Hi
this may be unrelated to the new version, but I've never had gameex crash on me nor have any problems with input, but tonight after I auto-updated to the new version, after coming out of 10minutes of a SSF game and back into gameex, the gamepad input stopped working inside gameex (even though it worked to run the game and in the game, but coming back the gamepad would not control gameex nav).
So I used the mouse to run a different game - which didn't load - I got a black screen so I clicked Esc to go back to gameex and then the UI showed up and GameEx crashed with this error:
Can you help? thanks :) Or can I reinstall the version before tonight's update?
00:58:29.1 6/4/2012: Opening Configuration File
00:58:29.2 6/4/2012: GameEx: Version 12.62: Starting Log
00:58:29.2 6/4/2012: Operating System Platform: Win32NT
00:58:29.2 6/4/2012: Operating System Name: Windows 7
00:58:29.2 6/4/2012: Operating System Version: 6.1.7601
00:58:29.2 6/4/2012: Aero running
00:58:29.2 6/4/2012: Initializing Vista/Windows 7 volume control
00:58:29.2 6/4/2012: AMD Phenom(tm) 8750 Triple-Core Processor, 3839MB
00:58:29.2 6/4/2012: 2.41Ghz - 3 Cores or CPU's
00:58:29.2 6/4/2012: Running Randomize()
00:58:29.2 6/4/2012: Loading PlugIns
00:58:29.2 6/4/2012: Checking for applications to Launch On Startup
00:58:29.2 6/4/2012: Running Misc startup tasks
00:58:29.2 6/4/2012: Setting Menu types
00:58:29.2 6/4/2012: Getting Configuration Values
00:58:29.2 6/4/2012: Using Theme: Default - Dark Gloss
00:58:29.2 6/4/2012: Checking for alternate Image Directory for Theme: Default - Dark Gloss
00:58:29.2 6/4/2012: Launching HideOS.exe
00:58:29.2 6/4/2012: Initialising Video/MNG DLL's
00:58:29.2 6/4/2012: GameEx will check for media insertion (may affect performance)
00:58:29.2 6/4/2012: Hiding Taskbar
00:58:29.2 6/4/2012: Is Media Center running?
00:58:29.2 6/4/2012: Checking/Creating LCD Registry values
00:58:29.2 6/4/2012: Check Media Center Exit/Start Mode
00:58:29.2 6/4/2012: Media Center Mode 2
00:58:29.3 6/4/2012: Video previews on. Warning: Only recommended on modern systems
00:58:29.3 6/4/2012: Snap Delay set to: 3
00:58:29.3 6/4/2012: Get other settings
00:58:29.3 6/4/2012: Desktop set to Hide ICONS and set Background to Black
00:58:29.3 6/4/2012: Set: Find emulator artwork on best match basis
00:58:29.3 6/4/2012: Start work for Form
00:58:29.3 6/4/2012: Getting Original Screen Size
00:58:29.3 6/4/2012: Opening Database Connection
00:58:29.3 6/4/2012: Initializing Component
00:58:29.3 6/4/2012: MAME Path is: C:\Emulators\MAME
00:58:29.3 6/4/2012: MAME EXE file is: mame64.exe
00:58:29.4 6/4/2012: ROM Paths are: C:\Emulators\MAME\roms;C:\Roms\MAME\Roms
00:58:29.4 6/4/2012: Catver.ini is located at: C:\GameEx\DATA\catver.ini
00:58:29.4 6/4/2012: controls.ini is located at: C:\GameEx\data\controls.ini
