and tried again twice... still same error. I'll have to try
to get the exact error message, and post it, but I believe the error is video related
as it is in the process of checking the video specs, memory etc when it happens.
As a registered version user, if necessary, is there a way to roll it back to the last
version and keep the registered user info, configuration etc if necessary?
Any help appreciated. Always worked flawlessly before this update.
I've copied / pasted the error file I get when I try to run GameEx below.
If I were to download GameEx latest version, and run the install... will I lose the current config, and registration information thereby losing the
features enabled? Thanks Tom... Love the software, always worked like a charm.
07:59:54.4 6/8/2012: Opening Configuration File
07:59:54.5 6/8/2012: GameEx: Version 12.66: Starting Log
07:59:54.5 6/8/2012: Operating System Platform: Win32NT
07:59:54.5 6/8/2012: Operating System Name: Windows XP
07:59:54.5 6/8/2012: Operating System Version: 5.1.2600
07:59:54.5 6/8/2012: Intel® Pentium® 4 CPU 2.66GHz, 511MB
07:59:54.6 6/8/2012: 2.67Ghz
07:59:54.6 6/8/2012: Running Randomize()
07:59:54.7 6/8/2012: Loading PlugIns
07:59:54.8 6/8/2012: Checking for applications to Launch On Startup
07:59:54.8 6/8/2012: Running Misc startup tasks
07:59:54.9 6/8/2012: Setting Menu types
07:59:54.9 6/8/2012: Getting Configuration Values
07:59:54.9 6/8/2012: Using Theme: Acidbrain Vision
07:59:54.9 6/8/2012: Checking for alternate Image Directory for Theme: Acidbrain Vision
07:59:55.0 6/8/2012: Launching HideOS.exe
07:59:55.0 6/8/2012: Initialising Video/MNG DLL's
07:59:55.0 6/8/2012: GameEx will check for media insertion (may affect performance)
07:59:55.0 6/8/2012: Hiding Taskbar
08:00:15.1 6/8/2012: Is Media Center running?
08:00:15.2 6/8/2012: Checking/Creating LCD Registry values
08:00:15.3 6/8/2012: Check Media Center Exit/Start Mode
08:00:15.3 6/8/2012: Media Center Mode 2
08:00:15.6 6/8/2012: Video previews on. Warning: Only recommended on modern systems
08:00:15.6 6/8/2012: Snap Delay set to: 4
08:00:15.6 6/8/2012: Get other settings
08:00:15.6 6/8/2012: Desktop set to Hide ICONS and set Background to Black
08:00:15.6 6/8/2012: Set: Find emulator artwork on best match basis
08:00:15.6 6/8/2012: SlikStik support enabled
08:00:15.6 6/8/2012: Using DirectInput for keyboard input
08:00:15.6 6/8/2012: Start work for Form
08:00:15.6 6/8/2012: Getting Original Screen Size
08:00:15.6 6/8/2012: Opening Database Connection
08:00:25.7 6/8/2012: Initializing Component
08:00:26.7 6/8/2012: MAME Path is: C:\Mame32
08:00:26.8 6/8/2012: daphne Path is: C:\Emulators\Daphne
08:00:26.8 6/8/2012: daphne EXE file is: Daphne.exe
08:00:26.8 6/8/2012: Use daphne on. Daphne.exe will launch games
08:00:26.8 6/8/2012: MAME EXE file is: Mame32.exe
08:00:26.9 6/8/2012: ROM Path is: C:\Mame32\roms
08:00:26.9 6/8/2012: Catver.ini is located at: C:\GameEx\DATA\catver.ini
08:00:27.1 6/8/2012: controls.ini is located at: C:\Mame32\ctrlr\Xarcade.cfg
08:00:27.1 6/8/2012: History.dat is located at: C:\GameEx\DATA\history.dat
08:00:27.1 6/8/2012: nplayers.ini is located at: C:\GameEx\DATA\nplayers.ini
08:00:27.2 6/8/2012: command.dat is located at: C:\GameEx\DATA\command.dat
08:00:27.2 6/8/2012: MAMEinfo.dat is located at: C:\GameEx\DATA\mameinfo.dat
08:00:27.3 6/8/2012: Loading Controls.ini map file
08:00:27.6 6/8/2012: Snap Path is: C:\Assets\MAME\Snap
08:00:27.6 6/8/2012: Background Snap Path: Not Found
08:00:27.6 6/8/2012: AVI Snap Path is: C:\Assets\MAME\Video_AVI_HI_QUAL
08:00:27.7 6/8/2012: Flyer Path is: C:\Assets\MAME\flyers
08:00:27.8 6/8/2012: Cabinet Path is: C:\Assets\MAME\Cabinets
08:00:27.9 6/8/2012: Cabinet 3D Path is: C:\GameEx\DEMO\MAME\cabinets3d
08:00:28.0 6/8/2012: Title Path is: C:\Assets\MAME\Titles
08:00:28.1 6/8/2012: PCB Path is: C:\Assets\MAME\PCB
08:00:28.1 6/8/2012: Artwork Preview Path is: C:\Assets\MAME\Artwork
08:00:28.2 6/8/2012: Panel Path is: C:\Assets\MAME\CP
08:00:28.2 6/8/2012: Manual Path is: C:\Assets\MAME\Manual
08:00:28.2 6/8/2012: Icon Path is: C:\Assets\MAME\Icons
08:00:28.3 6/8/2012: Marquee Path is: C:\Assets\MAME\Marquee
08:00:28.3 6/8/2012: Applying Language/Text
08:00:28.3 6/8/2012: Text/Language: English
08:00:28.6 6/8/2012: Loading Custom Emulators
08:00:28.6 6/8/2012: Loading Emulator 2: Nintendo SNES
08:00:28.9 6/8/2012: Loading Emulator 3: Nintendo N64
08:00:28.9 6/8/2012: Loading Emulator 4: Atari 2600
08:00:29.0 6/8/2012: Loading Emulator 6: [Console] Nintendo NES (FCE Ultra)
08:00:29.0 6/8/2012: Loading Emulator 7: Sega Genesis
08:00:29.2 6/8/2012: Loading Emulator 8: [Console] SNK Neo-Geo (Nebula)
08:00:29.3 6/8/2012: Loading Emulator 9: Sony Playstation
08:00:29.4 6/8/2012: Loading Emulator 10: [PC] Microsoft MSX (blueMSX)
08:00:29.5 6/8/2012: Loading Emulator 11: [Pinball] Future Pinball
08:00:29.6 6/8/2012: Loading Emulator 12: [Pinball] Visual PinMAME
08:00:29.8 6/8/2012: Loading Emulator 13: [Arcade] Arcade (MAME140)
08:00:29.8 6/8/2012: Using 3D Alpha Blended Animations.
