[RESOLVED] Attract mode loses focus after update 20 12.62
May be a bug? Today i update to gameex 12.62 , but now atrract mode lost focus and drop to windows, With alt+tab go back to game but at exit the game gameex dont nack and go back to windows :(
Byeee
Chaskas - I separated this issue from the News thread reporting the release of the new version. This will ensure your issue doesn't get lost in an indirectly related thread.
Byeee
Chaska,
Could you please tell me what Attract mode is running when this happens?
The log...
15:37:02.6 04/06/2012: Opening Configuration File
15:37:03.0 04/06/2012: GameEx: Version 12.63: Starting Log
15:37:03.0 04/06/2012: Operating System Platform: Win32NT
15:37:03.0 04/06/2012: Operating System Name: Windows XP
15:37:03.0 04/06/2012: Operating System Version: 5.1.2600
15:37:03.0 04/06/2012: AMD Athlon XP 3000+, 1024MB
15:37:03.1 04/06/2012: 2,17Ghz
15:37:03.1 04/06/2012: Running Randomize()
15:37:03.4 04/06/2012: Loading PlugIns
15:37:03.6 04/06/2012: Checking for applications to Launch On Startup
15:37:03.6 04/06/2012: Running Misc startup tasks
15:37:03.6 04/06/2012: Setting Menu types
15:37:03.6 04/06/2012: Getting Configuration Values
15:37:03.7 04/06/2012: Using Theme: Acidbrain Vision
15:37:03.7 04/06/2012: Checking for alternate Image Directory for Theme: Acidbrain Vision
15:37:03.7 04/06/2012: Launching GameExtender.exe (GameExtender Viewer)
15:37:04.9 04/06/2012: Launching HideOS.exe
15:37:04.9 04/06/2012: Initialising Video/MNG DLL's
15:37:04.9 04/06/2012: GameEx will check for media insertion (may affect performance)
15:37:04.9 04/06/2012: Hiding Taskbar
15:37:05.9 04/06/2012: Is Media Center running?
15:37:05.9 04/06/2012: Checking/Creating LCD Registry values
15:37:06.2 04/06/2012: Check Media Center Exit/Start Mode
15:37:06.2 04/06/2012: Media Center Mode 2
15:37:06.4 04/06/2012: Video previews on. Warning: Only recommended on modern systems
15:37:06.5 04/06/2012: Custom Keyboard Input enabled: Getting custom codes
15:37:06.5 04/06/2012: Custom Game Device Input enabled: Getting custom codes
15:37:06.6 04/06/2012: Snap Delay set to: 3
15:37:06.6 04/06/2012: Get other settings
15:37:06.6 04/06/2012: Desktop set to Hide ICONS and set Background to Black
15:37:06.6 04/06/2012: Using DirectInput for keyboard input
15:37:06.6 04/06/2012: Start work for Form
15:37:06.6 04/06/2012: Getting Original Screen Size
15:37:06.6 04/06/2012: Opening Database Connection
15:37:12.5 04/06/2012: Initializing Component
15:37:12.8 04/06/2012: MAME Path is: D:\Emulators\mame
15:37:12.9 04/06/2012: Model 2 Path Path is: D:\Emulators\Model2
15:37:13.0 04/06/2012: Model 2 EXE file is: emulator.exe
15:37:13.0 04/06/2012: Model 2 emulator with command line support detected
15:37:13.0 04/06/2012: Use Model 2 on. emulator.exe will launch Sega Model 2 games
15:37:13.0 04/06/2012: ZiNc Path is: D:\Emulators\zinc
15:37:13.1 04/06/2012: ZiNc EXE file is: ZiNc.exe
15:37:13.1 04/06/2012: Use ZiNc on. ZiNc.exe will launch PSX games
15:37:13.1 04/06/2012: MAME EXE file is: mamep.exe
15:37:13.2 04/06/2012: ROM Path is: D:\Emulators\mame\roms
15:37:13.2 04/06/2012: Catver.ini is located at: D:\GameEx\DATA\catver.ini
15:37:13.3 04/06/2012: controls.ini is located at: D:\GameEx\data\controls.ini
15:37:13.3 04/06/2012: History.dat is located at: D:\GameEx\DATA\history.dat
15:37:13.3 04/06/2012: nplayers.ini is located at: D:\GameEx\DATA\nplayers.ini
15:37:13.3 04/06/2012: command.dat is located at: D:\GameEx\DATA\command.dat
15:37:13.3 04/06/2012: MAMEinfo.dat is located at: D:\GameEx\DATA\mameinfo.dat
15:37:13.4 04/06/2012: Loading Controls.ini map file
15:37:13.5 04/06/2012: Snap Path is: D:\Emulators\mame\snap
15:37:13.5 04/06/2012: Background Snap Path is: D:\Emulators\mame\snap
15:37:13.6 04/06/2012: AVI Snap Path is: D:\Emulators\mame\vidsnap
15:37:13.6 04/06/2012: Flyer Path is: D:\Emulators\mame\flyers
15:37:13.6 04/06/2012: Cabinet Path is: D:\Emulators\mame\Cabinet
15:37:13.7 04/06/2012: Cabinet 3D Path is: D:\Emulators\mame\cabinets3d
15:37:13.7 04/06/2012: Title Path is: D:\Emulators\mame\titles
15:37:13.7 04/06/2012: PCB Path is: D:\Emulators\mame\pcb
15:37:13.8 04/06/2012: Artwork Preview Path is: D:\Emulators\mame\artwork
15:37:13.8 04/06/2012: Panel Path: Not Found
15:37:13.8 04/06/2012: Manual Path is: D:\Emulators\mame\manuals
15:37:13.9 04/06/2012: Icon Path is: D:\Emulators\mame\icons
15:37:13.9 04/06/2012: Marquee Path is: D:\Emulators\mame\Marquee
15:37:13.9 04/06/2012: Applying Language/Text
15:37:13.9 04/06/2012: Text/Language: Spanish
15:37:14.2 04/06/2012: Loading Custom Emulators
15:37:14.2 04/06/2012: Loading Emulator 1: [Arcade] Arcade (ZiNc)
15:37:14.3 04/06/2012: Loading Emulator 2: [Arcade] Model 2 (Model2)
15:37:14.3 04/06/2012: Loading Emulator 3: [Console] Nientiendo N64
15:37:14.4 04/06/2012: Loading Emulator 4: [Console] Nintendo NES (Nestopia)
15:37:14.5 04/06/2012: Loading Emulator 5: [Console] Sega Dreamcast (nullDC)
15:37:14.5 04/06/2012: Loading Emulator 6: [Pinball] Future Pinball
15:37:14.6 04/06/2012: Loading Emulator 7: [Pinball] Visual Pinball
15:37:14.7 04/06/2012: Loading Emulator 8: Raiden II
15:37:14.8 04/06/2012: Loading Emulator 9: Thunder
15:37:14.8 04/06/2012: Loading Emulator 10: [Console] Sony Playstation (pSX)
15:37:14.9 04/06/2012: Loading Emulator 11: Dream Pinball 3d
15:37:14.9 04/06/2012: Loading Emulator 12: [Console] Nintendo SNES (Snes9x)
15:37:15.0 04/06/2012: Loading Emulator 13: [Arcade] Arcade (MAME)
15:37:15.1 04/06/2012: Using 2D Animations
15:37:15.1 04/06/2012: Retrieving resolution setting
15:37:15.6 04/06/2012: Using General Font: Trebuchet MS
15:37:15.6 04/06/2012: Using Title Font: Trebuchet MS
15:37:15.6 04/06/2012: GameEx will try to reduce CPU usage
15:37:21.8 04/06/2012: Initialising Direct3D
15:37:22.2 04/06/2012: Setting Resolution to 1024x768 32 bit color
15:37:22.3 04/06/2012: Creating Surfaces
15:37:22.7 04/06/2012: Creating Primary Surface - Full Screen Mode
15:37:22.8 04/06/2012: Creating Back Buffer
15:37:22.8 04/06/2012: Version 2 Theme being used. Loading.