00:58:29.4 6/4/2012: History.dat is located at: C:\GameEx\DATA\history.dat
00:58:29.4 6/4/2012: nplayers.ini is located at: C:\GameEx\DATA\nplayers.ini
00:58:29.4 6/4/2012: command.dat is located at: C:\GameEx\DATA\command.dat
00:58:29.4 6/4/2012: MAMEinfo.dat is located at: C:\GameEx\DATA\mameinfo.dat
00:58:29.4 6/4/2012: Loading Controls.ini map file
00:58:29.4 6/4/2012: Snap Path is: C:\Assets\MAME\Snaps
00:58:29.4 6/4/2012: Background Snap Path is: C:\Assets\MAME\Snaps
00:58:29.4 6/4/2012: AVI Snap Path is: C:\Assets\MAME\VideoSnaps
00:58:29.4 6/4/2012: Flyer Path is: C:\Assets\MAME\Flyers
00:58:29.4 6/4/2012: Cabinet Path is: C:\Assets\MAME\Cabinets
00:58:29.4 6/4/2012: Cabinet 3D Path: Not Found
00:58:29.4 6/4/2012: Title Path is: C:\Assets\MAME\Titles
00:58:29.4 6/4/2012: PCB Path is: C:\Assets\MAME\PCBs
00:58:29.4 6/4/2012: Artwork Preview Path is: C:\Assets\MAME\Artwork
00:58:29.4 6/4/2012: Panel Path is: C:\Assets\MAME\Panels
00:58:29.4 6/4/2012: Manual Path is: C:\Assets\MAME\Manuals
00:58:29.4 6/4/2012: Icon Path is: C:\Assets\MAME\Icons
00:58:29.4 6/4/2012: Marquee Path is: C:\Assets\MAME\Marquees
00:58:29.4 6/4/2012: Applying Language/Text
00:58:29.4 6/4/2012: Text/Language: English
00:58:29.5 6/4/2012: Loading Custom Emulators
00:58:29.5 6/4/2012: Loading Emulator 1: [Arcade] Arcade Machines (MAME)
00:58:29.5 6/4/2012: Loading Emulator 2: [Retro] Atari 2600 (Stella)
00:58:29.5 6/4/2012: Loading Emulator 3: [Pinball] Visual Pinball
00:58:29.5 6/4/2012: Loading Emulator 4: [Console] Sega Genesis (Fusion)
00:58:29.5 6/4/2012: Loading Emulator 5: [Console] Sega Saturn (SSF)
00:58:29.5 6/4/2012: Loading Emulator 6: [Console] Sony Playstation (ePSXe)
00:58:29.5 6/4/2012: Loading Emulator 7: [Console] Nintendo Wii (Dolphin)
00:58:29.5 6/4/2012: Loading Emulator 8: [Handheld] Sega Game Gear (Fusion)
00:58:29.5 6/4/2012: Loading Emulator 11: [Retro] Nintendo NES
00:58:29.5 6/4/2012: Loading Emulator 12: [Console] Super Nintendo SNES
00:58:29.5 6/4/2012: Loading Emulator 13: [Retro] Colecovision
00:58:29.5 6/4/2012: Loading Emulator 14: [Retro] TurboGrafx-16
00:58:29.5 6/4/2012: Using Version 3 Themes Animations
00:58:29.5 6/4/2012: Retrieving resolution setting
00:58:29.5 6/4/2012: Using General Font: Trebuchet MS
00:58:29.5 6/4/2012: Using Title Font: Trebuchet MS
00:58:29.6 6/4/2012: Initialising Direct3D
00:58:29.7 6/4/2012: Applying GameEx is Loading Image
00:58:29.7 6/4/2012: Setting Resolution to 1920x1080 32 bit color
00:58:29.7 6/4/2012: Creating Surfaces
00:58:29.9 6/4/2012: Creating Primary Surface - Full Screen Mode
00:58:29.9 6/4/2012: Creating Back Buffer
00:58:29.9 6/4/2012: Loading graphic Surfaces
00:58:29.9 6/4/2012: Display is running at: 1920x1080 32bit color, 59hz
00:58:29.9 6/4/2012: Adapter: ATI Radeon HD 3200 Graphics
00:58:29.9 6/4/2012: Max texture size: 8192x8192
