I am having sound problems using ParaJVE 0.7 in windows XP.
The sound is very intermittment or stuttering.
Everything else (apart from the sound) seems to be working fine.
Are you having problems with the sound via the emulator when you run it outside of GameEx?
Please post the contents of the configuration.xml file found in the data directory of your ParaJVE install folder.
nevermind i fixed it :)
thanks for your help.
Glad you got it solved. Will you please post your solution in case someone else runs into this problem? Marking as resolved. Also, welcome to the forums! ;)