15:37:22.8 04/06/2012: Loading Button Data
15:37:22.8 04/06/2012: Loading Font Data
15:37:22.8 04/06/2012: Loading Layout Data
15:37:22.9 04/06/2012: Loading Taskbar Data
15:37:22.9 04/06/2012: Loading graphic Surfaces
15:37:22.9 04/06/2012: Display is running at: 1024x768 32bit color, 75hz
15:37:22.9 04/06/2012: Adapter: NVIDIA GeForce 6600 GT
15:37:22.9 04/06/2012: Max texture size: 4096x4096
15:37:22.9 04/06/2012: Available texture memory: 228MB
15:37:22.9 04/06/2012: Initialising Bass Audio Library
15:37:23.2 04/06/2012: Creating Surfaces Misc and Dialogs
15:37:23.9 04/06/2012: Creating Surfaces Volume
15:37:23.9 04/06/2012: Creating Surfaces Arrows
15:37:24.0 04/06/2012: Creating Surfaces GameEXlogo Text
15:37:24.0 04/06/2012: Creating Surfaces Toolbar
15:37:24.2 04/06/2012: Creating Surfaces Toolbar Controls
15:37:24.3 04/06/2012: Creating Surfaces Backgrounds
15:37:24.3 04/06/2012: Creating Surfaces GameEx Logo
15:37:24.4 04/06/2012: Creating Surface Unselected
15:37:24.4 04/06/2012: Creating Surfaces Home & Exit
15:37:24.5 04/06/2012: Creating Surfaces Snaps
15:37:24.5 04/06/2012: Creating Surfaces Menu and List Bars
15:37:24.7 04/06/2012: Creating Fonts
15:37:24.7 04/06/2012: Creating Game Font
15:37:25.1 04/06/2012: Creating Game Font Faded
15:37:25.3 04/06/2012: Creating Title Font
15:37:25.3 04/06/2012: Restoring Title Font From Cache
15:37:25.7 04/06/2012: Creating Menu Font
15:37:26.0 04/06/2012: Creating Font Black
15:37:26.1 04/06/2012: Creating Font Black Small
15:37:26.3 04/06/2012: Fonts Created Succesfully
15:37:26.3 04/06/2012: 3MB Video Memory Used
15:37:26.8 04/06/2012: Attempting to load game list
15:37:28.3 04/06/2012: GameExtender Not found snap: D:\GameEx\THEMES\Acidbrain Vision\MEDIA\GameExLogo.png
15:37:28.3 04/06/2012: Starting GameExtender on: 127.0.0.1:8383
15:37:28.3 04/06/2012: GameExtender using specific custom images for systems.
15:37:28.4 04/06/2012: MAME CMD options: -nowindow -joy -skip_gameinfo
15:37:28.5 04/06/2012: Creating DirectSound Device
15:37:28.5 04/06/2012: Trying: Controlador primario de sonido
15:37:28.5 04/06/2012: Loading Sound Files
15:37:28.7 04/06/2012: DirectSound Device Created Successfully
15:37:28.7 04/06/2012: Initialising DirectInput for Gamepad support
15:37:28.9 04/06/2012: Using Device Twin USB Joystick
15:37:28.9 04/06/2012: Using Device Xin-Mo Dual Arcade
15:37:28.9 04/06/2012: Using Device LPT1: LPT-switch Joystick 1
15:37:28.9 04/06/2012: Using Device LPT1: LPT-switch Joystick 2
15:37:28.9 04/06/2012: Using Device UnKnown?
15:37:29.2 04/06/2012: Initialising DirectInput for Keyboard support
15:37:29.3 04/06/2012: Loading Start Page
15:37:29.5 04/06/2012: Initializing MCE Remote
15:37:29.5 04/06/2012: Playing intro sound file
15:37:29.5 04/06/2012: Initialization OK! Starting GameEx!