00:58:29.9 6/4/2012: Available texture memory: 1892MB
00:58:29.9 6/4/2012: Initialising Bass Audio Library
00:58:30.0 6/4/2012: Creating Surfaces Misc and Dialogs
00:58:30.1 6/4/2012: Creating Surfaces Volume
00:58:30.1 6/4/2012: Creating Surfaces Arrows
00:58:30.2 6/4/2012: Creating Surfaces GameEXlogo Text
00:58:30.2 6/4/2012: Creating Surfaces Toolbar
00:58:30.2 6/4/2012: Creating Surfaces Toolbar Controls
00:58:30.2 6/4/2012: Creating Surfaces Backgrounds
00:58:30.2 6/4/2012: Creating Surfaces GameEx Logo
00:58:30.3 6/4/2012: Creating Surface Unselected
00:58:30.3 6/4/2012: Creating Surfaces Snaps
00:58:30.3 6/4/2012: Creating Surfaces Menu and List Bars
00:58:30.3 6/4/2012: Creating Fonts
00:58:30.3 6/4/2012: Creating Game Font
00:58:30.5 6/4/2012: Creating Game Font Faded
00:58:30.6 6/4/2012: Creating Title Font
00:58:30.6 6/4/2012: Restoring Title Font From Cache
00:58:30.9 6/4/2012: Creating Font Black
00:58:31.0 6/4/2012: Creating Font Black Small
00:58:31.1 6/4/2012: Fonts Created Succesfully
00:58:31.2 6/4/2012: 8MB Video Memory Used
00:58:31.8 6/4/2012: Attempting to load game list
00:58:32.0 6/4/2012: MAME CMD options: -nowindow -joy -skip_gameinfo
00:58:32.1 6/4/2012: Creating DirectSound Device
00:58:32.1 6/4/2012: Trying: Primary Sound Driver
00:58:32.1 6/4/2012: Loading Sound Files
00:58:32.1 6/4/2012: DirectSound Device Created Successfully
00:58:32.1 6/4/2012: Initialising DirectInput for Gamepad support
00:58:32.2 6/4/2012: Using Device Controller (Xbox 360 Wireless Receiver for Windows)
00:58:32.2 6/4/2012: Loading Start Page
00:58:32.3 6/4/2012: Initializing MCE Remote
00:58:32.3 6/4/2012: Initialization OK! Starting GameEx!
00:58:32.3 6/4/2012: Testing Main Loop Once: Processing Frame
00:58:32.6 6/4/2012: Testing Main Loop Once: Main Loop ran successfully
01:02:35.3 6/4/2012: Screensaver - Turning Off Display
01:02:35.3 6/4/2012: Shutting down display
01:02:45.4 6/4/2012: Restoring Window
01:02:45.4 6/4/2012: Reinitializing Graphics System
01:02:47.2 6/4/2012: Returning to GameEx
01:03:21.9 6/4/2012: Validating: Emulator_1: Snap Path: C:\Assets\MAME\Snaps
01:03:21.9 6/4/2012: Validating: Emulator_1: Control Panel Path: C:\Assets\MAME\Controls
01:03:21.9 6/4/2012: Validating: Emulator_1: Title Snap Path: C:\Assets\MAME\Titles
01:03:21.9 6/4/2012: Validating: Emulator_1: Box Art Path: C:\Assets\MAME\Boxes
01:03:21.9 6/4/2012: Validating: Emulator_1: Cart Art Path: C:\Assets\MAME\Cartridges
01:03:21.9 6/4/2012: Validating: Emulator_1: Manual Path: C:\Assets\MAME\Manuals
01:03:21.9 6/4/2012: Warning: Emulator_1: MAPFile Does Not Exist
01:03:21.9 6/4/2012: Validating: Emulator_2: Snap Path: C:\Assets\Atari 2600\Snaps
01:03:21.9 6/4/2012: Validating: Emulator_2: Control Panel Path: C:\Assets\Atari 2600\Controls
01:03:21.9 6/4/2012: Validating: Emulator_2: Database: [Console] Atari 2600
