When starting a new theme, what option should I choose for the theme version and what are the differences between them?
I've completed a theme and chose version 4, I'll upload pics later.
I use v4 just because its the most recent. No reason not to just make v4 themes afaik.
Ok, thanks, I'll upload some snaps of my theme soon, not going to upload it yet because it needs tweaking a little bit more.
Gonna make the comp? ;)
I think I'll give it a miss, I've looked at the entries and my theme doesn't make the grade, if I spend more time on my theme I might think about it.
I can understand if you are not comfortable, but the only way to win is to play! Yes, there is lots of competition, but it takes more than knock-your-socks-off good looks to have a successful theme. I have submitted quite a few themes over the last few years and I can find quite a bit of fault in every one of them. I can proudly say that quite a few of them have proven popular despite any misgivings I may have regarding them. If the theme requires too much effort to make work for an end-user, it will not necessarily win on its looks alone.
My theme is more pro looking than funky, I will upload some pics later and u can give me some pointers.
I have a couple more things to add to it, like loading screen, jukebox and icons, but for most of the icons im using yours (Draco1962).
Understood. The theme I am presently working on is a very simple 1920x1200 layout with color gradient backgrounds, minimalist foreground elements. I am eliminating "dedicated" menu bar areas as well as list and image areas (i.e., no frames or transparencies to indicate where they are). All logos are getting a total remake and there will be no emulator specific backgrounds created. In the end it will be very plain but pleasing for HTPC use.