15:37:29.5 04/06/2012: Testing Main Loop Once: Processing Frame
15:37:31.2 04/06/2012: Testing Main Loop Once: Main Loop ran successfully
15:41:32.7 04/06/2012: Starting Attract Mode
15:41:32.7 04/06/2012: Reading MAME hall of fame
15:41:33.4 04/06/2012: Shutting down display
15:41:33.9 04/06/2012: Setting Up RawInput Hook
15:41:33.9 04/06/2012: Launching RawInputHook.exe
15:41:35.9 04/06/2012: Running: cmd.exe /c D: D:\Emulators\mame\mamep.exe mmatrix -rompath D:\Emulators\mame\roms -nowindow -joy -skip_gameinfo -bezel -artwork_directory artworkgameex
15:41:43.9 04/06/2012: Validating: Emulator_1: Snap Path: D:\Emulators\mame\vidsnap
15:41:43.9 04/06/2012: Validating: Emulator_1: Title Snap Path: D:\Emulators\mame\Title
15:41:43.9 04/06/2012: Warning: Emulator_1: Title Snap Path Does not exist
15:41:43.9 04/06/2012: Validating: Emulator_1: Box Art Path: D:\Emulators\mame\flyer
15:41:43.9 04/06/2012: Warning: Emulator_1: Box Art Path Does not exist
15:41:43.9 04/06/2012: Validating: Emulator_1: Cart Art Path: D:\Emulators\mame\Cartridges
15:41:43.9 04/06/2012: Warning: Emulator_1: Cart Art Path Does not exist
15:41:43.9 04/06/2012: Validating: Emulator_1: Manual Path: D:\Emulators\mame\Manuals
15:41:44.0 04/06/2012: Validating: Emulator_2: Snap Path: D:\Emulators\mame\vidsnap
15:41:44.0 04/06/2012: Validating: Emulator_2: Control Panel Path: D:\Emulators\Assets\Arcade\Model2\Controls
15:41:44.0 04/06/2012: Warning: Emulator_2: Control Panel Path Does not exist
15:41:44.0 04/06/2012: Validating: Emulator_2: Title Snap Path: D:\Emulators\mame\Titles
15:41:44.0 04/06/2012: Validating: Emulator_2: Box Art Path: D:\Emulators\mame\Boxes
15:41:44.0 04/06/2012: Warning: Emulator_2: Box Art Path Does not exist
15:41:44.0 04/06/2012: Validating: Emulator_2: Cart Art Path: D:\Emulators\mame\Cartridges
15:41:44.0 04/06/2012: Warning: Emulator_2: Cart Art Path Does not exist
15:41:44.0 04/06/2012: Validating: Emulator_2: Manual Path: D:\Emulators\mame\Manuals
15:41:44.0 04/06/2012: Validating: Emulator_3: Snap Path: D:\Emulators\Project64\Snaps
15:41:44.1 04/06/2012: Validating: Emulator_3: Control Panel Path: D:\Emulators\Project64\Controls
15:41:44.1 04/06/2012: Validating: Emulator_3: Database: [Console] Nintendo N64
15:41:44.1 04/06/2012: Validating: Emulator_3: Title Snap Path: D:\Emulators\Project64\Titles
15:41:44.1 04/06/2012: Validating: Emulator_3: Box Art Path: D:\Emulators\Project64\Boxes
15:41:44.1 04/06/2012: Validating: Emulator_3: Cart Art Path: D:\Emulators\Project64\Cartridges
15:41:44.1 04/06/2012: Validating: Emulator_3: Manual Path: D:\Emulators\Project64\Manuals
15:41:44.1 04/06/2012: Validating: Emulator_4: Snap Path: D:\Emulators\Assets\Nintendo NES\Snaps
15:41:44.1 04/06/2012: Warning: Emulator_4: Snap Path Does not exist
15:41:44.1 04/06/2012: Validating: Emulator_4: Control Panel Path: D:\Emulators\Assets\Nintendo NES\Controls
15:41:44.1 04/06/2012: Warning: Emulator_4: Control Panel Path Does not exist
15:41:44.1 04/06/2012: Validating: Emulator_4: Database: [Console] Nintendo NES
15:41:44.2 04/06/2012: Validating: Emulator_4: Title Snap Path: D:\Emulators\Assets\Nintendo NES\Titles
15:41:44.2 04/06/2012: Warning: Emulator_4: Title Snap Path Does not exist
15:41:44.2 04/06/2012: Validating: Emulator_4: Box Art Path: D:\Emulators\Assets\Nintendo NES\Boxes
15:41:44.2 04/06/2012: Warning: Emulator_4: Box Art Path Does not exist
15:41:44.2 04/06/2012: Validating: Emulator_4: Cart Art Path: D:\Emulators\Assets\Nintendo NES\Cartridges
15:41:44.2 04/06/2012: Warning: Emulator_4: Cart Art Path Does not exist
15:41:44.2 04/06/2012: Validating: Emulator_4: Manual Path: D:\Emulators\Assets\Nintendo NES\Manuals
15:41:44.2 04/06/2012: Warning: Emulator_4: Manual Path Does not exist
15:41:44.2 04/06/2012: Validating: Emulator_5: Snap Path: D:\Emulators\mame\vidsnap
15:41:44.2 04/06/2012: Validating: Emulator_5: Control Panel Path: D:\Emulators\Assets\Sega Dreamcast\Controls
15:41:44.2 04/06/2012: Warning: Emulator_5: Control Panel Path Does not exist
15:41:44.2 04/06/2012: Validating: Emulator_5: Database: [Console] Sega Dreamcast
15:41:44.2 04/06/2012: Validating: Emulator_5: Title Snap Path: D:\Emulators\mame\Titles
15:41:44.2 04/06/2012: Validating: Emulator_5: Box Art Path: D:\Emulators\mame\Boxes
15:41:44.2 04/06/2012: Warning: Emulator_5: Box Art Path Does not exist
15:41:44.2 04/06/2012: Validating: Emulator_5: Cart Art Path: D:\Emulators\mame\Cartridges
15:41:44.2 04/06/2012: Warning: Emulator_5: Cart Art Path Does not exist
15:41:44.2 04/06/2012: Validating: Emulator_5: Manual Path: D:\Emulators\mame\Manuals
15:41:44.2 04/06/2012: Validating: Emulator_6: Snap Path: D:\Emulators\Future Pinball\Marquee
15:41:44.3 04/06/2012: Validating: Emulator_6: Control Panel Path: D:\Emulators\Future Pinball\Future Pinball\Controls
15:41:44.3 04/06/2012: Warning: Emulator_6: Control Panel Path Does not exist
15:41:44.3 04/06/2012: Validating: Emulator_6: Database: [Pinball] Future Pinball
15:41:44.3 04/06/2012: Validating: Emulator_6: Title Snap Path: D:\Emulators\Future Pinball\Marquee
15:41:44.3 04/06/2012: Validating: Emulator_6: Box Art Path: D:\Emulators\Future Pinball\Boxes
15:41:44.3 04/06/2012: Warning: Emulator_6: Box Art Path Does not exist
15:41:44.3 04/06/2012: Validating: Emulator_6: Cart Art Path: D:\Emulators\Future Pinball\Cartridges