01:03:21.9 6/4/2012: Validating: Emulator_2: Title Snap Path: C:\Assets\Atari 2600\Titles
01:03:21.9 6/4/2012: Validating: Emulator_2: Box Art Path: C:\Assets\Atari 2600\Boxes
01:03:21.9 6/4/2012: Validating: Emulator_2: Cart Art Path: C:\Assets\Atari 2600\Cartridges
01:03:21.9 6/4/2012: Validating: Emulator_2: Manual Path: C:\Assets\Atari 2600\Manuals
01:03:21.9 6/4/2012: Validating: Emulator_3: Snap Path: C:\Assets\Visual Pinball\Snaps
01:03:21.9 6/4/2012: Validating: Emulator_3: Control Panel Path: C:\Assets\Visual Pinball\Controls
01:03:21.9 6/4/2012: Validating: Emulator_3: Instructions Path: C:\Assets\Visual Pinball\Instructions
01:03:21.9 6/4/2012: Validating: Emulator_3: Database: [Pinball] Visual Pinball
01:03:21.9 6/4/2012: Validating: Emulator_3: Title Snap Path: C:\Assets\Visual Pinball\Titles
01:03:21.9 6/4/2012: Validating: Emulator_3: Box Art Path: C:\Assets\Visual Pinball\Boxes
01:03:21.9 6/4/2012: Validating: Emulator_3: Cart Art Path: C:\Assets\Visual Pinball\Cartridges
01:03:21.9 6/4/2012: Validating: Emulator_3: Manual Path: C:\Assets\Visual Pinball\Manuals
01:03:21.9 6/4/2012: Validating: Emulator_4: Snap Path: C:\Assets\Sega Genesis\Snaps
01:03:21.9 6/4/2012: Validating: Emulator_4: Control Panel Path: C:\Assets\Sega Genesis\Controls
01:03:21.9 6/4/2012: Validating: Emulator_4: Database: [Console] Sega Genesis
01:03:21.9 6/4/2012: Validating: Emulator_4: Title Snap Path: C:\Assets\Sega Genesis\Titles
01:03:21.9 6/4/2012: Validating: Emulator_4: Box Art Path: C:\Assets\Sega Genesis\Boxes
01:03:21.9 6/4/2012: Validating: Emulator_4: Cart Art Path: C:\Assets\Sega Genesis\Cartridges
01:03:21.9 6/4/2012: Validating: Emulator_4: Manual Path: C:\Assets\Sega Genesis\Manuals
01:03:21.9 6/4/2012: Validating: Emulator_5: Snap Path: C:\Assets\Sega Saturn\Snaps
01:03:21.9 6/4/2012: Validating: Emulator_5: Control Panel Path: C:\Assets\Sega Saturn\Controls
01:03:21.9 6/4/2012: Validating: Emulator_5: Instructions Path: C:\Assets\Sega Saturn\Instructions
01:03:21.9 6/4/2012: Validating: Emulator_5: Database: [Console] Sega Saturn
01:03:21.9 6/4/2012: Validating: Emulator_5: Title Snap Path: C:\Assets\Sega Saturn\Titles
01:03:21.9 6/4/2012: Validating: Emulator_5: Box Art Path: C:\Assets\Sega Saturn\Boxes
01:03:21.9 6/4/2012: Validating: Emulator_5: Cart Art Path: C:\Assets\Sega Saturn\Cartridges
01:03:21.9 6/4/2012: Validating: Emulator_5: Manual Path: C:\Assets\Sega Saturn\Manuals
01:03:21.9 6/4/2012: Validating: Emulator_6: Snap Path: C:\Assets\Sony Playstation\Snaps
01:03:21.9 6/4/2012: Validating: Emulator_6: Control Panel Path: C:\Assets\Sony Playstation\Controls
01:03:21.9 6/4/2012: Validating: Emulator_6: Instructions Path: C:\Assets\Sony Playstation\Instructions
01:03:21.9 6/4/2012: Validating: Emulator_6: Database: [Console] Sony Playstation