08:00:29.8 6/8/2012: Retrieving resolution setting
08:00:31.2 6/8/2012: Using General Font: Trebuchet MS
08:00:31.2 6/8/2012: Using Title Font: Trebuchet MS
08:00:31.2 6/8/2012: GameEx will try to reduce CPU usage
08:00:31.2 6/8/2012: Initialising Direct3D
08:00:32.3 6/8/2012: Applying GameEx is Loading Image
08:00:32.8 6/8/2012: Setting Resolution to 1024x768 32 bit color
08:00:32.9 6/8/2012: Creating Surfaces
08:00:34.5 6/8/2012: Creating Primary Surface - Full Screen Mode
08:00:34.5 6/8/2012: Creating Back Buffer
08:00:34.6 6/8/2012: Version 2 Theme being used. Loading.
08:00:34.6 6/8/2012: Loading Button Data
08:00:34.6 6/8/2012: Loading Font Data
08:00:34.6 6/8/2012: Loading Layout Data
08:00:34.7 6/8/2012: Loading Taskbar Data
08:00:34.7 6/8/2012: Loading graphic Surfaces
08:00:34.7 6/8/2012: Display is running at: 1024x768 32bit color, 60hz
08:00:34.7 6/8/2012: Adapter: SAPPHIRE RADEON X300SE
08:00:34.7 6/8/2012: Max texture size: 2048x2048
08:00:34.7 6/8/2012: Available texture memory: 236MB
08:00:34.8 6/8/2012: Initialising Bass Audio Library
08:00:35.0 6/8/2012: Creating Surfaces Misc and Dialogs
08:00:35.9 6/8/2012: --**--
08:00:35.9 6/8/2012: Error: Parameter is not valid.
08:00:36.8 6/8/2012: at System.Drawing.Bitmap..ctor(String filename)
08:00:36.8 6/8/2012: at Direct2D.Direct2d.Surface.a(String A_0, Device A_1)
08:00:36.8 6/8/2012: at Direct2D.Direct2d.Surface..ctor(String Filename, Device Device)
08:00:36.8 6/8/2012: at GameEx.GameEx.mainform.RestoreSurfaces(Boolean JustDispose, Boolean NoDispose, Boolean ONLYDispose)
08:00:36.8 6/8/2012: at GameEx.GameEx.mainform.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4, Int32 A_5, Int32 A_6, Boolean A_7, Boolean A_8)
08:00:36.8 6/8/2012: at GameEx.GameEx.mainform.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4, Int32 A_5, Int32 A_6, Boolean A_7)
08:00:36.8 6/8/2012: at GameEx.GameEx.mainform.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4, Int32 A_5, Int32 A_6)
08:00:36.8 6/8/2012: at GameEx.GameEx.mainform.b(Boolean A_0, Boolean A_1, Boolean A_2)
08:00:36.8 6/8/2012: at GameEx.GameEx.mainform.ig(Boolean reinit, String ctheme, Boolean nohideos)
08:00:36.8 6/8/2012: at GameEx.GameEx.mainform..ctor()
08:00:36.8 6/8/2012: Closing database connection
08:00:36.9 6/8/2012: Disposing Plugins
08:00:36.9 6/8/2012: GameEx is exiting with errors
08:00:36.9 6/8/2012: Deleting search cache
08:00:37.4 6/8/2012: ERRORS DETECTED: EXITING
08:00:38.7 6/8/2012: Bye
I always recommend making a backup but if you download and run the install that way, your configs should be OK.
I see there's another newer version.... try that one, or try re-installing the one previously that seemed to mess things up?
Thanks again Draco, much appreciated.
Running the install that way is "exactly" the same as the auto update. There is no difference and by the look of your log I can see that will deffinitly fix your problem.
Marking as Resolved!
Edited by Draco1962
This thread is now marked as Resolved and has been closed. If the problem re-occurs, please start a new thread.