15:41:44.3 04/06/2012: Warning: Emulator_6: Cart Art Path Does not exist
15:41:44.3 04/06/2012: Validating: Emulator_6: Manual Path: D:\Emulators\Future Pinball\FPRules
15:41:44.3 04/06/2012: Validating: Emulator_7: Snap Path: D:\Emulators\Pinball\Snap
15:41:44.3 04/06/2012: Validating: Emulator_7: Video Snap Path: D:\Emulators\Pinball\Snap
15:41:44.3 04/06/2012: Validating: Emulator_7: Control Panel Path: D:\Emulators\Pinball\Controls
15:41:44.3 04/06/2012: Warning: Emulator_7: Control Panel Path Does not exist
15:41:44.3 04/06/2012: Validating: Emulator_7: Database: [Pinball] Visual PinMAME
15:41:44.3 04/06/2012: Validating: Emulator_7: Title Snap Path: D:\Emulators\Pinball\Snap
15:41:44.3 04/06/2012: Validating: Emulator_7: Box Art Path: D:\Emulators\Pinball\Artwork
15:41:44.3 04/06/2012: Validating: Emulator_7: Cart Art Path: D:\Emulators\Pinball\Cartridges
15:41:44.3 04/06/2012: Warning: Emulator_7: Cart Art Path Does not exist
15:41:44.3 04/06/2012: Validating: Emulator_7: Manual Path: D:\Emulators\Pinball
15:41:44.3 04/06/2012: Validating: Emulator_8: Music Path: G:
15:41:44.3 04/06/2012: Warning: Emulator_8: Music Path Does not exist
15:41:44.3 04/06/2012: Validating: Emulator_10: Snap Path: D:\Emulators\Sony Playstation\Sony Playstation\Snaps
15:41:44.3 04/06/2012: Warning: Emulator_10: Snap Path Does not exist
15:41:44.3 04/06/2012: Validating: Emulator_10: Control Panel Path: D:\Emulators\Sony Playstation\Sony Playstation\Controls
15:41:44.3 04/06/2012: Warning: Emulator_10: Control Panel Path Does not exist
15:41:44.3 04/06/2012: Validating: Emulator_10: Database: [Console] Sony Playstation
15:41:44.3 04/06/2012: Validating: Emulator_10: Title Snap Path: D:\Emulators\Sony Playstation\Sony Playstation\Titles
15:41:44.3 04/06/2012: Warning: Emulator_10: Title Snap Path Does not exist
15:41:44.3 04/06/2012: Validating: Emulator_10: Box Art Path: D:\Emulators\Sony Playstation\Sony Playstation\Boxes
15:41:44.3 04/06/2012: Warning: Emulator_10: Box Art Path Does not exist
15:41:44.3 04/06/2012: Validating: Emulator_10: Cart Art Path: D:\Emulators\Sony Playstation\Sony Playstation\Cartridges
15:41:44.3 04/06/2012: Warning: Emulator_10: Cart Art Path Does not exist
15:41:44.3 04/06/2012: Validating: Emulator_10: Manual Path: D:\Emulators\Sony Playstation\Sony Playstation\Manuals
15:41:44.3 04/06/2012: Warning: Emulator_10: Manual Path Does not exist
15:41:44.3 04/06/2012: Validating: Emulator_12: Snap Path: D:\Emulators\SNES\Snaps
15:41:44.3 04/06/2012: Validating: Emulator_12: Control Panel Path: D:\Emulators\SNES\Nintendo SNES\Controls
15:41:44.3 04/06/2012: Warning: Emulator_12: Control Panel Path Does not exist
15:41:44.3 04/06/2012: Validating: Emulator_12: Database: [Console] Nintendo SNES
15:41:44.3 04/06/2012: Validating: Emulator_12: Title Snap Path: D:\Emulators\SNES\Titles
15:41:44.3 04/06/2012: Validating: Emulator_12: Box Art Path: D:\Emulators\SNES\Boxes
15:41:44.3 04/06/2012: Validating: Emulator_12: Cart Art Path: D:\Emulators\SNES\Cartridges
15:41:44.4 04/06/2012: Validating: Emulator_12: Manual Path: D:\Emulators\SNES\Manuals
15:41:44.4 04/06/2012: Restoring Emulator from Cache: 3
15:41:44.6 04/06/2012: Restoring Emulator Database From Cache: 3
15:41:44.8 04/06/2012: EmUDBCache Diff: 12/11/2009 21:23:33 - 28/11/2011 14:25:09
15:41:44.8 04/06/2012: Not Restoring Emulator from Cache: 4
15:41:44.9 04/06/2012: Restoring Emulator from Cache: 5
15:41:44.9 04/06/2012: Restoring Emulator Database From Cache: 5
15:41:45.0 04/06/2012: Restoring Emulator from Cache: 6
15:41:45.1 04/06/2012: No Database Data: 6
15:41:45.1 04/06/2012: Restoring Emulator from Cache: 7
15:41:45.2 04/06/2012: No Database Data: 7
15:41:45.3 04/06/2012: Restoring Emulator from Cache: 10
15:41:45.3 04/06/2012: No Database Data: 10
15:41:45.4 04/06/2012: Restoring Emulator from Cache: 12
15:41:45.5 04/06/2012: Restoring Emulator Database From Cache: 12
Partially fixed !!
This is a full log :wacko: , looking in that i can see " Loading Emulator 13: [Arcade] Arcade (MAME)" then the log stop at
I dont remember add mame emulator at emulator list, but deleting this entry the gameex work partially ok, now not lost focus an return, but in background i can see this screen
This is the new log
15:54:17.4 04/06/2012: Opening Configuration File
15:54:17.8 04/06/2012: GameEx: Version 12.63: Starting Log
15:54:17.8 04/06/2012: Operating System Platform: Win32NT
15:54:17.8 04/06/2012: Operating System Name: Windows XP
15:54:17.8 04/06/2012: Operating System Version: 5.1.2600
15:54:17.9 04/06/2012: AMD Athlon XP 3000+, 1024MB
15:54:17.9 04/06/2012: 2,17Ghz
15:54:17.9 04/06/2012: Running Randomize()
15:54:18.2 04/06/2012: Loading PlugIns
15:54:18.4 04/06/2012: Checking for applications to Launch On Startup
15:54:18.4 04/06/2012: Running Misc startup tasks
15:54:18.4 04/06/2012: Setting Menu types
15:54:18.4 04/06/2012: Getting Configuration Values
15:54:18.5 04/06/2012: Using Theme: Acidbrain Vision
15:54:18.5 04/06/2012: Checking for alternate Image Directory for Theme: Acidbrain Vision
15:54:18.5 04/06/2012: Launching GameExtender.exe (GameExtender Viewer)
15:54:19.7 04/06/2012: Launching HideOS.exe
15:54:19.7 04/06/2012: Initialising Video/MNG DLL's
15:54:19.7 04/06/2012: GameEx will check for media insertion (may affect performance)
15:54:19.7 04/06/2012: Hiding Taskbar
15:54:20.6 04/06/2012: Is Media Center running?