01:03:21.9 6/4/2012: Validating: Emulator_6: Title Snap Path: C:\Assets\Sony Playstation\Titles
01:03:21.9 6/4/2012: Validating: Emulator_6: Box Art Path: C:\Assets\Sony Playstation\Boxes
01:03:21.9 6/4/2012: Validating: Emulator_6: Cart Art Path: C:\Assets\Sony Playstation\Cartridges
01:03:21.9 6/4/2012: Validating: Emulator_6: Manual Path: C:\Assets\Sony Playstation\Manuals
01:03:21.9 6/4/2012: Warning: Emulator_6: MAPFile Does Not Exist
01:03:21.9 6/4/2012: Validating: Emulator_7: Snap Path: C:\Assets\Nintendo Wii\Snaps
01:03:22.0 6/4/2012: Validating: Emulator_7: Control Panel Path: C:\Assets\Nintendo Wii\Controls
01:03:22.0 6/4/2012: Validating: Emulator_7: Instructions Path: C:\Assets\Nintendo Wii\Instructions
01:03:22.0 6/4/2012: Validating: Emulator_7: Database: [Console] Nintendo Wii
01:03:22.0 6/4/2012: Warning: Emulator_7: Database Does not exist
01:03:22.0 6/4/2012: Validating: Emulator_7: Title Snap Path: C:\Assets\Nintendo Wii\Titles
01:03:22.0 6/4/2012: Validating: Emulator_7: Box Art Path: C:\Assets\Nintendo Wii\Boxes
01:03:22.0 6/4/2012: Validating: Emulator_7: Cart Art Path: C:\Assets\Nintendo Wii\Cartridges
01:03:22.0 6/4/2012: Validating: Emulator_7: Manual Path: C:\Assets\Nintendo Wii\Manuals
01:03:22.0 6/4/2012: Validating: Emulator_8: Snap Path: C:\Assets\Sega Game Gear\Snaps
01:03:22.0 6/4/2012: Validating: Emulator_8: Control Panel Path: C:\Assets\Sega Game Gear\Controls
01:03:22.0 6/4/2012: Validating: Emulator_8: Database: [Handheld] Sega Game Gear
01:03:22.0 6/4/2012: Validating: Emulator_8: Title Snap Path: C:\Assets\Sega Game Gear\Titles
01:03:22.0 6/4/2012: Validating: Emulator_8: Box Art Path: C:\Assets\Sega Game Gear\Boxes
01:03:22.0 6/4/2012: Validating: Emulator_8: Cart Art Path: C:\Assets\Sega Game Gear\Cartridges
01:03:22.0 6/4/2012: Validating: Emulator_8: Manual Path: C:\Assets\Sega Game Gear\Manuals
01:03:22.0 6/4/2012: Validating: Emulator_11: Snap Path: C:\Assets\Nintendo\Snaps
01:03:22.0 6/4/2012: Validating: Emulator_11: Title Snap Path: C:\Assets\Nintendo\Titles
01:03:22.0 6/4/2012: Validating: Emulator_12: Snap Path: C:\Assets\Super Nintendo\Snaps
01:03:22.0 6/4/2012: Validating: Emulator_12: Control Panel Path: C:\Assets\Super Nintendo\Controls
01:03:22.0 6/4/2012: Validating: Emulator_12: Instructions Path: C:\Assets\Super Nintendo\Instructions
01:03:22.0 6/4/2012: Validating: Emulator_12: Title Snap Path: C:\Assets\Super Nintendo\Titles
01:03:22.0 6/4/2012: Validating: Emulator_12: Box Art Path: C:\Assets\Super Nintendo\Boxes
01:03:22.0 6/4/2012: Validating: Emulator_12: Cart Art Path: C:\Assets\Super Nintendo\Cartridges
01:03:22.0 6/4/2012: Validating: Emulator_12: Manual Path: C:\Assets\Super Nintendo\Manuals
01:03:22.0 6/4/2012: Validating: Emulator_13: Snap Path: C:\Assets\Coleco Vision\Snaps