15:54:20.8 04/06/2012: Checking/Creating LCD Registry values
15:54:21.1 04/06/2012: Check Media Center Exit/Start Mode
15:54:21.1 04/06/2012: Media Center Mode 2
15:54:21.3 04/06/2012: Video previews on. Warning: Only recommended on modern systems
15:54:21.3 04/06/2012: Custom Keyboard Input enabled: Getting custom codes
15:54:21.3 04/06/2012: Custom Game Device Input enabled: Getting custom codes
15:54:21.4 04/06/2012: Snap Delay set to: 3
15:54:21.4 04/06/2012: Get other settings
15:54:21.4 04/06/2012: Desktop set to Hide ICONS and set Background to Black
15:54:21.4 04/06/2012: Using DirectInput for keyboard input
15:54:21.4 04/06/2012: Start work for Form
15:54:21.4 04/06/2012: Getting Original Screen Size
15:54:21.4 04/06/2012: Opening Database Connection
15:54:27.7 04/06/2012: Initializing Component
15:54:28.1 04/06/2012: MAME Path is: D:\Emulators\mame
15:54:28.2 04/06/2012: Model 2 Path Path is: D:\Emulators\Model2
15:54:28.2 04/06/2012: Model 2 EXE file is: emulator.exe
15:54:28.3 04/06/2012: Model 2 emulator with command line support detected
15:54:28.3 04/06/2012: Use Model 2 on. emulator.exe will launch Sega Model 2 games
15:54:28.3 04/06/2012: ZiNc Path is: D:\Emulators\zinc
15:54:28.3 04/06/2012: ZiNc EXE file is: ZiNc.exe
15:54:28.3 04/06/2012: Use ZiNc on. ZiNc.exe will launch PSX games
15:54:28.3 04/06/2012: MAME EXE file is: mamep.exe
15:54:28.4 04/06/2012: ROM Path is: D:\Emulators\mame\roms
15:54:28.4 04/06/2012: Catver.ini is located at: D:\GameEx\DATA\catver.ini
15:54:28.5 04/06/2012: controls.ini is located at: D:\GameEx\data\controls.ini
15:54:28.5 04/06/2012: History.dat is located at: D:\GameEx\DATA\history.dat
15:54:28.5 04/06/2012: nplayers.ini is located at: D:\GameEx\DATA\nplayers.ini
15:54:28.6 04/06/2012: command.dat is located at: D:\GameEx\DATA\command.dat
15:54:28.6 04/06/2012: MAMEinfo.dat is located at: D:\GameEx\DATA\mameinfo.dat
15:54:28.6 04/06/2012: Loading Controls.ini map file
15:54:28.7 04/06/2012: Snap Path is: D:\Emulators\mame\snap
15:54:28.8 04/06/2012: Background Snap Path is: D:\Emulators\mame\snap
15:54:28.8 04/06/2012: AVI Snap Path is: D:\Emulators\mame\vidsnap
15:54:28.8 04/06/2012: Flyer Path is: D:\Emulators\mame\flyers
15:54:28.9 04/06/2012: Cabinet Path is: D:\Emulators\mame\Cabinet
15:54:28.9 04/06/2012: Cabinet 3D Path is: D:\Emulators\mame\cabinets3d
15:54:29.0 04/06/2012: Title Path is: D:\Emulators\mame\titles
15:54:29.0 04/06/2012: PCB Path is: D:\Emulators\mame\pcb
15:54:29.1 04/06/2012: Artwork Preview Path is: D:\Emulators\mame\artwork
15:54:29.1 04/06/2012: Panel Path: Not Found
15:54:29.1 04/06/2012: Manual Path is: D:\Emulators\mame\manuals
15:54:29.2 04/06/2012: Icon Path is: D:\Emulators\mame\icons
15:54:29.2 04/06/2012: Marquee Path is: D:\Emulators\mame\Marquee
15:54:29.2 04/06/2012: Applying Language/Text
15:54:29.2 04/06/2012: Text/Language: Spanish
15:54:29.6 04/06/2012: Loading Custom Emulators
15:54:29.6 04/06/2012: Loading Emulator 1: [Arcade] Arcade (ZiNc)
15:54:29.7 04/06/2012: Loading Emulator 2: [Arcade] Model 2 (Model2)
15:54:29.7 04/06/2012: Loading Emulator 3: [Console] Nientiendo N64
15:54:29.8 04/06/2012: Loading Emulator 4: [Console] Nintendo NES (Nestopia)
15:54:29.9 04/06/2012: Loading Emulator 5: [Console] Sega Dreamcast (nullDC)
15:54:29.9 04/06/2012: Loading Emulator 6: [Pinball] Future Pinball
15:54:30.1 04/06/2012: Loading Emulator 7: [Pinball] Visual Pinball
15:54:30.1 04/06/2012: Loading Emulator 8: Raiden II
15:54:30.2 04/06/2012: Loading Emulator 9: Thunder
15:54:30.2 04/06/2012: Loading Emulator 10: [Console] Sony Playstation (pSX)
15:54:30.2 04/06/2012: Loading Emulator 11: Dream Pinball 3d
15:54:30.3 04/06/2012: Loading Emulator 12: [Console] Nintendo SNES (Snes9x)
15:54:30.4 04/06/2012: Using 2D Animations
15:54:30.4 04/06/2012: Retrieving resolution setting
15:54:31.0 04/06/2012: Using General Font: Trebuchet MS
15:54:31.0 04/06/2012: Using Title Font: Trebuchet MS
15:54:31.0 04/06/2012: GameEx will try to reduce CPU usage
15:54:37.1 04/06/2012: Initialising Direct3D
15:54:37.5 04/06/2012: Setting Resolution to 1024x768 32 bit color
15:54:37.5 04/06/2012: Creating Surfaces
15:54:38.0 04/06/2012: Creating Primary Surface - Full Screen Mode
15:54:38.0 04/06/2012: Creating Back Buffer
15:54:38.0 04/06/2012: Version 2 Theme being used. Loading.
15:54:38.0 04/06/2012: Loading Button Data
15:54:38.0 04/06/2012: Loading Font Data
15:54:38.0 04/06/2012: Loading Layout Data
15:54:38.2 04/06/2012: Loading Taskbar Data
15:54:38.2 04/06/2012: Loading graphic Surfaces
15:54:38.2 04/06/2012: Display is running at: 1024x768 32bit color, 75hz
15:54:38.2 04/06/2012: Adapter: NVIDIA GeForce 6600 GT
15:54:38.2 04/06/2012: Max texture size: 4096x4096
15:54:38.2 04/06/2012: Available texture memory: 228MB
15:54:38.2 04/06/2012: Initialising Bass Audio Library
15:54:38.4 04/06/2012: Creating Surfaces Misc and Dialogs
15:54:39.2 04/06/2012: Creating Surfaces Volume
15:54:39.2 04/06/2012: Creating Surfaces Arrows
15:54:39.3 04/06/2012: Creating Surfaces GameEXlogo Text
15:54:39.3 04/06/2012: Creating Surfaces Toolbar
15:54:39.5 04/06/2012: Creating Surfaces Toolbar Controls
15:54:39.6 04/06/2012: Creating Surfaces Backgrounds
15:54:39.6 04/06/2012: Creating Surfaces GameEx Logo
15:54:39.7 04/06/2012: Creating Surface Unselected
15:54:39.7 04/06/2012: Creating Surfaces Home & Exit
15:54:39.8 04/06/2012: Creating Surfaces Snaps
15:54:39.8 04/06/2012: Creating Surfaces Menu and List Bars
15:54:40.1 04/06/2012: Creating Fonts
15:54:40.1 04/06/2012: Creating Game Font
15:54:40.5 04/06/2012: Creating Game Font Faded
15:54:40.6 04/06/2012: Creating Title Font
15:54:40.7 04/06/2012: Restoring Title Font From Cache
15:54:41.1 04/06/2012: Creating Menu Font
15:54:41.3 04/06/2012: Creating Font Black
15:54:41.4 04/06/2012: Creating Font Black Small
15:54:41.6 04/06/2012: Fonts Created Succesfully
15:54:41.7 04/06/2012: 3MB Video Memory Used
15:54:42.1 04/06/2012: Attempting to load game list
15:54:43.6 04/06/2012: GameExtender Not found snap: D:\GameEx\THEMES\Acidbrain Vision\MEDIA\GameExLogo.png
15:54:43.6 04/06/2012: Starting GameExtender on: 127.0.0.1:8383
15:54:43.7 04/06/2012: GameExtender using specific custom images for systems.
15:54:43.7 04/06/2012: MAME CMD options: -nowindow -joy -skip_gameinfo
15:54:43.7 04/06/2012: Creating DirectSound Device
15:54:43.7 04/06/2012: Trying: Controlador primario de sonido
15:54:43.8 04/06/2012: Loading Sound Files
15:54:43.9 04/06/2012: DirectSound Device Created Successfully
15:54:43.9 04/06/2012: Initialising DirectInput for Gamepad support
15:54:44.2 04/06/2012: Using Device Twin USB Joystick
15:54:44.2 04/06/2012: Using Device Xin-Mo Dual Arcade
15:54:44.2 04/06/2012: Using Device LPT1: LPT-switch Joystick 1
15:54:44.2 04/06/2012: Using Device LPT1: LPT-switch Joystick 2
15:54:44.2 04/06/2012: Using Device UnKnown?
15:54:44.5 04/06/2012: Initialising DirectInput for Keyboard support
15:54:44.6 04/06/2012: Loading Start Page
15:54:44.8 04/06/2012: Initializing MCE Remote
15:54:44.8 04/06/2012: Playing intro sound file
15:54:44.8 04/06/2012: Initialization OK! Starting GameEx!
15:54:44.8 04/06/2012: Testing Main Loop Once: Processing Frame
15:54:46.4 04/06/2012: Testing Main Loop Once: Main Loop ran successfully
15:58:48.1 04/06/2012: Starting Attract Mode
15:58:48.1 04/06/2012: Reading MAME hall of fame
15:58:48.7 04/06/2012: Shutting down display
15:58:49.1 04/06/2012: Setting Up RawInput Hook
15:58:49.2 04/06/2012: Launching RawInputHook.exe
15:58:51.1 04/06/2012: Running: cmd.exe /c D: D:\Emulators\mame\mamep.exe umk3 -rompath D:\Emulators\mame\roms -nowindow -joy -skip_gameinfo -bezel -artwork_directory artworkgameex
15:58:59.0 04/06/2012: Validating: Emulator_1: Snap Path: D:\Emulators\mame\vidsnap
15:58:59.0 04/06/2012: Validating: Emulator_1: Title Snap Path: D:\Emulators\mame\Title
15:58:59.0 04/06/2012: Warning: Emulator_1: Title Snap Path Does not exist
15:58:59.0 04/06/2012: Validating: Emulator_1: Box Art Path: D:\Emulators\mame\flyer
15:58:59.0 04/06/2012: Warning: Emulator_1: Box Art Path Does not exist
15:58:59.0 04/06/2012: Validating: Emulator_1: Cart Art Path: D:\Emulators\mame\Cartridges
15:58:59.0 04/06/2012: Warning: Emulator_1: Cart Art Path Does not exist
15:58:59.0 04/06/2012: Validating: Emulator_1: Manual Path: D:\Emulators\mame\Manuals
15:58:59.0 04/06/2012: Validating: Emulator_2: Snap Path: D:\Emulators\mame\vidsnap
15:58:59.0 04/06/2012: Validating: Emulator_2: Control Panel Path: D:\Emulators\Assets\Arcade\Model2\Controls
15:58:59.0 04/06/2012: Warning: Emulator_2: Control Panel Path Does not exist
15:58:59.0 04/06/2012: Validating: Emulator_2: Title Snap Path: D:\Emulators\mame\Titles
15:58:59.0 04/06/2012: Validating: Emulator_2: Box Art Path: D:\Emulators\mame\Boxes
15:58:59.0 04/06/2012: Warning: Emulator_2: Box Art Path Does not exist
15:58:59.0 04/06/2012: Validating: Emulator_2: Cart Art Path: D:\Emulators\mame\Cartridges
15:58:59.0 04/06/2012: Warning: Emulator_2: Cart Art Path Does not exist
15:58:59.0 04/06/2012: Validating: Emulator_2: Manual Path: D:\Emulators\mame\Manuals
15:58:59.1 04/06/2012: Validating: Emulator_3: Snap Path: D:\Emulators\Project64\Snaps
15:58:59.1 04/06/2012: Validating: Emulator_3: Control Panel Path: D:\Emulators\Project64\Controls
15:58:59.1 04/06/2012: Validating: Emulator_3: Database: [Console] Nintendo N64
15:58:59.3 04/06/2012: Validating: Emulator_3: Title Snap Path: D:\Emulators\Project64\Titles
15:58:59.3 04/06/2012: Validating: Emulator_3: Box Art Path: D:\Emulators\Project64\Boxes
15:58:59.3 04/06/2012: Validating: Emulator_3: Cart Art Path: D:\Emulators\Project64\Cartridges
15:58:59.3 04/06/2012: Validating: Emulator_3: Manual Path: D:\Emulators\Project64\Manuals
15:58:59.3 04/06/2012: Validating: Emulator_4: Snap Path: D:\Emulators\Assets\Nintendo NES\Snaps
15:58:59.3 04/06/2012: Warning: Emulator_4: Snap Path Does not exist
15:58:59.3 04/06/2012: Validating: Emulator_4: Control Panel Path: D:\Emulators\Assets\Nintendo NES\Controls
15:58:59.3 04/06/2012: Warning: Emulator_4: Control Panel Path Does not exist
15:58:59.3 04/06/2012: Validating: Emulator_4: Database: [Console] Nintendo NES
15:58:59.4 04/06/2012: Validating: Emulator_4: Title Snap Path: D:\Emulators\Assets\Nintendo NES\Titles
15:58:59.4 04/06/2012: Warning: Emulator_4: Title Snap Path Does not exist
15:58:59.4 04/06/2012: Validating: Emulator_4: Box Art Path: D:\Emulators\Assets\Nintendo NES\Boxes
15:58:59.4 04/06/2012: Warning: Emulator_4: Box Art Path Does not exist
15:58:59.4 04/06/2012: Validating: Emulator_4: Cart Art Path: D:\Emulators\Assets\Nintendo NES\Cartridges
15:58:59.4 04/06/2012: Warning: Emulator_4: Cart Art Path Does not exist
15:58:59.4 04/06/2012: Validating: Emulator_4: Manual Path: D:\Emulators\Assets\Nintendo NES\Manuals
15:58:59.4 04/06/2012: Warning: Emulator_4: Manual Path Does not exist
15:58:59.4 04/06/2012: Validating: Emulator_5: Snap Path: D:\Emulators\mame\vidsnap
15:58:59.4 04/06/2012: Validating: Emulator_5: Control Panel Path: D:\Emulators\Assets\Sega Dreamcast\Controls
15:58:59.4 04/06/2012: Warning: Emulator_5: Control Panel Path Does not exist
15:58:59.4 04/06/2012: Validating: Emulator_5: Database: [Console] Sega Dreamcast
15:58:59.4 04/06/2012: Validating: Emulator_5: Title Snap Path: D:\Emulators\mame\Titles
15:58:59.4 04/06/2012: Validating: Emulator_5: Box Art Path: D:\Emulators\mame\Boxes
15:58:59.4 04/06/2012: Warning: Emulator_5: Box Art Path Does not exist