01:03:22.0 6/4/2012: Validating: Emulator_13: Title Snap Path: C:\Assets\Coleco Vision\Titles
01:03:22.0 6/4/2012: Validating: Emulator_13: Box Art Path: C:\Assets\Coleco Vision\Boxes
01:03:22.0 6/4/2012: Validating: Emulator_13: Cart Art Path: C:\Assets\Coleco Vision\Cartridges
01:03:22.0 6/4/2012: Validating: Emulator_13: Manual Path: C:\Assets\Coleco Vision\Manuals
01:03:22.0 6/4/2012: Validating: Emulator_14: Snap Path: C:\Assets\TurboGrafx-16\Snaps
01:03:22.0 6/4/2012: Validating: Emulator_14: Control Panel Path: C:\Assets\TurboGrafx-16\Controls
01:03:22.0 6/4/2012: Validating: Emulator_14: Instructions Path: C:\Assets\TurboGrafx-16\Instructions
01:03:22.0 6/4/2012: Validating: Emulator_14: Title Snap Path: C:\Assets\TurboGrafx-16\Titles
01:03:22.0 6/4/2012: Validating: Emulator_14: Box Art Path: C:\Assets\TurboGrafx-16\Boxes
01:03:22.0 6/4/2012: Validating: Emulator_14: Cart Art Path: C:\Assets\TurboGrafx-16\Cartridges
01:03:22.0 6/4/2012: Validating: Emulator_14: Manual Path: C:\Assets\TurboGrafx-16\Manuals
01:03:22.5 6/4/2012: Cache Diff: - sega saturn
01:03:22.5 6/4/2012: Not Restoring Emulator from Cache: 5
01:03:23.0 6/4/2012: Not Restoring Emulator Database From Cache: 5
01:03:29.0 6/4/2012: Cache Diff: - false
01:03:29.0 6/4/2012: Not Restoring Emulator from Cache: 2
01:03:29.4 6/4/2012: Not Restoring Emulator Database From Cache: 2
01:03:29.6 6/4/2012: Cache Diff: - true
01:03:29.6 6/4/2012: Not Restoring Emulator from Cache: 3
01:03:30.0 6/4/2012: Cache Diff: - sega genesis
01:03:30.0 6/4/2012: Not Restoring Emulator from Cache: 4
01:03:30.4 6/4/2012: Not Restoring Emulator Database From Cache: 4
01:03:30.6 6/4/2012: Cache Diff: - sony playstation
01:03:30.6 6/4/2012: Not Restoring Emulator from Cache: 6
01:03:31.0 6/4/2012: Not Restoring Emulator Database From Cache: 6
01:03:31.1 6/4/2012: Cache Diff: - false
01:03:31.1 6/4/2012: Not Restoring Emulator from Cache: 8
01:03:31.5 6/4/2012: Not Restoring Emulator Database From Cache: 8
01:03:33.6 6/4/2012: Creating instance of global keyboard hook
01:03:33.7 6/4/2012: Mounting: C:\Roms\Sega Saturn\Roms\Christmas NiGHTS into Dreams Sampler (U)(Saturn)\291 Christmas NiGHTS into Dreams (U).mds
01:03:44.4 6/4/2012: Running: cmd.exe /c C: SSF.exe f:\
01:03:44.5 6/4/2012: Shutting down display
01:14:08.3 6/4/2012: Exiting Game
01:14:08.3 6/4/2012: Closing Process
01:14:10.9 6/4/2012: Unmounting Image
01:14:11.4 6/4/2012: Writing Stats
01:14:11.5 6/4/2012: Plugin: Game Exit
01:14:11.5 6/4/2012: Plugin: Process Commands
01:14:11.5 6/4/2012: Refreshing Keyboard
01:14:11.6 6/4/2012: Initialising Audio
01:14:11.6 6/4/2012: Relaunching HideOS
01:14:11.9 6/4/2012: Restoring Window
01:14:11.9 6/4/2012: Reinitializing Graphics System
01:14:12.2 6/4/2012: 21 Consecutive Exceptions Occured
01:14:12.2 6/4/2012: Object reference not set to an instance of an object.