15:58:59.4 04/06/2012: Validating: Emulator_5: Cart Art Path: D:\Emulators\mame\Cartridges
15:58:59.4 04/06/2012: Warning: Emulator_5: Cart Art Path Does not exist
15:58:59.4 04/06/2012: Validating: Emulator_5: Manual Path: D:\Emulators\mame\Manuals
15:58:59.4 04/06/2012: Validating: Emulator_6: Snap Path: D:\Emulators\Future Pinball\Marquee
15:58:59.4 04/06/2012: Validating: Emulator_6: Control Panel Path: D:\Emulators\Future Pinball\Future Pinball\Controls
15:58:59.4 04/06/2012: Warning: Emulator_6: Control Panel Path Does not exist
15:58:59.4 04/06/2012: Validating: Emulator_6: Database: [Pinball] Future Pinball
15:58:59.4 04/06/2012: Validating: Emulator_6: Title Snap Path: D:\Emulators\Future Pinball\Marquee
15:58:59.4 04/06/2012: Validating: Emulator_6: Box Art Path: D:\Emulators\Future Pinball\Boxes
15:58:59.4 04/06/2012: Warning: Emulator_6: Box Art Path Does not exist
15:58:59.4 04/06/2012: Validating: Emulator_6: Cart Art Path: D:\Emulators\Future Pinball\Cartridges
15:58:59.4 04/06/2012: Warning: Emulator_6: Cart Art Path Does not exist
15:58:59.4 04/06/2012: Validating: Emulator_6: Manual Path: D:\Emulators\Future Pinball\FPRules
15:58:59.5 04/06/2012: Validating: Emulator_7: Snap Path: D:\Emulators\Pinball\Snap
15:58:59.5 04/06/2012: Validating: Emulator_7: Video Snap Path: D:\Emulators\Pinball\Snap
15:58:59.5 04/06/2012: Validating: Emulator_7: Control Panel Path: D:\Emulators\Pinball\Controls
15:58:59.5 04/06/2012: Warning: Emulator_7: Control Panel Path Does not exist
15:58:59.5 04/06/2012: Validating: Emulator_7: Database: [Pinball] Visual PinMAME
15:58:59.5 04/06/2012: Validating: Emulator_7: Title Snap Path: D:\Emulators\Pinball\Snap
15:58:59.5 04/06/2012: Validating: Emulator_7: Box Art Path: D:\Emulators\Pinball\Artwork
15:58:59.5 04/06/2012: Validating: Emulator_7: Cart Art Path: D:\Emulators\Pinball\Cartridges
15:58:59.5 04/06/2012: Warning: Emulator_7: Cart Art Path Does not exist
15:58:59.5 04/06/2012: Validating: Emulator_7: Manual Path: D:\Emulators\Pinball
15:58:59.5 04/06/2012: Validating: Emulator_8: Music Path: G:
15:58:59.5 04/06/2012: Warning: Emulator_8: Music Path Does not exist
15:58:59.5 04/06/2012: Validating: Emulator_10: Snap Path: D:\Emulators\Sony Playstation\Sony Playstation\Snaps
15:58:59.5 04/06/2012: Warning: Emulator_10: Snap Path Does not exist
15:58:59.5 04/06/2012: Validating: Emulator_10: Control Panel Path: D:\Emulators\Sony Playstation\Sony Playstation\Controls
15:58:59.5 04/06/2012: Warning: Emulator_10: Control Panel Path Does not exist
15:58:59.5 04/06/2012: Validating: Emulator_10: Database: [Console] Sony Playstation
15:58:59.5 04/06/2012: Validating: Emulator_10: Title Snap Path: D:\Emulators\Sony Playstation\Sony Playstation\Titles
15:58:59.5 04/06/2012: Warning: Emulator_10: Title Snap Path Does not exist
15:58:59.5 04/06/2012: Validating: Emulator_10: Box Art Path: D:\Emulators\Sony Playstation\Sony Playstation\Boxes
15:58:59.5 04/06/2012: Warning: Emulator_10: Box Art Path Does not exist
15:58:59.5 04/06/2012: Validating: Emulator_10: Cart Art Path: D:\Emulators\Sony Playstation\Sony Playstation\Cartridges
15:58:59.5 04/06/2012: Warning: Emulator_10: Cart Art Path Does not exist
15:58:59.5 04/06/2012: Validating: Emulator_10: Manual Path: D:\Emulators\Sony Playstation\Sony Playstation\Manuals
15:58:59.5 04/06/2012: Warning: Emulator_10: Manual Path Does not exist
15:58:59.5 04/06/2012: Validating: Emulator_12: Snap Path: D:\Emulators\SNES\Snaps
15:58:59.5 04/06/2012: Validating: Emulator_12: Control Panel Path: D:\Emulators\SNES\Nintendo SNES\Controls
15:58:59.5 04/06/2012: Warning: Emulator_12: Control Panel Path Does not exist
15:58:59.5 04/06/2012: Validating: Emulator_12: Database: [Console] Nintendo SNES
15:58:59.5 04/06/2012: Validating: Emulator_12: Title Snap Path: D:\Emulators\SNES\Titles
15:58:59.5 04/06/2012: Validating: Emulator_12: Box Art Path: D:\Emulators\SNES\Boxes
15:58:59.5 04/06/2012: Validating: Emulator_12: Cart Art Path: D:\Emulators\SNES\Cartridges
15:58:59.5 04/06/2012: Validating: Emulator_12: Manual Path: D:\Emulators\SNES\Manuals
15:58:59.6 04/06/2012: Restoring Emulator from Cache: 3
15:58:59.8 04/06/2012: Restoring Emulator Database From Cache: 3
15:58:59.9 04/06/2012: EmUDBCache Diff: 12/11/2009 21:23:33 - 28/11/2011 14:25:09
15:58:59.9 04/06/2012: Not Restoring Emulator from Cache: 4
15:59:00.1 04/06/2012: Restoring Emulator from Cache: 5
15:59:00.1 04/06/2012: Restoring Emulator Database From Cache: 5
15:59:00.2 04/06/2012: Restoring Emulator from Cache: 6
15:59:00.2 04/06/2012: No Database Data: 6
15:59:00.2 04/06/2012: Restoring Emulator from Cache: 7
15:59:00.2 04/06/2012: No Database Data: 7
15:59:00.4 04/06/2012: Restoring Emulator from Cache: 10
15:59:00.4 04/06/2012: No Database Data: 10
15:59:00.5 04/06/2012: Restoring Emulator from Cache: 12
15:59:00.5 04/06/2012: Restoring Emulator Database From Cache: 12
16:01:06.5 04/06/2012: Setting Up RawInput Hook
16:01:06.7 04/06/2012: Running: cmd.exe /c D: D:\Emulators\mame\mamep.exe solomon -rompath D:\Emulators\mame\roms -nowindow -joy -skip_gameinfo -bezel -artwork_directory artworkgameex
16:03:07.7 04/06/2012: Shutting down RawInput Hook
16:03:10.8 04/06/2012: Returning From Attract Mode
16:03:24.0 04/06/2012: Exiting GameEx!
16:03:24.0 04/06/2012: Disposing all videos
16:03:24.1 04/06/2012: Deleting temporary Karaoke videos
16:03:24.1 04/06/2012: Disposing Image List
16:03:24.1 04/06/2012: Disposing Fonts
16:03:24.1 04/06/2012: Disposing Surfaces
16:03:24.2 04/06/2012: Saving Settings
16:03:24.2 04/06/2012: Closing GameExtender Viewer
16:03:24.2 04/06/2012: Shutting down Bass
16:03:24.3 04/06/2012: Closing HideOS.exe
16:03:24.7 04/06/2012: Disposing Plugins
16:03:24.7 04/06/2012: Closing database connection
16:03:24.7 04/06/2012: Checking for applications to Launch On Exit
16:03:24.8 04/06/2012: Bye
Same problem here since 12.62. I'm on XP Pro
When attract mode start, i've an error message from XP : Game ex has crashed.....
and after about 30 seconds, it return to the Gameex Menu and the attract mode no longer start again
Never had the problem before since 2 years of use of Gameex
I've tried to do a manual install of the 12.63 -> same issue
In the windows problem report, it's mentionned " system.nullreferenceexception"
Dunno what is this..
The Gameex log file is (just the end as we can see the error here) :
22:01:41.7 04/06/2012: Restoring Emulator from Cache: 23
22:01:41.8 04/06/2012: Restoring Emulator Database From Cache: 23
22:01:42.2 04/06/2012: Restoring Emulator from Cache: 24
22:01:42.2 04/06/2012: Restoring Emulator Database From Cache: 24
22:01:42.4 04/06/2012: Restoring Emulator from Cache: 25
22:01:42.5 04/06/2012: Restoring Emulator Database From Cache: 25
22:01:42.6 04/06/2012: Restoring Emulator from Cache: 27
22:01:42.7 04/06/2012: Restoring Emulator Database From Cache: 27
22:01:43.0 04/06/2012: Restoring Emulator from Cache: 29
22:01:43.1 04/06/2012: Restoring Emulator Database From Cache: 29
22:01:54.9 04/06/2012: Exception occured running Attract Mode
22:01:54.9 04/06/2012: La référence d'objet n'est pas définie à une instance d'un objet.
22:01:54.9 04/06/2012: à GameEx.GameEx.mainform.BypassDisclaimer(Int32 ProcID, String RomName, Boolean CheckForCredit)
22:01:54.9 04/06/2012: à GameEx.GameEx.mainform.c(Boolean A_0)
22:01:54.9 04/06/2012: Shutting down RawInput Hook
22:01:55.3 04/06/2012: Mouse Input is disabled
22:01:56.2 04/06/2012: Returning From Attract Mode
22:04:38.5 04/06/2012: 21 Consecutive Exceptions Occured
22:04:38.5 04/06/2012: Erreur de l'application.
22:04:38.5 04/06/2012: à Microsoft.DirectX.Direct3D.Sprite.Begin(SpriteFlags flags)
22:04:38.5 04/06/2012: à Direct2D.Direct2d.Surface.Draw(RectangleF DesRect, Rectangle SrcRect, Byte Alpha, Byte Red, Byte Green, Byte Blue, Single Rotation)
22:04:38.5 04/06/2012: à GameEx.GameEx.mainform.DrawGameTextSelected(Int32 x, Int32 y, String textstring, Boolean notrans, Boolean forfade, Boolean forfade2, Boolean overidelscale)
22:04:38.5 04/06/2012: à GameEx.GameEx.mainform.i()
22:04:38.5 04/06/2012: à GameEx.GameEx.mainform.ad()
22:04:38.5 04/06/2012: Trying reinitialising the display after sleeping for 4 seconds
22:04:38.5 04/06/2012: Exception count will be dropped to 15
22:04:42.5 04/06/2012: Mouse Input is disabled
22:04:43.7 04/06/2012: Mouse Input is disabled
EDIT : Full log Added
Same issue for me too
It's only MAMe related because attract mode with others emulators works fine
Perhaps it has to do with groovymame 0.146 i'm using (upgraded in the same time as 12.62)
I'll try a different version and tell you the result
Same issue with your last Gameex.exe
I've tried with other groovymame version and with vanillia mame-> same issue
Could it be related to Bezel or Gameex artwork within attractive mode???
I'll try disabling them.
Well, the error doesn't show up in the log anymore, but it is still here
Log attached but we can't see anything special
Tom how can i disable the Gameex artwork to show up in attract mode?
I want to try without but i can't find how
With the latest Gameex.exe you provided, the error appears again but Gameex seems to work normally
I explain :when in attract mode, i press a button ,then return to the main menu, relaunch attract mode without problem (but the error message is still in background)