01:14:12.2 6/4/2012: at Direct2D.Direct2d.Device.TestCooperativeLevel()
01:14:12.2 6/4/2012: at GameEx.GameEx.mainform.ad()
01:14:12.2 6/4/2012: Trying reinitialising the display after sleeping for 4 seconds
01:14:12.2 6/4/2012: Exception count will be dropped to 15
01:15:38.1 6/4/2012: Mounting: C:\Roms\Sega Saturn\Roms\Saturn Bomberman (U)(Saturn)\304 Saturn Bomberman (U).mdf
01:15:48.9 6/4/2012: Running: cmd.exe /c C: SSF.exe f:\
01:15:49.1 6/4/2012: Shutting down display
01:16:23.9 6/4/2012: Exiting Game
01:16:23.9 6/4/2012: Closing Process
01:16:26.6 6/4/2012: Unmounting Image
01:16:27.1 6/4/2012: Writing Stats
01:16:27.2 6/4/2012: Plugin: Game Exit
01:16:27.2 6/4/2012: Plugin: Process Commands
01:16:27.2 6/4/2012: Refreshing Keyboard
01:16:27.3 6/4/2012: Initialising Audio
01:16:27.3 6/4/2012: Relaunching HideOS
01:16:31.0 6/4/2012: Restoring Window
01:16:31.0 6/4/2012: Reinitializing Graphics System
01:16:31.3 6/4/2012: --**--
01:16:31.3 6/4/2012: 21 Consecutive Exceptions Occured: Exiting
01:16:31.3 6/4/2012: Closing database connection
01:16:31.3 6/4/2012: First Exception:
01:16:31.3 6/4/2012: Object reference not set to an instance of an object.
01:16:31.3 6/4/2012: at Direct2D.Direct2d.Device.TestCooperativeLevel()
01:16:31.3 6/4/2012: at GameEx.GameEx.mainform.b(Boolean A_0, Boolean A_1)
01:16:31.3 6/4/2012: at GameEx.GameEx.mainform.LaunchEmu(Boolean LaunchedFromAttract)
01:16:31.3 6/4/2012: at GameEx.GameEx.mainform.ProcessGameMenu4()
01:16:31.3 6/4/2012: at GameEx.GameEx.mainform.Processgamemenu(Boolean overridereturn)
01:16:31.3 6/4/2012: at GameEx.GameEx.mainform.ad()
01:16:31.3 6/4/2012: Last Exception:
So, is this new problem just me? Is no one having any issues with the new version and gameex losing gamepad nav after coming back from a game? 12.61 was ROCK-solid and never crashed or had any issues at all...
thanks for any help
Sorry for posting to the wrong thread.
Any thoughts on my issues regarding gamepad nav stopping after entering a game with 12.62? Is there a way to revert to 12.61? thanks :)
Thank you for the prompt update and the excellent software! 12.63 seems to fix the gamepad nav issue :)
There is however a minor cosmetic issue, the loading panel at the bottom of the screen is no longer semi-transparent, it is blended with solid white so you cant read what the text says. But otherwise so far so good thanks!
There has been another update since my last post and I cant recreate that cosmetic issue anymore so I guess this is resolved. Thanks for the quick updates :)
